-=MrLF=-
Hát mit mondjak szomorú vagyok, kihúzom addig a ZEN-ig a Phenom II-vel, aztán döntök hogy merre tovább.
protonmail.com Secure Email Based in Switzerland . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . startpage.com The world's most private search engine from Netherland
-=MrLF=-
[AMD Kaveri Refresh arriving in mid-2015, codename 'Godavari']
The main difference between Godavari and Kaveri will come with respect to frequencies and thus performance. Godavari will apparently maintain the same TDPs as Kaveri but offer up to 20 per cent higher clock speeds. The source recently acquired details of the new Godavari flagship that is expected to be called the A10-8850K.
The A10-8850K is, for all intents and purposes, a faster A10-7850K. On the CPU side the base clock stays the same but the turbo clock is boosted by 0.1GHz, to 4.1GHz. The GPU gets the largest boost, rising from 720MHz to 856MHz - a 19 per cent increase. In our experience with the A10-7850K even the new 856MHz GPU core clock is conservative since 1,000MHz is readily attainable with overclocking.
The rest of the Godavari line-up reportedly includes the following models: A10-8750, A8-8650K, A8-8650, A6-8550K, Athlon X4 870K, Athlon X4 850, A10 Pro-8850B, A10 Pro-8750B, A8 Pro-8650B, A6 Pro-8550B and A4 Pro-8350B. All of the aforementioned APUs and CPUs will work with existing FM2+ motherboards after board vendors issue the relevant BIOS updates.
Kicsit magasabb órajelek, azonos TDP a Kaverivel, FM2+ lapokba BIOS frissítés után.
- EAFC 24
- LEGO klub
- Macska topik
- Vodafone mobilszolgáltatások
- Renault, Dacia topik
- Intel Core i3 / i5 / i7 / i9 10xxx "Comet Lake" és i3 / i5 / i7 / i9 11xxx "Rocket Lake" (LGA1200)
- BMW topik
