Téma összefoglaló
(Utoljára frissítve: 2024.04.20)
Patice
Megerősítem. Nekem is megjött:
"Dear Synology users,
Synology® confirmed known security issues (reported as CVE-2013-6955 and CVE-2013-6987) which would cause compromise to file access authority in DSM. An updated DSM version resolving these issues has been released accordingly.
The followings are possible symptoms to appear on affected DiskStation and RackStation:Exceptionally high CPU usage detected in Resource Monitor:
CPU resource occupied by processes such as dhcp.pid, minerd, synodns, PWNED, PWNEDb, PWNEDg, PWNEDm, or any processes with PWNED in their names
Appearance of non-Synology folder:
An automatically created shared folder with the name “startup”, or a non-Synology folder appearing under the path of “/root/PWNED”
Redirection of the Web Station:
“Index.php” is redirected to an unexpected page
Appearance of non-Synology CGI program:
Files with meaningless names exist under the path of “/usr/syno/synoman”
Appearance of non-Synology script file:
Non-Synology script files, such as “S99p.sh”, appear under the path of “/usr/syno/etc/rc.d”
If users identify any of above situation, they are strongly encouraged to do the following:For DiskStation or RackStation running on DSM 4.3, please follow the instruction here to REINSTALL DSM 4.3-3827.
For DiskStation or RackStation running on DSM 4.0, it’s recommended to REINSTALL DSM 4.0-2259 or onward from Synology Download Center.
For DiskStation or RackStation running on DSM 4.1 or DSM 4.2, it’s recommended to REINSTALL DSM 4.2-3243 or onward from Synology Download Center.
For other users who haven’t encountered above symptoms, it is recommended to go to
DSM > Control Panel > DSM Update page, update to versions above to protect DiskStation from malicious attacks.Synology has taken immediate actions to fix vulnerability at the point of identifying malicious attacks. As proliferation of cybercrime and increasingly sophisticated malware evolves, Synology continues to casting resources mitigating threats and dedicates to providing the most reliable solutions for users. If users still notice their DiskStation behaving suspiciously after being upgraded to the latest DSM version, please contact security@synology.com.
Sincerely,
Synology Development Team"Eladó: Intel NUC J5005, Xbox 360, Daewoo Matiz, Lenovo dokkoló
Úgy nem jó nekem.. Akkor passzív vagyok. Csak úgy jó, ha az internal porthoz a 9091-es TM portot írom.
NAS tűzfalon ugye engedélyeztem a 9091-es portot, csak így megy nekem a TM, illetve ha nincs engedélyezve, akkor a GUI sem csatlakozik.
DDNS beállítottam, ahhoz viszont a 9091-es service, illetve 5000-es portokat engedélyeztem a routeren, hogy telóról el tudjam érni a DSM-et, illetve a TM-et. Ide ugyebár internal-hoz nem kellett semmit sem írnom. Fura hogy amit írtok úgy totál passzív vagyok.
iPhone 13 Pro Max
chemand
Tegnap már majdnem feladtam, nagyon sokféleképpen próbáltam könyvtárakat hozzáadni (add Path pontnál) a Serviio Consol-ban amikor eszembe jutott, hogy esetleg Android alatt is meg lehetne próbálni.
Találtam is egy programot (ServiiDroid) amivel sikerült a NAS megosztott hálózati könyvtárait beállítani! Most úgy néz ki, hogy működik a Serviio, és végre tudok előre-hátra pörgetni a filmekbe is, amit a Syno médiaszerverénél nem tudtam.Ja és még valami, a filmeknél a TV-n egy kép jelenik meg a filmből, nem a gyári filmszalag.
Na basszus tényleg.. Ki is ment teljesen a fejemből
Meg is találtam Katt ha esetleg más is ki akarja próbálni.
Köszi hogy említetted újra
Patice Nekem még 4.3 van fent, de időzítést nem találtam erre. Ah értem, akkor csak képeknél csinálja a kis "előnézetet"
iPhone 13 Pro Max
Elemental
Ez igaz, de akkor, hogy seedelhess, érintetlenül kell hagyni a letöltött mappát, gondolom. Én alapból átnevezek minden letöltést.
Plusz, akkor onnan menne a seed, ahol a végleges helye van a cuccnak.
Én ráakasztottam egy 500-as külső lemezt, azt adtam meg a DS-ben ideiglenes helynek, ott van a @download mappa, onnan megy a seed. Fölöslegesen nem terheli a belső lemezeket.[ Szerkesztve ]
pomk
Felhívtam az eladót. Mondtam neki, hogy téves a hirdetés.
