stigma
Igen, ebben igazad van. 10év TM után váltottam Qbitre mert sokkal jobb volt, de a szokás nagy úr, mert sokat a progit szeretik, hogy listában kiválasztom és nem beírom a webes felületen.
Első körben én is féltem a webgui-tól mely a Qbit-nál van, de tökre hozzászoktam már Chrome és Vivaldi böngészőben kellemesen gyorsan megy minden.....iPhone 13 / iPad 9th Gen. Wifi 64GB...
enginev3.0
Köszi, király vagy, nem jelzett a Qbit, de ha rákerestem rögtön kidobta, már nézem is
Thursday January 06th 2022 - qBittorrent v4.4.0 release
qBittorrent v4.4.0 was released.
WINDOWS: Users of Windows 10+ can also use the Qt6 version of the installer. Qt6 offers better HiDPI compatibility. Known issue: The text on the progress bar may have wrong color or not appear at all. You may switch to the regular version(Qt5 based) until it is resolved. The Qt6 version isn't tested much. The v4.4.x series will probably be the last one that supports Qt5 and therefore Windows 7 and 8. It will see releases at least until the summer of 2022.
LINUX: An AppImage is now offered. It uses the latest versions of Qt6, libtorrent, boost, openssl. It is created on Ubuntu 20.04 and it should work on any other similarly aged distro. It isn't well tested. Also Ubuntu 20.04 is dropped from the PPAs because it doesn't have the minimum required Qt5 version (5.15.2). The AppImage should cover any users left on that version.
MACOS: Builds will be uploaded in the next days. This entry will be updated to contain relevant info, so check back here too.v4.4.0 changelog:
FEATURE: Support for v2 torrents along with libtorrent 2.0.x support (glassez, Chocobo1)
FEATURE: Support for Qt6 (glassez)
FEATURE: Expose libtorrent hashing_threads settings (Anton Bershanskiy)
FEATURE: Add "Notification timeout" option (kevtechxx)
FEATURE: Add connection_speed to advanced settings (Chocobo1)
FEATURE: Announce to all trackers if IP changed (#15001) (zhuangzi926)
FEATURE: Add tooltip for various columns (Chocobo1)
FEATURE: Add context menu to toggle content tab columns (#15164) (AbeniMatteo)
FEATURE: Add filter "Checking" to side panel (#15166) (AbeniMatteo)
FEATURE: Add "Forced metadata downloading" state (#15185) (AbeniMatteo)
FEATURE: Remember last viewed page in Options dialog (#15230) (Chocobo1)
FEATURE: Add tooltip to listening port spinbox (Chocobo1)
FEATURE: Add "Skip hash check" option for watched folders (glassez)
FEATURE: Add "Show torrent options" double-click action (glassez)
FEATURE: Allow setting temp folder per torrent/catergory (glassez)
FEATURE: Support folder based UI Themes (Prince Gupta)
BUGFIX: Save "resume data" once file priority is changed (glassez)
BUGFIX: Show priority menu at top level if there is no other in Add New Torrent dialog (FozzeY)
BUGFIX: Capitalize "peer flags" descriptions (Chocobo1)
BUGFIX: Reorder peer flags (Chocobo1)
BUGFIX: Show "last activity" value under all circumstances (Chocobo1)
BUGFIX: Elide text from the right for all columns' header (smigii)
BUGFIX: Fix startup with different profiles (jagannatharjun)
BUGFIX: Move a few torrent context menu actions into "Torrent options" dialog (thalieht)
BUGFIX: Allow deselecting radio buttons in "Torrent options" for mixed torrents (thalieht)
BUGFIX: Apply file priority changes correctly (a-sum-duma, Chocobo1)
BUGFIX: Use proper string for Korean language (OctopusET)
BUGFIX: Disable "add peers" menu items instead of hiding it (Chocobo1)
BUGFIX: Disable system tray icon menu when app is exiting (Chocobo1)
BUGFIX: Show GUI lock icon after system tray icon is initialized (Chocobo1)
BUGFIX: Apply selected layout to displayed torrent content in "Add New Torrent" dialog (glassez)
WEBUI: Add reverse proxy source IP resolution (#15047) (HiFiPhile)
WEBUI: Support navigating UI tables with arrow keys (Thomas Piccirello)
WEBUI: Support expanding/collapsing UI folders with arrow keys (Thomas Piccirello)
WEBUI: Support sorting UI tables via touch (#15205) (Tom Piccirello)
WEBUI: Add pieces progress bar to General tab (Jesse Smick)
WEBUI: Update authors page (Chocobo1)
WEBUI: Set icon sizes attribute (Daniel Aleksandersen)
WEBUI: Add meta application name (Daniel Aleksandersen)
WEBUI: Sort WebUI language selection values (Chocobo1)
WEBUI: Use correct URL scheme in user prompt when HTTPS is enabled (Chocobo1)
RSS: Stick Unread row to top in RSS feed list (Prince Gupta)
RSS: Correctly use fallback icons for RSS feed in GUI (jagannatharjun)
SEARCH: Add context menu for tabs in search widget (#14926) (Anton)
SEARCH: Add more download options to torrent search result right-click menu (a-sum-duma)
WINDOWS: Add windows-clang support (#15115) (Biswapriyo Nath)
WINDOWS: Update python installer URL for Windows (xavier2k6)
WINDOWS: NSIS: Update Simplified Chinese translation (Losiki)
LINUX: Prolong wait time for shutdown for qbittorrent-nox (Chocobo1)
LINUX: Install vector program icon (Chocobo1)
LINUX: Add detection for OpenBSD, Haiku in configure script (Chocobo1)
MACOS: Update Mac icons for Big Sur (17jiangz1)
EXPERIMENTAL: Setting to store/load fastresume/torrent files in an SQLite database (glassez)
OTHER: Many internal code refactorings and bug fixing by many peopleA sas száll ide - száll oda, de a szálloda nem sas ide - sas oda || Logitech <3 || Xiaomi 4 Pro gen2 <3
TeeJay
4.3.9 az utolsó 1.x libtorrenten futó, 4.4.0 foglalt szóval ha valami frissített libtorrentes verziót kiadnak az 4.3.9.x lehet de majd kiderül.
