hroleez
tierbatyo
#485
Szóval idekopizva (elnézést a hossza miatt!):
padlas1 ~ # revdep-rebuild
Configuring search environment for revdep-rebuild
Environment mismatch from previous run, deleting temporary files...
Checking reverse dependencies...
Packages containing binaries and libraries broken by a package update
will be emerged.
Collecting system binaries and libraries... done.
(/root/.revdep-rebuild.1_files)
Collecting complete LD_LIBRARY_PATH... done.
(/root/.revdep-rebuild.2_ldpath)
Checking dynamic linking consistency...
broken /usr/bin/gnuplot (requires libpdf.so.2)
broken /usr/bin/kino (requires libraw1394.so.5)
broken /usr/bin/lav2wav (requires libdv.so.2)
broken /usr/bin/lav2yuv (requires libdv.so.2)
broken /usr/bin/lavaddwav (requires libdv.so.2)
broken /usr/bin/lavinfo (requires libdv.so.2)
broken /usr/bin/lavplay (requires libdv.so.2)
broken /usr/bin/lavrec (requires libdv.so.2)
broken /usr/bin/lavtrans (requires libdv.so.2)
broken /usr/bin/mkvmerge (requires libFLAC.so.4)
broken /usr/bin/openjade (requires libosp.so.3)
broken /usr/bin/playsound (requires libFLAC.so.6)
broken /usr/bin/yuv2lav (requires libdv.so.2)
broken /usr/lib/kde3/libk3bflacdecoder.so (requires libFLAC++.so.2 libFLAC.so.4)
broken /usr/lib/libSDL_sound-1.0.so.1.0.0 (requires libFLAC.so.6)
broken /usr/lib/liblavfile-1.6.so.0.2.2 (requires libdv.so.2)
broken /usr/lib/openoffice/program/python-core-2.3.4/lib/lib-dynload/_bsddb.so (requires libdb-3.1.so)
broken /usr/lib/openoffice/program/python-core-2.3.4/lib/lib-dynload/_tkinter.so (requires libtcl8.3.so libtk8.3.so)
broken /usr/lib/openoffice/program/python-core-2.3.4/lib/lib-dynload/bz2.so (requires libbz2.so.0)
broken /usr/lib/openoffice/program/python-core-2.3.4/lib/lib-dynload/mpz.so (requires libgmp.so.3)
broken /usr/lib/xine/plugins/1.0.0/xineplug_flac.so (requires libFLAC.so.4)
broken /usr/lib/xine/plugins/1.0.0/xineplug_inp_vcd.so (requires libvcd.so.0)
done.
(/root/.revdep-rebuild.3_rebuild)
Assigning files to ebuilds... done.
(/root/.revdep-rebuild.4_ebuilds)
Evaluating package order...
Warning: Failed to resolve package order.
Will merge in ''random'' order!
Possible reasons:
- An ebuild is no longer in the portage tree.
- An ebuild is masked, use /etc/portage/packages.keyword
and/or /etc/portage/package.unmask to unmask it
..... done.
(/root/.revdep-rebuild.5_order)
All prepared. Starting rebuild...
emerge --oneshot =app-cdr/k3b-0.11.20 =app-office/openoffice-bin-2.0.1 =app-text/openjade-1.3.2-r1 =media-gfx/gnuplot-3.8j =media-libs/sdl-sound-1.0.1-r1 =media-libs/xine-lib-1.0 =media-video/kino-0.7.5-r1 =media-video/mjpegtools-1.6.2-r3 =media-video/mkvtoolnix-1.0
Calculating dependencies
emerge: there are no ebuilds to satisfy ''=app-cdr/k3b-0.11.20''.
revdep-rebuild failed to emerge all packages
you have the following choices:
- if emerge failed during the build, fix the problems and re-run revdep-rebuild
or
- use -X or --package-names as first argument (trys to rebuild package, not exact
ebuild)
or
- set ACCEPT_KEYWORDS=''~<your platform>'' and/or /etc/portage/package.unmask
(and remove /root/.revdep-rebuild.5_order to be evaluated again)
or
- modify the above emerge command and run it manually
or
- compile or unmerge unsatisfied packages manually, remove temporary files and
try again (you can edit package/ebuild list first)
To remove temporary files, please run:
rm /root/.revdep-rebuild*.?_*
padlas1 ~ #
ACCEPT_KEYWORDS beállítva.
