A ZIDOO médialejátszó topik célja, hogy segítsük egymást
a minél jobb moziélmény elérésére
és a problémák megoldására.
Feltöltés folyamatban.
Ötleteket és segítséget Pü-ben várok.
Zidoo is not streaming player.
AZ új PRO boxok már
rendelkeznek
DRM L1
támogatással.
sony89
Z9X:
v6.0.90(Without Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_202012311835_ota-package.zip
MD5: 20B87A79C5F46626C450B7F7371F0439
v6.0.90_G(Build in Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_G_202012311849_ota-package.zip
MD5: DB3F350CA1001B1EB62DF02E5D4818E2
Z10 Pro:
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_202012311756_ota-package.zip
MD5: 9BCC4311FF818BD27C14E3F3D2C3ACB2
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_G_202012311810_ota-package.zip
MD5: C3D9D028D6F92B1E49CECBD56C091ECB
Z1000 Pro:
v6.0.66(Without Google play)
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_202012311707_ota-package.zip
MD5: 433F983521D9FCF04E9224954808379E
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_G_202012311723_ota-package.zip
MD5: 92F96C617370D71A848C90D84B5FC31F
UHD3000:
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_202012311612_ota-package.zip
MD5: C25559805AD181A6D72331774EB73AAD
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_G_202012311638_ota-package.zip
MD5: 1EBCD1E225686CA4A20C985DE7A0B172
Happy new year!!!Change logs:
system
1. Fix the problem that some Dolby Vision videos are stuck (some MKV videos).
2. Fix that some TVs cannot output 3D by default.
3. Optimize online video streaming.
4. Optimize HDMI IN preview.
5. Fix the problem that the Blu-ray navigation cannot automatically frame rate switch.
6. Add Dolby Vision compatibility mode (this mode for the latest SONY 9000H firmware LLDV is abnormal, and some old LG TV HDMI IN models only support 2160P30 DV)..
player
1. Add UPNP video playback function.
2. Fix individual movies will be rustle of PCM audio.
3. Fix some videos cannot be played.
4. Fix the problem of audio slow output when paused.
5. Optimize bookmark playback function.
6. Optimize the subtitle download function.
7. Optimize the problem that the external srt subtitle will occasionally flash.
8. Fix output information display error problem on the information display interface.
Poster wall
1. Optimize NFO analysis.
2. Optimize part of the UI.
music player
1. Increase UPNP music playback function.
2. Optimize lyrics function.
3. Fix the problem that the song cannot be cut normally after playing from the file manager.
4. Optimize information acquisition in detail page.
File manager
1. Increase UPNP function.
2. Optimize NAS boot and mount speed.
3. Optimize UI.
Picture manager
1. Increase network picture page.
2. Add UPNP picture slideshow.
3. Fix the problem that the system music does not stop when slideshow.
Quick setting
1. Increase the compatibility mode switch of transparent transmission power amplifier (for some power amplifiers).
2. Increase the time setting of the bookmark function.
3. Add Dolby Vision compatibility mode.
4. Add resolution lock function.
Mobile APP (scan the QR code of the machine to download and update)
1. Fix the problem that the music search page cannot play music.
2. File manager adds UPNP function.
3. Optimize the cue music playback function.
4. Optimize music favourite function.
5. Added music play-list mode.
6. Optimize some UI.BUÉK!
sony89
Adott egy Zidoo Z10 Pro és egy win 10 es PC, egy hálózaton vannak SMB vel összekötve a PC ben lévő HDD-k ről a filmeket szépen látja le is játsza...
