HookR
válasz kabelmania27 #46585 üzenetére
Este óta (a log-okból úgy látom azóta is folyamatosan) ismét népmesébe illő a netkapcsolat. Hol volt, hol nem volt. Hívjam megint az ügyfélszolgálatot? Csak hát nem rég lett cserélve, ezért gondolom most sem leszek előrébb egy modemcserével. Max. ideig-óráig.
▌www.thunderbolts.info | youtube.com/ThunderboltsProject ▌16personalities.com▐
HookR
válasz kabelmania27 #46607 üzenetére
2016-04-06 10:09:38: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:50:16: [Info] Authorized;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5c:23:3b:4...
2016-04-06 09:50:09: [Info] TLV-11 - unrecognized OID;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=0...
2016-04-06 09:50:09: [Minor] Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=b0:c2:...
2016-04-06 09:50:09: [Minor] Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=b0:c2:...
2016-04-06 09:50:08: [Warn] DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
2016-04-06 09:50:05: [Info] Honoring MDD; IP provisioning mode = IPv4
2016-04-06 09:49:53: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2016-04-06 09:49:20: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:49:20: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2016-04-06 09:49:20: [Warn] MDD message timeout;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5...
2016-04-06 09:46:38: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:46:38: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2016-04-06 09:46:38: [Warn] MDD message timeout;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5...
2016-04-06 09:45:37: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2016-04-06 09:41:17: [Info] Authorized;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5c:23:3b:4...
2016-04-06 09:41:17: [Major] Unicast Maintenance Ranging attempted - No response - Retries...
2016-04-06 09:41:17: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:40:20: [Info] TLV-11 - unrecognized OID;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=0...
2016-04-06 09:40:19: [Minor] Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=b0:c2:...
2016-04-06 09:40:19: [Minor] Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=b0:c2:...
2016-04-06 09:40:19: [Warn] DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
2016-04-06 09:40:15: [Info] Honoring MDD; IP provisioning mode = IPv4
2016-04-06 09:40:02: [Major] Received Response to Broadcast Maintenance Request, But no Un...
2016-04-06 09:39:30: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:39:30: [Warn] MDD message timeout;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5...
2016-04-06 09:34:59: [Major] Started Unicast Maintenance Ranging - No Response received - ...
2016-04-06 09:12:51: [Info] Authorized;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=00:01:5c:23:3b:4...
2016-04-06 09:12:46: [Info] TLV-11 - unrecognized OID;CM-MAC=b0:c2:87:db:0e:dd;CMTS-MAC=0...
2016-04-06 09:12:45: [Minor] Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=b0:c2:...
2016-04-06 09:12:45: [Minor] Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=b0:c2:...
2016-04-06 09:12:44: [Warn] DHCP WARNING - Non-critical field invalid in response ;CM-MAC...[ Szerkesztve ]
szabogabor10
válasz kabelmania27 #46664 üzenetére
Igen, de szerintem ez még pár évbe beletelik. De ne legyen igazam.
Nyugaton se nagyon terjedt még el. Svájcban ebben az évben tervezik bevezetni.[ Szerkesztve ]
iPhone 14 Pro Max -- iPad Pro -- tv 4K -- Watch — Mac — AirPods Pro 2nd gen
szabogabor10
válasz kabelmania27 #46667 üzenetére
Végülis igaz.
zool1
válasz kabelmania27 #46638 üzenetére
Áramtalanítottam a modemet, tápcsatit kihúztam kb 10 percre, utána vissza és "lőn világosság"....
H_András
válasz kabelmania27 #46677 üzenetére
Csak net elofizetes van. Teve, telefon nincs. Berlo vagyok, a tulaj kulfoldon... fel eve lakom itt, semmi gond nem volt eddig, illetve egyszer aramszunet utan kellett ujrainditanom. Most ez nem segitett. Azt latom a ledek allapotabol,hogy nem is jon jel a szolgaltatotol. A honlapon nem talaltam erre a keruletre karbantartast, ezert batorkodtam ide irni. Mivel itt meg nem volt gond, nem tudom mennyit szoktak varni a hibabejelentessel mondjuk igy hogy tobb ora eltelt, nem vagyok elegedett szomszedokbol egy sincs itthon persze, higy megtudjam, masnal van-e szolgaltatas.
