bigmasterg
válasz fi:zi'k #4198 üzenetére
Akkor gondolom nem adnak hozzá tápot.
Ugyan akkora a teljesítmény elemről és tápról is ?
Ki tudod próbálni valamilyen nagyobb ohm-os / nehezebben hajtható fejhallgatóval is ?
Mondjuk ha még mindig nálad van a bravo, akkor gondolom a sextett is. Azzal például hogy boldogul ?
Esetleg K601/Hd600 kategóriával elbírna-e.Már csak azt a sok kimenetet nem értem, hogy minek. Meg egy rca bementet rárakhattak volna, ha már xlr-t raktak.
Mondjuk az xlr-t sem értem, ha nem tud szimmetrikus meghajtást. Vagy 2 jack-el tud balanced erősítést? mint ez[ Szerkesztve ]
bigmasterg
válasz fi:zi'k #4231 üzenetére
"They market the thing as a “personal subwoofer”, which is an interesting way of saying it is a portable hardware based EQ box with an emphasis on the low end. It also acts as somewhat of an amp although it does is not really advertised as such and does not have its own volume control. The theory is that you run your source flat (with no EQ or bass boost applied) and then send the signal into the ZO which takes care of it from there, thus adding a (hopefully good) EQ option to practically any device. The ZO sells for $119 and comes with a 60 day money back guarantee."
szerk.:
"The most apparent change to the sound one notices with the ZO is indeed boosted bass – but not only in the usual sense that the already available frequencies get louder. Instead, the existing bass also gets deeper, seemingly defying laws of physics and electronics. Usually, a given speaker can’t reproduce frequencies lower than its margin of efficiency allows, it can only move so much air before it stops working properly and starts to distort. With the ZO however even extremely bass-deficient phones, such as the Koss KSC75, AKG K701, or any Etymotic model, can become natural sounding in the lower audible spectrum. However, the ZO doesn’t create bass when there is none in the source material. Recordings of string quartets will basically stay untouched by the Smartvector processing, they won’t be turned into a rave party.
Well, that added bass sure sounds excellent in every aspect. It’s by the book – tight, punchy, textured, roomy, deep, not intruding the midrange."
p_adam
válasz fi:zi'k #4957 üzenetére
Erre csak azt tudom mondani, hogy most van aki head-fi-n egy Stax Omega II + HeadAmp Blue Hawaii SE-vel használja a 25$-os Belden összekötő kábelt a 30x annyiba kerülő ezüstkábel helyett és elégedett.
Még gondolkodok hogy variálok az XLR kábelekkel én is hogy kiderüljön tényleg megéri-e költeni rá vagy jó ez a Belden/Mogami/Canare/Gotham stb stb kategória is. Azt mondjuk még hozzáteszem hogy az XLR elvileg ellenállóbb a zajokra tehát elvileg a különbségek RCA-n jobban kijönnek.Az biztos hogy a bemelegedés Sokkal többet számít nálam, kár hogy a Parasound trafója zizeg kicsit ezért estére inkább ki szoktam kapcsolni (ki kell húzni a kábelt mert az On/Off kapcsoló is csak a fényeket oltja ki .
Bodz
Szerintem elég nagy különbségek vannak már ebben az árkategóriában is. Qed Profile Audio kábelt használok. Vettem hozzá egy Positive Cable Optimum Librát. Sűrűbb, sötétebb, kevésbé részletes hang, karcos magas lett az eredmény. Nagyon nem tett jót a DT 990-nek ez a kábel.
Egyébként mennyi igaz abból, hogy az ezüstözött kábelektől finomodnak a magasak?
guppy
válasz fi:zi'k #5441 üzenetére
Szerintem ebbe akkor kellett vna belefogni amikor megjelent, u is (ahogy fapaci is írta) Magyarországon a "divat" "népszerű" termékekre szokott kereslet lenni (lásd DacMagic), ami az idő múlásával csökken (persze amíg nemjön vmi jobb u ilyen áron addig lesz rá). - Persze ez magánvélemény nekem nincs semmilyen tapasztalatom etéren - nem is értem minek okoskodom bele
Il Dottore - az LCD2-t megvetted már vagy csak tervben van ?
ami az erősítőt illeti én egy AMB M^3 néznék/építenék hozzá, de ahogy bigmasterg is irta,DACod már van hozzá ? (s ha van milyen, esetleg tervezel e szimmetrikus rendszert építeni)[ Szerkesztve ]
contaxg
contaxg
válasz fi:zi'k #5459 üzenetére
Az Áfa és némi költség biztos rá jön még. De ez az Audinstra is igaz, ha hivatalosan akarja valaki forgalmazni. Elvileg a HRT kb. egy tizessel olcsóbb lesz.
