The Division 2 (PC, XO, PS4) összefoglaló
Tudod, mit jelent az, hogy nemezis? Az érintett, erősebb fél kinyilatkoztatása a méltó büntetés mértékét illetően. Az érintett fél jelen esetben egy szadista állat... én.
9.30kor lesz egy scheduled, félórás, majd 10.00tól ER, félórás.
Weekly maintenance for The Division at 9:30 CEST (in 10 minutes), downtime ~30 minutes.
Emergency maintenance for The Division 2 at 10 AM CEST (in 40 minutes), downtime is also expected to be 30 minutes.
a black tuskos drónkezelő újra röpteti a drónjait.
pts tu4 patch notes
ptsre felkerült egy olyan változtatás, hogy a generic protocol modokat és a generic system modokat már nem lehet sárga vagy zöld cuccokba belerakni. Mods
Generic Protocol Mod and Generic System Mod can no longer be equipped in High-End, Gear Set and Exotic items.
You will still be able to equip them in lower quality items.
All other mods can be equipped in slots matching their type (Offense, Defense, Utility).
Developer comment: Generic mods could be stacked in unhealthy ways and the gear mod eco system has not been in a place we are happy with and it had led to some unwanted behavior such as low-level farming for generic mods.Missions
Roosevelt Island
Shipping containers containing virus samples will now be easier to spot.NPCs
Removed “bulletproof” backpacks from NPCs that would block all incoming damage.
Decreased acceleration of NPCs when repositioning in cover.
Enabled Engineer archetype NPCs to setup Turrets on the ground if no valid cover position exists.
Fixed various issues with Controller archetype NPCs getting stuck or being unresponsive in certain situations.
NPCs can’t be suppressed when deploying a Drone.UI
Removed redundant “!” for new items shown in Cache Content in Proficiency Caches.
Apparel Caches should now only display a “!” in the UI when a key is acquired and once the key has been seen should disappear.
There’s now a timer that shows the cooldown before being able to kick a player from a group.Skills
Further improved the Reviver Hive which should result in it more reliably reviving downed agents.
Assault Drone
After killing its current target, the Assault Drone will now attack the enemy the player is currently shooting. If no target is being shot, it will attack the closest enemy to its owner instead.Talents
Rooted
The talent description now states the intended cooldown of 60 seconds.Commendations
Further improved Discovery Merits to allow loot boxes opened by other players count towards every group member’s progress.Bug fixes
Fixed weird lighting in some tunnels.
Fixed an issue where grouped players could disconnect after leaving a Classified Assignment.
Fixed an issue where enemy NPCs could lose track of players in Operation Dark Hours.
Fixed an issue where players would be unable to claim the weekly Clan Cache.
Fixed an issue where rails in DZ West did not appear on barriers surrounding a checkpoint.
Fixed an issue where Master Sergeant Quiroz in the Space Administration HQ would jump down earlier than intended. He was a bit to eager.
Fixed an issue where an explosion was missing in the Space Administration HQ before Master Sergeant Quiroz appears.
Fixed an issue where Weasel’s weapon could fly out of his hand. Sweaty palms can be a real issue for some people.
Fixed an issue where players could not be attacked at a certain spot in the Stadium map.
Fixed an issue where several collectibles would not automatically play when picked up.
Fixed an issue where the accuracy of a player in the Activity Summary could be negative.
Fixed an issue where opening the Top CXP Clan menu could cause frame drops.
Fixed an issue where the objective for “Return to the White House” would not complete if you skipped the cinematic.
Fixed an issue where players could get stuck when being revived by another player and the Control Point Officer at the same time.
Fixed an issue which would prevent players from opening the Strategic info when downed in Operation Dark Hours.
Fixed an issue which could prevent the Call for Help animation to be visible for other players.
Fixed an issue where inspecting a player through the social menu after being downed could cause the menu UI to persist during gameplay.
Fixed an issue where the “Open Cache” and “Back” buttons on the Apparel Event Cache UI would disappear, when pressing both buttons at the same time.
