GAMEPOD.hu témák
Keresés
Geza ba
Samsung faqbol:
To clean your monitor safely, follow these steps:
1. Disconnect the power cord.
2. Spray a small amount of non-abrasive cleanser on a lint free cloth (not directly on the monitor).
3. Gently wipe the surface. Use as little pressure as possible.
You should never use any harsh chemicals to clean your LCD monitor. Cleansers with the following agents are OK to use:
* Water
* Vinegar (mixed with water)
* Isopropyl Alcohol
* Petroleum Benzene
Do Not use cleaners that contain the following agents:
* Acetone
* Ethyl Alcohol
* Ethyl Acid
* Ammonia
* Methyl Chloride
Warning: Do not spray any liquids directly on the monitor. Always apply the solution to your cloth first, not directly to the parts you are cleaning. Apply as little pressure as possible when you clean.
Applying too much pressure or spraying liquids directly onto the screen or case of the LCD Monitor may cause damage to the display which will not be covered under warranty.
- Ukrajnai háború
- Stellar Blade
- AMD off topik: VGA, CPU, APU és minden, ami AMD
- Így építsd a billentyűzeted!
- Linux felhasználók OFF topikja
- Bemutatkozott a Moto G32 4G
- Luck Dragon: MárkaLánc
Új prémium hirdetések