Dumi86:
Libtorrent 2.x óta már nem a torrent kliens kezeli a cache-t hanem az OS
ami elviekben jobb lesz hardver kihasználás szempontjából csak ugye a windows mégsem tökéletes így jelen pillanatban azt történik hogy a cache-t csurig tölti letöltött adattal és utána kezdi el kiírni az OS a meghajtóra csak ugye gigás netnél gyorsabban jön a cucc mint ahogy a HDD ki tudná írni emiatt az öszes cache elfogy és mivel az OS a RAM-ot is használja azt is 99%-ra lefoglalja.
Ez nem is lenne baj hiszen a RAM azért van hogy hasznájuk és ne 60% szabadon lógjon, és az OS kezelné ha jól működne.
Na majd ezt kell valahogy javítaniuk és akkor viszont jó lesz a 2.x libtorrentMixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
Dumi86
Ahhoz kellene normális gép is Amúgy én elhiszem ezt a bugot nektek. Előfordul az ilyen simán bármilyen programnál. Azzal lenne baj ha szarnának rá magasról és mondjuk hónapok után is benne maradna a hiba.
Mobil: Samsung Galaxy A41 DS (2020) Android 12.0 PC: Asus K31AN , Samsung 8GB DDR3L Ram , Crucial BX500 480GB SSD , Gigabyte 720 GT 1Gb , Windows 10 Home 21H2 (19044.2075) OEM , Vivaldi 5.3.2679.61 , Eset Nod32 Antivirus 15.2.11.0
TeeJay
Közben megtaláltam
Aki szeretné a 4.4.1-et kipróbálni de libtorrent 1.2.15-ön az linkre megy, alul megkeresi a
"qBittorrent-CI_Windows-x64_libtorrent-1.2.15" zip-et
Letölt majd kitömörít oda ahol a qBittorrent telepítve van
Aztán lehet tesztelniMixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
mpo
Az a jó, hogy nem egyértelmű, a magyar szóhasználat miatt.
A webböngészőkben a címsor vagy címsáv (address bar, location bar, URL bar) a
böngésző ablakának az a része (vezérlőeleme vagy controlja), ami az aktuálisan mutatott weboldal URL-jét mutatja, illetve lehetővé teszi a betöltendő URL begépelését. A legtöbb böngészőben működik az automatikus kiegészítés a cím beírása közben – ez általában a böngészési előzmények alapján történik.
A számítástechnikában a címsor vagy címsáv (title bar) grafikus felhasználói felületeken az ablak azon részét jelenti, ahol az ablak címe megjelenik. Nevezik még az ablak fejlécének is. A legtöbb grafikus operációs rendszerben, illetve ablakkezelőben a címsor az alkalmazás ablakának tetején, vízszintes csík formájában jelenik meg.
