arn
válasz RexMaximus #45333 üzenetére
Ez nem az en hazam, csak gondolkodom, hogy atepitem e ilyenbe... Nem tudom erdemes e bealdozni a dragon szellozeset es rugalmassagat, nemi plusz esztetikumert
facebook.com/mylittleretrocomputerworld | youtube.com/mylittleretrocomputerworld | instagram.com/mylittleretrocomputerworld
arn
az enyem kicsit szellosebb ez az en buildem, nemtom bealdozzam e.
arn
válasz Sanchez638 #45340 üzenetére
Ibm power3?
arn
Olyan kerdesem lenne, akinek van w32p vlbs kartyaja, hany nanos ramokkal van? Azt nezem, hogy 45-70ig szereltek mindennel.
arn
válasz DarthSun #45348 üzenetére
Jo lenne tudni, hogy ilyenkor mi tortenik... Milyen idozitesekkel, orajelen jarhat. Bar gyanitom a legbiztosabb, ha gyarilag 2ms 45nsos, tsengnel elvileg szamit, hogy 1 v 2m. Bar pl a trional is szamitana, hogy 64 v 32 bit, aztan kozben semmi elteres dos alatt.
A normalisabb vlbs s3asok is olyan ritkak mar, mint a feher hollo.
arn
13. ET6000 memory bandwidth hype and the impact on video modes
Tseng has always had wet dreams about memory bandwidth, and their press announcements about the ET6000 memory bandwidth are no exception.
They claim the ET6000 using MDRAM is capable of reaching an incredible 1.2 Gbytes/sec of bandwidth. That would surpass just about everything on the market (even SGI).
And that would be true, _if_ they actually used the fastest available MDRAMs on their boards, which they don't. The stunning 1.2 GByte mark is only reached when using 4 MDRAM chips at their max clock rate of 166 MHz. But due to design limitations, the first-generation ET6000 can only drive the memories at 92 MHz (that will change when the ET6100 and ET6300 hit the streets).
This means the max. theoretical bandwidth available on current ET6000 boards is "only" 360 MB/sec on boards with 2 MDRAM chips, and 720 MB/sec on boards with 4 MDRAM chips. And this assumes a best-case situation (=extremely long bursts -- the MDRAMs use a shared address/data bus, much like the PCI bus does). In the real world, unaligned accesses both from the PCI bus and the accelerator will reduce the effective available bandwidth. The current ET6000 boards peak out at about 225 MB/sec, with 2 or 4 MDRAMs.
Whatever you may have read in press releases, the ET6000 has a 32-bit memory bus (not 128 bits; that's only the accelerator data path within the chip, if anything). That means that, with their 16-bit busses, 2 MDRAM chips already use the full bus capacity. Having 4 memory chips on an ET6000 board will not give you extra memory bandwidth.
Memory bandwidth limits the maximum resolution you can use at a given color depth. The ET6000 RAMDAC can cope with 135 MHz in any situation. But the RAM cannot. At 32bpp (sparse 16M color mode), using a 135 MHz pixel clock would require a memory bandwidth of 135*4 = 540 MB/sec, which the current ET6000 boards simply cannot cope with. And then you still need some spare bandwidth for the PCI bus and the accelerator.
That is why some modes will be refused, depending on your MDRAM memory layout, even if the amount of memory would permit such a mode. See also the trouble shooting section to see what can happen if too little memory bandwidth is available.
arn
arn
De tud, mar 8900clre is raktak 24 bites ramdacot. Bar ott ugy emlekszem, hogy bugos volt, mert nem rgb volt, amit tobb program akkoriban nem tudott lekezelni. Dos alol mondom.
arn
válasz DarthSun #45468 üzenetére
Ha egy chipsetet kellene valasztani, hogy melyik volt a legjobb, az tuti a bx lenne... Nem oszver chipsetnek keszult, megis lekezeli a procikat 233-1400mhzig, harom-negy generaciot is lefed.
arn
A pentiumnal eleve mar csak eltero architekturakrol beszelhetunk, de attol meg mind "pentium class". A pentiumot lehetett volna meg sokaig skalazni, ahogy jottek a kisebb csikszelessegek, csak Intelnel volt fejlettebb lepcso, a masik ket gyarto meg abbol fozott, amibol lehetett, ezert szulettek a mindenfele hibrid megoldasok. De attol meg a 486dlc is inkabb 386 es az 5x86 is 486 szintu es alapu processzor.
