Bandit79
Includes support for new GeForce RTX laptops, and delivers the optimum performance in Futuremark's 3DMark Port Royal benchmark, which has just added a new feature test for NVIDIA Deep Learning Super Sampling (DLSS).
Implemented performance improvements on multiple titles, such as Witcher 3. when using G-SYNC and SLI on Pascal and Maxwell GPUs.
Game Ready - Provides the optimal gaming experience for:N/A
3D Vision Profiles - Added or updated the following 3D profiles:N/A
SLI Profile - Added or updated the following SLI profiles:Anthem
Assetto Corsa Competizione - AFR enabled for Turing GPUs
Battlefleet Gothic: Armada 2 - AFR enabled for Turing GPUs
Life is strange Season 2 - AFR enabled for Turing GPUs
NBA 2K19 - AFR enabled for Turing GPUs
Space Hulk Tactics - AFR enabled for Turing GPU
Driver Fixes (For full list of fixes please check out release notes)[Gamestream][OS HDR]: Stream is not set to launch in HDR despite having HDR display attached to the PC and client. [2467526]
[GeForce Experience]: Share FPS overlay appears in the Twitter UWP app from the Microsoft Store. [2465033]
[G-SYNC]: Flickering may occurs in games if G-SYNC is enabled. [2399845]
[G-SYNC]: With G-SYNC enabled, after hot-plugging a G-SYNC display and then a GSYNC Compatible display, the right half of the G-SYNC Compatible display may go blank. [200484819]
Important Open Issues (For full list of open issues please check out release notes)[GeForce RTX 20 series]: Event ID 14 error appears in event viewer logs when Digital Vibrance setting is changed. [2488424]
[SLI][Shadow of the Tomb Raider][G-SYNC]: Flickering occurs in the game when launched with SLI, HDR, and G-SYNC enabled [200467122]
[G-SYNC]: With a G-SYNC and G-SYNC Compatible display connected in clone mode, flashing occurs on games played on the G-SYNC display with G-SYNC enabled. [200482157]
[HDR][Ni no Kuni 2]: Enabling HDR causes the application to crash when launched. [2483952]
[ARK Survival]: Multiple errors and then blue-screen crash may occur when playing the game. [2453173]
[Batman: Arkham Origins]: PhysX fog renders incorrectly [2451459]
[Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
Dynamic Super Resolution (DSR) is not available for monitors with 4k2k timings. [2496987]
Random desktop flicker occurs on some multi-display PCs [2453059]
- Redmi Note 13 Pro 5G - nem százas, kétszázas!
- Már elérhető a Resident Evil 4 Remake magyar szinkronja (PC)
- Tippmix
- bitpork: Fogyasztásra ítélve
- Automata kávégépek