De ha a PC ről akarom elérni a Zidoo t és akár a PC ről átküldeni fájlokat rá az nem sikerül mintha a PC nem látná a Zidoo-t ..csak egyoldalú a lejátszás ami szerintem hülyeség...Mi lehet a gond, mit nem jó állítottam be ? win 10 ben kell valamit állítani vagy a Zidoo n?
sony89
válasz Beni2360 #13614 üzenetére
ugyanazon a hálózaton van a Zidoo is meg a Pc is nincs IP cm ütközés vagy hasonló! A zidoo van nézem hálózaton keresztül a filmeket a PC ben lévő HDD-ről! Ezert nem értem ha abba az irányba jó a hálózat és mindent lát a Zidoo amit a PC n megosztok , másik írányba a PC miért nem látja a Zidoo-t..
nem DHCP n van a Zidoo, hanem fix IP címen! 192.168.1.125 a pc IP címe meg : 192.168.1.88 -
sony89
válasz feherzaj45 #13623 üzenetére
Így sem látja nálam !
Fogalmam sincs mi lehet a baj már mindent megnéztem ... -
sony89
válasz Beni2360 #13630 üzenetére
Persze hogy be van kapcsolva az SMB1 is ...mondom a Zidoo látja a gépet onnan játszok le filmeket , zenéket 3db HDD van a gépben azon vannak a cuccok! Egyik írányba jó a hálózat de a win 10 nem látja Zidoo-t mintha ott se lenne ha a PC ről akarom elérni , ezt nem értem!
sony89
Nalam Zidoo Z10 Pro van az is szépen lejátsza a HDR és a Dolby Vision tartalmakat is... Tv LG Oled 55CX... 😀
sony89
válasz thomasvold #14726 üzenetére
Nem csak egy sata portja van kívülről? Nekem Zidoo Z10 Pro van benne egy 4TB hdd meg még gondoltam rakok rá egy másik HDD t de csak egynek van hely kívül.... Vagy nem?
sony89
válasz thomasvold #14730 üzenetére
Oksa, így helyes! Zidoo Z10 Pro jó kis vas!
Amúgy én egy 5A-es tápot vettem hozzá mindjárt a gyári tápja egy percet sem ment pihen a dobozában , na az 5A minden elbír mehet bele is meg az oldalába is HDD..
sony89
Nekem egy Zidoo Z10 Pro van én is rá raktam a ZetaTorrent Pro-t szépen teszi dolgát jönnek is le a filmek de valamiért csak 15-17M-val...mi lehet a hiba? Kábellel csatlakozik a Zidoo a routerhez ami gigabites és 1000-es Telekom net van... -
sony89
sony89
Valaki más próbálta az új HBOMAX-ot nézni Zidoon pl Z10Pro-n akár?
Ha igen milyen a kép és hang?Köszi!
sony89
Nekem is Zidoo Z10 Pro van LG CX oled hez plusz Sony 4k projektor teljesen jó minden anyag lejátszásra... Bátran megveheted! Viszont netflix hbomax stb felejtős rajta ez nem streamingre lett kitalalva...
sony89
válasz Frankie65 #15310 üzenetére
nekem ilyen van [link]
Ez viszi a Netflix-et akár 4K HDR, az HBOMAX ot is akár 4K HDR, meg majd a Disney+ is fog rajta menni...
hivatalos Netflix 4K támogatással is rendelkezik.
Google tanúsítvány is van!!!
Jó kis gép és olcsó..
Egy hibája van ha DolbyVision vagy HDR es az anyagot kézzel kell bekapcsolnod egyelőre még automatán nem vált , de talán majd javítanak a szoftverén idővel.. -
sony89
sony89
Zidoo Z10 Pro ra most melyik firmware a legjobb? Állítólag a legfrissebb Beta-ra nem érdemes frissíteni...
Az enyémen mos a 6.3.6.0 van -
sony89
válasz nt0524 #15607 üzenetére
Hello!
Nekem Zidoo Z10 Pro van ami nagyon jó lejátszó de sajna streamingre egy nagy 0
Ezért vettem egy MECOOL KM2 mediaboxot...ez nagyon jó mert Google licensz és Netflix licensz is megtalálható benne, ezért mindegyik streaming szolgáltató max felbontás és akár Atmos hanggal is képes menni rajta..