[link]Ha érted, akkor már elavult.
valakky
jaja, legyen neked bad, mert duplán "frankó" a szövegértésed. igen, ezek eredetiben is eléggé szar bikkfanyelvek. valszeg mert évtizedek óta szintén "frankó" szövegértésű kódereken alapulnak, akiknek sokszor nem anyanyelve az angol, vagy épp a saját nyelvét se beszélte soha anyanyelvi szinten.
időnként vicces volt anno látni, ahogy a programozók sokszor egymást se értik. a csúcs az volt, mikor szegény üzemeltetés próbálta személyesen kinyomozni, hogy na itt mire gondolt a költő... aztán az jött ki belőle, hogy szegényke azt a technológiai hátteret sem érti, amire írta, és az aktív, beszélt szókincse se érhette az el 1000-ret. az anyanyelvén. -
zsolt_64
Csak windows 10 ről(folyamatosan frissített) tudok nyilatkozni.
qqcqqc: itt pont a telhetelenségről van szó , bár most már van max memory param is. A lényeg hogy addig nem kezdi kiírni a letöltött anyagot amíg tele nem zabálta magát. Az előző verziónál az egész rendelkezésre álló memóriát. Ha viszont szünetelted a letöltést akkor mint a őrült elkezd kiírni a lemezre, de úgy hogy átmentileg lefagyasztja az egészet
valakky
azért nem mindegy, hogy pl a digis gigabiten tölti le, vagy az én 15 megabites feltöltési sebességemen csorog majd fel neki
de nálam is vannak az ultrahülyék/extrakényelmesek, akiknél időnként előfordul, hogy a gúgli tárhelyemre töltöm fel, onnan megy a link, hogy töltse le, de az sokkal macerásabb, sokkal több kattintás. ha hímnemű, sok sört kellett már fizessen nekem eddig ezért, ha nőnemű, akkor nagyon jónak kellett hozzá lennie az ágyban l
lmbtq-nál nem tudom, de szerintem sör. hacsak nincs cicije, amiből sör folyik.[ Szerkesztve ]
TeeJay
Csak annyit mondok gyorsan ki tud bukni hogy valaki belépett az oldalra Budapesten majd véletlenül a haverja Győrben 10perc múlva... Tudom van teleport gépe...
Illetve tudjuk mindenki távoli asztal meg teamviewer használó de hidd el gyorsan ki fog derülni mikor valakinek a belépései ide oda ugrálnak települések meg országok közöttMixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
TeeJay
totron
Igen, a legnagyobbét leginkább. Hát abban a tekintetben, hogy az alapértelmezés a 264 és külön feltüntetés nélkül erre is számítasz - ahogy a hardverlejátszód is. Új szelek, meg minden, értem, legyen. De lássam azt az 5-öst akkor a névben, aztán nincs keserű meglepi később. Megy offline helyre is cucc, ismerősnek, 3-4 hetes etapokkal. Olyanra értettem ahol ez nem volt benne névben.
(#45461) BBéci, a követeléssel ugyanott vagy, mintha csak a tartalom miatt néznél meg valamit. Ezért is pártolom végül az elengedést, vagyis a kompromisszum is az élet része.
Gabesz87
Én gépet fejlesztettem, és a régi konfigomat home server-ként használom ezentúl. OMV-t tettem rá, Dockerben fut a QBittorent, Portainer-ben.Szóval nem virtualizálva van.
Így ezentúl nem kellesz, hogy a PC-m menjen torrent miatt. Ezt az Electorrentet meg ajánlották, mint Win-es GUI a qbit-hez. Egyszerűbbé tenné a letöltést. EZért szeretném beállítani. -
sztanozs
Docker igazából nem virtualizálás, csak egy lezárt shell környezet a meglevő kernel felett. Szóval ha nincs a docker lekorlátozva, az kb olyan, mintha simán csak telepítve lenne a futtató környezetbe...
JOGI NYILATKOZAT: A bejegyzéseim és hozzászólásaim a személyes véleményemet tükrözik; ezek nem tekinthetők a munkáltatóm hivatalos állásfoglalásának...
sztanozs
konténerizálás azért jó, mert:
- könnyen elkülöníthetők a feladatok
- könnyebben elkerülhetők a névütközések
- egymással nem kompatibilis user-modulok is telepíthetők egyszerre különböző konténerekbe
- sz@rul megírt proigramokat (pl aminek kell root vagy group 0 access) is lehet úgy futtatni, hogy nem veszélyesek a futtatókörnyezetre
- egyszerű a hálózatkezelés és a NAT, biztosítja a konténer
- a konténer modell alapján könnyen klónozható (párhuzamosan futtatható) ugyanaz a csomagEbből persze nem minden áll meg egy QBT-re, de azért a könnyű menedzselhetőség és transzportálhatóság nagy előny tud lenni.
amargo
- Sandbox-ban unprivileged módban fut (ma már a legtöbb így van megírva)
- egyszerű backup és restore
- több példányban futtathatod, egyszerűen
- az erőforrást is szabályozhatod
- verziók kezelése is egyszerűszerk:
hopp, na pont hasonlókat emeltünk ki sztanozs-al.[ Szerkesztve ]
“The workdays are long and the weekend is short? Make a turn! Bike every day, bike to work too!”
amargo
A qbittorrent-nox-ot nem ismerem, így lehet nem látom át megfelelően, hogy ez kimondottan miért kellene docker-be rakni. De én még egy curl-t is onnan használok..