Szóval ezt adta.
[Szerkesztve] -
hroleez
Létetik valamilyen srcipt, amivel gyakorlatilag egy pillanatképet csinálok a rendszer mindennemű beállításáról, és pl. akármi hiba megjelenése után ebből fel tudom építeni újra a rendszert? Vagy máshogy megkérdezve, mit mentsek ehhez?
Köszi, R. -
hroleez
dr_strange
#480
Nem sokban térünk el, amin próbálom egy Athlon XP 1500+, x86. gentoo-sources-2.6.14-gento-r5.
hroleez
dr_strange
#478
Nekem ezt adja, ha be akarom tölteni a configod:
arch/i386/defconfig:287: trying to assign nonexistent symbol BLK_DEV_ADMA
arch/i386/defconfig:360: trying to assign nonexistent symbol SCSI_MEGARAID
arch/i386/defconfig:401: trying to assign nonexistent symbol SCSI_QLA6322
arch/i386/defconfig:472: trying to assign nonexistent symbol NETLINK_DEV
arch/i386/defconfig:564: trying to assign nonexistent symbol NET_FASTROUTE
arch/i386/defconfig:565: trying to assign nonexistent symbol NET_HW_FLOWCONTROL
arch/i386/defconfig:715: trying to assign nonexistent symbol SOUND_GAMEPORT
arch/i386/defconfig:771: trying to assign nonexistent symbol QIC02_TAPE
arch/i386/defconfig:807: trying to assign nonexistent symbol DRM_GAMMA
arch/i386/defconfig:993: trying to assign nonexistent symbol USB_STORAGE_HP8200e
arch/i386/defconfig:1019: trying to assign nonexistent symbol USB_HPUSBSCSI
arch/i386/defconfig:1054: trying to assign nonexistent symbol USB_TIGL
arch/i386/defconfig:1112: trying to assign nonexistent symbol DEVFS_FS
arch/i386/defconfig:1113: trying to assign nonexistent symbol DEVPTS_FS_XATTR
arch/i386/defconfig:1241: trying to assign nonexistent symbol X86_STD_RESOURCES
' invalid for INIT_ENV_ARG_LIMIT
make[1]: *** [menuconfig] Error 1
make: *** [menuconfig] Error 2
a kernel 2.6.14-gentoo-r4 -
hroleez
dr_strange
#476
Most néztem, az usb pendrive-nak sem jön létre eszköz!
Amit látok dmesg-gel:
ohci_hcd 0000:00:02.0: wakeup
usb 2-3: new full speed USB device using ohci_hcd and address 2
scsi0 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
Vendor: Generic Model: USB Flash Disk Rev: 7.77
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 0
usb-storage: device scan complete
usb 2-3: USB disconnect, address 2
De /dev/sda sehol...
Elküldenéd a .config-od? -
hroleez
dr_strange
#474
Megcsináltam, kézi fordítással, az eredmény teljesen ugyanaz
Miért nem jön létre a hangeszköz??? ALSA szegény betölti a modulokat, de a mixer már keresi az eszközt...
Most néztem a 2.6.15-ös kernelt a portage fában, érdemes lenne azzal próbálnom?
R.
[Szerkesztve] -
hroleez
Na, mosr pukkadtam ki..
Eddig simán fordult a kernel, most meg busybox source tarball kell neki... Bruhhhahhha...
Keményít a dolog rendesen. -
hroleez
hroleez
Ha nem lenne udev a kernelben, akkor az udevstart működne? És minden jel arra mutat ám, hogy bele van forgatva!
Lehet, hogy userspace udev csak?
A hotplug ill. coldplug mit csinál pontosan?
Egyébként megvolt az emerge és hozzá vannak adva a default runlevelhez.
