Ambrosius
GA-7VTXE VIA KT266A AGPset
PROCESSOR
Socket A for AMD Athlon™/Athlon™XP/Duron™ 200/266 MHz FSB processors
Supports 500MHz ~ 1.5GHz CPU and faster
FSB adjustable by BIOS up to 161MHz(no guarantee)
CPU voltage overclockable by adding 5%, 10% CPU voltage
CHIPSET
VIA KT266A(VT8366A) System controller north bridge
VIA VT8233 V-Link south bridge
AC97 codec
MEMORY (DDR)
Supports PC1600/DDR200 or PC2100/DDR266 DDR memory
Supports up to 3GB DDR memory
3DIMMs of 184-pin DDR sockets
Supports 72bits ECC type DRAM integrity mode
SLOT
1 x AGP 4X slot
5 x PCI slots support 33MHz & PCI 2.2 compliant
I/O
2 x UDMA ATA 66/100 bus master IDE ports on board
1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board
1 x joystick, 1 x line-in, 1 x line-out and 1 x MIC on board
2 x USB ports on board, 2 x USB ports by cable
1 x IrDA connector
POWER
ATX power connector
Power-on by LAN, RTC, Modem and Switch
Power-off by Windows ® 95/98/Me/2000/NT/XP shut down and Switch
FORM FACTOR
ATX form factor, 4 layers PCB (21 x 30.40 cm)
H/W MONITORING
2 cooling fan connectors
Stop CPU fan in suspend mode
System health status detect and report by BIOS
H/W detect and report power-in voltage, CPU voltage and CMOS battery status
BIOS
Dual BIOS, 2 x 2Mbit flash ROM, enhanced ACPI feature for PC98/Win98/Win2000 compliance, Green, PnP, DMI, INT13 (>8.4GB) and Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP & CD-ROM bootable
AC recovery ON/OFF control
Auto-detect and report system health status
Supports @BIOS™
OTHER FEATURES
Suspend-To-RAM (STR)
Supports USB KB/MS Wake up from S3
Poly fuse for keyboard over-current protection
Supports EasyTune III™
DRIVER
VIA 4 in 1 service pack utility
Hardware monitor utility
*There speed settings are not guaranteed by GIGABYTE.
- Lőn világosság: megérkezett új fénymérőnk
- Redmi Note 13 Pro 5G - nem százas, kétszázas!
- Gumi és felni topik
- Samsung Galaxy Note20 Ultra - a tollnak nincs ellenfele
- Milyen légkondit a lakásba?
- TCL LCD és LED TV-k
- Gyúrósok ide!
