arn
Azt vki el tudna mondani nekem hol van differencia sc55on a canvas es a gmidi kozott?
facebook.com/mylittleretrocomputerworld | youtube.com/mylittleretrocomputerworld | instagram.com/mylittleretrocomputerworld
arn
válasz quailstorm #53153 üzenetére
arn
válasz jokeph #53174 üzenetére
Mas tappal is nezted? Az intel 98ban jelentetett meg utoljara isas chipsetet. Ezen van? Ipari lapokon szokott lenni, de ez nem altalanos a p4 lapoknal.
ATX12V 1.2 Edit
A relatively minor revision from January 2002. The only significant change was that the −5 V rail was no longer required (it became optional). This voltage was required by the ISA bus, which is no longer present on almost all modern computers.[ Szerkesztve ]
arn
kicsit kibovitettem a vlbs benchet.
a tesztgep def beallitasokkal:
CPU Intel DX4 100 WB
Mainboard Asus VL/I-486SV2GX4 rev 2.1
Mainboard chipset SiS 85C471
Mainboard cache 256kB 15ns
BIOS setup default
RAM 16M 60ns 72pin FPM
OS MS-DOS 6.22WDC Paradise Bali32 1M VLB ARK Logic ARK1000VL
S3 86C805-P 1M VLB
miro Crystal 20SD VL 2M VLB S3 Vision864
Hercules PowerDynamite 2M VLB Tseng ET4000/W32pvolt egy masik et4000 is, de hajszalra ugyanazt hozta, mint a hercules.
benchek:
1990\3DBENCH
1990\3DBENCH2
1992\WOLF3D
1993\DOOM
1995\PERLMARK
1996\CHRIS3D VGA
1996\CHRIS3D 640x480
1996\DUKE3D VGA
1996\DUKE3D 640x480
1996\JEST VGA
1996\PCPBENCH VGA
1996\PCPBENCH 640x480
1996\QUAKE VGA
1996\QUAKE 640x480
1997\AI_BENCH
1997\MDK
1997\NTS
1997\SKBENCH 640x480atlag:
100,00% WDC Paradise Bali32 1M VLB ARK Logic ARK1000VL
98,42% Hercules PowerDynamite 2M VLB Tseng ET4000/W32p
97,61% miro Crystal 20SD VL 2M VLB S3 Vision864
90,18% S3 86C805-P 1M VLBvga:
97,03% miro Crystal 20SD VL 2M VLB S3 Vision864
96,96% Hercules PowerDynamite 2M VLB Tseng ET4000/W32p
90,91% S3 86C805-P 1M VLBvesa:
101,10% Hercules PowerDynamite 2M VLB Tseng ET4000/W32p
98,67% miro Crystal 20SD VL 2M VLB S3 Vision864
88,16% S3 86C805-P 1M VLBdoom (talan a legjobban passzol hozza korban):
39,54 FPS WDC Paradise Bali32 1M VLB ARK Logic ARK1000VL
37,67 FPS Hercules PowerDynamite 2M VLB Tseng ET4000/W32p
37,27 FPS miro Crystal 20SD VL 2M VLB S3 Vision864
34,03 FPS S3 86C805-P 1M VLBtovabbi reszletek (masodik ful): [link]
arn
válasz nakos1212 #53251 üzenetére
Na jo, de melyikhez kell ennyi ram? 99 vegen az ubergepekben volt 128m ram, ami 2000 vege fele nott 256mra. 2001ben meg jott a winxp - a winxp ota lenyleg ritka az olyan jatek, ami nem megy mai gepen.
arn
válasz quailstorm #53257 üzenetére
Pedig a 2001 eleg overkill volt latvanyra a maga koraban a pixelshader talan csak a dx9es jatekokkal valt elterjedte az evtized kozepen, es az utolso igazan elleejtos 3dmark latvanyra, ami megelozte korat. Mongy demoscene szeru demo, talan a 2000 volt az utolso, nekem a 2001 mar inkabb techdemo volt. 2000ig, a mindenki kartyaja elsa gtsig egy aktualis 3ds kartya a hozza megfelelo geppel nem sok embernek volt.
Bar en is mindig a techdemokat ereztem a leghamarabb elavulonak, mert a technikai reszen hamar tulleptek akkoriban. Nekem ami a mai szemmel is szep, az az ati 9700 techdemoi, egy hl2vel meg barmikor eljatszom ugy, hogy apam de jol nez ez ki meg mindig... a crysis nyitojelenetei ma sem rosszak.
arn
válasz Sanchez638 #53288 üzenetére
egy honapban jottek ki...
arn
A gyori jedlik jo volt a 90es evek elso feleben nem volt kerdes, hova megyek. Tobbet tanult az ember ott, mint a fosulin/egyetemen. Bar en a tudas nagy reszet magam szedtem ossze, egyszeruen vagy nem, vagy nem olyan szinten tanitottak az aktualis dolgokat. Akkoriban az alkalmazott es az oktatott tudas fenyevekre voltak egymastol, remelem mar mashogy van.
arn
vegre sikerult lepuceralnom, szinte teljesen karcmentes - a modokat is szepen valtogatja, es gyorsan. baromira orulok, hogy szinte "kidobando" aron sikerult megvenni, keresni sem tudtam volna jobbat, remelem sokaig mukodik - ilyet keressetek tfts retrozashoz (dell 2007fp).
