CsaBully
válasz CPT.Pirk #60639 üzenetére
500 gb-os HDD ,optikai helyén amit tárolónak használok, és dual-boot win10/Manjaro KDE rendszer van az SSD-n
csatolás : /run/media/csabull/D2/[ Szerkesztve ]
Referencia: http://phmegbizhatosag.atw.hu/phtabla.php?nev=CsaBully ..Írj privátot,ha fel akarod venni velem a kapcsolatot.
válasz CPT.Pirk #60661 üzenetére
Kössz!
Ezt dobta:
# cpupower frequency-info
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 4.0 us
hardware limits: 1.10 GHz - 1.70 GHz
available frequency steps: 1.70 GHz, 1.50 GHz, 1.30 GHz, 1.10 GHz
available cpufreq governors: conservative userspace powersave ondemand performance schedutil
current policy: frequency should be within 1.10 GHz and 1.70 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency: 1.10 GHz (asserted by call to hardware)
boost state support:
Supported: yes
Active: no
Boost States: 3
Total States: 8
Pstate-Pb0: 2700MHz (boost state)
Pstate-Pb1: 2400MHz (boost state)
Pstate-Pb2: 2000MHz (boost state)
Pstate-P0: 1700MHz
Pstate-P1: 1500MHz
Pstate-P2: 1300MHz
Pstate-P3: 1100MHz
Pstate-P4: 900MHzTehát van, de nem aktív.
Eladó régi hardverek: https://hardverapro.hu/apro/sok_regi_kutyu/friss.html
Slownz
válasz CPT.Pirk #60717 üzenetére
Persze:
Disk /dev/sda: 111,8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x7843e261Device Boot Start End Sectors Size Id Type
/dev/sda1 2049 215981605 215979557 103G 83 Linux
/dev/sda2 215981606 234436544 18454939 8,8G 82 Linux swap / SolarisDisk /dev/sdb: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0xdb0ddb0dDevice Boot Start End Sectors Size Id Type
/dev/sdb1 2048 976773119 976771072 465,8G 83 LinuxDisk /dev/sdc: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xb36cefe4Device Boot Start End Sectors Size Id Type
/dev/sdc1 2048 1953523711 1953521664 931,5G 83 LinuxDisk /dev/sdd: 28,7 GiB, 30752000000 bytes, 60062500 sectors
Disklabel type: dos
Disk identifier: 0x00000000Device Boot Start End Sectors Size Id Type
/dev/sdd1 32 60062499 60062468 28,7G c W95 FAT32 (LBA)---------------------------------------------------------------------------------------------------------------
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a device; this may
# be used with UUID= as a more robust way to name devices that works even if
# disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=82f34ceb-8aa2-42f6-94ba-ae20ae9441b7 / ext4 defaults,noatime,discard 0 1
UUID=62554d73-b6c7-40b7-acf2-319a31bee463 swap swap defaults,noatime,discard 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=af5757a3-7657-4a36-9212-9c102f8f5e3d /media/tarkomatas/af5757a3-7657-4a36-9212-9c102f8f5e3d ext4 defaults,noatime 0 0
UUID=93b1fe90-bb8c-44ad-99b0-8685dc4fc9bb /media/tarkomatas/93b1fe90-bb8c-44ad-99b0-8685dc4fc9bb ext4 defaults,noatime 0 0---------------------------------------------------------------------------------------------------------------
Ha már bemásoltam, lenne még egy kérdésem. A mostani beállítás szerint bár működik frankón az összes HDD, ami benne van és el is érem őket, de macarás, hogy a legtöbb program, amiben meg akarok nyitni egy fájlt a HDD-ről nem rakja ki nekem a bal oldalra, a root mellé, hanem mindig ki kell tallóznom a path-ot, ami elég macerás. Van erre megoldás? Ugyanezt szeretném megoldani akkor is, ha pendrive-ról szeretném fájlokat betallózni.
#68216320
válasz CPT.Pirk #60731 üzenetére
A probléma túlmutat ezen a gépen. Jó ideje (>1éve) képtelen vagyok a vga driverekkel megbírkózni.
