dynax
sziasztok
korábban már jártam itt
de most hasonloan nem tudom telepíteni egy x96air tipusraelvileg s905x3 van benn 2GB és 100Mb ezért a weboldal szerint ez kell :sm1_s905x3_2g , és kártyáról megy is szépen , de ha akarom átrakni belsőre hibákat dob
először 1-4 menüpont volt , 3-as nyomtam ott ezt dobta :
Free space of 'partition CE_FLASH': 512MB
Warning: Could not find 'dto' partition!
Could not find 'CE_STORAGE' partition!
Failed to read size of partition 'CE_STORAGE'!
Failed to create new partition table!_____________________________________________________
utána probáltam 1-est nyomni akkor ezt irta :
Free space of 'partition CE_STORAGE': 6131MB
Used space of '/flash': 256MB
Used space of '/storage': 6MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
e2fsck 1.47.0 (5-Feb-2023)
[QUOTA WARNING] Usage inconsistent for ID 1000:actual (1601658880, 1449) != expe cted (1601662976, 1449)
[QUOTA WARNING] Usage inconsistent for ID 10000:actual (250167296, 2771) != expe cted (250171392, 2771)
[QUOTA WARNING] Usage inconsistent for ID 10024:actual (50049024, 953) != expect ed (50053120, 953)
[QUOTA WARNING] Usage inconsistent for ID 10025:actual (22024192, 193) != expect ed (22028288, 193)
[QUOTA WARNING] Usage inconsistent for ID 10049:actual (983941120, 10618) != exp ected (983945216, 10618)
[QUOTA WARNING] Usage inconsistent for ID 1000:actual (1191378944, 1231) != expe cted (1191383040, 1231)
[QUOTA WARNING] Usage inconsistent for ID 10000:actual (238469120, 2641) != expe cted (238473216, 2641)
[QUOTA WARNING] Usage inconsistent for ID 10024:actual (38293504, 406) != expect ed (38297600, 406)
[QUOTA WARNING] Usage inconsistent for ID 10025:actual (5193728, 145) != expecte d (5197824, 145)
[QUOTA WARNING] Usage inconsistent for ID 10049:actual (388845568, 3951) != expe cted (388849664, 3951)
Error running pclose on cmd: `e2fsck -fy /dev/loop2`. Error: 1
e2fsck: File system errors corrected
resize2fs 1.47.0 (5-Feb-2023)de itt megállt
__________________________________________________________________
ez után már 7 menüpontom volt ezért probáltam törölni , akkor ezt kaptam :
Warning!
ALL existing CoreELEC data on eMMC will be lost!
Press enter to abort!
Continue? [y]: y
mount: /var/media/CE_FLASH: wrong fs type, bad option, bad superblock on /dev/loop5, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
Error running pclose on cmd: `mount -o rw,loop /dev/loop4 /media/CE_FLASH`. Error: 32
Error executing cmd 'mount -o rw,loop /dev/loop4 /media/CE_FLASH'
Failed to mount 'CE_FLASH' partition!_______________________________________________________________________
valaki esetleg ?
nyomkodom a gombokat de félek megint tégla lesz
dynax
nfsu17
#103025
na sikerült a nexust felrakni és át is másolni
abba tudna valaki segíteni hogy a nexus és az omega között nagy a különbség ?
eddig jo volt nekem a 9.2.8 is csak pár honapja a tmdb elérhetetlenné vált és azt irta hogy nem lehet letölteni/frissiteni így nem voltak borítoim ,a youtube is vacakolt és betudtam annak hogy régi verzio és biztos azért nem megy , gondoltam omegát rakok fel azzal nem lehet gond , de igy most az egyiken nexus van a másikon omega , támogatás szempontjábol lesz különbség ? főleg ez a két dolog érdekel ( youtube meg a méditár borítokkal )
dynax
akkor fellelkesülve az elöbbi sikerén nekiestem az elsőnek ( s905x ) nyomtam 7-es mert 7 menüpont volt utána viszont nem volt 4 menüpont csak 2 ,mivel 1-es abban is van
gondoltam jo lesz viszont itt nem sikeres a másolás , ezzel áll meg és nem megy továbbPlease choose one option? [1/2]: 1
Free space of 'partition CE_STORAGE': 9974MB
Used space of '/storage': 658MB
Continue? [y]: y
Starting to format the new 'CE_FLASH' partition...
mkfs.fat 4.2 (2021-01-31)
Stopping Kodi before start of copy process!
