2010-es verzió elég jó.
Thanos was right.
Ki használ még bármilyen Zone Alarm terméket? Gyerünk-gyerünk, ki vele..
Thanos was right.
Már tudom miért akartam ide írni...
Szóval ha valaki gondolkodik az Extreme Security kipróbálásán akkor mindenképp a legújabb beta verziót töltse le, ahhoz képest, hogy beta teljesen használható és rengeteg javítás, fejlesztés van benne a korábbi verzióhoz képest.
Innen lehet letölteni regisztráció után: Link
Nem muszáj valós adatokat megadni.
És itt a változások listája:
Fixed issues between 9.1.061.000 and 9.1.118.000:
* Support for IPv6 filtering has been added to our firewall
* Compatibility with Microsoft Security Essentials
* Communication issues with our registration server have been fixed
* Compatibility with Windows Firewall during ZoneAlarm installation has been resolved
* The diagnostics tool has been fixed to submit more detailed logging data
* Memory usage reduced by memory leaks fixed in Full Disk Encryption and the user interface
* Improved Browser Security support for the latest versions of Firefox
* Additional logging for the SmartDefense Advisor system has been added
* Multiple update dialogs will no longer appear when updates are available
* Improved Browser Security stability when visiting phishing sitesKnown Issues:
* Cancelling the installation of Full Disk Encryption may prevent future installations of Full Disk Encryption.
* Installing Adobe Flash may be blocked on some machines when Browser Security is enabled.
* On Windows 7, the Program Compatibility Wizard may appear on some machines. Simply click "This program installed correctly," as this warning is erroneous.
* "Stop all Internet Activity" or "Internet Lock" feature may stay on when restarting ZoneAlarm.Thanos was right.
Új beta.
Fixed issues between 9.1.118.000 and 9.1.180.000:
Improvement to stability, fixed several most common crashes.
Improvement to Program Advisor to reduce alerts for known programs.
Improvement to Antivirus updates.
Fixed erroneous message that Recovery Data for Hard Drive Encryption is out of date.
Browser Security: Addressed issue with installation of Adobe Flash.
Fix memory leak during hard drive encryption.
Include latest Antivirus dat files in the install.Known Issues:
During installation of Hard Drive Encryption, the Recovery Wizard may not start automatically before encryption, and need to be started manually from the Main panel.
Browser Security may not operate on Windows Vista with Firefox 3.6.
On Windows 7, the Program Compatibility Wizard may appear on some machines. Simply click "This program installed correctly", as this warning is erroneous.
Phishing site alerts may not display correctly in Firefox 3.6.Thanos was right.
Megjelent az új végleges verzió:
ZoneAlarm Extreme Security version 9.1.507.000
Letöltés itt: Link
Változások listája itt: Link
A többi termék is frissült, kivéve az ingyenes tűzfal verziót, az még béta állapotban van, de napokon belül kiadják a véglegest ami megszünteti az AVG antivírus-al való összeakadást és persze egyéb javításokat is tartalmaz.
Thanos was right.
- Microsoft licencek KIVÉTELES ÁRON AZONNAL - UTALÁSSAL IS AUTOMATIKUS KÉZBESÍTÉS - Windows és Office
- Fallout 4 Pip-Boy edition
- Office Professional Plus 2013, 2016, 2019, 2021 RETAIL licenckulcsok - MEGA Akció!
Cég: Ozeki Kft
Cég: Ozeki Kft