Eddig két laptopom volt, amire nem tudtam Ubuntut tenni és használni, mert egyszerűen nem érzékeli a kattintásokat. Mintha nem a képernyőn megjelenő elemre kattintanék. Néha működik a kattintás ablakon belül (pl:settings), de ha ilyenkor megnyit egy újabb ablakot (pl: settings/language) akkor abban már biztosan nem működik. Próbáltam Ubuntu 16.04, 18.06, Lubuntu, Kubuntu, stb verziókat.
Mindkét laptop igp+nvidia párossal van.
HD3000+540M és HD Graphics 530+960M párosítás. Nem tudok másra gondolni, mint valami vga driver gondra. Természetesen 1000 megoldást próbáltam már végig, rendszerint előbb-utóbb odáig jutva, hogy már be sem bootol csal low graphics mode ablakot látok a képernyőn vagy még azt sem. Aztán kezdem az egész installt elölről.De most ugyanez a jelenség van az öreg 945GM esetében is. Lubuntu-val is próbáltam ezen az öreg vason, az sem lett jobb. Tök lényegtelen, hogy lassú-e vagy nem, nem működik jól.
Asztali gépen viszont tökéletesen működnek.
Egyszerűen az őrületbe kerget már, hogy ennyire vacak az egész. Az utolsó a 14.04 volt, amit tudtam használni a HD3000+540M párossal, akkor bumblebee is ment még rá.[ Szerkesztve ]
#68216320
válasz CPT.Pirk #60738 üzenetére
A helyzet az, hogy más gépeken is Ubuntu van, nem szeretnék több féle OS-el dolgozni.
Majd valamikor nekifutok újra, most megint kifeküdt a gép, éppen a fájlrendszer lett oda egy fagyás/power off miatt.
Nincs Bp-en valahol valami Linux-os klub, ahol házi feladatnak feladhatnám ezt? -
#68216320
válasz CPT.Pirk #60747 üzenetére
Cirka 2-3 év után kiderült, hogy miért nem tudok egymásra nyitott ablakokban kattintani semelyik gépemen, egyik distro-val sem.
Tessék kapaszkodni: a Logitech M705 egerem miatt.
Ma reggel mikor kiderült, azt hittem lefordulok a székről
Ezt az egeret használom évek óta. ha egyik gépről megyek át a másikra, akkor viszem magammal. Ugyebár az os ezt usb egérnek és billentyűzetnek ismeri fel, mert a külön gombjai valami billentyűzet kombinációkat jelentenek. Namost ha be van dugva a vevője az usb-be és az egér be van kapcsolva, akkor bármi mást is használok (touchpad, második egér) akkor sem lesz jó. Olyan érzésem van, mintha a fókusz valahogy a megnyitott ablak alatti területre kerülne. Ha kattintok a felső ablakban valamire és az alsó ablakban ugyanott van valami gomb, akkor az alsó ablakban történik a klikk esemény.Kezdett lemerülni az elem, ezért kikapcsoltam az egeret és touchpad-al próbálkoztam és láss csodát, hirtelen minden működött
ALFA
válasz CPT.Pirk #60753 üzenetére
Ez a gondom, ff tartosan 50-90% cpu terhelest okoz es idonkent hirtelen letolt valamiket, amik osszessegeben napi 100 MB-osak es nem tudom, hova mennek, mert nincs nyoma:
ubuntu sw centre-t megnyitva tovabbra is tartos 100% cpu terheles van.
Valami nagyon nem jo itt es most nem tudok ujratelepiteni, mert hataridos munkam van es nincs semmi tartalekom, amire akarcsak atmeneti mentest tudnek vegezni.
Amit ma megtehetsz - miért nem tetted meg tegnap?
ALFA
válasz CPT.Pirk #60755 üzenetére
Most ismet van egy kis idom, a kovetkezo a helyzet.
Amikor gond volt, akkor cpu teljes terhelessel ment, kiderult, valami xorg okozta.
A kernelben sikerult visszallni egy elozo verziora, de ott csak kis valtozas volt (talan 043 volt es most 037, vagy hasonlo.) es most a ff-t is visszaallitottam 45.02-re, nana, hogy ezuttal torolte az osszes konyvjelzot, mig frisiteseknel nem bantotta oket.:-(Az indulo programok mindegyike be volt pipalva, azok nagy reszet kivettem, most probalgatom, hogy mire van szukseg a gep indulasakor, eleg keves info van, igy csak talalgatok. Az udvozlesre nincs, abban biztos vagyok, a tobbi tucatnyinal most jatszogatok.