Fixed an issue where Hunters could be revived outside the radius of their Reviver Hive, as well as being revived an unlimited amount of time.
Fixed an issue where enemy NPC faces would not correctly target players while strafing.
Fixed an issue where NPCs could get stuck while spawning in DZ East.
Fixed an issue where players could stare into the void.
Fixed an issue where players could jump into a patio they should not have access to. No trespassing!
Fixed an exploit that allowed the Hive skill to become un-targetable and shoot at enemy players at a specific location on Fort McNair.
Fixed an issue where setting the difficulty level for a mission from within a Classified Assignment did not apply that difficulty level and did not reset the mission.
Fixed an issue where players could receive multiple Ivory Keys from the same Hunter.
Fixed an issue where NPC speed after turning would be incorrect.
Fixed an issue where NPCs would skip animations after jumping.
Fixed an issue where the Call for Backup would not be received by players having the option activated.
Fixed an issue where players could spawn below the map when teleporting to a reconnecting player.
Fixed an issue where the audio could get corrupted when playing a cinematic.
Fixed an issue where Lucy and Buddy could become permanently invulnerable in Operation Dark Hours.
Fixed an issue where audio for collectibles could become corrupted after prolonged gameplay.
Fixed an issue where players could become unable to interact with the agent’s note in the “Investigate the Safe House” side mission.
Fixed an issue where players were unable to interact with the laptop and liberate a Safe House.
Fixed an issue where players could get stuck in the map overview after completing the Dark Zone South intro mission.
Fixed an issue where a player could revive multiple agents at the same time with the Reviver Hive.
Fixed an issue where the difficulty of a bounty would be different in the Bounties tab and the Mega Map.
Fixed an issue where players could be revived by the Reviver Hive after the Razorback encounter ended when the whole team was downed.
Fixed an issue where when placing a turret on a car the Turret would drop down to the floor.
Fixed an issue where players could sometimes not be able to move around circular cover.
Fixed an issue where players would be able to see through the map when looking at a window on the Stadium map.
Fixed several issues where the turrets in DZ-West would fire at Rogue Agents beyond the intended range.
Fixed an issue where a turret in the DZ-West could fire through a fence at Checkpoint Delta.
Fixed an issue where Turrets could fall through the floor, roof and other objects.
Fixed an issue where players would be able to see through the map when looking at a window in DZ-West.
Fixed an issue where the dialogue audio could switch to English when playing with a different language setting.
Fixed an issue that could cause FPS drops on PC when opening the Ubisoft Club Rewards.
Fixed an issue where random Open World encounters would not spawn.
Fixed an issue where several parts of the Specialization UI were missing localization.
Fixed some weird doors.
Fixed an issue where some Assault Rifles would not hinge correctly on the Crusader Shield.
Fixed an issue where players would be unable to inspect apparel within the Apparel Event Cache UI.
Fixed an issue where pressing the “Inspect” and “View Stats” buttons at the same time would cause the text from the two pages to overlap in the UI.
Fixed some weird stairs.
Fixed an issue where extra ammunition from mods would not properly be added to Skills.
Fixed an issue where Manny would repeatedly thank agents for saving hostages in a Classified Assignment. He’s really thankful, ok?
Fixed an issue where Conflict Caches could reward loot below the player’s World Tier when playing with lower level agents in a party.
Fixed an issue that didn’t allow player to see previous Distinctions of the Week in the Clan Quarters.
Fixed an issue where killed NPCs could clip through objects they fell on.
Fixed an issue where notifications toasts were missing when completing an activity, after abandoning several projects in a row.
Fixed an issue where Inaya al-Khaliq would stay in an A-Pose after being recruited. She has now relaxed.
Fixed an issue where inspecting a player would show the inspecting player’s stats instead.
Fixed an issue where reloading while using a Shield would play the wrong animation.
Fixed an issue where the debriefing audio after completing a mission could play several times.
Fixed icons on Auxiliary Skill Mods which should now show the icon of the Skill they can be equipped in[ Szerkesztve ]
én eddig nem csináltam, de most már nem is fogok nekiállni. nagyon vicces egyébként, hogy elvileg nem is kaphattunk volna wt5ös generic modokat.