Az se felejtésetek el, hogy az ami árak sok esetben Áfa nélkül vannak megadva és államonként különböző Áfával terhelik ezeket. Persze ez is vicces európai mércével max 5-6 százalék szokott lenni.
A jó zenehallgatáshoz nem feltétlen kell minőség. Az egy intellektuális kaland, amit mindenki a saját szintjén élhet meg. A hifi egy eszköz ami ezt az élményt fokozza, de nem feltétlen szükséges hozzá.
contaxg
válasz fi:zi'k #5464 üzenetére
Igen kb 13eFt lenne nagyjából a különbség és van benne erősítő és DAC is.
Il Dottore
Szerintem hozhatnál pár SH Lavry a csapatnak![ Szerkesztve ]
KMT
válasz fi:zi'k #5512 üzenetére
Ha az 50 a felső határ, akkor lehet benne fantázia. Sajnos az ebay-es, szállítást is tartalmazó ár elég kedvező ehhez képest.
Itthon a Zero lenne a riválisa, arról nem sok infót találtam, hogy melyik a "jobb". Esetleg egy komolyabb összehasonlító teszt lendíthetne a dolgon.
guppy
válasz fi:zi'k #5545 üzenetére
Szerintem csak azoknak lehet érdekes akik gyorsan akarnak ilyet venni, sztem az emberek többsége ebben az árkategóriában kétszer is meggondolná honnan veszi ~5k különbségért, és még lehet szerencséjük is és akkor 37 ből itt van.
Sztem 45-7k lenne az ideális ár az ebayes konkurenciával szemben. -
guppy
válasz fi:zi'k #5597 üzenetére
áfás számlával nem jön ki 47 ből ? (ami a garanciá illeti az valóban nagyon meg tudja dobni az árat, erre nem is gondoltam h mivan ha tönkremegy egy neadj istn) - nincs tapasztalatom ezen a téren, így csak a véleményemet írtam le úgy mint egy lehetséges vásárló h hogyan látom én a dolgokat, nem kritizálni akartalak
a szerencsés dolgot azért írtam mert fennál az esélye, gyakorlatilag viszont esélytelen.Hifimant sztetek hol hirdessem meg ? (sztereo erősítők, fej fülhallgatók, hangkártyák)
p_adam
válasz fi:zi'k #6175 üzenetére
Ezt legegyszerűbb neki megírni
Visszatérve a mérési témára tényleg elkel majd egy összehasonlítás 'a' végfok és a CEC között. Míg a mérésekben az utóbbi biztosan sokkal jobb (a végfokon egy pici zaj hallható volt amikor legutóbb próbáltam, persze csak némán), valószínűleg nem is kicsivel, addig szimplán hangban már egyáltalán nem biztos.
contaxg
- Digitális detox a Nokiától
- Ukrajnai háború
- Villanyszerelés
- Okos Otthon / Smart Home
- Vezetékes FEJhallgatók
- Békéscsaba és környéke adok-veszek-beszélgetek
- Díszdobozos Lenovo Yoga Slim 7i Pro "Kis Gamer" Ultrabook 14" -40% i5-11300H 16/512 QHD+ 2,8K OLED
- Ryzen5 esport Gamer(16gb ddr4/m2 ssd/win10/Vega11)
- HP ProBook 430 G6, 13,3" FULL HD IPS, I5-8265U, 8GB DDR4, 256GB SSD, WIN 10/11, SZÁMLA, GARANCIA
- Dell Latitude 3420, 14" FULL HD IPS, I5-1145G7 CPU, 8GB DDR4, 256GB SSD, W11, Számla, Garancia
- Dell Latitude 7280, 12,5" FHD IPS Kijelző, I5-6300U, 8GB DDR4, 256GB SSD, WIN 10, Számla, garancia
