mokuska02
A fórumot azért hoztam létre,hogy a Zappiti 4k tipusú médialejátszók tulajdonosai könnyebben megtalálják egymást,megosztva a tapasztalatokat,információkat.Megfelelő számú hozzászólás után összefoglaló is lesz.[ Szerkesztve ]
mokuska02
A hazai megjelenésről egy cikk:
A magyarországi forgalmazó:
A 2 rackes verzióról a teszt:
Hivatalos fórum:
Specifikáció:
Technical Specifications
● Processor: Realtek RTD1195.
● CPU: Dual core CPU.
● GPU: Dual core GPU.
● DSP: Video and Audio DSP with hardware acceleration.
● Cache: 512 KB L2.
● Internal flash memory: 5 GB.
● Connectors: HDMI 1.4 CEC, 2x USB 2.0 (at the back), 1x USB 3.0 (side), Audio/Video analogue output, Optical S/PDIF output, Ethernet 10/100/1000 Mb/s, Wi-Fi 802.11b/g/n, SD Card reader / MMC (side), AC connector, AC button On/Off (at the back), LED display on front switchable with a physical button.
● Internal storage: Hot swap internal SATA HDD 3.5" rack (up to 8 TB pre formatted HDDs). To transfer your data, connect your HDD in a docking station for eSATA / USB 3.0 for a high speed transfer between your computer and your HDD. You can also transfer your data via Wi-Fi or Ethernet Gigabit. You can finally copy/paste your files in your internal HDD from an external HDD connected via USB 3.0. Note: HDD not included.
● Media sources: External HDD (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC/MMC), PC and NAS in local network (SMB, UPnP, HTTP), other Internet and local network media sources. External multi-bay USB storage enclosures supported.
● Internet navigator: Chrome. (Possibility of installing other browsers).
● DLNA: Full support of DLNA standard (1.5 or 2.0).
● DRM: PlayReady, Widevine, HDCP, DTCP-IP.
● Video codecs: HEVC, H.265, MVC, AVC, MPEG-2, MPEG-4, XVID, DIVX, WMV9, FLV, VC-1, H.264/x.264, CVD 1.0/2.0, SVCD, AVS, Sorenson Spark L70, VP8 ; Very High Speed video bitrates supported up to 120Mbit/s.
● Video file formats: BD ISO, BDMV, MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, WMV, DVD-ISO, VIDEO_TS, AVCHD 2.0 (AVCHD 3D, AVHD Progressive, and AVCHD 3D / Progressive).
● Video output flexibility: Output video in any resolution and format from SD to 1080p (1920x1080, up to 60p), Ultra HD (3840x2160, up to 30p) and 4K (4096x2160, 24p only). Display your movies in true 24p (23,976 Hz oupout).
● Audio Codecs: AC3, DTS MPEG, MP3, AAC, LPCM, ALAC, APE, M4A, AIFF, WAV, VSELP, FLAC, Ogg/Vorbis; lossless and audiophiles formats support (up to 192 kHz / 32-bit).
● Audio playback functions: album cover art support, folder playback, random, repeat playlist, repeat title.
● Multichannel Audio HD: DTS, DTS-HD, Dolby Digital, Dolby Digital Plus, Dolby TrueHD, Dolby Atmos - Bitstream (RAW) and downmix 2.0.
● Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, SUB/IDX external), PGS (BD ISO, BDMV, M2TS), DVBSUB (DVB-T, DVB-S, DVB-C).
● 3D Hardware acceleration: OpenGL.
● Photo file formats: JPEG, HD JPEG (depends of apps).
● Supported formatting: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write), Mac OS enhanced (read-write).
● Ethernet: 10/100/1000 Mb/s.
● Wi-Fi: IEEE 802.11n 2.4 GHz with 2 antennas.
● Network playback: Special optimisation of the network, guaranteeing better performances of the local network playback no matter which type of media thanks to SMB protocol (HEVC UHD files included) via Gigabit Ethernet or Ethernet 10/100.[ Szerkesztve ]
mokuska02
A fórum azért jött létre hogy a tulajok egymás tapasztalatait megosszák egymással,de akinek nincs tapasztalata vele az mi alapján itéli meg?A Dune Solo 4k eleve 109k a Zappiti 4K mini pedig 75k akkor miért is gyenge?A HiMediáról annyit hogy q5 pro-t akartam venni és először azt mutatták meg aztán a Zappitit.A Zappitit vettem,nem véletlen.Semmi extrát nem mutatott a Beelink Mini MXIII után.
mokuska02
Igen amiket leírtál én is azt vettem észre.A felskálázás baromi jó de a 4k tartalmakból válogatós.Manapság egyébként még 4k film se nagyon van és még az se dőlt el melyik formátum a nyerő.De ha szépen skáláz fel már sima 720 p anyagot akkor nem mindegy hogy az eleve 4 k anyaggal hogy boldogul?Valljuk be szabad szemmel nehezen észrevehető de cserébe 4x akkora helyet foglal a tárolón.Szerintem jó kis lejátszó amíg igazi 4 k tartalom nincs addig a felskálázás is jó.