Most xorg tartosan 15-20%-on van, a ff 15-rol indul, es egyebekkel egyutt cpu terheles 50% kornyeken van, idonkent hullamosan ff felugrik 75%-ra, majd visszaesik, tehat ff fogja a cpu-t.
A letoltesek hektikusak, ures weboldalnal is csinalja idonkent, alig par weboldalt nezegetek, egyszerre csak egyet, tehat nem a weboldalak tartalmat tolti le elore. ahogy a korabbi kepen lathato, mindig hirtelen, tuskeszeruen van valami letoltes, mig a cpu terheles lassabban ingadozik.
Az ubuntu sw centre-t elinditva cpu terheles azonal es tartosan 100%-ra szogezodik, ff nem fut olyankor, tehat a xorg es egyebek feletti reszt mind elhasznalja az a progi, gyakran 68%-ot is fog a cpu-bol, gondolom, az a szabad maximum.
ALFA
válasz CPT.Pirk #60766 üzenetére
Kiprobaltam, de nincs semmi lehetoseg, csak vagy belepek, vagy guest-kent "demo" modban hasznalhatom a gepet. Kiprobaltam, ekkor a xorg nem indul el a htop szerint.
A bejelentkezesi kepernyonel a jobb felso sarokban egy kek korben levo feher emberke ikon jelenik meg, kepernyo betumeretet es kontrasztot lehet allitani, mas lehetoseg nincs.
csurgoi
válasz CPT.Pirk #60761 üzenetére
Bocsánat a duplázásért, de nagyon be voltam vagyok szarva az adatvesztés miatt.
Az általad javasoltakat megprobáltam a superblockra ezt a választ kaptam:
A grarted meg egy 8 kb-os particiót dobott fel a meglévő s mellé(927Db meg a swap4 gb) egy nagy kérdőjellel.
Most probálom az Easeust remélem azzal sikerül valamit visszanyerni.https://500px.com/stevetailor https://www.flickr.com/photos/128564341@N08/
-Ben-
válasz CPT.Pirk #60797 üzenetére
Megpróbáltam leszedni minden drivert, nagyjából sikerült is. Visszatenni egy újat, na az már nem sikerült a törött csomagok miatt. Próbáltam „javítani” a törött csomagokat, de hiába....
A nyílt driverrel se jó, pont emiatt kezdtem el az nV driverekkel babrálni....
Miért lenne jobb döntés egy "Mint" jelen pillanatban?Egyébként egy „GT 710” kártya dolgozik a gépben.
-Ben-
válasz CPT.Pirk #60799 üzenetére
Az az érdekes, hogy már 16.04 alatt se volt minden rendben. Akkor is darabos volt, pl. görgetéskor, több videó egyidejű megnyitásakor. Iszonyatosan lassult, de a 18.04 még sokkal rosszabb. Eddig egy 9400 GT -t használtam, most próbálgatom a 710 -zel, de egyikkel se akar normálisan működni....
-Ben-
válasz CPT.Pirk #60801 üzenetére
Igen, pont ezért „erőltetem” a mai napig az nVidiát, de úgy tűnik már erre se lehet alapozni.
Sajnos nem oldotta meg. Nem engedi telepíteni a legfrissebb NV szoftvert synapticból.
„E: /tmp/apt-dpkg-install-KUB8HS/09-libnvidia-gl-390_390.48-0ubuntu3_i386.deb: new libnvidia-gl-390:i386 package pre-installation script subprocess returned error exit status 2
E: /tmp/apt-dpkg-install-KUB8HS/13-libnvidia-gl-390_390.48-0ubuntu3_amd64.deb: new libnvidia-gl-390:amd64 package pre-installation script subprocess returned error exit status 2”Próbálgatnám én, de nincs cd/dvd olvasóm, pendrive -ról meg az Istenért se akar bootolni egyik se..
lev258
válasz CPT.Pirk #60803 üzenetére
A Catalyst már megszűnt, a nyílt drivert pedig az AMD rakta rendbe. A 3D teljesítményére ma már nem lehet panasz és még mindig ki tudnak sajtolni belőle egy kis javulást.
