zambozoli
Műszaki adatok:
Size
Amazfit GTR 47mm : 47.2X 47.2X 10.75mm
Amazfit GTR 42mm : 42.6 X 42.6 X 9.2mmWeight (without strap)
Amazfit GTR 47mm
: Aluminum alloy: about 36g,
: Stainless steel: about 48g
: Titanium metal: about 40gAmazfit GTR 42mm : about 25.5g
Waterproof and dustproof level : 5ATM
Screen
Amazfit GTR 47mm : 1.39″AMOLED, Resolution – 454X 454, 326 ppi
Amazfit GTR 42mm : 1.2″ AMO-ED, resolution 390 X 390, 326 ppiTouch
Helicon Gordon Gorilla 3rd generation tempered glass + AF coatingStrap Type
Amazfit GTR 47mm : aluminum alloy – brown leather strap, stainless steel – brown leather strap strap, metal – fluoro rubber strapAmazfit GTR 42mm : star black – black silicone strap, cherry powder – pink silicone strap, moonlight day – white Silicone strap, coral red – red silicone strap
special edition: white leather strap strapWidth
Amazfit GTR 47mm : 22mm
Amazfit GTR 42mm : 20mmSensors
Bio Tracker PPG Bio-tracking optical sensor
6-axis accelerometer sensor
3-axis geomagnetic sensor
Air pressure sensor
Capacitive sensor
Ambient light sensor
GPS GLONASS positioning
NFC city bus subway, access control card simulation
BT5.0 BLEBattery
Amazfit GTR 47mm : 410mAh LiPo
Amazfit GTR 42mm : 195mAh LiPo
magnetic charging stand,
2Pin Pogo Pin charging
Charging time : theoretical charging time is about 2 hoursEndurance Battery Life
Amazfit GTR 47mm
Daily use mode: 24-day heart rate normally open, sleep monitoring, 15 minutes per day GPS turn-on, 150 messages pushed, lift the wrist screen 30 times, NFC swipe 4 times a day, other operations 5 minutes basic watch mode: 74 Turn off Bluetooth, heart rate and other functions every day, and raise your hand to shine 100 times a day.
GPS continuous working time: 40 hoursAmazfit GTR 42mm
daily use mode: 12 days heart rate normally open, sleep monitoring, 15 minutes per day GPS is turned on, 150 messages are pushed, the wrist is illuminated 30 times, NFC is swiped 4 times a day, other operations 5 Minute basic watch mode: 34 days to turn off Bluetooth, heart rate and other functions, raise the hand to brighten 100 times.
GPS continuous working time: 22 hours per day
* Battery usage time may vary depending on usage, settings and many other factors, actual results may vary.Supported Devices
Android5.0 and above,
iOS10.0 and above supportIn Box equipment
magnetic charging stand, manual accessoriesÜdv:ZZ