[Szerkesztve] -
hroleez
dr_strange
#465
Lehet, bár a wikis leírások alapján csináltam, ami nem modulban van eszköz, az szépen létre is jön. Elvileg csak kernelbeállításokkal lehet baj, nem?
hroleez
A coldplug-ot próbáld meg, Sipi ajánlotta nekem is! Úgy csináltam eddig, hogy ugye betölti a modulokat, eszköz nincs. Belépek root-ként (vagy su) és kiadom az udevstart paracsot, így létrejönnek az eszközök, majd alsamixer-rel újraállítom a hangerőket...
és mindezt 2006-ban kedvenc oprendszeremen...
Roland -
hroleez
Feltettem simán emergével a skype-ot, nálam megfelelő a hang, jól csörög, csak annyi, hogy minden beszélgetés után ki kell lépni és újraindítani. Konferenciabeszélgetés is bármilyen partnerrel jól megy.
Nem lehet winfosos skype-ot használni wine alatt? Mondjuk még a bétát is webkamerával..?
[Szerkesztve] -
hroleez
Én sem értem. Gyakorlatilag már a bootolás közbeni alsasound indítása is kudarcba fullad, ugyanis betöltődnek a modulok, de a mixer nem tudja visszaírni a régi értékeket - mivel nincs eszköz! Ergo defaultol -> mindent újra állíthatok, ha hangot szeretnék. Persze egy jól irányzott udevstart után... A boot folyamatkor kiírja, ha elindul a hotplug? mert nekem benne van a default runlevelbe, de semmi jelzés nincs, hogy elindult-é...
Köszi,
R.
[Szerkesztve] -
hroleez
hroleez
dr_strange
#446
Köszönöm, kipróbálom. Most minden 100-on van...
hroleez
Felment a howto szerint csont nélkül az ALSA, bár az eszközök mindig csak egy udevstart után jönnek létre... Mind1, simán az alsasound betölti a bt87x és intel8x0 modulokat, alsamixerrel felnyomva minden 100-ra, mplayer lejátsza a muzsikát, de hang egy szál sem... A /dev-ben minden eszköz, mixer, sequencer, létrejön. Hmmm. A hangrendszer egy fejhallgató, hardveresen működik.
Mi lehet ez? Tutti valami bagatel dolgot nem csináltam.. de mit?
(más: a videoeszközöket meggyógyítottam.)
R.
[Szerkesztve] -
hroleez
dr_strange
#443
Jajj, hamu a fejemre! most ijedtem meg! Bassszus 5-ös nyelvtan érettségi nesze nekem...
Tutti elírás....
Roland
[Szerkesztve] -
hroleez
A bttv megvolt a modulba, a hangra ilyedtem meg egy picit, de már így ok. Ilyen régen volt a bttv külön csomag?
Mióta a kernel része?
A párhuzamos portra kapcsolódó eszköz egy speciális dolog lenne, konkrétan egy AVR programozó külyü. Bár éjjel alvás mellett gondolkodtam, lehet, hogy usb-s alapon megoldható a dolog. Mindenesetre érdekelne a párh. portos megoldás.
Aztán sikerült az udev-es felállás!
És az ACPI is!
Az új kernellel kapcsolatban azért van némi kérdésem (lehet nem kernelfüggő némelyik, de ennél vettem észre):
- /linuxrc-t azonnal bootolás után keresi. Hol a manóba kell ez kikapcsolni (legalább azt, hogy ne várjon, ill. írja ki)?
- bttv (ismét...), usb-s webcam modulbetöltés után hol vannak az eszközeik? /dev/video?
- a hotplug-ot rc-update-val hozzáadtam defaultra. Ez pontosan hogy megy? Felismeri a rádugott eszközt a pc-re és csinál neki egy /dev/.. bejegyzést? A szükséges modulokat is betölti hozzájuk?
- megfigyeltem, hogy a vesafb-tng-vel mielőtt nem fut az X, gyors a scrollozás, listázás, de amint futott az X (indítás, kilépés) utána pl egy dmesg lelassul 8-10 mp-re... Normális ez?