Starting copying of data to the eMMC!
Please do NOT interrupt this progress till it's finished!
Copy all data from '/flash' to '/media/CE_FLASH'
210.53M 82% 32.36MB/s 0:00:01
Synchronize data on disk with memory, please wait...
rsync: connection unexpectedly closed (2330 bytes received so far) [generator]
rsync error: error in rsync protocol data stream (code 12) at io.c(231) [generator=3.2.7]kártyárol megy csak jobb lenne a belső , lehet valami megoldás erre ?
dynax
megvaan !!!
miután 1-es nyomtam azt irja vegyem ki a kártyát és inditsam ujra , gondoltam gyorsabb ha a coreelecben a távirányitoval azt mondom neki hogy restart from emmc/nand , na ekkor az andorid indul , de ha nem vagyok lusta és kiveszem a kártyát , kihuzom a dugot akkor miután áramot adtam neki a belső táhyleről indul a CE
megjegyzem még mindig nem értem hogy ha 7-es nyomtam és letöröltem akkor hogyan marad rajta andorid utána
na mostmég frissiben nekiállok az elsőnek
köszi mégegyszer !!! pár perc mulva irok ujra az első doboz hibájával
dynax
nfsu17
#103005
android fut éppen , mivel nincs benn másik tárhely , szerintem
az van a belsőn de ugyanzet irja Existing CoreELEC dual boot installation found on eMMC
Migrate CoreELEC dual boot to single boot installation
Use CoreELEC data from
[1] current used SD or USB device
[2] the existing data on eMMC
[3] existing backup on current used SD or USB device
Renew current CoreELEC dual boot installation on eMMC
[4] current used SD or USB device
[5] existing backup on current used SD or USB device
[6] Make a backup of current CoreELEC dual boot installation on eMMC to current used SD or USB device
[7] Remove current CoreELEC dual boot installation on eMMCmiután egyest nyomtam ezt irta ki :
Please choose one option? [1/2/3/4/5/6/7]: 1
Failed to create new partition table! -
dynax
köszi a választ és visszatérek az első részére (s905x)de möst örülnék ha nem lenne egy ujabb a téglám ennél , szoval kérdezném ezt a második részt mert tuti összekeverem és 4 téglám lesz
szoval a másodiknál (s905x3) láthatóan müködne a másolás és 4-est nyomtam ami leszedte a 9.2.8-at a belső helyről , most ott androidom van a belsőn és benne a kártya az omegával amit felraknék , 1-7-ig melyikkel tudnám átmásolni a belsőre a kártya tartalmát hogy az bootoljon ?
dynax
és akkor ha a belső helyen 9.2.8 van akkor nem tudok felrakni singla bootban mondjuk omegát amig nem rakom vissza az androidot ?
elkezdtem egy másik boxomat is , gondoltam max az első marad kártyán ha nem tudom átmásolni de itt meg másik hiba van
nincs valami oldal ami elmagyarázza ezt ?
[7] Remove current CoreELEC dual boot installation on eMMCnyomtam 1-et
Failed to create new partition table!szoval ezen sem futott le zökkentőmenesen
vagy csak röviden ha 7-est nyomok kinyirja a dualbootot a belső helyen de felrakja oda a mostani probálgatást usb-ről ?