mokuska02
Igen olvastam a régebbi firmware verziókkal eléggé bugos volt.Én a legfrissebbel kaptam és eddig egy két apróságot leszámítva meg vagyok vele elégedve.A gyári fórummal kapcsolatban szkeptikus vagyok,elêg új gyártónak számít lehet hogy fizetett trollok ledegradálták és azért szüntették meg.Nem a legjobb lejátszó a piacon de nem is a legrosszabb,igaz magas az ára de engem a képe kárpótol ☺
mokuska02
Francia vélemények a lejátszóról
mokuska02
Új termék a franciáktól!!!
Zappiti 4K HDR család
http://www.av-online.hu/lejatszo/zappiti-4k-hdr-lejatszok_1990
Itt lehet megvásárolni:
http://www.avland.hu/webshop/products?prsearch=zappiti
Személyes vélemény:Én nem sietném el a vásárlást,idő kell még mire az egyébként erős hardverre nagyon jól optimalizálják a rendszert.Jelen pillanatban sokkal jobb vétel és jobban kihasználható az egy generációval ezelőtti Zappiti 4K.Kiforrott rendszerével és igényes felskálázásával a házimozik egyik elengedhetetlen kelléke,most még kedvezőbb áron.
mokuska02
válasz donceleger8 #25 üzenetére
Véleményem szerint nagyon igényes termékcsalád,viszonylag új gyártók,de látszik hogy próbálnak minőségi vonalon helytállni.Nekem Zappiti 4K Mini-m van elégedett vagyok vele a legutóbbi szoftverfrissítés óta.Előtte néha eldobott pár képet,ami picit zavart,de a képminőség az pazar.Még egy jóideig marad nekem ez,megvárom hogy koforrjon a HDR széria utána én is benevezek egyre .Azt ne felejtsük el hogy célhardver,filmnézésre találták ki,a specifikáció annyira nem lényeges.Új gyártók tehát kaptak támadást mindenhonnan ezért nincs fórumuk sem,sok volt a fizetett troll.Én viszont saját véleményt írok,van tapasztalatom,kb 50 filmet néztem már rajta és meg vagyok elégedve.Egyszerűen kezelhető,célhardver azért ennyi az ára(tehát HTPC-vel sincs semmi értelme összehasonlítani ,mert ahooz hozzáértőnek kell lenni).
mokuska02
Amit marketing bullshitnek gondolsz és azt mondod nincs benne semmilyen képjavító azt mire alapozod?Mert volt dolgom pár lejátszóval mindig a szememre hagyatkoztam és azért ezt vettem mert ennek volt a legszebb a képe.Akár laptopot vagy a tv beépített lejátszóját de még a Himedia Popcorn és társait megnézve számomra ez volt az az eszköz amin láttam hogy valamivel többet "mutat". 4k tévén használom jópár filmet megnéztem vele és garantálom neked hogy a MagicPixel nem csak parasztvakítás.Igen ez egy szakmai fórum mi tulajok próbáljuk leírni tapasztalatainkat mert ezek a lényeges dolgok annak akik ilyen lejátszót akarnak venni.
mokuska02
Nem csak személyes tapasztalatot lehet leírni,de azért valljuk be én legalább is jobban hiszek annak aki ilyet használ.Én nem védem hanem a saját tapasztalataimat írom le.Ez egy nagyon jó lejátszó ,saját tapasztalat.Az,hogy külföldi fórumok mit írnak meg hogy mik az én tapasztalataim 2 külön dolog.hiába írják nekem hogy zöld az ég én nem hiszem el,mert van szemem és látom hogy nem.Ugyanez van a Zappiti lejátszókkal is.Legalább is nálam.
mokuska02
válasz donceleger8 #36 üzenetére
Az AV-Land szaküzlete tőlem kb 2 utcányira van.Én amikor megvettem megmutatták nekem mit tud.Nem kell nekik merevlemez,van mindenféle tartalom hálózaton divx-től 4ksamplén át 3d isoig minden.Segítenek mindenben és nem akarnak átverni,azért is mutatnak meg mindent.VTEN ,q5 Pro és a Zappiti közül ez nyert,ők is ezt ajánlották és én is ezt tartottam e legjobbnak a 3 közül.Azt javaslom menj be és nézz meg mindent úgy válassz akkor nem tévedhetsz.
mokuska02
válasz donceleger8 #49 üzenetére
Ha 4k filmet nem akarsz nézni ez a lejátszó is jó választás volt 😀
mokuska02
válasz donceleger8 #76 üzenetére
Én próbáltam nekem működik 😀
mokuska02
Azért húzzák le mert nem nekik készült.Nem számokból meg adatokból kell megítélni hanem megnézni mire való és arra jó is amire való 😁