7etape: Nézd meg, melyik Nvidia driver támogatja a kártyád. Nem mindegyik változat (branch) jó bármely kártyához. Azért javasoltam már az elején másik grafikus felületet, mert abból kiderülne, hogy adott Ubuntuval van gondod vagy Nvidia driverrel. Nem hiszem, hogy nálad ilyenről lenne szó, de volt már példa olyanra is, hogy valaki kínlódott a videókártyával meg a driverekkel, aztán kiderült, hogy a kártya-alaplap haldoklott, nem kapta meg a feszültséget rendesen.[ Szerkesztve ]
Ubuntu MATE 20.04, hobbi cayenne termesztő
lev258
válasz CPT.Pirk #60809 üzenetére
Nvidia honlapjáról ne akarjon senki drivert telepíteni, elég körülményes. Ezért van ppa, onnan elérhető a frissebb is, gond nélkül.
Ha valaki leszedi a drivert, utána erősen ajánlott a sudo apt-get purge nvidia* parancs is, mielőtt másikkal próbálkozna.Ubuntu MATE 20.04, hobbi cayenne termesztő
-Ben-
„sudo apt-get purge nvidia-opencl-icd-340” >>
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapotinformációk olvasása... Kész
Próbálja futtatni az „apt --fix-broken install” parancsot ezek javításához.
Az alábbi csomagoknak teljesítetlen függőségei vannak:
libglx0:i386 : Függ ettől: libglx-mesa0:i386 de az nincs telepítésre megjelölve vagy
libglx-vendor:i386
libnvidia-ifr1-390 : Függ ettől: libnvidia-gl-390 de az nincs telepítésre megjelölve
libnvidia-ifr1-390:i386 : Függ ettől: libnvidia-gl-390:i386 de az nincs telepítésre megjelölve
nvidia-driver-390 : Függ ettől: libnvidia-gl-390 (= 390.48-0ubuntu3) de az nincs telepítésre megjelölve
Ajánlja: libnvidia-gl-390:i386 (= 390.48-0ubuntu3)
E: Teljesítetlen függőségek. Próbálja kiadni az „apt --fix-broken install” parancsot csomagok nélkül (vagy telepítse a függőségeket is!). <<Az apt --fix-broken installt próbáltam már, illetve a komplett nvidia állományt eltávolítani....
Pendrive téma: legközelebb megnézem, hogy milyen hibával áll le a telepítés.
-Ben-
válasz CPT.Pirk #60815 üzenetére
A lev285 által említett „etcher” nagyon jó.. Sikerült telepítenem pendriveról a 18.04 -et (és még gyorsabb is volt, mint dvd -ről). Úgy döntöttem, hogy inkább újat telepítek, mert sok idő menne el ezzel a vacakolással.
Hogyan telepítsem a 390-es szoftvert konzolból, hogy maradéktalanul feltegyen minden szükséges csomagot? -
-Ben-
válasz CPT.Pirk #60825 üzenetére
Maga a chakra nemigazán jön be sajnos.. Nem érzem túlságosan felhasználóbarátnak, legalábbis Ubuntu után. Úgyhogy remélem lesz megoldás erre a problémára, de egyre inkább úgy tűnik, hogy nem lesz. Zárt 390-es szoftverrel se jó. Szinte ugyanolyan darabos, lassú.... Valamivel azért jobbnak érzem, de elenyésző a különbség.
-Ben-
válasz CPT.Pirk #60845 üzenetére
Igazából, most hogy nézegettem a KDE-t, sokkal szimpatikusabb - és szebb -, mint a gnome 3. Bár a solus féle gnome 3 azért szebb, mint az Ubuntué. Esetleg, szerinted van értelme kipróbálni az ubuntut KDE-vel? Hátha nem lassul... Mert, ha ez így marad, akkor sajnos kukázom az ubuntut..
Terminálból tudom úgy telepíteni, hogy minden szükséges csomagot feltegyen hozzá? Egyszer próbálkoztam másfajta kezelőfelülettel, be is borult egy kicsit......
