The Division 2 (PC, XO, PS4) összefoglaló
arnikusz
Tájékoztatásul:
RELEASE OF TITLE UPDATE 6.1 on DECEMBER 10th, 2019
Improvements to Audio issues
Fixes to Apparel Drop issues
Remove alarm in the White House "again"
Changes to UI with how loot drops are viewed
Fixes to invisible walls with NPCs spawning points
Negotiators Dilemma - Added a fuse for added visual warning when the grenade drops
Fixes to Cassie (Gun Runner)
Removed "requirements" for purchasing items.
Fixes for the UI for her spawning time
Fixes for Cassie Vendor icon not appearing on the map.
Hardcore Mode "BETA"
New Character (must have an available character slot to select)
No access to your stash (will have access to vanity items)
PERMA DEATH
All game modes will be playable in Hardcore Mode (DZ, LZ, Raid). Servers will only allow for other Hardcore Players access.
Please provide your feedback about your experience or suggestions.
Rewards - anything earned in this mode will not be transferable to other characters and will be lost on death.
YOLO Hat for reaching Level 2
Situation: Snowball & Apparel Event
Holiday Care Package on its way
3 Pieces of Equipment
Holiday Hat
"The Sleigher" - A new gun that will shoot snowballs that will confuse opponents. A guaranteed drop, the first time from "The Hoarder" (aka Loot Goblin, Loot Troll).
If you shoot his backpack, you will get an item. If you follow after him, he will lead you to an ambush.
The Hoarder can be found in the LZ only and will spawn randomly around the world.
Silent Night Apparel Event
December 10th thru 31st. Keys can still be used till January 7th.
Key drop has had RNG removed. Receive 1 key for every 3 Field Proficiency Caches or 1 key for every 5 DZ Caches.
Able to "gift" purchased keys to other players.Soha ne azonosulj a legyőzöttekkel
arnikusz
Valaki ahelyett hogy lelötte volna a nagy táskás mobot követte már a csapdáig?
arnikusz
Patch notes még nincs addig is:
Apparel Event #5 – Silent Night
How to get Apparel Event Keys
Changes have been made to how players acquire Apparel Event Keys:
Guaranteed key with every three Field Proficiencies.
Guaranteed key with every five Dark Zone Proficiencies.
Weekly Apparel Projects reward three keys.
Gifting Apparel Event Keys is now possible.Negotiator’s Dilemma 3 Piece Talent “Blowback” Change
Updated to change the behavior of the launched grenade.
The grenade no longer explodes immediately on contact.
The grenade now has a fuse timer (currently 2 seconds) from launch before it explodes.
The UI now appears immediately on launch to warn players of the incoming projectile.
If the fuse is not finished, it will land on the ground and wait for the fuse to end before exploding.-- Megy a kukába- most is csak 1 hétig bohóckodtam vele.Cassie Mendoza Update
With TU6.1 they're also updating Cassie's stock.
Cassie will now always have two named items, one Weapon, one Gear slot item and the Shield Splinterer available in her stock.
The two named items will change every rotation, while the Shield Splinterer will always be available.
To see the Shield Splinterer players must have unlocked the Ivory Key lockbox in the Base of Operations by defeating all Hunters.
They will also exclude any named items that require Blueprints from the Special Field Research from that point on, to ensure that the stock is always available to all players, regardless of their progress in the Field Research.
arnikusz
Holnap a Santa sapkára a Lincoln Memorial missionnál vadásszatok míg meg nincs log out ki be. A futó csókából a nagy zsákkal esik.
arnikusz
válasz Anonymus23 #14495 üzenetére
Nálam laggol veszettül a netem lesz a ludas azután adta be, hogy összefutottam a mobbal.
Van ilyen maszk is eléggé kidolgozatlanok.Soha ne azonosulj a legyőzöttekkel
arnikusz
válasz Kis Tigris #14503 üzenetére
Ha városban vagy elég, ha községben mint én akkor negatíve irányban befolyásolhatja a településre telpített régi szerverük sajnos, a korábbi hsz-imből láthatod mikkel futok össze mostanában.
arnikusz
válasz Anonymus23 #14513 üzenetére
Nem érdekel engem se, mert inkább csinálom az eventes mókát, megha a Clann Raidezn inkább oda megyek, de a DZ is csábít.