@norti: nice catch, köszi.
válasz Anonymus23 #9952 üzenetére
60-70k lő egy liberty csupaszon, ráöltözés nélkül, testre, és ezzel a holsterrel az egyből a healthre megy.
válasz arnikusz #9934 üzenetére
és mi az ott legalul, középen? ami az smg ikonjából nyitható, és úgy néz ki, mint egy ütvefúró?
@Anonymus23: amióta kijött a raid, úgyse volt időm bemenni dz-be.
@Egonyolc: 2 offensice mod slot, és egy utility mod slot van benne.
gúnár skill tree@pts
protipp: azt tudtátok, hogy a ruháknál is van loadout, nem csak a felszerelésnél?
volt tegnap sotg.
a lőtéren valami ojjektum belelóg a tűzvonalba, és az blokkolhatja a lövéseket. javítják. máshol a játékban nem fordul elő (kár, pedig ez kényelmesen megmagyarázná, miért krumpli az aimom.)
speckó lőszer akkor fog esni, ha egy csík (a lenti képen feketével, balra) betelik a hudon.
a generic modokról már volt szó, csak generic modos slotba fognak belemenni. a piros modok viszont bee fognak menni az összes piros slotba, a kékek az összes kékbe, stb.
TU4@PTS:
signature spec pont emelés 160ról 165re - a maradék 5 pontot ki kell farmolni. minden fegyver damage-ra lehet minden signature fán specelni, de egyszerre az összesre nem.
a tac50-et, és a számszeríjat buffolni fogják, a .50es jelentősen többet fog sebezni, a nyíl meg páncélt törhet. ez még nincs fent a ptsen.Tudod, mit jelent az, hogy nemezis? Az érintett, erősebb fél kinyilatkoztatása a méltó büntetés mértékét illetően. Az érintett fél jelen esetben egy szadista állat... én.
písz tesó, nem azért írtam, de tényleg nem értem, hogy mi a koncepció. he ez egy szóló build, akkor nem szóltam. szép nagy tankod van, amire lelövik, biztosan el tudsz bújni.
ha mégsem, akkor a többiek már leírták, de nagy vonalakban az én meglátásom:
unstoppable force-nál a max armorra nő a sebzésed, de 168k health tankod van, ami már clutch nélkül is jó health tanknak. neked armor kellene, és health tankoddal dps-t veszítesz.
a teknősbékának még nem igazán láttam értelmét. 5% armor regent ad, ami a 225k tankodra 11,25k. ha 3x ekkora lenne még mindig azt mondanám, hogy a medkit 100%ra teszi a páncélodat ugyanennyi idő alatt, és van belőle 7 (raiden 2, de esik a mobokból szépen), a chem launcher is a többszörösét gyógyítja, és még mást is, aki arra jár, a hiveról meg nem is szólva. sajnos az armor regen önmagában nem egy túlságosan használható dolog, mert nagy késéssel kezd el működni, és ha közben meglőnek, megszakad, és várhatsz megint.
plusz infó még, hogy a normál armor regen megszakad, amikor fedezékbe mész. aztán újra elindul, és amikor a patience is elindul, a normál armor regen megszakad, és 3 másodperc múlva újra elindul.mosómaci növeli a heal mennyiségét. sajnos továbbra is meg kell várnod, amíg elkezd működni az armor regen, és még lekorlátoztad magad 4 pirosra.
szvsz ebbe a buildbe túl sok mindent akartál belerakni, ez így szerintem zsákutca. de ha már mindenáron ezt akarod erőltetni, és le tudsz menni 3 pirosra, akkor keress olyan kesztyűt, amin van compensated. a max 3. piros miatt valószínűleg úgysem lesz sok crited. viszont valószínűleg sebzésed sem, ezért érdemes olyan fegyverosztályt választani rá, aminek nagy az alapsebzése (hogy a 15% awd többet ér, ha nagy a base damage).
a clutchos build a berzerk miatt 7 vagy több piros, és a clutch az 4 vagy kevesebb kék. sajnos ebbe nem fér bele, hogy a 4 kék ne health legyen, és rá kell még valószínűleg pakolni talentet, ami healthet növel, vagy murakamit.
azon a buildeden, amin armor tank kellene, hogy legyen, health tank van, amin health tank kellene, hogy legyen, azon meg nagyon kicsi.
válasz Hublot #10081 üzenetére
kell azért még némi mazochizmus, hogy az ember ilyen körülméynek között játszon.
