Az előzmények:
GaburroSan
Na a hétvégi event eredménye:
T32 megvéve, majd eladva, M103 megvéve, Panther2 megvéve. 3db venti+3 töltésgyorsító megvéve!
T59+Stug3 kombóval cirka 5M a hétvége eredménye! Köszönöm WG az Eventet! Minden másra ott a Mester kártya! -
GaburroSan
HA még nem volt akkor itt [link] lesz majd a kövi Type nyerési lehetőség! Persze majd ha kijött a 8.5
GaburroSan
Huh... remélem is mert vissza akarom venni a SU-100-at vagy a 152 fun-nak!
GaburroSan
válasz malnabokor #4151 üzenetére
Én a KV-5ös tankom szeretném újra látni! Teljesen véletlenül adtam el! Szerintem be voltam rugva!
GaburroSan
Mennyi idő míg válaszolnak rá??
GaburroSan
Na én ilyet kaptam vissza!
Hello Commander,Thank you for telling us about your issue.
We do not normally help in cases like this, but we can grant you a one-time exception and restore your tank for you. However, please keep in mind that we will only do it once. We won't be able to do this again in the future.
Please remember that you always get a confirmation window that you have to accept before selling the tank, where you can decide if you want to dismiss the tank's crew and dismount the modules or not.
In order to bring your tank back, we will need you to have as many credits as you earned when your son sold the KV-5 (1500000) as well as a free garage slot. We will need to remove those credits and we will use the garage slot to place your newly restored tank.
Once you have enough credits and the free garage slot, please get back to us and confirm that you want the tank restored, and that you understand this is will be a one-time exception.I hope you will enjoy all your future battles!
Regards,
Anthony Orwell,
EU support team -
GaburroSan
Hello Commander,
Thanks a lot for your confirmation.
I would like to inform you that we have successfully restored your KV-5 by deducting 1.500.000 credits from your account
Please do not hesitate to contact us for any kind of further issues you may have, we would be more than happy to help you!
Good luck in the battles and have a nice day,
Murat Corlu
Customer Service Europe
Nah a WG-nek minden elismerésem!
Pénzügyi Tranzakciók.
Dátum: 2013. május 10. 14:37:18
A krediteket levontuk a számládról: 1 500 000
Nyugta.
Dátum: 2013. május 10. 14:37:39
Jármű érkezett: KV-51 fél nap alatt visszakaptam!!!
GaburroSan
Az M103nál az első kifejleszthető ágyúval kell kiharcolni a T110E5, mert amikor azt kifejleszted, abban a percben megkapod a maxos ágyút is! Miért?? Mert ugyan az ágyú van a T110E5 mint az M103-on, és a motorból fejleszted ki a T110E5-öst és nem az ágyúból. Tehát amikor kifejleszted a T110E5 akkor kettőt kapsz 1 fejlesztés áráért! + Spórolsz 1 valag xp-t is!
GaburroSan
Ha volt már róla szó akkor na haragudjatok!
8.6-os Arty és TD változások[link]
A jó hír az Artysoknak ( 50% xp) és a TDnek (- 33%) ,hogy eltörlik a bünti xp-t és kapnak extra kreditet és xp ha segítik a csapatnak a ellen folyamatos gyengítését pl, csomó modul sérülés, letrackelés, legénység kilövése, stb...
A rossz hír: -20% pontosság csökkentése![ Szerkesztve ]
GaburroSan
1 kis morzsa az új tier 9-es Amerikai Artyhoz!
M53/55:
Crew:
Commander
Driver
Gunner
Gunner
Loader
LoaderThe main technical characteristics of the tank:
Health: 1 550
Weight: 450
Hull armor: 25.4/12.7/12.7
Turret armor: 12.7/12.7/12.7
Engine power: 810
Max speed: 56.3/14
Traverse Arc: -30..+30
Rate of turret turn: 10 deg/s
View range: 350
Radio range: 750Gun: _203mm_Howitzer_M47 (azt hiszem ez van most az M40/43-on de nem vagyok benne biztos)
- Rate of fire: 1.38
- Reload time: 43.5
- Aim time: 7
- Ammo: 20
- Shell damage: 1850/1450/1850
- Penetration: 102/241/102Engine Continental AV-1790-7B
- Type: gasoline
- Power: 810Radio: AN_PRC_25
- Signal range: 750Suspension :
- Chassis_M53_55_2 -
GaburroSan
válasz Plasticbomb #7100 üzenetére
szerintem ez elírás lesz!