180 nanon a k6 kinkeservesen skalazodott 500ig, addig egy palomino 1733ig.
arn
arn
805om mar volt nekem is
trio64et pl mar nehezebb lehet fellelni, mint egy w32p tsenget, de a vision864 is eleg ritka mar. asszem a trio64v+ volt az utolso, amivel keszult vlbs kartya.
arn
wanted
Processzor
Intel Pentium II 450Alaplap
Intel 430FX PCI+ISA 1995
Asus P55T2P4 PCI+ISA 1996
Asus P2B-S/LS rev 1.05+ AGP+PCI+ISA 1998
Asus P2B-DS rev 1.06+ AGP+PCI+ISA 1998
Gigabyte GA-5AX rev 5.2 AGP+PCI+ISA 1999
Asus USB/MIR/PS/2 mouseHangkártya
Gravis Ultrasound < 3.7 ISA 1992
Gravis Ultrasound Plug & Play ISA 1995
Roland MT-32 module 1987
Roland SC-55 module 1991
Roland SC-55mkII module 1993
Roland SCB-55 waveblaster 1995
Roland SCD-15 waveblaster 1995
Roland SCM-15 waveblaster 1995
Creative Sound Blaster AWE32 CT3900 ISA 1994Videokártya
Tseng ET4000/W32p VLB 1994
ARK Logic ARK1000VL VLB 1994
S3 Trio64 VLB 1994
Tseng ET6000 PCI 1995
Diamond 3Dfx Voodoo2 12M PCI 1998
GeForce2 Ultra 64M AGP 2000
Radeon 9700 Pro 128M AGP BBA 2002Egyéb
Western Digital Caviar 31000 1000M IDE 1994
Spire Falconrock 2003
Zalman ZM-NB32 2002[ Szerkesztve ]
arn
en cddrivert sose toltok configsysbol, csak ha kell kesobb
arn
válasz DarthSun #45536 üzenetére
Van erre program egy batchfilet inditok, es betolja a memoriaba. Emlekeim szerint olyat is tud, hogy pl elinditok egy programot egerrel es utana kiszedi a membol.
arn
De hogy a fene essen bele, nem birja a transparent modot, fagyogat tole. Mennyire altalanos ujabb (vision 864+) s3 kartyaknal? A vogonson is irta mas is, ez eddig elkerulte a figyelmemet. A 805 siman megy. Pedig fasza kis kartya, gyorsabb lenne, vesa modok is megvannak 15, 16, 24, 32 biten is.
Mongy nem szettimingolva akarom hasznalni, csak def biossal, de bosszanto.
arn
szerintem nem letezett de ertelme se nagyon lett volna, mert a vlb csak kiterjesztese volt az isanak, ha nem kell nagyobb savszelesseg, felesleges. vlb slotbol amugy se lehetett "tetszoleges szamut" a lapra rakni.
arn
válasz Chris82 #45596 üzenetére
az, valszeg a dspt jeloli (4.xx) - a vibra nem mas, mint egy sb16, amit egy chipbe integraltak. az elso verzio meg kevesbe integralt, pl nincs benne fm, kulon chip kell hozza. a masodikba cqmet tettek.
T1 = CT-1310 (SB 1.0, DSP 1.x: 1.05), CT-1320 (SB 1.5, DSP 1.x: 1.05)
T2 = CT-1330 SB Pro (DSP 3.00?)
T3 = CT-1350(B) SB 2.0 (DSP 2.x: 2.01)
T4 = CT-16×0 SB Pro 2 (DSP 3.x: 3.01/3.02)
T5 = SB Pro Micro Channel
T6 = CT-17xx, CT-22xx, CT-27xx, CT-28xx SB16 (DSP 4.x: 4.01/4.04/4.05/4.11/4.12+)
T10 = Sound Blaster Micro Channel[ Szerkesztve ]
arn
válasz DarthSun #45597 üzenetére
begyujtottem jopar fele sb16ot, mind ment ugyanazzal a beallitassal. ami meglepett, hogy a vibra talan a legkompatiblitsebb... talaltam olyan jatekot, ami a masodik generacioson fagy, vagy nincs hangja (elvileg siman sbt tamogat a jatek, de a vibran kuvul semmi massal nem szolalt meg, sbproval sem).
arn
Hude vad szine van jo hasznalatot. En 93ban kaptam az elso pcm, igy az elotti dolgok mar nem nagyon erdekelnek.
arn
válasz DarthSun #45623 üzenetére
Haszalni persze en is hasznaltam suliban 286ot meg xtt, de az mar nem az en vilagom. A kis dx4 jo balansz, a dx2 is parkolopalyara kerult, azert egy doomot futtasson rendesen.