dynax
nfsu17
#102986
nyomtam yes-t
mivel ezer éves box nem lett volna nagy kár
a léyneg hogy nem sikerült, kártyáról megy de nem tudja átmásolni valmaiért, és persze a kártya is jo de pl a médiátarmmentését nem tudm rárákni mert baromi lassu , gondolom a kártya miatt és befagy , de ettől eltekintve megy rendesen -
dynax
nfsu17
#102980
elvileg s905x van benne 2GB rammal , a corelec oldalon az uj telepitésnél kiválaszottam a device s905X és 2GB ram tipust ekkor kiirja hogy használjam a gxl_p212_2g dtb-t ,
rufussal kiirtam , és átnevezve bemásoltam a gxl_p212_2g -t dtb.img-re ahogy le van irva , a box elindul az omega elindul
belépek ssh-val de az instaltointernal parancsra azt irja hogy használjam a ceemc parancsot , amikor ezt kiadom azt irja hogy a rendszer nem támogatja a gxl_p212_2g , majd hogy nincs coreelec instal az emmc-n és hogy a single boot mode nem lehetséges
[2] existing backup on current used SD or USB deviceha valaki megátmogatna örülnék mert kicsit parázok hogy ez lesz a 3. téglám
dynax
AiRLAC
#102977
nem a pendrivre rakom rufusszal az letöltött image file-t és arrol bootolva települ ? mondjuk ez megmagyarázná
szoval akkor rufussal rakjam kártyára és ha megy akkor paranncsal másoljam át ? abban voltam hogy telepítő van mint a librelecnél , ott pendrive készül és onnan telepítem -
dynax
olyan kérdésem lenne hogy friss telepítést szeretnék de valamiért a pendrievra telepíti a coreelec-et az instal és nem a memóriakártyára vagy belső tárhelyre
ennek mi lehet az oka ? nem kérdez semmit , magától csinálja , nem tudom kiválasztani hogy hova rakja -
dynax
AiRLAC
#102945
igen , ezt én is olvastam hogy előbb másik kártya aztán bemásolni és emlékszem régen én is csináltam így de arra is emlékszem hogy van otthon másik kettő a téglásítva lett
szoval gondoltam ha csak frissitem akkor ez elkerülhetem
meg reméltem a frissitéssel pl nem veszik el a táviányító stb...van sok táblázat ami biztosan egyértelmű lenne de még mindig nem tudom mi az az "ne" és "ng"
dynax
sony309
#102937
be tudom állítani a képfrissitést meg van olyan hogy állítsa a képfrissitést a médiától függően , a coreelec alatt nem kell foglalkoznom megy rendesen csak a librelelc alatt nem
ha a film képfrissitésére gondolsz azt a windowsban nézem meg simán jobb egérgomb , tulajdonságok
de a filmjeim mind 24fps-ek ami meg home video az 50 vagy 60 szoval macerás kapcsolgatni ezért maradt a coreelec pedig váltanék ha tudnám miért nem vált
dynax
sziasztok ! a boxomon 9.2.8-as corelec van és már nem müködiuk sajna tmdb-ről a borító letöltés , gondolom ezért ... szoval rászántam magam hogy felrakok valami újabbat és elakadtam ott hogy ha a coreelec oldalon az omega verziora akarok frissiteni akkor megkérdezi hogy ne vagy ng , mivel jó pár éve foglalkozam ezzel ez is új nekem
hol tudom megnézni hogy az enyémen ne vagy ng van illetve linknek valami szájbarágos update leirásról is nagyon örülnék
illetve ha valaki tudna segíteni hogy a libreelecben miért nem vált képfrissitést a kodi, a netes filmek 24fps-e és a homevideo 60 fps-e között azt is nagyon megköszönném , ugynaugy beállítottam mint a coreleces változatban , a corelecnél megy a librelecnél nem megy
dynax
sziasztok ! a sima 905-től kezdve már volt 5-6 boxom , a végén 905x3 az utolso és nagyon szerettem de van hogy homevideot szeretnék nézni ami 4k/60fps és ugy tűnik ehez már ez kevés
a gazdaságosabb kategóriából tudnátok ajánlani olyat ami viszi ezt gond nélkül ? a S922X chip erősebb mint a 905x3 ? ez lehet megoldás ? -
dynax
na összesítve most már bármit csinálok a corelec indul el , gyorsan feláll , ssh-n rögtön belépek és beenged de a hdmi-n nincs kép
valaki járt már így hogy nincs kép a hdmi-n miközben fut a ce rendesen ? -
dynax
hát most az a baj hogy alap indulással nincs kép
ha nincs bent a kártya andorid indul mert van adb (ssh nincs) de kép nincs , ha ekkor adbben beirom a reboot update parancsot elindul a recovery menu és ott system reboottal már jol indul az android van kép de alapbol , sima inditással csak kép nélkül indul
ha android fut berakom a kártyát és adb-ben reboot update akkor elindul a kárytán lévő coreelec , ilyenkor van kép , nincs adb , van ssh , ha ilyenkor a ce-ben ujrainditom jol indul el de ha kihuzom és ugy indul ujra megint nincs kép , ekkor a coreelec indul , nincs adb viszont van ssh és itt kezdem ujra ...