GaburroSan
Végül is ha 1 T10 artynak 1800 HP-ja lesz 1 szavunk sem lehet!!!!! (szopást megkezdeni!!!) A végleges patch Jun.24 elött fog kijönni! (ennyit lehetett a fejlesztőktől kihúzni)
GaburroSan
A szuper repeszpáncélt a következő tankok kaphatják meg:
(SUPER-HEAVY SPALL LINER)
USSR: KV-4, KV-5
Germany: GW typ E, Jagdtiger 8,8 , Jagdtiger, JagdPz E-100, VK4502 B, Maus, Lowe, E-75, E-100, VK7201
USA: T95, Т110Е3
Britain: Tortoise, FV215b, TOG II* -
GaburroSan
Az Artyk várható elhelyezkedése:
TIER II - SU-18
TIER III - SU-26
TIER IV - SU-5
TIER V - SU-122A (new vehicle)
TIER VI - SU-8 (moved from Tier V)
TIER VII - SU-51 (moved from Tier VI) ====== TIER VII - SU-14-1 (new vehicle)
TIER VIII - SU-14 (moved from Tier VI)
TIER IX - Obj. 212 (moved from Tier VII)
TIER X - Obj. 261 (moved from Tier VIII)- German SPG line has been reworked:
New SPGs added: G.Pz. Mk. VI (e) (Tier II), Pz.Sfl. IVb (Tier IV), G.W. Tiger (P) (Tier VIII)
NOW THE TREE WILL LOOK LIKE THIS:
TIER II - G.Pz. Mk. VI (e) (new vehicle)
TIER III - Sturmpanzer I Bison (moved from Tier II)
TIER IV - Pz.Sfl. IVb (new vehicle) ====== TIER IV Sturmpanzer II (moved from Tier II)
TIER V - Sturmpanzer 38(t) Grille (moved from Tier IV)
TIER VI - Hummel (moved from Tier V)
TIER VII - Gw Panther (moved from Tier VI)
TIER VIII - G.W. Tiger (P) (new vehicle)
TIER IX - Gw Tiger (moved from Tier VII)
TIER X - Gw E-100 (moved from Tier VIII)- USA SPG line has been reworked:
Added new SPGs: M44 (Tier VI), M53/M55 (Tier IX).
TIER II - T57
TIER III - M37
TIER IV - M7 Priest
TIER V - M41
TIER VI - M44 (new vehicle)
TIER VII - M12 (moved from Tier VI)
TIER VIII - M40/M43 (moved from Tier VII)
TIER IX - M53/M55 (new vehicle)
TIER X - T92 (moved from Tier VIII)- French SPG line has been reworked:
Added new SPG: AMX 105 AM mle. 47 (Tier IV), Bat.-Châtillon 155 55 (Tier IX)
TIER II - BS
TIER III - Lorr.39LAM
TIER IV - AMX 105 AM mle. 47 (new vehicle)
TIER V - AMX 105 AM (moved from Tier IV)
TIER VI - AMX-13 F3 AM (moved from Tier V)
TIER VII - Lorraine 155-50 (moved from Tier VI)
TIER VIII - Lorraine 155-151 (moved from Tier VII)
TIER IX - Bat.-Châtillon 155 55 (new vehicle)
TIER X - Bat Chatillon 155 (moved from Tier VIII) -
GaburroSan
Még 1 fontos dolog lesz a kövi 8.6 patch-ben! Akiknek van prém tankja azok most fognak nekem örülni!! (ha még nem tudják) 1-7 tier-ig income buffot fognak kapni a járművek!!! Úgyhogy 1 jó meccs t6-t7 járművel is hozhat annyit mint 1 t8-as!!!!
GaburroSan
válasz Napfénysüti #7172 üzenetére
A T8-asok maradnak ahol vannak!
GaburroSan
World of Tanks Starter Pack Giveaway for New Players
Join World of Tanks today and get an Alienware Arena exclusive Starter Pack.
Your Starter Pack Invitation Code for New Players includes:
• 1000 Gold
• Premium Account for Five Days
• 100,000 CreditsMake sure to follow the instructions to get your Invite Code key and redeem your Starter Pack.
Please note these keys are only available for European members and they will only be valid on the European World of Tanks server until July 31st.
Ha valaki újrakezdené, vagy ismerőseinek kell invite kód akkor tessék! [link] még van 6055 db!!!
GaburroSan
Whhhhhááá
Super Heavy repeszpáncél 750.000 kredit áááááááááááááááá -
GaburroSan
Ehhhhh 8.6 patch első csata! 5-5 arty oldalanként és nálunk a 9es betcset a legelső...nagy LOL!!!
GaburroSan
Az Amcsi eventet kaptuk meg!!!Már kint van a wot oldalán!
GaburroSan
49k xp kell az E-100hoz és prém nélkül tolom!!!Meglássuk 15-ig meglesz-e az xp!