- próbáltam az udevinfo -a -p `udevinfo -q path -n /dev/sda` parancsot a pendrive csatlakoztatása és modulbetöltés után, azt írta nincs ilyen eszköz. Pedig a dmesg-ben írja, hogy van.
Roland
[Szerkesztve] -
hroleez
MOst forgatom a kernelt, és ''észrevettem'', hogy a bttv hangmodulja kimarad, ha nem forgatom be az ALSA-t, utána ezt a bttv emergelésével megoldhatom?
Hogyan lehet egy párhuzamos portra dugott eszközt felismerni? (ala dbus?)
Roland -
hroleez
dr_strange
#436
Nálam sem ugrik fel dugás után semmilyen ablak!
Ez amolyan humán feature?
Sorry, de nem lehetett kihagyni, ahogy neked sem! -
hroleez
Köszönöm!
Nagyon bonyolult az automatikus eszközfelismerés után a mount egyben? Az kell a feleségem gépére, ha benyomja a digitális kamerát (usb mass storage-vel megy), egyből induljon a gthumb neki.
Már elkezdtem összeírni a kavarjaim.. Az a baj, hogy én is Slackware, és Suse dolgokból jöttem, bár 96-ban csak Slaki volt amit megszerezhettem...
[Szerkesztve] -
hroleez
Köszi! Akkor csak az ACPI-t beleforgatom. Az ALSA-s howto-ban van egy ''set up dmix for OSS'' rész is, azzal ne foglalkozzak?
Én sem értettem az nforce-audio guide-ot, és nem is működött..
Ti tartjátok bennem a gentoo-s lelket!
Viszont kavarodás még sok van bennem ...
[Szerkesztve] -
hroleez
dr_strange
#425
Mi az a minimális bonyodalom?
Köszi, megpróbálom este. Tegyem be a grub.conf-ba a gentoo=nodevfs bejegyzést?
Az nforce-audio-ra ez nem jó a legújabb kernellel: [link] ?
Roland
[Szerkesztve] -
hroleez
Köszi, muzsikál a dolog végre...!
Kernelbeli alsa driverrel. Az lehet, hogy az nvidias driver hangja szebb?? Ez amolyan szubjektív, de máshogy szól...
Lassan azért pipálom ki a kernelfordítási ''hibáim''!
De most meg nem kapcsol ki a halt parancsra... Pedig van ACPI és APM is beleforgatva.
Most hasonlítgatom a régi kernelem configját az újjal...
Közben van egy CANYON szuperolcsó webkamerám, beizgítottam, ha valakit érdekel leírom.
Bruhhhaha, ez az udev-es dolog még nem fért teljesen a fejembe... Meg ahogy olvasom az itt leírt tapasztalatokat.. Hááát. Minek kell bonyolítani az udev-vel? Bocs, ha amatőr kérdés..
Roland -
hroleez
Azért maradt némi üröm első körben az örömben:
- nforce-audio felmegy, de modulbetöltésnél: fatalis dolog, ismeretlen paraméter: ''spdif_status''
- indulánál keresi ill. vár a /linuxrc-re. Miért? Eddig nem volt erre szükség.
- udev ill. devfs ajánlgatás
- 1280x1024-32@75 vesafb-tng-vel nem megy, csak 60Hz-ben. radeonfb-vel ezzel simán ment. Semmit nem állítottam itt, csak a radeonfb lett vesafb-tng-re.
Üdv,
Roland -
hroleez
Szóval a klibc-s hibám ez: [link]
A klibc pkg fenn van a genkernel megfelelő helyén.
Másnak símán gnekernelezi a 2.6.14-es forrást?
R. -
hroleez
Sima (genkerneles) kernel fordításnál is kell a klibc? Hogy tegyem fel az emerge klibc-n kívül?
R. -
hroleez
Próbálom a 2.6.14-essel. Majd leírom az eredményeket.
Viszont, gondolván, ha már fordítok, megcsinálom ezt is (fbsplash):
A genkerneles változatát. Felteszi a splashutist rendesen az emerge, majd amikor a genkernel --menuconfig --gensplash=emergence all a modulokat fordítja, hibával elszáll, hogy nem találja a klibc-t packaget. Ami értehetlen, mert fenn van.