@arnikusz: addig is. nézd meg, hogy az indító aoe után mennyi armorja van még a kutyáknak.
válasz Snip3r_HUN #10140 üzenetére
gg!
@Anonymus23: akkor már hivatalosan is farmon van a zóna, igaz?
e3 spoiler
remélem benitez még egyben van. Tudod, mit jelent az, hogy nemezis? Az érintett, erősebb fél kinyilatkoztatása a méltó büntetés mértékét illetően. Az érintett fél jelen esetben egy szadista állat... én.
tac .50 dmg buff a ptsen:
pts-en nerfelték a mercilesst...
[link]a többi sig fegyver sebzését is normalizálták.
remélem csak ui bug.[ Szerkesztve ]
válasz -=Jam=- #10210 üzenetére
valószínűleg sosem gondolták végig, hogy ez így fog működni. tipikus agilis módszertani baki, hogy telibefossuk az impact analysist.
omg dráma van
válasz Anonymus23 #10231 üzenetére
465ös r&k fegyvertokom van.
válasz Garsza #10326 üzenetére
valószínűleg azért, mert a spotter (?) pulse bónusza multiplikatív (ez érthető), az on the ropes-é pedig nem (ez már kevésbé). de ez csak egy tipp, nem tudom, hogy valóban így van-e.
válasz Snip3r_HUN #10429 üzenetére
az attól függ, hogy csapat, vagy szóló. csapatban nekem is ennyi, szólóban 15-20szal több.
gunner walktrough. redditről loptam.
nádzson sukár lett a named fegyverek skinje.
válasz Anonymus23 #10575 üzenetére
többen írták redditen, hogy változtattak a raiden.
pl. lucy már lelő, ha az aoe-ja alatt blindfire-ozol.Tudod, mit jelent az, hogy nemezis? Az érintett, erősebb fél kinyilatkoztatása a méltó büntetés mértékét illetően. Az érintett fél jelen esetben egy szadista állat... én.
válasz -=Jam=- #10645 üzenetére
ja, nekem is fel kéne húzni még egyet. és most, hogy elfogytak a dailyből és a weeklyből is a blueprintek, akár ezt is csinálhatom, legalábbis a holster után.
válasz Habugi #10635 üzenetére
szerintem szokjunk hozzá, hogy ez így marad. a massive az ilyen bugokat nem javítja túl gyorsan, szóval egy ideig biztosan így marad.
csak erős idegzetűeknek:
seb lafotry (ő csinálta a raidet) azt írta twitteren, hogy nem változtattak sem boomer, sem buddy healjén. egyetlen dolgot javítottak, mégpedig lucynál a blind fire-t. viszont működik a berzerk lmg-vel, gondolom ezt fogják javítani.
válasz BenSopra #10650 üzenetére
nem Norbi, hanem én. és nem számított lóf@szt sem, nincs jó ar szettem, se jó ar-em. egy szóló, armor on killes pve szettem van az arhez, és kb egyszer sem tudtam lehúzni az aggrót akkor, amikor lelőttük. ebből ítélve dps csökkenés volt nálam, nem növekedés.
rádásul el is felejtettem visszarakni a rifle-t a végére, úgyhogy ott is estem-keltem, meg bújócskáztam a sárga mobokkal, mert se tankom se dpsem sincs benne megfelelő.[ Szerkesztve ]
válasz Kiscsőke #10655 üzenetére
ne szokj hozzá, hamar kiveszik majd.
ja és az exo holsterrel ne erőltessétek a szkópos lövéseket.