Az ember egész életében gyermek marad, csak a játékai változnak / Sarcasm - because beating the shit out of people is illegal
zool1
Model: Cisco EPC3208
Vendor: Cisco
Hardware Revision: 1.0
Bootloader Revision: 2.3.1_R3
Current Software Revision: e3200-ESIP-16-v302r125562-130611c_upc
Firmware Name: e3200-ESIP-16-v302r125562-130611c_upc.bin
Firmware Build Time: Jun 11 11:11:07 2013
Cable Modem Status: OperationalCable Modem State
DOCSIS Downstream Scanning: Completed
DOCSIS Ranging: Completed
DOCSIS DHCP: Completed
DOCSIS TFTP: Completed
DOCSIS Data Reg Complete: Completed
DOCSIS Privacy: EnabledDownstream Channels
Power Level: Signal to Noise Ratio:
Channel 1: 4.2 dBmV 40.8 dB
Channel 2: 1.3 dBmV 39.9 dB
Channel 3: 1.8 dBmV 39.7 dB
Channel 4: 2.9 dBmV 40.7 dB
Channel 5: 3.1 dBmV 40.8 dB
Channel 6: 3.7 dBmV 40.8 dB
Channel 7: 3.8 dBmV 40.8 dB
Channel 8: 0.7 dBmV 39.9 dBUpstream Channels
Power Level:
Channel 1: 44.8 dBmV
Channel 2: 44.7 dBmV
Channel 3: 44.7 dBmV
Channel 4: 45.7 dBmV[ Szerkesztve ]
zool1
válasz kabelmania27 #46694 üzenetére
Nincsen.
H_András
válasz kabelmania27 #46679 üzenetére
Köszönöm, közben eljöttem otthonról, mikor visszaértem minden rendben, akkor ezek szerint csak volt egy jó pár órás kimaradás (olyan este hat felé már elértem a nas-t távolról, előtte helyreállhatott a szolgáltatás).
az értékekeket azért megnézem.Az ember egész életében gyermek marad, csak a játékai változnak / Sarcasm - because beating the shit out of people is illegal
gduck
válasz kabelmania27 #46735 üzenetére
Downstream Channels
Channel 1: 4.5 dBmV 40.8 dB
Channel 2: 3.9 dBmV 40.7 dB
Channel 3: 4.3 dBmV 40.4 dB
Channel 4: 5.6 dBmV 40.6 dB
Channel 5: 5.8 dBmV 40.8 dB
Channel 6: 6.7 dBmV 40.9 dB
Channel 7: 7.0 dBmV 41.4 dB
Channel 8: 6.1 dBmV 40.3 dBUpstream Channels
Power Level:
Channel 1: 44.5 dBmV
Channel 2: 45.0 dBmV
Channel 3: 45.0 dBmV
Channel 4: 0.0 dBmV -
gduck
ztsoft
válasz kabelmania27 #46749 üzenetére
Pont a modem elé van az egyik rakva, a másik meg a bejövőre, azaz a modem duplán van leválasztva. Amúgy alig változott valamit az érték, mikor be lett téve a leválasztó.
Jó dolog fontosnak lenni, de fontosabb, hogy jók legyünk.
cocka
válasz kabelmania27 #46776 üzenetére
Jelráfogásnál YES van írva, szóval akkor gondolom van.
