DeckardCain
Ami coffee lake-el kapcsolatos. ha igaz mivel wccftech
"The new 6 core parts will feature 50% more cores, threads and cache compared to current offering. So we are looking at next-generation Core i7 mainstream SKUs with 6 cores, 12 threads and 12 MB of L3 cache. Similarly, the Core i5 models will be the first Intel mainstream models with full support for hyperthreading support. The Core i5 models will ship with 4 cores, 8 threads and 8 MB of L3 LLC (Last Level Cache). This is up from 4 cores, 4 threads and 6 MB of LLC on the current Core i5 model.
All models in the Coffee Lake S family will feature the next generation Intel GT2 tier graphics chip. The Pentium series would include 2 cores, 4 threads and up to 4 MB of L3 cache. There will also be some models with 3 MB L3 cache while featuring GT1 tier graphics chips."
"Intel 10nm CPUs To Launch in 2018 – Feature Support on Z390 Chipset
Finally, it’s mentioned that 10nm CPUs will be arriving to the consumer family on a new chipset known as Z390 which Intel is actively working on for Q1 2018. This chipset will be called CNL-PCH (Cannonlake PCH) so it’s quite evident that Intel is developing the new chipset for their upcoming 10nm Cannonlake CPUs. No information aside from this is shared on Cannonlake as of yet."[ Szerkesztve ]
DeckardCain
Hulyen irtam, heti 50grammal csokkentem.😊 aztan ha megall a sulycsokkenes ingadoztatok, hogy felporogjon AZ anyagcsere. Nalam amikor nincs dieta 400-500g ch megy. Gyors AZ anyagcserem. Dieta vegen olyan 180ig megyek le. AZ ala mar nem kemia nelkul.
Fos windows phone-rol sz@r potyogni.
DeckardCain
válasz DeckardCain #63619 üzenetére
Nyilvan ha megy a fogyas, nem minden heten megy az 50 grammos csokkentes.
DeckardCain
válasz Erdei88 #63622 üzenetére
Ez esetben a "masra" gondoltam.mivel mindig is szteroidok nelkul edzettem, dieta alatt is tartom magam ehhez. Gyors AZ anyagcserem, es "cucc" nelkul mar nehez jelentos izomveszteseg nelkul befejezni a dietat. Mindket dietam 89-90 kgval fejeztem be, A vegen napi 150-180g chval. Igyis megvolt egy kb 8 kilos fogyas 3-4 honap alatt, Ami nekem eleg egy tomegeles utan. 180 centihez pont jo nekem.
DeckardCain
Bioware új játéka?
Anthem -
DeckardCain
Hexus.net-en van i9 7900x review. Telorol nem tudom linkelni.
DeckardCain
Core i9 – Our Unbiased - Review Linus Tech Tips
Nem normális -
DeckardCain
válasz keIdor #65274 üzenetére
Azon gondolkodok ha megjelenik a 4/8as i5, veszek hasznaltan egy 6700k-t ami meg a b150es lapban is elketyeg a 4ghz-en. 2 hete vettem 16gb ramot. Ez igy 1080ti-ig ok lenne 1440p-ben. Remelem hogy a 2070 tudni fog min egy 1080-1080ti szintet. Aztan egy ket evig letudva az egesz.
DeckardCain
DeckardCain
válasz #Morcosmedve #66120 üzenetére
DeckardCain
Telorol nem megy a link..
http://www.guru3d.com/news-story/core-i3-8300-with-four-cores-and-eight-threads-spotted.html -
DeckardCain
Lehet mégis jó lesz bányászni a Vega.
AMD Radeon RX Vega 64 to be great for mining"Seems the hash rate on VEGA is 70-100 per card, which is insanely good."
66299:
DeckardCain
Na akkor kezdödik
Első vega "teszt".
Semmi meglepő, jöhet a volta kb. -
DeckardCain
DeckardCain
Intel Core i7-8700K vs. Intel Core i7-7700K
A többi cpu is fent van (8700, 8600k, 8400) -
DeckardCain
válasz cyberkind #67296 üzenetére
Na igen érdekes lesz a 4/8 vs 6 mag. Nekem sima i5ről akár még jó lehet, de ha eszem van beszerzek egy használt 6700/6700k-t és nem kell lapot cserélnem.
De a héten néztem van már 190e-s evga 1080 FTW icx2 újonnan is.. De gyors elhessegettem a gondolatot... Az is elég ami van jelenleg.. Inkább megveszem az új tv-m hamarosan...
DeckardCain
válasz Devid_81 #67740 üzenetére
Vicc mar. Mondjuk ma megrendeltem a destiny 2ot. Kiprobaltam a betat es siman ment 1080p-ben ( i5,1060 6gb, 16gb ram). Egy ideig el leszek vele. Szerintem mostanaban nem cserelek semmit inkabb veszek egy 4k tvt meg hdd-ket.
Ertelemes upgrade monitor 170-300e, Vga 200-270e meg egy csere i7-re. Inkabb passz heti par ora jatek mellett. -
DeckardCain
Na akkor ez is felkerul a listara. Egyre tobb minden van ezen a listan😊
- ARCTIC Liquid Freezer 360 II A-RGB rev.3 ( Garancia )
- NAD M25 7Ch Master Series végfok végerősítő
- Sony 55-210mm f/4.5-6.3 OSS (Sony E)
- Eladó több mint 2 év garanciával - LG OLED48C21LA / 4K/UHD/2160P/120Hz/OLED
- Razer Blade 16 2023 (i9 13950HX,RTX 4090 16Gb, 32GB DDR5 5600Mhz, 2x 1TB, 16" Dual UHD+FHD+ MiniLED)