szova valamit a bootlaoderben is elszurtam
dynax
miután leirtam ez volt az első tippem
nem volt kép a hdmi-n de futott a coreelec , volt ssh , beirtam a reboot updatet és be is jött mivel ujraindult és meg nem tudom magyarázni hogyan de elindult az eredeti android
amit azért nem értek mert ssh csak ugy lehetett hogy ment a coreelec , de ha az volt fent akkor honnan jott vissza az android ? most kezdtem elölről , kártyáról megy a coreelec de nem tudom merjem-e ujra belsőre rakni mivel nem tudom mi votl a hiba nem tudom mit kerüljek el ... -
dynax
eseleg valaki tudna egy olyan parancsot adni amit ssh alatt tudok kiadni és ujrainditás után a kártyáról bootol , hogy elinduljon a ce telepítő ?
dynax
a parancs nem segített
esetleg valami olyan parancs amivel ujra indulna a telepítő ?
ez volt a 8. dobozom amire ce-t raktam , igazábol sosem volt gond , eloszor elindult kártyáról és mivel ment gondoltam átmásoltam belsőre , vissza nem raknám a régi androidszerüséget de ha ujra rá birnám hogy induljon telepítő egy kártyárol akkor az is jo lenne nekem
dynax
köszi ! az adb shell-lel tényleg könyebb
hát ugy tünik 4Gb-ost vettem , a matrica rajta 4GB-os de találtam a neten olyan irást miszerint van ami fake 4GB-os , valoszinuleg az enyém is ilyen volt , mert a 4GB-os dtb.img-vel nem indult a telelpités de amint ráraktam a 2GB-ost máris ment
gyorsan felraktam , örültem , ráküldtem a ceemmc -t , na azota nincs kép
putty-al elérem , fut , be tudok lépni de a hdmi kimenten nincs kép
valaki nem látott egy leirást ami step by step leirja hogy ssh-n keresztül hogyan tudnék inditani uj telepítést ?
vagy hogyan csináljak képet ujra a hdmi-n ?
dynax
zsiga68
#98847
most egyet előre jutottam , az x96 airnél sikerült microsdről elinditani de nem tudom átmásolni a belső tárhelyre de a ceemmc -x parancsnál 1-4-ig bármit választok mindig kevés a tárhely
az x3 mininél változatlan , nincs benne reset gomb igy egy zipet másolok a kártyára azt inditom az updatenél , ujraindul de csak az android reoveryig jutok , nem indul el a telepités -
dynax
sziasztok ! régebben sima 905-os boxokra lazán fel tudtam rakni a coreelec/liberelec valamelyikét de most az ujabb 905x3 szivat
van egy x3mini és egy x96air de egyikre sem tudom felrakni , 5 különböző pendriveot és 2 microsd kártyát probáltam de nem indul el , van esetleg valakinek ötlete mit szúrok el ? ennyi hibás cuccom nem lehet de egyszerűen nem tudom rábirni hogy a coreele logo elinduljon bootnál
az x96airnél fogpiszkáloval indul , de csak a recovery menu jön be , az x3 mininél zip fájlot tallozok be , de ott is csak a recovery menüig jutok
dynax
sziasztok ! órák óta szívok és nem birom felrakni a ce-t
már több dobozomra is felraktam , igaz az évekkel ezelött volt de most tippem nincs mi van. X96Air a tipus , a fogpiszkálós dolog megy mert ha nincs bent pendrive akkor elindul az andorid menüje de ha berakom a pendrive-ot akkor az x96 logo után csak feketeség van. 5 pendrive-val porbáltam , az egyiken van led és világit amikor elvileg onnan bootolna szoval az is azt támasztja alá hogy elindul a pendriverol. a dtb-t átneveztem dtb.img-re , a kiválasztott dtb fájl elvileg jo de már másik lettővel is probáltam azonos 905x3-ból de nem akar felmenni , bármilyen ötletet szívesen fogadok! köszi előre is