Amúgy véletlenül túl sokszor nyomtam a lefelét és most frekvenciavizsgálat van. Na ABBÓL, hogy kell kilépni?
cocka
válasz kabelmania27 #46780 üzenetére
Hú várjál most akkor melyik képernyőt nézzem? Mármint melyiken lesz kiírva az erősség meg a minőség?
justice84
válasz kabelmania27 #46787 üzenetére
Downstream Channels:
Channel 1: -1.0 dBmV 39.7 dB
Channel 2: -0.1 dBmV 39.9 dB
Channel 3: -0.4 dBmV 40.0 dB
Channel 4: -0.3 dBmV 40.1 dB
Channel 5: -1.0 dBmV 39.5 dB
Channel 6: -0.3 dBmV 40.0 dB
Channel 7: -0.3 dBmV 40.3 dB
Channel 8: -0.6 dBmV 40.1 dBUpstream Channels:
Power Level:
Channel 1: 42.5 dBmV
Channel 2: 42.2 dBmV
Channel 3: 42.4 dBmV
Channel 4: 42.2 dBmV -
justice84
válasz kabelmania27 #46789 üzenetére
Modemnél nincs csillapító, az osztót még nem tudtam megnézni 5m-es létrát kellene szereznem a padláson van ha sikerül szereznem megnézem.
Szerk:
F csatlakozó nem laza, kitekertem majd újra meghúztam.[ Szerkesztve ]
cocka
Na, ilyeneket mértem:
prandris
válasz kabelmania27 #46767 üzenetére
Megnéztem az elosztót így néz ki [link], a modem jelerősséget nem tudom hol lehet megnézni, nem találom.
Zitronensaft nem bírok kerestetni vele digitális csatornát valamiért, a jelszint opció is inaktív. Manuálisan tudnám beírkálni.
prandris
válasz kabelmania27 #46798 üzenetére
prandris
válasz kabelmania27 #46800 üzenetére
Ci-slot van benne, de nincs még kártyám, csak írta Zitronensaft hogy így is lehet fogni pár kódolatlant próbának. De csak az analógokat találja.
kabelmania27
Ez alapján próbáld meg vagy írd le a tévé tipusát akkor rálehet keresni hogy használható-e a médiacard.
prandris
válasz kabelmania27 #46802 üzenetére
LG 42lf652V a TV. A UPC hivatalos oldalán nem írja ezt a tipust, de itt a bevezetőben benne van a listában (meg olvastam, hogy OK a upc kártya az LG fórumon itt) Akkor lehet jobban járok ha hívok szerelőt is.
A listában nem találtam 14. Kerületet, de a Budapestivel megpróbáltam manuálisan az m1-et de nincs jel.[ Szerkesztve ]
prandris
válasz kabelmania27 #46804 üzenetére
Okés köszönöm a segítséget.
justice84
válasz kabelmania27 #46794 üzenetére
Na sikerült feljutni csillapító nincs.
IN: a bejövő , Out: megy a PCT-2000-3S 5-1002MHz -120dB RFI -be , TAP06: megy a modemhez.Szerk:
(#46794)
PCT-2000-3S 3 ága is használatba van sajnos.[ Szerkesztve ]
justice84
válasz kabelmania27 #46809 üzenetére
Köszönöm a segítséget.
szabogabor10
válasz kabelmania27 #46859 üzenetére
Igen, teljesen rendben vannak.
válasz kabelmania27 #46870 üzenetére
ha mégis elromlik cserélni fogják
Nem is az a gond, hogy cserélik-e, hanem hogy elveszik ami rajta van. + Nálam is előfordult már hogy megakadt, mikor pörgettem át a reklámot. Nekem is egyből a bizonytalan szektor jutott eszembe. Ilyenkor meg két esélyes, hogy cserélik. Lehet meg kell várni míg végleg elromlik, vagy kijön egy olyan szerelő aki hajlandó lecserélni a box-ot.
Hol lehet meglesni, hogy éppen milyen meleg a merevlemez?Freeware, és akciós programok egy helyen https://www.facebook.com/freewarenews
ilias
válasz kabelmania27 #46890 üzenetére
Ha azt nézzük, hogy a régi csomagomhoz hozzákérem azt amit most kapok a napokban a UPC-től, akkor kb.14-15e körül lenne az alapdíjunk, ehelyett 10.640.- lesz, ami nem rossz.
szabogabor10
válasz kabelmania27 #46909 üzenetére
Itt van a mediacard is, nem vittem vissza.
