TP-Link WR1043ND - N450 router
Muad_
Hi,
Van egy kis problemam Digi-s kabelnettel. A routeren a vargalex build van most fent:
OpenWrt vargalex v1.1.3 r32649 / LuCI Trunk (trunk+svn8881)A logokban ezt latom:
Jul 21 17:54:09 OpenWrt daemon.info pppd[769]: Plugin rp-pppoe.so loaded.
Jul 21 17:54:09 OpenWrt daemon.info pppd[769]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Jul 21 17:54:09 OpenWrt daemon.notice pppd[769]: pppd 2.4.5 started by root, uid 0
Jul 21 17:54:09 OpenWrt daemon.info pppd[769]: PPP session is 265
Jul 21 17:54:09 OpenWrt daemon.warn pppd[769]: Connected to xx:xx:xx:xx:xx:xx via interface eth0.2
Jul 21 17:54:09 OpenWrt daemon.info pppd[769]: Using interface pppoe-wan
Jul 21 17:54:09 OpenWrt daemon.notice pppd[769]: Connect: pppoe-wan <--> eth0.2
Jul 21 17:54:09 OpenWrt kern.info kernel: [ 38.630000] eth0: link up (1000Mbps/Full duplex)
Jul 21 17:54:09 OpenWrt kern.info kernel: [ 38.630000] device eth0.1 entered promiscuous mode
Jul 21 17:54:09 OpenWrt kern.info kernel: [ 38.640000] device eth0 entered promiscuous mode
Jul 21 17:54:09 OpenWrt kern.info kernel: [ 38.650000] br-lan: port 1(eth0.1) entered forwarding state
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.130000] cfg80211: Calling CRDA for country: HU
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.140000] cfg80211: Regulatory domain changed to country: HU
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.140000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.150000] cfg80211: (2402000 KHz - 2494000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.160000] cfg80211: (4910000 KHz - 5835000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jul 21 17:54:10 OpenWrt kern.info kernel: [ 40.650000] br-lan: port 1(eth0.1) entered forwarding state
Jul 21 17:54:10 OpenWrt user.notice ifup: Enabling Router Solicitations on lan (br-lan)
Jul 21 17:54:10 OpenWrt user.notice startservices: /etc/hotplug.d/block/50-startservices script not enabled. Please change ENABLED value to 1 in script for enabling.
Jul 21 17:54:12 OpenWrt user.notice startservices: /etc/hotplug.d/block/50-startservices script not enabled. Please change ENABLED value to 1 in script for enabling.
Jul 21 17:54:12 OpenWrt kern.info kernel: [ 42.460000] device wlan0 entered promiscuous mode
Jul 21 17:54:13 OpenWrt user.notice startservices: /etc/hotplug.d/block/50-startservices script not enabled. Please change ENABLED value to 1 in script for enabling.
Jul 21 17:54:13 OpenWrt daemon.info pppd[769]: Remote message: Too many sessions^J
Jul 21 17:54:13 OpenWrt daemon.err pppd[769]: PAP authentication failed
Jul 21 17:54:13 OpenWrt daemon.notice pppd[769]: Connection terminated.
Jul 21 17:54:13 OpenWrt daemon.info pppd[769]: Exit.
Jul 21 17:54:13 OpenWrt daemon.notice netifd: Interface 'wan' is now downSzoval mintha meg az elozo login session aktiv lenne es ezert nem tud ujra kapcsolodni. Es csak ha kezzel connectalok akkor tud felmenni a netre. Ez most egy restart utana volt. Szoval ha a routerben csinalok egy restartot akkor nem bontja megfeleloen a kapcsolatot vagy miert lehet ez, hogy nem tud felmenni a netre router start utan?
Muad_
válasz Intruder2k5 #29138 üzenetére
Thx.
Atolvastam par oldalt mar a forumbol, de ezeken vhogy atfutottam. Ugy nez ki, hogy mukodik a workaround nalam is. -
Muad_
válasz wwenigma #29402 üzenetére
En regisztraciotol szamitva 2 oran belul megkaptam a tunnelt meg a subnetet is. Viszont mikor a routeren szerettem volna beallitani akkor egy kis problemaba utkoztem en is.
Nekem egy OpenWrt vargalex v1.1.3 r32649 van most a routeren. Az elso csomagot amit irt a leiras (kmod-ipv6) meg sikerult felrakni viszont a kovetkezo kettot mar nem talaltam: kmod-ip6tables, ip6tables. Amit meg lattam, hogy az ures hely sem sok maradt a routeren: Free space: 31% (180.00 KB)
Szoval ha rakotok egy regebbi pendrivet a routerre akkor mit kene majd beconfigolni, hogy azt hasznalja a router (mire kene felmountolni)? A hianyzo csomagokat honnan lehetne letolteni vagy mit kene felrakni azok helyett?