GaburroSan
TIER II - SU-18
TIER III - SU-26
TIER IV - SU-5
TIER II - T57
TIER III - M37
TIER IV - M7 Priest
TIER V - M41
TIER II - BS
GaburroSan
Háááá meglett az E-100!!!
1 meccs: győztünk meglett a 3.osztály!
2 meccs: győztünk meglett az 1.osztály, top gunnal!
Az IS-7 elbújhat mellette!!! -
GaburroSan
Ez azoknak szól akik a WOWP-vel is játszanak!!!Na azok jól figyeljenek!
Play the World of Warplanes Beta During E3 and Earn Gold for Your World of Tanks Account!We know most of our players will not be able to attend this year's E3, but we certainly haven't forgotten about you. Along with our normal retinue of events and specials for tanks, the Community Team members responsible for World of Warplanes (Mugsy_ & Hathore) have put together some events to coax you over to the airborne combat side of things.
If you haven't yet applied for World of Warplanes Beta access, you can do so on the World of Warplanes portal. You'll need to sign in using your normal World of Tanks credentials.
We'll be posting complete details for these events on the World of Warplanes portal soon, but here's a brief rundown:
Ground Control to Major_RampageThis event might be the most low maintenance one we do during E3, it's entirely automated - -take a breather Major_Rampage. Each day between June 3rd & 7th, the top 10 pilots who destroy the most ground targets will receive 4,000 in their World of Tanks and World of Warplanes accounts.
Flying High Five TournamentThis event will be a best three out of five, five versus five, at tier V. See what we did there? Five. Five things, over and over. It's a theme. This event will take place on June 5th. More details to come.
Prizes:
10,555
8,555
6,555Earn Your Wings Event
This event is easy (for the Wargaming event staff anyway, not so much for all you competitors out there), it's also entirely automated. No need to submit an entry. Each day, the top 10 pilots who destroy the most enemy planes or get the most assists in destroying enemy planes while piloting a tier IV or tier V aircraft will get 5,000 added to their World of Tanks account.
Get Airborne EventIf you're just starting out, and find that you aren't quite able to net a top spot in any of the events listed above, then this shindig is for you! All that's required is that you play a total of at least 100 games between the days of June 10th &14th and you'll net yourself 1,750 for both your World of Tanks and World of Warplanes accounts. If you're a dedicated pilot and manage 200 battles you'll be rewarded with 5,000 gold!
GaburroSan
Skacok!
Még ma tart a Big ann Heavy!!!Szóval még akciós áron megy a Tiger 2, E-75, E-100!!!!
Aki ezeket szeretné még ma akciós áron beszerezheti!!Az E-100 nál nem mind1 hogy 6,1 millió vagy 4,3 m!![ Szerkesztve ]
GaburroSan
Na most már tuti hogy nálunk is a Francia TD-k lesznek a Big and Heavy második felvonásában!! Oroszon és az Amcsin is ez van!
GaburroSan
Ez volt a tavalyi Operation Bagration!!!
Here is the list of offers for the duration of this special:
50% discount on the purchase of the following vehicles:
Soviet Medium Tank Tier VI: T-34-85
Soviet Tank Destroyer Tier V: SU-85
German Tank Destroyer Tier VI: JagdPz IV
German Medium Tank Tier V PzKpfw III/IVx3 experience for the first victory of the day
x2 credits when using the following vehicles:
German Medium Tank Tier V PzKpfw III/IV -
GaburroSan
Megfelelő kezekben a csatát eldöntheted vele!! Főleg mivel 50-60% tier 7ben játszik és oda ez a gyorstüzelő tökéletes! 3,7sec rof 120-180 dmg közötti sebzést oszt ki! KV1-s kioszt 12,5 sec alatt akár 488 dmg addig a Panther/M10 3x120-180=360-540 dmg!!! Szóval nem rossz!!
GaburroSan
Changed the price for the E-25 Premium TD. Now it costs 6700 gold.
GaburroSan
1 kis Panther/M10 meccs! (idáig a legjobb köröm) és nem kaptam meg az ászt vele!!!
ha kíváncsiak vagytok a csatára akkor ide--------->[link]
GaburroSan
Hmmm ezzel is megvan a top gun! DE nézzétek meg az úcsó kill-t nagyon durva!!!
[link] s itt a game!
GaburroSan
Küldetés Teljesítve!!
Victory!
Lakeville 2013. július 16. 19:44:39
T69
: 1 005 35 595Mission completed! Award:
Equipment added: Large Repair Kit (x2)Most ez földhöz vágott!!!
MODERÁTOR
(rögzített hozzászólás)
Figyelem!
- LEGO klub
- PayPal
- Malwarebytes Anti-Malware
- Motoros topic
- World of Tanks - MMO
- Foxpost
- Az alaplapgyártókra hárítja az Intel az egyes Core CPU-k stabilitási gondját
