moldav20
Én egy sima Mi WiFi 3-at próbálok padavanosítani linux alatt. Egy reddites leírást követtem, de a firmware build mindig errorral végződik. Tudnátok esetleg segíteni?
HOSTLD scripts/kconfig/conf
scripts/kconfig/zconf.tab.o: In function `zconflex':
zconf.tab.c.text+0xff6): undefined reference to `kconf_id_lookup'
zconf.tab.c.text+0x10a7): undefined reference to `kconf_id_lookup'
collect2: error: ld returned 1 exit status
scripts/Makefile.host:113: recipe for target 'scripts/kconfig/conf' failed
make[5]: *** [scripts/kconfig/conf] Error 1
/home/david/rt-n56u/trunk/user/busybox/busybox-1.24.x/Makefile:443: recipe for target 'silentoldconfig' failed
make[4]: *** [silentoldconfig] Error 2
Makefile:519: recipe for target 'include/autoconf.h' failed
make[3]: *** [include/autoconf.h] Error 2
make[3]: Leaving directory '/home/david/rt-n56u/trunk/user/busybox/busybox-1.24.x'
Makefile:4: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/home/david/rt-n56u/trunk/user/busybox'
Makefile:152: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/david/rt-n56u/trunk/user'
Makefile:185: recipe for target 'user_only' failed
make: *** [user_only] Error 2/------------------------------------------------------------------------------/
/home/david/rt-n56u/trunk/libs/libiconv/libiconv-1.13.1/libcharset/libtool: line 46: -mips32r2: command not found
/home/david/rt-n56u/trunk/libs/libiconv/libiconv-1.13.1/libtool: line 49: -mips32r2: command not found
checking for Doxygen tools... checking for dot... not found
checking for doxygen... not found
/home/david/rt-n56u/trunk/libs/libvorbis/libvorbis-1.3.2/libtool: line 42: -mips32r2: command not found
Cég: Ozeki Kft
Cég: Ozeki Kft