Hol a boxot használom, hol a TV-t. Most épp a TV-t, ha átváltok boxra, megnézem neked az értékeket.[ Szerkesztve ]
szabogabor10
válasz kabelmania27 #46911 üzenetére
Igen, pont ezért tartottam meg a kártyát is, "benyelve" egy ideig a 2. médiaeszköz felárat.
A képminőségnél nem nagyon veszek észre különbséget ugyanazon képbeállítások mellett. De lehet észreveszek majd, ha még jobban koncentrálok.
A csatornaváltás lassabb a TV esetében kb. 2 másodperccel. Ami azért elég jelentős. Meg is lepődtem, milyen gyorsan vált csatit a box.
Te, ez nehéz döntés lesz.Az még király dolog a boxnál, hogy Horizon Go-ból tudok rögzítést beállítani, és ez tényleg működik is. A távirányítás is működik. Az is jó dolog, hogy 2 tuneres, és az is, hogy a felvétel része és a timeshift is zökkenőmentesen működik. Az viszont nem, hogy egyidőben 2 műsort nem tud felvenni, ha ki van kapcsolva a box, ezt itt már mások is írták. Nem egészen értem. És ez a GUI...komolyan szinte bántja a szemem. Szomorú vagyok, hogy ezt a boxot így elcseszték ezzel.
Szóval az a helyzet, hogy ha akarom az extra funkciókat, kénytelen leszek elviselni a felületet. És nem tudom, hogy így is akarom-e ezeket a funkciókat. A legideálisabb az lenne, ha megtartanám a boxot és a kártyát is, de 1550 Ft-ért azért kicsit luxus lenne.
Marko445
válasz kabelmania27 #46933 üzenetére
Szia !
Nagyon szépen köszönöm a gyors válaszod!
Upstream:Transmitter # Channel ID Lock Status Frequency Modulation Symbol Rate Channel Type Power
1 65 Locked 59800000 64QAM 5120000 ATDMA 42.3
2 63 Locked 46600000 64QAM 5120000 ATDMA 40.8
3 64 Locked 53200000 64QAM 5120000 ATDMA 41.0
4 66 Locked 26600000 64QAM 5120000 ATDMA 40.5Downstream:
1 8 Locked 410000000 256QAM 6952000 38.6 11.8
2 9 Locked 418000000 256QAM 6952000 39.0 11.7
3 10 Locked 426000000 256QAM 6952000 38.5 11.1
4 11 Locked 434000000 256QAM 6952000 37.8 10.0
5 12 Locked 442000000 256QAM 6952000 37.8 9.6
6 13 Locked 450000000 256QAM 6952000 37.8 9.6
7 14 Locked 458000000 256QAM 6952000 38.1 9.8
8 15 Locked 466000000 256QAM 6952000 38.2 10.0Megnéztem közben, amit még kérdeztél tőlem, hogy akkor milyen osztóval van elosztva. Egy Atronix csatlakozó van bele kötve. Nem láttam rajta olyan feliratot, hogy Fam/Attenuator. (Lehet, hogy itt most egy külön eszközre gondolsz, bocsi, de nem vagyok nagy szakértő hozzá.)
Természetesen asztali számítógépet használok, tehát vezetékes UTP kábellal csatlakozom a modemhez.
Sajnos nem, többször is próbáltam újraindítani a modemet, de nem oldott meg a probléma. A barátnőm is szintén itthonról dolgozik ő is vezetékesen van rajta és őt szintén ledobja a modem. De viszont érdekesség, hogy amikor ő egyedül használja neki megy, tehát őt nem dobja le az 1:13 percnél. -
Marko445
válasz kabelmania27 #46947 üzenetére
Köszönöm szépen mindenkinek a segítséget!