válasz Hublot #10681 üzenetére
mi másért kínlódnánk vele...? a world first megvolt aznap, az meg nagyon nem mozgat, hogy 1 hét, vagy 20 perc alatt megy le.
válasz Hublot #10687 üzenetére
ja, meg pixi
@i@lex: soha senki nem mondott olyat, hogy ez valamikor is eshet bárhol a raiden kívül.
válasz John Marston #10708 üzenetére
van egy olyan hipotézisünk, hogy egy héten egy karakternek minden bossból és a végén a ládából egyszer eshet EB.
a láda evidens (heti egyszer tudod csak kinyitni), a bossok viszont a raid-specifikus lootot csak egyszer dobják ki hetente (nemcsak EB, hanem tip of the spear, aces & heights, negotiators dillemma). ez alapján ha farmolni akartok, ahhoz kelleni fognak alt karik is.Tudod, mit jelent az, hogy nemezis? Az érintett, erősebb fél kinyilatkoztatása a méltó büntetés mértékét illetően. Az érintett fél jelen esetben egy szadista állat... én.
tegnap már mondtam a klán ts-en lévő tagjainak, de leírom ide is, hogy a massive most azt szondázza, hogy mit szólnának a játékosok egy olyan változtatáshoz a gear seteken, hogy az 5-6 darabos bónuszokat elérhetővé tennék 3 és 4 darab viselése esetére.
de olyat továbbra sem akarnak, hogy a gear set legyen az új meta. azt akarják, hogy bizonyos szituációkban ez legyen a legerősebb, de általánosan, nyers erőben ne.
I want them to specifically be powerful, but at a specific playstyle and role. I want to avoid a gear set being more powerful at raw damage than a good high end build, because otherwise it becomes the only build in the meta.
a skilleket ezektől függetlenül buffolni fogják valamelyik következő patch-csel.
No, not at all changing that. Just buffing their effects. More info to comeja és a quick draw talentet át lehet vinni egy másik holsterre az exoticról.
saját felelősségre lehet ezzel játszani. emiatt valószínűleg ma is lesz majd egy hotfix, és rossz esetben elveszíted az így moddolt tárgyat, jó esetben csak rollbackelik. azt nem tudom, hogy tudod újra lekraftolni az exo holstert.ja és még valami, amit kipróbálhattok raiden:
FYI...you can stop Buddy from Healing himself by applying Sweet Dreams Debuff on him ( you need to melee hit him repeatedly)
Debuff isnt shown on him since he got his overcharge icon on him most of the Time
mivel megjelent a redditen, várhatóan ezt is nagyon hamar ki fogják patchelni.[ Szerkesztve ]
válasz Kiscsőke #10726 üzenetére
félreértettél. a quick draw most átrakható. várhatóan ma vagy holnap, vagy best case hétfőn kipatchelik, és nem lesz az, és valószínűleg azt a tárgyat is rollbackelik, vagy egy másik, random talent lesz rajta, amire átraktad. vagy en block bebukod mindkettőt.
@cikasz: elvileg ez a debuff nem jár le, szóval 1x megmeleezed őket, és ennyi. nem kell ottmaradni.
ezek eddig is voltak.
@cikasz: ez csak feltevés, elmélet, alapul véve a leírást. ki kell majd próbálni. worst case minden lucy ae előtt le kell neki verni egy maflást.
- Szinte bankkkártya méretű a LattePanda x86-os SBC-je
- Azonnali mobilos kérdések órája
- Gaming notebook topik
- Vezetékes FÜLhallgatók
- World of Tanks - MMO
- ThinkPad (NEM IdeaPad)
- Gigabyte GA-H81M-DS2 rev:2.1 LGA 1150 alaplap
- IPhone SE2 2020 64GB megkímélt akku 86%
- Asus P8H67 LGA 1155 alaplap
- Bomba ár! Fujitsu LifeBook E754 - i7-4712MQ I 8GB I 128SSD I 15,6" I HDMI I Cam I W10 I Garancia!
- Bomba ár! Fujitsu LifeBook E754 - i5-4GEN I 8GB I 128SSD I 15,6" FHD I HDMI I Cam I W10 I Garancia!