Azt mondta, hogy a DS213j modellt árulják, és hogy a hirdetés téves, javítják.Mondjuk kíváncsi lettem volna mi van akkor, ha leütöm anélkül hogy itt figyelmeztettetek volna és utólag derül ki, hogy nem is azt hirdeti, ami a szövegben van.
Jaa, hogy oda van írva, hogy az elírás és tévedés jogát fenntartják...
Most komolyan, ez az egy mondat bárkit bármi alól fel tud menteni?! Mert akkor meghirdetek egy piros Trabantot Ferrariként 100 millióért, és odaírom ezt a mondatot hátha valami hozzá nem értő emberke megveszi.
És evvel nem a jelenlegi eladót kívánom bántani, csak számomra elég érdekes, hogy az ide vonatkozó törvények ezt engedik. -
pomk
Igazából csak annyi, hogy a "120"-as és a "140"-es jelzők a netre a letöltési sebességre vonatkozik, és akkor ez nálam "20". Ez csak ismeret bővítés miatt kérdeztem. Én ezt "20 megás"-nak ismerem.
A mentés manuális, vagy automata? Ha automata, meg tudod adni, hogy melyik könyvtárakat mentse le 2x naponta? A külső tud aludni míg a belső mükődik, esetleg fordítva, vagy is-is? -
Patice
Én Win alatt próbálkoznék első körben valamilyen adat visszaállító programmal.
Ha nem sikerül, akkor a sokszor linkelt Ubuntu-s módszerrel linux alatt próbálkoznék ilyesmivel.
Csak elmélkedem. Még sohasem próbáltam.
MrCsiT
Egy TP-Link 1043ND -t vettem. Egy Edimax Br6594N vagy ilyesmi nevűt váltott, az elég sokszor megállt valamiért mostanában. Vagy sok lett neki már a NAS-sal együtt a meló, vagy nem tudom.
A TP-linket a gyári 3.15.31 Build 130925 Rel.32445n fw-vel használom, és nem tervezem, hogy pulcsit, julcsit, lucy-t,vagy egyéb kedves hölgyet tegyek rá/alá.Találtam egy érdekességet a NAS fájlrendszer elérésére. Azt még nem tudom, hogy vajon működik-e, amit leírnak:
http://www.wijngaard.org/get-access-to-synologys-filesystem/
Azért nézegettem a ddnsnev.synology.me-t, mert
- érdekelt, hogy működik-e, és az edimaxxal elértem;
- szebb a név, mint az IP.Nincs semmi tiltva a NAS-ban, más lesz a megoldás. Routerben nem találtam NAT loopback-et.
"Nekem a "link" egy hivatkozás legyen, ne egy ember ?!" - by Mr.CsiT
bigdady
Még ezzel a survielance stationnal szívok: ugyanis a camerám nincs a támogatott listában illetve csak a nappali változata az enyém meg éjjellátó is. Szóval ha támogatottként választom ki akkor csak a s.stationt lehet kiválasztani mozgásérzékelőnek a kamera sensorát nem (ami azért kell mert brutális érzékeny a s.station programja és folyamatos jelzést küld).
Viszont ha egyedi kameranak állitom be az enyém akkor az érzékenység megjavul viszont csak akkor küld emailt/push-t ha rögzít is a kamera, ha csak mozgást érzékel akkor nem. Ördögi kör.
Egyelőre kifogott rajtam
Ha valaki küzd ilyennel netán megoldotta valahogy ne tartsa magában[ Szerkesztve ]
tobias40
Linket dobnátok róla?
Jó lenne ha még egy kamerát tudnék rakni a syno-ra de nem fogok 15000-et fizetni a licenszért...Nekem kültéri van ezért nem tudom megmondani mennyi led kell beltérre,de a kültériből kiindulva minél több!
5-8 méterre simán ellátok a kamerámmal éjszaka is de az arcokat,részleteket nem látom és nem is hiszem hogy ezekkel ez megoldható lenne.
Nekem Foscam kamerám van ami nem forgatható de merem ajánlani bárkinek! (FI8904W)
- Getac UX10 G2 i5-10210U 8GB RAM 256GB SSD Win 10 Pro
- Hoppá! Dell Precision 7550 Tervező Vágó Laptop -70% 15,6" i7-10875H 32/512 Quadro RTX 3000 6GB FHD
- Honor Magic6 Lite 256GB, Kártyafüggetlen, 1 Év Garanciával
- Dell 7390 13,3" FULL HD/i5-8250U/DDR4 8Gb/256GB M2 SSD/HDMI/4G/CAM/BT/Wifi/Új AKKU 1 Év Gari!
- Aszta! Dell Precision 7550 Tervező Vágó Laptop -70% 15,6" i9-10885H 64/512 Quadro RTX 5000 16GB! FHD
