Taci
válasz hackeeeee #9626 üzenetére
Azért itt is lesz változás bőven. Nem egy rövid lista.
Here's the full changelog for Android 8.0 update on Samsung Galaxy S8 and S8+---------------------------
Galaxy S8 (SM-G950F)
Build Number : G950FXXU1CRB7
Android version : Oreo (Android 8.0.0)
Release Date : 2018-02-28
Samsung Experience 9.0 upgrade with Android OreoSamsung Experience 9.0 brings you Android Oreo, with exciting new features from Samsung and Google based on feedback from users like you.
We recommend that you back up your important data to keep it safe during the upgrade.
Some apps, including Samsung Pay, Samsung Internet, Samsung Notes, and Email, should be updated individually before you can update your OS.Here’s what’s new.
Biometrics
To improve your security, features that use biometrics (face, fingerprints, and irises) are only available when you use a secure screen lock type (pattern, PIN, or password). When you switch to a non-secure screen lock type (Swipe or None), biometric authentication is suspended for unlocking and for verification in apps like Samsung Pay and Samsung Pass. If you're using biometrics now without a secure screen lock type, you'll be able to continue after the upgrade, but changing to a secure screen lock type is recommended.Quick Panel
Manage notifications for each app with notification categories (supported apps only).
Icons will be shown at the bottom of the notification panel for notifications that aren't currently visible.Home Screen
Touch and hold an app to display shortcuts to common or recommended tasks within the app (supported apps only).
Notification badges on app icons are linked with the notification panel. Clear a notification in one location, and it will also be cleared in the other location.Samsung Keyboard
The toolbar gives quick access to useful functions.
The GIF keyboard lets you send GIFs.
More high-contrast keyboards are available.System Performance
Background services are limited to improve performance and battery life.
Currently running apps will always be shown in the notification panel.Edge screen
Improved font size, color, and other settings for better Edge panel visibility.
Touch and hold the Edge panel handle to change its position.
Added 3 more Edge lighting effects and color customization for apps.Lock Screen and Always On Display
New clock styles for the Lock screen and Always On Display.
Adjust the transparency of notifications to get the look you want.Smart View
Let your phone's screen go dark when mirroring to another screen.Samsung account
Control your account settings and profile information for multiple apps.
Tap your profile picture on the main Settings page to access your profile information and account settings.Samsung Cloud
View and manage photos and notes stored only in Samsung Cloud.
Store any type of file in Samsung Cloud Drive.
Select specific items to delete or restore from your backups.
See how big each backup is and how many items it contains.Samsung Dual Messenger
Install a second copy of a messaging app so you can use two accounts at the same time. For apps that verify accounts using phone numbers, you'll need a different phone number for each account.
Touch and hold a messaging app on the Home or Apps screen to install the second account or go to Settings - Advanced features - Dual Messenger.Find My Mobile
Back up Secure Folder to Samsung Cloud remotely when your phone is lost.
Lock Samsung Pass using Find My Mobile.Samsung DeX
See more apps at once by changing the app list view to full-screen.
Use Game launcher in Samsung DeX for a full-screen gaming experience.
Added support for 2 additional Samsung covers (LED View Cover, Clear View Standing Cover).Other improvements
Bluetooth now supports high-quality audio codecs, including AAC and Sony LDAC.
Video player includes auto repeat and 2x speed option.
Voice Recorder provides smart tips to conveniently block calls while recording.
Email lets you flag Microsoft Exchange ActiveSync emails.
Samsung Health's new sticky notification lets you see your step count at a glance.
Clock now includes a Landscape mode and timer sound options.
The digital clock widget goes directly to the Clock app when you tap it.
Samsung Pass added the ability to manage usernames and passwords in third-party apps. -
Kasya
válasz hackeeeee #9753 üzenetére
Szomoru, azt hittem 8.1...
Siman hasznalatfuggo. 40 fokos aksi homerseklet felett felett hatvanyozottabb a beeges vezselye. Egy komolyabb grafikaju jatek pl siman felmelegiti a telefont...es tobbynire allando kepekkel operal.
Nekem eddig minden amoledem beegett 2-3 honap utan. Igen komolyan valtoztatnom kellett a felhasznaloi szokasaimat, hogy elkeruljem[ Szerkesztve ]
Pioneer
A Note 4 pont 3 és fél éve jelent meg. Akkor a nővéred telója max 3-3,5 éves lehet.
A Note 4-em 1,5 év után égett be, full fényerőn a Dolphin böngésző asztali nézetben.
A Note 8-amat már csak 2/3 fényerőn használom, de így is világosabb, mint a Note 4 volt.PROFESSZIONÁLIS Delid / Relid Intel Processzorokhoz, garantált minőségben! LGA1150-től LGA1700-ig! Link: https://hardverapro.hu/apro/professzionalis_delid__re-lid_lga_1155_1150_1151_garantalt/friss.html
daninet
válasz hackeeeee #9802 üzenetére
samu napokban beadott egy patentot a kijelzős ujjlenyomat olvasóhoz, szerintem az és az s9 kamera lesz az ujdonság (a kötelező cpu/gpu váltáson kivül) plusz beleraknak pár szoftveres gimmicket.