Viszont téves információt adtam Nektek, mert nem az első hozzászólásomban található modemmel rendelkezünk, hanem egy Technicolor TC7200 modemmel, nem tudom, hogy ez mennyit változtat rajta.
Csináltam a koax-ról képet, az úgy biztos többet fog mondani, de akkor ezek szerint nem ezekkel van a probléma. Gondolom, hogy nincs megcserélve az F csatlakozók bemenete, mivel ez a probléma csak múlthét csütörtök óta van jelen, ha pedig rosszul lenne, akkor eddig is fent áll volna ez a gond.Az F csatlakozók ellenőrzése után akkor mikor legközelebb tesztelni tudom, mindenképpen Bridge módban fogom megpróbálni hátha a wifi jel zavarna-e be. A Wi-Freet pedig nem használjuk még a mai nap során le fogom mondani.
Viszont, ha ezek megoldások egyik sem orvosolja a problémákat, akkor inkább modem vagy szoftveres bajom lehet? -
jeffo
válasz kabelmania27 #46949 üzenetére
Kérnék infót, szerintetek ez a koax elosztó jó-e: egyik felén kék alapon fehér betűvel 3DSS2 felirat, jobb felső sarokban A betű, másik felén fehér alapon fekete betűvel CE 2145 felirat, ugyanígy néz ki, mint ezen a képen: [link]
Fam/Attenuator csillapító nincs az elosztó egyik ágán sem, Cabelcon 4.9 felirat van mindhárom csatlakozón, mint a Marko445 által megosztott képeken. Ugye egyik kábel megy a modemhez, a másik a mediaboxhoz.
A padláson is el lehet osztva, mert további 2 helyre lett igényelve box, de net csak nálam van.Hosszabb időn át tartó letöltésekkel, feltöltésekkel nem tudtam tesztelni, mert még archiválnom kell a gépemről, de előfordult, hogy speedtest közben is leakadt a net. Arra tippelek, mintha akkor akadna jobban, ha a mediabox is be van kapcsolva, mert péntek késő este már lekapcsoltam, és utána reggelig nem volt gond, legalábbis a böngészéssel.
A wifit a modemben kikapcsoltam, egyelőre az alap router módban próbáltam. Azon gondolkoztam, ha modem módra kapcsolom, és rákötök egy tp-link 8 portos gigabit switchet, úgy meg lehet-e osztani a netet a gépek között, ha fix ip-ket állítok be, de gondolom nem, kellene külön egy router is.
Másik gondom, hogy visszajött a földhurok vagy mi, ami ugye a Telekom IPTV bekötés után megszűnt, mivel akkortól nem volt annyi koax kábel itt a tévés állvány mögött, 1 kábel vissza lett húzva. A lényeg, hogy van egy Hyundai Mbox médialejátszó, ha arra rákötöm a UPC mediaboxot, akkor rendben van minden, jó a kép és a hang, de ha a számítógépben lévő Avermedia DVD EZ Maker 7 USB digizőre kötöm az mediaboxot, akkor búg a hang. Az rca kábel is néha ráz.
Van erre valami tippetek, hogyan lehet ezt helyrehozni? Ha az említett csillapító segítene, akkor hol lehet ilyet venni, és hova szereljem rá?[ Szerkesztve ]
OTika
válasz kabelmania27 #47034 üzenetére
Köszi. Már az LG Led TV topikban megírták, h a Mediabox-szal működik rendesen.
Roland78
válasz kabelmania27 #47095 üzenetére
Szia,
nem találom milyen értékeknek kellene lennie...