arn
Transparent modban a legvaratlanabb helyeken fagy... hiaba allitottam akarmit, csak erre erzekeny. Ugyanez a kartyaverziod van? Mongy def biossal is gyorsabb, mint a masik ketto agyontweakelve.
arn
Vogons listaban olvastam hasonlokat, es tobben is irtak, hogy a 864/964 nem nagyon szereti a magasabb fsbket sem. Nalam egy 95os bios van, az 5xet nem ismeri fel rendesen, de azert ment benne.
arn
válasz bacsis #45647 üzenetére
Baromsag... Meg a draga ebayen is lehet v2ot venni 25 eur kornyeken. Mostanaban szeretbek azt hinni az emberek, hogy vmi csodat orizgetnek otthon, ezert is ultek ra sokan.
arn
33mhzen vlbnel landmarkban mennyi a max? Mert ennel a kartyanal vmi 23k transparentben, lehet vmi timingot nagyon szukre vettek, es nem bir mar tobbet.
arn
486ra en is 622ot tervezek egyelore 710 van rajta.
arn
Ezeknek a korai dualos rendszereknek mi ertelme?
arn
asus p2b - megizzadtam vele rendesen, de mar megy benne a coppermine 1000. 1.10es verzio, mar olyan ic van rajta, ami 1.3vig tamogatja a procikat, es 150fsbig el lehet menni. ezeket a ficsoroket a masodik generacios bxekbe tettek (p3b-f, be6, etc), pedig ezt a lapot 99 legelejen gyartottak, igy jo esellyel vmi c300 volt a tarsa eredendoen (mint a kepen).
igazabol a 3 isaslot miatt vettem, de az mar okafogyotta valt, a rap10 ment a 486ba. meg amugyis keptelenseg kicsit hosszabb kartyat belerakni a hazcsatlatkozok miatt. az asusnak ez vmi heppje volt? a p3bbe is ugy lehet belefeszegetni dolgokat a masodik slotba.
ami viszont erdekes, ha az sb16 benne van a gepben, nem indul el a guspnp setupja, ha kiveszem ok. p3bben ez mukodott. amugy rendesen szol mindket kartya.
lehet nem artana melle egy -5vos tap, mert a diagnosztika panaszkodik miatta.
lehet epitek kore egy 98as konfigot - p450 + tnt + v2
arn
arn
nah asszem kellene egy vilagosabb meghajto... vegulis egy osfractal
Pentium III @ 2000
Asus P3B-F rev 1.04
Intel Pentium III 1000EB
Mosel Vitelic PC133 SDRAM 7ns 256M
Asus NVIDIA GeForce2 GTS 32M AGP
Creative Sound Blaster 16 CT2290 ISA
Creative Sound Blaster Live! CT4620 PCI
Gravis Ultrasound Plug & Play 1.0 8M ISA
Seagate Barracuda 7200.7 40G
Samsung / Compaq SC-148 48x CD-ROM IDE
In Win IW-A500
Chieftec GPS-350EB-101A
Cherry G83 PS/2 US
Logitech S96 PS/2[ Szerkesztve ]
arn
nah nincs vkinek egy tiptop allapotu 10-12x dvdje 2000bol? jo penzt adok erte mar csak a tap, meg a vinyo tipusa ut el 2000tol, de a taphoz nem nyulok, a vinyohoz is csak akkor, ha teljesen hibamentesen talalok.
arn
válasz Sanchez638 #45703 üzenetére
mitol leszek beljebb? egy ultra esetleg erdekelne, az meg belefer idoben. de egy deluxe?
(#45702) Ganz-[HUN]: szerintem az atxes hazak nagy reszebe belemegy az ats lap.
arn
koszi!
ez 40mhz... a miro 33on vitt majd 23000et. ami azert erdekes, mert szinkron modban ugyanannyit mennek a 805tel (16e), transparentben a 805 20ere ugrik, a miro meg 23ra. szvsz vmilyen timing nagyon szukre lehet szabva annal a kartyanal, es ha kicsit tweakeled, elhasal.
arn
válasz Sanchez638 #45706 üzenetére
stilusos? ugyanez a kartya, csak van rajta olyan kibemenet, amit sose hasznalok. az ultra legalabb gyorsabb. az se erdekelne, ha a fapados lenne tvout nelkul.
- Bloodborne (PS4)
- Gigabyte alaplap topik
- Amazon Fire TV stick/box
- Azonnali processzoros kérdések órája
- Milyen SSD-t vegyek?
- Netflix