Viszont szerintem meg is válaszoltad a kérdést, kb 4-5x többet "mókolsz" vele, mintha docker-be tennéd és még a központosítást nem is hoztam fel.
Ettől még ki mit szeret jobban, én jobban szeretem, ha 1db fájlba van összefogva minden egymáshoz tartozó (docker-compose, persze kell a config fájl is) és nem 4-5 helyen szétszórva.Ez a része tényleg ízlés kérdése.
amargo
Szuper, akkor ez ugyan az mint a qbittorrent image legalább is, amit a linuxserver-csinál.
Mint írtam korábban is én nem vonom kétségbe, hogy kinek mi jó, miért kellene docker-t használni, ha valakinek tökéletes a csomagkezelő és gyári megoldások.
adika4444
Látom itt is feljött az örök vita, konténerizálni vs. nem konténerizálni. Tény, hogy amiket írsz abszolút igaz, de egy jól megírt compose file esetén tényleg csak vissza kell másolni az adatokat ha költöztetek, up és minden hasít tovább.
A systemd-s megoldást is használtam, az is egyszerű mondjuk mint a faék. Bár én Debian-on vagyok, ott az apt repókban ritka a friss verzió (van backport, de abban nincs qbittorrent-nox), így meg ha van valami ami a régiben nincs, megint csak egyszerűbb a konténer. Az overhead-je ellenére én perpill inkább ezt preferálom, de ennek is megvannak a maga árnyoldalai.
#45483Gabesz87
A portot megtalálod a qbittorrent konfig fájljában, de alapból talán 8080. Figyelj rá, hogy ha nem 0.0.0.0-ra van bind-olva, akkor lehet, nem éred el kívülről. Rendesen átirányított portokkal írhatod a külső IP-t, de ha ócskább szolgáltatói eszköz routol, akkor benne van a pakliban, hogy nem fog tudni Hairpin NAT-ot, vagy is a belső hálóról nem fog menni a külső IP használata.
Ha jól emlékszem, régen a qBit kliens is tudott amúgy remote-ként működni és akkor távoli instance-t vezérelt. Biztos tudja most is (webui-val használom).[ Szerkesztve ]
üdv, adika4444
Gabesz87
Igen, megtaláltam. Nekem OMV alatt Dockerben fut, megfelelő Docker-es mappában meglett. ÉRdekes, mert Win alól be tudom tallózni, de megnyitni nem Nincs engedélyem a file megnyitásához. Putty-al midnight commanderrel meg tudom nézni a tartalmát, és itt a másik nagyon érdekes dolog, hogy a Westworld-re egy betű említés sincs, helyette a másik futó rorrenttel van tele a log, mégpedig ezzel:
Gabesz87
Hmm, nem mondanám, hogy nagy mestere vagyok ennek az egész Linux alapú mókának, egyszer szeretném beállítani, hogy minden működjön, és aztán kb. hozzá sem nyúlni. SZóval...beállítottam OMV-ben mergerfs-nél ezt:
allow_other,use_ino,cache.files=partial,dropcacheonclose=true,category.create=mfs
Portainer-ben a qbit stackben átírtam a config file helyét az egyik HDD abszikút elérési útjára, ahol van a Docker mappa. A download mappa elérési útját egyelőre hagytam a mergerfs-el hivatkozott elérési úton. De a hiba egyelőre ugyanúgy fennáll. -
sztanozs
Van aktivitás, kb 100 torrent fut folyamatosan (most is). De nem töltögetek le aktívan, egy egy könyv, vagy valami újdonság (amiből manapság kevés akad) ami nincs fent netflixen (bár arra sincs sok időm)…
tobias40
TeeJay
4.5 alpha1-et raktam ki amit githubon 1-2naponta cserélgetnek újabb master-ra
abból is a libtorrent 2.0.7-en futó verziókat használom hetek óta gond nélkül
RAM fogyasztás proci terhelés teljesen jó és kihajtja a gigás netet lazánMixgyűjteményem ---> https://www.mixcloud.com/teejayhouse/
"Manuális port forward ÉS UPnP?"
Nyilván vagy ez vagy az.
Egyszerre úgy sem engedi. De a lényeg a részletekben van, akinek kell megtalálja.Akinek a kliense nem ismeri a titkosítást azzal inkább nem akarok kommunikálni. Azt az 1‰ seeder veszteséget elviselem.
FIGYELEM!
● A fórumon TILOS A WAREZ!
● Torrent meghívó kunyeráló topik
- Computex 2024: bemutatkozott a Biostar alaplapok AMD-s zászlóshajója
- Napelem
- Computex 2024: ASRock minden mennyiségben
- A Biden-kormányt is zavarja a big tech és az adatközpontok energiaéhsége
- 3D nyomtatás