Nálam ezek vannak:
Csatorna Frekvencia (Hz) Jelszint (dBmV) SNR (dB) Moduláció Csatorna azonosító
1 426000000 5 38 256qam 3
2 418000000 5 38 256qam 2
3 410000000 5 38 256qam 1
4 434000000 5 38 256qam 4
5 442000000 5 38 256qam 5
6 450000000 5 38 256qam 6
7 458000000 5 38 256qam 7
8 466000000 5 38 256qam 8A modem (Mercury CH7465) egy 4-es elosztóra van kötve - nincs Fam/Attenuator bekötve
Roland78
válasz kabelmania27 #47098 üzenetére
Feltöltési:
Csatorna Frekvencia (Hz) Jelszint (dBmV) Jelsebesség (ksps) Moduláció Csatorna azonosító
1 37200000 41 5.120 64qam 10
2 52400000 41 5.120 64qam 12
3 45000000 42 5.120 64qam 11
4 30600000 41 5.120 64qam 9Összerendelt feltöltési csatornák
Csatorna Csatorna típusa T1 időtúllépés T2 időtúllépés T3 időtúllépés T4 időtúllépés
1 2.0 0 0 13 0
2 2.0 0 0 4 0
3 2.0 0 0 5 0
4 2.0 0 0 4 0 -
Roland78
válasz kabelmania27 #47100 üzenetére
Köszi. Megpróbálom majd...
De érdekes, hogy a régi modemmel semmi baj nem volt ugyanezzel az osztóval[ Szerkesztve ]
4Grider
válasz kabelmania27 #47103 üzenetére
Nem azelőtt kellene bekapcsolni őket, mielőtt az adott területen 500 Mbps-os netet értékesítenek?
vg
Szeretem amikor ilyeneket írsz, mert aki nincs otthon az antennázási témában (mint én) totál kínai.
Roland78
válasz kabelmania27 #47106 üzenetére
No, köszi a tippeket. Napközben már nem voltam itthon.
Bridge (modem) mód-ban stabilabb, gyorsabb minden.(speedtest továbbra is csak 240-300 Mbs között mozog.Majd alkalomadtán rákérdezek upc ügyfélszolgálaton, miért nincs 15ds freki
Igaz, most 6 hónapig elvileg free a 500-as net, de így nem tudom megérné-e a plusz 2e Ft-ot vagy sem. -
poli27
válasz kabelmania27 #47121 üzenetére
Inkább azt kérdezném meg a UPC től, hogy adhatnak el 500mbites netet 8ds frekire...
_Karesz_
válasz kabelmania27 #47112 üzenetére
Köszi szépen mindenkinek a választ!
A lakásban csak egy darab koax kábel van, a másik vége pedig kint lóg a lépcsőházban. Gyakorlatilag most lett felújítva az egész és újrahúzták a kábeleket is. Pár F csatlakozóval elboldogulok, csináltam már pár ilyet, meg egy CCNA-n is túl vagyok. Csak konkrétan azt nem tudtam, hogy mi jár a modem mellé. De ezek szerint adják hozzá a szükséges osztót és nem nekem kell megvennem.
betyar1974
válasz kabelmania27 #47136 üzenetére
Köszi és itt köszönöm Zitronensaft-nak is!
tomp
válasz kabelmania27 #47153 üzenetére
Sajnos nem.
ztsoft
UPC és Google dns-el is ugyan az van. -
tomp
ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=7ms TTL=56
Reply from 8.8.8.8: bytes=32 time=8ms TTL=56
Reply from 8.8.8.8: bytes=32 time=1517ms TTL=56
Reply from 8.8.8.8: bytes=32 time=7ms TTL=56Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 7ms, Maximum = 1517ms, Average = 384msNéha 1-1csomag el is veszik.
csandi86
válasz kabelmania27 #47151 üzenetére
Az elosztón 3DSS2 felirat áll, a csillapítón pedig 3 Db. Nem akarom elkiabálni, de most egy rezet után jobb kettővel a net (azért még most sem az igazi, meg már vagy tízszer rezeteltem az utóbbi 2 napban)
A modem értékei alatt mit értesz pontosan? Illetve melyik érték rossz, ha eléri az 50-et?
Üdv,
Csanád[ Szerkesztve ]
csandi86
válasz kabelmania27 #47161 üzenetére
Nagyon szépen köszönöm a gyors válaszokat!