arn
válasz Sanchez638 #53311 üzenetére
20 col, ips panel, 1600x1200, 4:3, dvi, dsub, svideo, video, pivotos - tobb mint idealis. talan vmi aktualis 21es eizo/nec lenne jobb, csak kerdes hogy kezelik az analog modokat, es az 700+ eur.
arn
arn
válasz zoltanz #53411 üzenetére
Anno 4850e x2vel epitettem htpct, xbmc alatt egy fhd videot se tudott lejatszani frame drop nelkul, csak gyorsitassal. Ill az i7 4770 se birja el az x265 videot 4kban. Ha a gyorsitas tamogatott, akkor a proci mar reszletkerdes, de egy mai alacsonyfogyasztasu (10w alatti) atom is kenterbeveri a gyorsabb c2duokat nyers teljesitmenyben.
arn
válasz frescho #53467 üzenetére
Ezeknek az integralt atomoknak nas, htpc a felhasznlasi terulete elsosorban. De olyan videokat dekodolnak es transzkodolnak, amit gyakran modern procik sem tudnak lejatszani kulso gpu nelkul, nemhogy egy core, toredek fogyasztasbol.
arn
Csinalsz egy virtualis meghajtot, feldobod a wint, bemountolod win10 ala (nativ tamogatja), ramasolgatsz, amit akarsz, majd atnyomod egy regi vinyora.
arn
válasz frescho #53479 üzenetére
Ez a dolog most is all... egy magon tud annyit, mai alkalmazasokban tobb szalon meg gyorsabb. Mi a gond? A fejlodesnek az is resze, hogy ugyanazt joval alacsonyabb fogyasztason kapod. Egy mai socnak alapveto resze a hwes gyorsitas, ettol is sokkal hatekonyabbak. Arrol nem is beszelve, hogy az alkalmazasi teruleteken, mint a nas, htpc, a hwes gyorsitas az elsodleges, a nyers cputeljesitmeny masodlagos.
arn
válasz frescho #53489 üzenetére
Nem terek ki... egy magon hasonlo, tobb magon jobb. De nehogy mar 2018ban az egy magos teljesitmeny legyen fontos. A hwes dolgok mar csak hab a tortan, es ez a lenyege, csak a c2d mar nyers teljesitmenyben sem jobb, semmilyen szempontbol sem.
De reszemrol mar hozzaszolasban leirtam, amit akartam, nem kivanok tobbet hozzafuzni.
arn
válasz RexMaximus #53532 üzenetére
A 486ba megy a midikartya, a rap10 kikerul egyelore - a ket hangmodulhoz (mt32, sc55) praktikusabb es jobb. A dos aranykorat igy minden szempontbol le tudom fedni midihez - gus, opl3, mt32, sound canvas, gmidi.
A gus pnp tartalekba lesz nincs kulonosebb vonzalom, ugyanugy a komplett gepek tartozekai, csak finomitok a konfigokon. A 486 lassan tobbet er, mint a modern gepem
arn
válasz RexMaximus #53536 üzenetére
Alapvetoen nekem is egy kartyam volt, a gus classic melle kerult kesobb egy sb16, mert eleg sok gond volt a gussal a jatekoknal - ez kb olyan 97 korul tortent. Ezutan amig isabusz volt, mindig az volt a masodlagos kartya (live, audigy volt talan az utolso).
arn
Hasznal vki ide-usb atalakitot? Az a terv, hogy a regi gepek vinyojait egy hosszabb kabelen keresztul ra tudjam kotni a modern gepre, backup, etc miatt.
arn
arn
bxben az 133as proci nem az igazi, csak a kesobbi lapok birtak stabilan, es azt is tulhajtott agpvel, amit sok videokartya nem birt (gf2gts tudja pl, tnt2ultra fagy).
arn
az ilyen lapokat mar a maga koraban is messze kerultem, igy passz a 366os procik kisebb valoszinuseggel mentek 550en, mint a 300asok 450en.
bh6bol is volt masodik verzio, amin volt ketharmadolas agpre 133as fsb mellett. az eredeti bh6 agpvel szvsz meg se fog nyekkenni 133on. az asus p3b szepen megy mar 133as fsbvel jol megvalasztott videokartyaval.
arn
kb annyi, hogy rendesen mukodni fog a lapodban amugy a katmai p3akkal szemben a tuningolt celeron a gyakorlatban semmilyen hatranyt nem szenvedett akkoriban. az sset kb semmi se tamogatta, amig az volt a csucsproci, hol a kisebb de gyorsabb cache, hol a nagyobb de alacsonyabb orajelu volt elonyosebb.
abba a lapba valszeg ez a max, slot1es procival: [link]
arn
ezeknek az atalakitoknal a kapcsolo erintkezoi ugyanugy mukodnek ats lapon, mint a normal atxes lapoknal? gyk ha rovidrezarom oket, akkor indul az atx tap... legalabbis ezeket szoktam gemkapoccsal rovidrezarni.
arn
válasz frescho #53690 üzenetére
mikori programokkal nezted? 99essel, amikor ezek mentek?
egyedul az nvidias drvek remlenek, hogy relativ koran kezdtek tamogatni.[ Szerkesztve ]
- Fogyjunk le!
- Microsoft Excel topic
- Ukrajnai háború
- Vicces képek
- (nem csak) AMD FX / Ryzen tulajok OFF topikja
- Sony Xperia 1 V - kizárólag igényeseknek
- Olcsó és visszafogottan elegáns kompakt AIO jön az ID-Cooling berkeiből
