KMT
Srácok, megy (már) android 4.1.2-n a viber? Csak mert a 4.1-re frissítés után ugye pár hétig nem működött (legalábbis nexus s-en). Most inkább várnék a rendszerfrissítéssel, amíg a több program "utoléri magát"...
KMT
válasz ViberMedia #445 üzenetére
Hello, Mr Viber!
Do you plan to develop the function of turning off the screen while speaking (when the phone is close to the head)? With Nexus s, the background light is still on, there is just a black screen, and it eats the battery... Manual switching off is not perfect, sometimes mutes the sounds/mic...
KMT
válasz ViberMedia #457 üzenetére
I have 2.2.3. How do I report it?
KMT
válasz ViberMedia #513 üzenetére
Thanks, I've already got the answer. Just to inform you, you are working on it. Thanks for the help!
KMT
válasz ViberMedia #587 üzenetére
BTW, Is it intentional that the volume buttons set the ringer volume (not the volume of the speaker) when you use it while viber is in calling/ringing state? Doesn't seem logical to me.
KMT
válasz ViberMedia #589 üzenetére
Ok... If you use the volume buttons (at side of the phone) while you call someone with normal phone (not viber) you set the volume of the "call" (or "speaker" / volume of the partner). With viber; if it's "calling" you still set the ringer volume, and only when you actually speak with the partner, then you can set the "call" volume.
KMT
Viber is still not able to correctly switch off the screen while speaking (so high battery usage)...
and still shows the times of missed calls as the time when the user switches on the mobile data/wifi...
and its sound quality sometimes gets worse (with updating)...
I don't understand. These seem to be easily correctable.
KMT
válasz ViberMedia #843 üzenetére
Thanks, looking forward to it!
- Horgász topik
- Audiokultúra - Hi-Fi-ről hifisen
- Melyik tápegységet vegyem?
- LED világítás a lakásban
- Asztalos klub
- Fotók, videók mobillal