Mivel van egy Sony 290ES projektorom fontos volt hogy ezek a szolgáltatók is tökéletes minőségben jöjjenek! Ki is tudjam a képet küldeni a Sony felé...
Idáig teljesen jól működik Netflix, HBO MAX és a Disney+ is akár 4K HDR Atmos minőséggel! -
sony89
Tegnap lefrissitettem a Zidoo z10 pro lejátszóm a legfrisebb firmware de nekem nem vált át automatán HDR10 re ha egy dolby vision filmet akarok nézni a projektoron ...nem tudom mi lehet a gond lehet valami beállitas hiba...
Ugye a projektor csak HDR10 et tud feldolgozni jó lenne ha az ilyen filmeknél automatán a HDR sávot adná ki a Zidoo..
Amúgy a projektor egy Sony 290ES
Mi lehet a gond melyik beállításokat nézzem át?Köszi!
sony89
válasz Beni2360 #15654 üzenetére
Akkor sorban...Igen a frissítés előtt is ez volt!
A Tv egy LG OLED 55CX, de ez itt most nem lényeg mert egy Denon 4400h erősítőn keresztül megy ki a kijelzők felé a jel...ugye az 2 HDMI kimenetes , de mikor a Sony 290 et használom az erősítőn úgy van beállítva menüből hogy csak arra menjen a HDMI jel a TV ilyenkor nem zavar be , tehet a kimenet nem AUTO ra van kapcsolva!Ahogy az első képen van majd megpróbálom milyen ha kikapcsolom azt az állást..
10m es PremiumCord 2.1 es 8K HDR Fiber HDMI kábel megy a projektor felé az tuti jó
Egyszerre mindig csak egy kijelző megy vagy a TV vagy a Projektor!
Az EDID a SonyTV menüre volt kapcsolva itt a képen csak egy próba volt hogy igy milyen lehet de így sem jó!
Pl ez a film:
Doctor Strange in the Multiverse of Madness
HDR FORMAT....: Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU
A Dolby Vision-t nem tamogato eszkozok a HDR10 alapsavot fogjak lejatszani.És itt se vált át automatikusan a HDR sávra hanem csak akkor ha én bekapcsolom azt hogy a Zidoo mindent HDR be adjon ki!
sony89
Miben jobb az új fw mint az előző?
sony89
válasz captainnemo #16930 üzenetére
Nekem is egy apple tv 2022 es van és mellette egy Zidoo Z10 Pro... Tökéletes páros
sony89
A Zidoo-k nem steaming re lettek kifejlesztve.... Kár erőltetni! Soha nem lesz olyan mint pl egy Apple 4k 2022 vagy egy Meccol km2 plus....
sony89
válasz sirelancelot #16993 üzenetére
Nem írtam hogy te erőltetnéd...
Nálam úgy van hogy van egy Zidoo Z10 plus a letoltott anyagokra BD 3D UHD stb..
Streamingre meg van egy Atv 2022 4k és így mindent fasza minőségben tudok nézni..
sony89
válasz sirelancelot #16997 üzenetére
Úgy tudom az időjárás app egyelőre nem működik talán a következő firmware ben javítják...
sony89
válasz thomasvold #17334 üzenetére
Nálam is marad a Z10 Pro... talán majd a Z30 Pro egyszer ha lesz..tökéletes a Z10 Pro szinte mindenhez...streaminghez meg van egy Apple TV 2022 azon minden jön akár 4K ban is...
Tomp fórumlakókn összefoglalója miként készítsünk Dolby Vision videót a ZIDOO X szériás lejátszóhoz.
Egy cikk egyik fórumtársuntól a
ZIDOO UHD200 lejátszóról.
Hang rendszer
oldaláról.
- Újabb Samsungok telepíthetik a Galaxy AI-t
- nVidia tulajok OFF topikja
- Vezetékes FÜLhallgatók
- Léghűtés topik
- Érkezik Magyarországa az LG szuper dizájnos hordozható projektora