dynax
Sziasztok! Egy kis kinai dobozon fut a corelec már több mint 1 éve , sajna a távirányító megadta magát. Gondoltam semmi gond a másik szobában van egy másik fajta doboz annak a távirányítóját belövöm a meson-ir segítségével, ugysem nézzük két helyen egyszerre, majd átviszem a távirányítót amikor kell. A lényeg hogy belöttem az másik távirányítóra a meson-ir dolgot , minden tökéltesesen működik csak bekapcsolni nem tudom
szoval minden gomb rendben , minden kodot leolvastam , minden gomb müködik , a power gomb kikapcsol ez sem gond csak bekapcsolni nem tud. Van esetleg valami ötlet ? Előre is köszi ! -
dynax
Sziasztok! Corelec+kodit használok, hálozaton keresztül egy windows megosztásból játsza le a filmeket de a médiatárba nem tudok berakni 28 filmet de csak azt a 28-at. Az összes film egy mappában azzal a több százzal együtt amit lát , a fájl részből látja , ha frissitem a médiatárat job felül látszik hogy megtalálja ezt a 28 filmet mint új film de a médiatárba nem kerül be , nem látszik. Másik filmet azóta már raktam be de ez a 28 kakuktojás. Már átneveztem de ugysem
valami ötlet ? Köszi előre is ! -
dynax
sziasztok ! olvastam sok jót ezekről a boxokrol és rendeltem egyet ami tegnap meg is jött
a cél az volt hogy a samsung tvre sajna nincs "rtl most" app és jó lett volna néha visszanézni amiről lemaradtam a tvben . Lelkesem le is szedtem erre a kütyüre a google playből az rtl most appot , ami teljesen jól is felment . Viszont eléggé mobilra lett optimailzálva és a tv közepén álllóban látszik a felület , ha kihuzom rajta a filmet akkor is az álló felület széléig huzza szét nem a tv szélig . A setupban találtam olyat hogy force land , akkor már jól fekvőben van de eltűnnek a gombok és nem engedi a felületen belül a teljes képernyőt . Van olyan hogy original akkor olyan mintha elfektetném a mobilt és ha már eljuttottam a filmig tökéletes de addig eljutni szenvedés mert aminek állóban kéne lenni az is fekvő , tehát a szöveg a tv aljáról felfelé fut
nincs valami jo megoldás , esetleg valaki nem használja ezt az app-ot ? köszi előre is a választ !
- Windows 11
- Milyen robotporszívót vegyek karácsonyra? (2025)
- Milyen házat vegyek?
- Nikon DSLR topik
- Milyen processzort vegyek?
- Brutál Gamer PC RTX 5060 Ti 16GB, i5-14400, DDR5 32GB Garis 2027-ig!
- Zotac Magnus One barebone számítógép Foxpost az árban !!
- i5 12500/ RTX3070/ 32GB DDR4/ 1TB SSD alapú konfig/ garancia/ ingyen foxpost
- Asus Gamer PC: i5-10600KF // RTX 3060 Ti // 1Tb SSD // 16Gb Ram
- AM4 csúcs félkonfig ! 5800X3D-MSI B550-G.SKILL Trident Z RGB 32GB (2x16GB)-512GB M2 + AIO HŰTŐ
- Eladó Samsung Galaxy S23 8/256GB / 12 hó jótállás
- REFURBISHED - Lenovo ThinkPad 40A9 USB-C Dock (ELKELTEK) - CSAK RENDELÉSRE
- GYÖNYÖRŰ iPhone 12 Pro 128GB Graphite-1 ÉV GARANCIA - Kártyafüggetlen, MS3669, 100% Akksi
- Samsung Galaxy S24 / 8/128GB / Kártyafüggetlen / 12 Hó Garancia
- Bomba ár! Lenovo ThinkPad T14s G2 - i7-11GEN I 16GB I 1TSSD I 14" FHD Touch I W11 I Cam I Gari!
DoItYourself