Szeretném a DPS karimon az EB alapsebzését feltornászni 28,7 -ről 30-ra, de a 6 módosítóból 1db van ami 5% AR sebzést ad a többi 4%-ot, 6%-at még nem láttam, meg az AWD is 1,5 és 25-ak.
Egyébként nem is nagyon mutogatnak ilyen videokat, jó csak 2 napja, de akkor is.
Minap láttam egy oroszt 82 szintű volt a Sheperdből. Ugyanakkor az egyik egy random UBI valami volt az egyik a fejlesztő csapatból, hát esettt kelt.Soha ne azonosulj a legyőzöttekkel
arnikusz
arnikusz
válasz s4hu|SyD^ #14520 üzenetére
Mindeközben a játékban szépen lassan elöjönnek a lelöhetetlen, vagy téged seperc alatt leterítő Herok PVP-ben. De a Mobok is produkálnak érdekes dolgokat. Jó lehet az 50 Mbit falusi netem is besegít, de nálam sajnos ez van. Hiába takarítottam a game mappából, vettem vissza egy kicsit a beállításokból.
arnikusz
válasz Anonymus23 #14522 üzenetére
Akkor a kapcsolatom lesz a lúdas, valamint, ha a családtagok közben egyéb eszközökkel neteznek az is ígya wifit- le fogom kapcsolni próbaképp este.
PVP szettet rakjatok már be- Köszönöm.
arnikusz
válasz Anonymus23 #14571 üzenetére
Felcsigásztak ezzel a Clutch builddel, megmutatná kérem egy fénykép erejééig.
arnikusz
arnikusz
válasz Anonymus23 #14593 üzenetére
Mély tisztelettel köszönöm. Pénteken összerakom és mehet a DZ csihi-puhi, vagy az esés kelés.
arnikusz
Perfekt Berserk a Den of thievesben 2 deffensive 1 offessive a z armor talent mellett.
arnikusz
Simán megy ez a hardcore mod, csak egyedül uncsi, most 6 os szinten tartok ha valaki érez késztetést esténként 20-22-ig vagyok. Ja és no Rambo.
arnikusz
Azt írják 93%-os Railsplitter van a Den of Thievesben.
arnikusz
válasz ÍzÍÍÍÍÍÍÍÍÍÍ #14701 üzenetére
Kéne rá egy kis skill power. Gratula.
Vzarmo a Clutch buildhez a 3 DH supergut.Soha ne azonosulj a legyőzöttekkel
arnikusz
Körkérdés:
Hardcore módban ki milyen specializációt választana, ha csak egyet lehetne?
Köszönöm.Soha ne azonosulj a legyőzöttekkel
arnikusz
válasz Gigant20 #14734 üzenetére
Semmi gond Clutch buildet tökéletesítek a maszk megy és jön egy Murakami, a zsák megy és jön egy DH sparkkal 2 offense 1 defense, a cél 240.000 körüli heal. Végül a Famas a mostani 20.4K helyett a max. ezzel az összeállítással 21.2K.
Innen indulok.Soha ne azonosulj a legyőzöttekkel
- Újra kiadták a Redmi Pad Prót
- Samsung LCD és LED TV-k
- Milyen Android TV boxot vegyek?
- Elhozná az olcsó önvezető autók korát az Xpeng
- Milyen hagyományos (nem okos-) telefont vegyek?
- Parfüm topik
- Házimozi belépő szinten
- Üzletből, garanciával, Macbook Air Retina 13" 2020, 8GBRAM 256GB SSD magyar bill
- Lenovo ThinkStation P330 Workstation: 3D tervezésre (CAD), videó vágásra, animációk készítésére(DCC)
- ASUS ROG STRIX RTX 3070 8GB
- Eladó ASUS ROG STRIX SCAR II GL704G kishibás gamer notebook
- ÚJ! // ÁR ALATT! // Edifier S3000 MK II // Muziker garancia