Akkuval tudnak még esetleg villantanide eléggé papirforma. Nem a 2000es évek ez már amikor a nokia kiadott kerek telefonokat poénból
Miért vegyem meg, ha 3x annyiért, 3x annyi idő alatt megépíthetem? ´¯`·.¸¸.·´¯`·.¸><(((º>
Igen, a note7 fiaskó után nagyot kellett mutatni. A Note 9 kevésbé esélyes rá, hogy akkora szintet lépjen, mint ami a note 5 - 8 közt volt. Majd a note X (vagy ha a note név is megy a lecsóba az S széria nevével együtt, akkor az aktuális cerkás zászlóshajó).
My name is Bond, James... Dean.
Ákkk
válasz hackeeeee #10233 üzenetére
Nekem van volt az első verzió és az új is nem túl jó eszköz a hangminősége még a gyári fejest se éri el a doboznak amiben tölteni lehet pár nyitás után letörik a tartópöcke.
Ennyi pénzért már normális fejest is lehet venni sőt már elég jó vesztességmentes zenelejátszót is.A technika nem az agy helyettesítő terméke.
thebear007
Nekem az első gen. volt, elajàndèkoztam, vacak,dràgàn. Most egy Monster Victoryt nyúzok, ez kibír 6 óràt is, au Icon X 40 percet.
Isten a saját képére teremtette meg az embert. Majd megadta a számára a választás szabadságáét, így mindannyian úgy csesszük el az életünket, ahogyan akarjuk.
Teal'C
válasz hackeeeee #10329 üzenetére
Kijelző full fényerő, 2sim bent, wifi, gps bár ezek et ha épp nem használod akkor 0-a.
MX Player-rel néztem videót avi, mkv formátumban 1.5-2.5gb méretekben a készülék memóriából de ezt leírtam nem olvastad?De ebből ismét kitunik milyen jó a fogyasztása az AMOLED kijelzőnek. Szerintem a legjobban a mobilnet zabál a telókban. Ezzel kezdhetnének valamit.
"Nagy az Isten állatkertje és alacsony a kerítés" Nem már nincs kerítés!!!
OCTAMD
válasz hackeeeee #10497 üzenetére
Simán XEH kódra még egy darabig lehet nem is lesz.
De ha felteszi az ember Odinnal a XEH,XEF stb utolsó 7es romot,akkor OTA-n lehúzza,mert sim nélkül XEF a kód
páran már megcsinálták azt tudom,ahogy leírtam pár napja
Yukyung Viliv S5 3G 32SSD Win7 Home Premium 32bit ,Toshiba Libretto W100-106 62GB SSD Win7 Home Premium 32bit
OCTAMD
válasz hackeeeee #10538 üzenetére
A simet célszerű kivenni,azért,mert ha bent van a magyar sim,akkor amikor kész a rom csere feljön ez az ablak és ha rányomsz esetleg az alsóra,akkor nem lesz oreod.
Ha nincs bent sim,nincs ez az ablak sem,tehát francián vagy
OCTAMD
válasz hackeeeee #10540 üzenetére
TMobilos Duos OXM XEH,tehát előbb szolgáltatós kell rá
Szolgáltatós telóknál egyszerűbb ,pl. Telenor vagy Voda vagy TMH Single mehet egyből fel a független
Luser2000
válasz hackeeeee #10935 üzenetére
Azt vedd figyelembe mindig, hogy hol végződteted a hívást és te kinek a hálózatán vagy.
- Ha az átirányítás hazai szolgáltató számára megy, amely földrajzilag is itthon van, akkor NEM roaming.
- Ha az átirányítás hazai szolgáltató számára megy, amely földrajzilag nem itthon van, akkor ROAMING.
- Ha az átirányítás nem hazai szolgáltató számára megy, amely földrajzilag itthon van, akkor ROAMING.
- Ha az átirányítás nem hazai szolgáltató számára megy, amely földrajzilag nem itthon van, akkor ROAMING.Mindezek attól függetlenek, hogy te a telefon/SIM kikapcsolása előtt az átirányítást hol kezdeményezted (itthon, még határátlépés előtt, vagy már külföldi szolgáltató hálózatában).
Apple iPhone 15pro, Apple Watch Ultra2, MacBook Air M2 13"
Tekintsd át a téma Összefoglalót!
Használd a gyorskeresőt (jobb felső sarokban van) a kérdés feltevése előtt, előfordulhat, hogy van már rá válasz.
Ha mégsem találtad meg a választ, kérdezz bátran!
- hardverapró
- Samsung Galaxy S24 128gb Cobalt Violet - Újszerű, akár beszámítással
- Új - Apple iPhone SE 2022 64GB - Red- Gyárilag független
- IPhone 15 Pro max 256GB gyári független megkímélt 2025.12.27. Apple garancia!
- Iphone 13 pro max 128 GB sierra blue kártyafüggetlen
- Samsung Galaxy A55 128gb Awsome Lilac - Újszerű, akár beszámítással
