Arcanus
Hát, én fejlesztem, ha érdekel hogyan jelentkezek be:
public void login(Context context, String email, String password, AuthStateListener authStateListener) {
if (NetworkUtils.isNetworkAvailable(context)) {
String url = PH.Api.URL_LOGIN;
StringRequest stringRequest = new StringRequest(Request.Method.POST, url,
response -> {
Document document = Jsoup.parse(response);
Element page = document.body().getElementById("page");
if (document.title().isEmpty()) {
finishLogin(context, email, password, page.select("img[class=hidden]").first().attr("src"), authStateListener);
} else {
authStateListener.onError(context.getString(R.string.error_occurred_try_again));
error -> {
Util.logError(User.class, error);
@Override
public Map<String, String> getParams() throws AuthFailureError {
Map<String, String> headerMap = new HashMap<>();
headerMap.put("email", email);
headerMap.put("pass", password);
headerMap.put("stay", "1");
headerMap.put("no_ip_check", "1");
headerMap.put("leave_others", "1");
return headerMap;
@Override
public Map<String, String> getHeaders() throws AuthFailureError {
Map<String, String> headers = new HashMap<>();
headers.put("User-agent", PHService.USER_AGENT);
return headers;
@Override
protected Response<String> parseNetworkResponse(NetworkResponse response) {
if (response.statusCode == HttpsURLConnection.HTTP_OK) {
Map<String, String> responseHeaders = response.headers;
String rawCookie = responseHeaders.get("Set-Cookie");
if (rawCookie != null) {
CookieSettings cookieSettings = new CookieSettings(context);
List<HttpCookie> httpCookies = HttpCookie.parse(rawCookie);
for (HttpCookie httpCookie : httpCookies) {
cookieSettings.add(httpCookie);
return super.parseNetworkResponse(response);
Init.getInstance().addToRequestQueue(stringRequest, null);
} else {
authStateListener.onError(context.getString(R.string.no_internet_connection));
}Sajnos nem sikerült megoldani, hogy a kapott identifiert (cookie) mindig elfogadja a PH szervere, ezért trükközök. (ezzel később fogok foglalkozni jelenlegi helyzet csak ideiglenes)
A
finishLogin
azért szükséges, mert miután bejelentkezel (weben) a PH átirányít, így az appban is követnem kell, hogy megkapjak minden szükséges adatot.Ezek után a kapott identifiert már szimplán tudom bárhol használni:
headers.put("User-agent", USER_AGENT);
headers.put("Cookie", PH.createCookies(context));
return headers;
}Mindezt a Volley library segítségével csinálom.
Arcanus
Igen, jól gondolod. Nyugi, annyi változás nem lesz, hogy minden hónapban újra írjam az appot. (3 hónapja nem volt változás, egy design újítás lesz, de akkor sem kell minden elölről írni)
Remélem nem fogja blokkolni. A forráskód nyitott, bármikor bárki megnézheti.. Nincs rejtegetni való. API-t nem hiszem hogy kapunk, ez van.
Meggyi001:
- P1 Gen3 27% 15.6" FHD IPS i7-10850H T1000 32GB 1TB NVMe ujjolv gar
- Oneplus 7 Pro 12/256GB gyári független szép/dobozos
- Apple iPhone 14 Pro Max 128GB (Deep Purple) FÜGGETLEN ELADÓ
- Latitude 7420 27% 14" FHD IPS i7-1165G7 16GB 512GB NVMe ujjolv IR kam gar
- Thinkpad T14 Gen3 27% 14" FHD+ IPS i5-1245U 16GB 512GB ujjolv IR kam gar
Cég: Ozeki Kft
Cég: Ozeki Kft
