Amazon topic
V.Stryker
BornToBePuli
#7631
SIkerült. Nagyon komolyan korrekt ügyfélszolgálatuk van. Minden elismerésem. Tegnap kb egy perc alatt reklámtalanították a Kindle-t. Ma mikor elküldtem a problémát felhívtak és még utána emailben is küldtek plusz infót.
Egyértelműen megéri világcégek termékeit választani. -
V.Stryker
Valaki segítene, hogy most ezzel mit is akarnak?
ear Vántsa,
thank you so much for your email, and for bringing this to our attention.
Because you used a second e-mail address, I would like to make you aware of a security measure:
For privacy reasons, we send information relating to your customer account with us only to the e-mail address that you use to log in with us.
I will therefore send my reply to your e-mail address on file with us and I ask that you use the contact form (https://www.amazon.de/kontaktformular) on our Help pages for all further enquiries. You will find my reply at the e-mail address associated with your Amazon.de customer account. Should you have a customer account with a mobile phone number only, please check your messages in the message centre on Mobile App.
By the way, you can access information on your orders online at any time. To do so, simply go to "Your Account" on our homepage (http://www.amazon.de/).
However, if you no longer use the e-mail address that you used when signing in for your first Amazon.de purchase, I recommend that you replace it with a current valid address.
This can be done only on our website because we want to ensure that the change is made by the account holder.
You can do this easily online by going to "Your Account" at the top right on our website (http://www.amazon.de). In the "Login & security" section, select the link "Change Your Name, E-mail Address or Password" and follow the instructions.
(You'll receive an automatic e-mail from us about the change.)
Also, please allow me to thank you for your kindness and patience, Vántsa; I hope that you will find the information provided helpful. It was a pleasure assisting you.
I wish you a wonderful day!
Warmest regards,
- One mobilszolgáltatások
- SD memóriakártyák (SD, SDHC, SDXC, micro SD)
- sziku69: Szólánc.
- Luck Dragon: MárkaLánc
- Android szakmai topik
- Revolut
- Meggyi001: Áram nélkül....méltóság nélkül.....
- HIBÁTLAN iPhone SE 2020 64GB White -1 ÉV GARANCIA - Kártyafüggetlen, MS4307, 100% Akksi
- M1 iPad Pro 11" 3. Gen 128GB Silver - 27% ÁFA (0434BE)
- Honor 200 Pro 512GB, Kártyafüggetlen, 1 Év Garanciával
- Dell Latitude 7420 Core i7-1185 G7, 16GB RAM, SSD, jó akku, számla, 6 hó gar, szép állapot
- Dell Precision 5511,15.6"FHD,i5-10400H,16GB DDR4,256GB SSD,WIN11,LTE kártya