Ha bridge módba teszem az nem azt jelenti, hogy kell egy másik router is a nethez amit erre csatlakoztatok rá? Kikapcsolom a Wi-Free-t, meg átállítom akkor ezt, megnézem milyen lesz úgy.
csandi86
válasz kabelmania27 #47164 üzenetére
A wi-free-t kikapcsoltam, azóta megint tökéletes. Bár miután rezeteltem már élvezhető szintre jutott a net.
Szóval nem tudnám kijelenteni, hogy konkrétan a wi-free miatt lehetett rossz, mert már jó ideje be van kapcsolva és eddig nem volt vele gond. Jó nyilván elromolhatnak a dolgok, de a routert is csak decemberben kaptam.Most nagyon nem értem a dolgokat, miért jó. Remélem nem hétfőn reggel lesz újra rossz, amikor dolgoznék.
Illetve szerintetek vissza lehet még mondani a technikust ilyenkor?
Üdv,
Csanád -
csandi86
válasz kabelmania27 #47170 üzenetére
Kint volt a technikus, átnézte a kábeleket. Mondta, hogy max csak 2 toldás lehetne, de itt 4 van. Amikor itt volt nem volt net semennyire, méricskélt egy csomót, illetve mondta, hogy ez a készülék ami nálam van (ubee) nem nagyon csípi a vpn-t a szoftverfrissítés óta, úgyhogy nagyon ajánlja, hogy rakjam bridge módba és kössek rá egy rendes routert inkább.
Már majdnem megnézte az épületben lévő valamilyen fő elosztót, amikor látta, hogy a környéken épp javítanak valamit, pontosabban a külső hálózattal volt valami gond, és azt szerelték. Szóval nem tudtam rábeszélni, hogy azt is nézze már meg. Most megint úgy tűnik, hogy okés a net, de időlegesen előfordult már máskor is. Ha megint rossz lesz, akkor bridge mód, másik router be (tp link wdr3600) és reménykedek.
Ja amit furcsálltam, hogy amikor mondtam neki, hogy jobb lett valamivel a net, amikor kikapcsoltam a wi-free-t, azt mondta, hogy a wi-free-t nem lehet kikapcsolni, le van tiltva, hogy ki lehessen kapcsolni, csak a routeren lévő sima wifit tudom kikapcsolni. De hát mondom, akkor a my upc oldalon miért van ott, hogy ki be lehet kapcsolni a szolgáltatást? De erre csak tovább szajkózta a dolgot és nem tudtam mire vélni, mert úgy tűnt, hogy ért mindenféle jelek leolvasásához és értelmezéséhez, és nehogy már ezzel ne legyen tisztában. Mármint csak ki vannak oktatva ilyesmikről a szerelők.
Ja meg mikor méricskélt mondta, hogy az előző kollégája olyan eszközzel volt kint, amivel nem is tudott olyan dolgokat mérni ami szükséges lett volna. Ok.
F_Zolee
válasz kabelmania27 #47182 üzenetére
Hát ez az és nekem mindig sikerül az ilyet megfogni. Persze a lottónál nem működik.
● Olvasd el az összefoglalót!
● Jelszinteket ide írhatsz!
● Díjnet téma ITT!
● Mobil szolgáltatások ITT!
- EA Sports WRC '23
- Béta iOS-t használók topikja
- Nem szavazza meg Musk 56 milliárd dolláros csomagját a norvég állami vagyonalap
- Foxpost
- Nők, nőügyek (18+)
- HP 2UK37AA USB-C / Thunderbolt dokkoló bontatlan gyári dobozban
- PS5 + AOC MONITOR
- MSI RX 580 ARMOR OC (8GB GDDR5 256bit) -- tesztelt :: BESZÁMÍTÁS! AKCIÓ!
- Samsung Galaxy S21 Ultra 5G 256GB, Kártyafüggetlen, 1 Év Garanciával
- Magyar Bill! Lenovo ThinkPad T440 - i5-4GEN I 8GB I 128SSD I 14" FHD I Cam I W10 I Garancia!