-Ben-
válasz CPT.Pirk #60855 üzenetére
Kipróbáltam a kubuntut és a mint cinnamon verziót. Egyik se olyan botrányosan lassú, mint a gnome 3, de sajnos nem tökéletesek. Kubuntu 18.04 alatt már a KDE se olyan fürge. Nem rossz, de a gépelés pl. nagyon lassú, a prohardver oldala chromiumról szinte lefagy, annyira lassú......
Eközben rákérdeztem ismerősnél, hogy mi a helyzet nála... Állítólag minden vaj simán, gördülékenyen működik. Igaz, neki egy GT 1050 -je van..... Azért általános használatra nehogy már kevés legyen egy GT 710 ...
Pirostank
válasz CPT.Pirk #60795 üzenetére
Szia,
sajna nincs valtozas,
terminalban ezt irja:
[00007fc5b40009c8] vdpau_avcodec generic error: decoder profile not supported: 7
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
[00007fc5b539a398] vdpau_avcodec generic error: decoder profile not supported: 7Köszönöm,
Üdv : Tankok
Frawly
válasz CPT.Pirk #60865 üzenetére
Igen, az is lehet, hogy nincs fent neki az adott csomag. Azért kértem inxi kimenetet, mert azon látni fogjuk milyen disztró, hányas kernel, milyen GPU, milyen GPU driver, hányos Xorg és Mesa. Azért nem inxi -Gxxx kimenetet kértem, mert az -Fxxx teljes reportot csinál, CPU, memória, minden hóbelebanc, ami fontos lehet szaggatás szempontjából.
FF-ban lehet ellenőrizni még, hogy az about:support oldalon mit ír a GPU gyorsításra.
Frawly
válasz CPT.Pirk #60874 üzenetére
4 éve használtam Mintet utoljára, akkor ott alapból ment. Aztán Kubuntun is ment alapból. Aztán Arch-on is ment, és megy a mai napig minden újratelepítés után. Csak akkor tiltódik le, ha nincs fent a megfelelő DRI-képes driver, így nem tud a FF gyorsítást használni. Szerintem Chackrán is kéne menjen alapból.
Frawly
válasz CPT.Pirk #60876 üzenetére
Igazad van, eddig nálam is Basic volt, most, hogy ránéztem. De nem értem, mert mégis van hardveres gyorsítás, nem akadnak a videók, normális a görgetés, nem laggol, nem szaggat, nem magas a prociterhelés. Most bekapcsoltam az about:configban a layers.acceleration.force-enabled értékét true-ra, így már Basic helyett OpenGL-t ír, de érdemben nem volt változás, semmi nem lett se gyorsabb, se gördülékenyebb, se a prociterhelés nem csökkent, ugyanolyan jól működik az egész, ahogy előtte.
Szerintem ennek az a magyarázata, hogy bár a FF nem használt hardveres gyorsítást, de a grafikus felület és/vagy a kompozitor viszont igen, így továbbra is hardveresen gyorsítva mentek a dolgok.
Ha nem ment volna, azt azonnal észreveszem, érzékeny vagyok arra a szaggatásra, lagolásra, amit a hardveres gyorsítás hiánya okoz. Ami előfordul, de akkor nincs fent a megfelelő GPU driver, és a FF is Basic helyett valami 0-át ír az about:support lapon. Akkor érezni is, hogy szaggat.
-Ben-
válasz CPT.Pirk #60896 üzenetére
Kubuntut is próbáltam, de az nem sokkal volt jobb, mint a gnome -os uborka. Persze azért jobb volt, de amiben igazán rossz, abban nem. Sajnos a weblapokon a görgetés nagyon silány, főleg ha youtube -ról van szó. Lehet, hogy beszerzek egy Radeont (bár nem sok „kedvem” van hozzá, mivel 1 hete vettem a GT 710-et...)
Kérdés, hogy egy olcsóbb Radeonnal is sima lenne -e, mint a palacsinta....? Mert, ha ugyanezt kapnám, akkor nyilván nincs sok értelme.[ Szerkesztve ]
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Vélemény Linux Mint Debian Edition 4
- Tudástár MX-Linux 19
- Bemutató Linux a mindennapokban: Manjaro KDE
- Hír A Steam Play hozza el a Windowsra írt játékokat Linuxra
- Hír Hova jut a világ? Linuxot kínál a Windows Store!