Mitől lehet ez?
R.
[Szerkesztve] -
hroleez
dr_strange
#396
Köszi. Gondoltam a befelforgatást a kernelbe
Lehet, hogy a legújabb gentoo-s kernellel nem lenne összeakadás?
R. -
hroleez
dr_strange
#394
Abban ugyanolyan felbontást tudok csinálni, mint a radeonfb-vel? (1280x1024-32@75).
Meg az mplayer is szerette a directfb-t radeonnal...
vesafb-tng? Ezt írjam be a grub.conf-ba?
R. -
hroleez
Fordítottam egy kernelt (2.6.8.1), amibe radeonfb-t tettem, majd grubba video=radeonfb:.... Szépen működik. Viszon az Xorg kilépéskor (ctrl+alt+back) simán lefagyassza keményre a gépet. Csak a hardver reset segíti a dolgot. Olyan a dolog, hogy zavaros, csíkos dolog látható, fekete alapon.
Modulok: fglrx, nvidia-agp, forcedeth, nvaudio, meg 1-2 sensors dolog.
Feltettem kernelforgatás után is az ati-drivers-t.
Abit nf7-s, Radeon 9550 GeCube.
Üdv és köszi,
Roland -
hroleez
Boldog, Békés, SzentKarácsonyt!
Eddig símán működött a HAMA-s usb-s kártyaolvasó:
modprobe ohci-hcd
modprobe usb-storage
mount -t vfat /dev/sda1 csatol
Aztán ma reggel fel szerettem volna nyomni a karácsonyi képeket, és állandóan azt írja ki, hogy nincs olyan eszköz
Muszály volt a céges laptopon xp alatt feltenni
Kernelt nem forgattam régóta.
kernel: 2.6.8.1, nvidiás alaplap (NF-7S)
Üdv és köszi,
Roland -
hroleez
Köszi! Megpróbálom a USE flaggel újraforgatni. De minek kell a sensord?
Egyébként meg pipecül hasít a gkrellm
IceWM-mel használom. Hoppá, létezik ez alá olyan időjárásos alk. desktopra?
De lett megint bajságom.
Csináltam egy emerge syc; emerge system; emerge world trióst és valami ilyen lett az eredménye:
login: root
configuration error - unknown item 'FAILLOG_ENAB' (notify administrator)
configuration error - unknown item 'LASTLOG_ENAB' (notify administrator)
és még vagy 5 ilyen hasonló hiba bejelentkezéskor... Mitől lett ez?
A másik, meg a repedt hintalónak sem akar lefordulni a libtool-1.5.20
ezt adja:
PS_CHECK_HEADER
/usr/share/aclocal/path_dps.m4:440: warning: underquoted definition of AC_PATH_DPS_CHECK
/usr/share/aclocal/path_dps.m4:450: warning: underquoted definition of AC_PATH_DPS
/usr/share/aclocal/path_dps.m4:525: warning: underquoted definition of AC_CHECK_DPS_NXAGENT
/usr/share/aclocal/path_dps.m4:558: warning: underquoted definition of AC_PATH_DPSET
/usr/share/aclocal/path_dps.m4:579: warning: underquoted definition of AC_PROG_PSWRAP
/usr/share/aclocal/path_dps.m4:172: file `path_dps.m4' does not exist
!!! ERROR: sys-devel/libtool-1.5.20-r1 failed.
!!! Function src_unpack, Line 126, Exitcode 1
!!! aclocal
!!! If you need support, post the topmost build error, NOT this status message.
Sipi! Asszem neked 1x2x elment magánba is, sorry...
Üdv és köszi,
Roland
[Szerkesztve] -
hroleez
Milyen programmal tudom megcsinálni, azt, hogy az asztali gépem hardverhiba esetén (hőfokok, venti leállás, stb.) jelezzen és normálisan álljon le?
Gép: ABIT NF7-S, 256M, Athlon XP 1500+
Köszi,
Roland -
hroleez
Eredetileg egy külön topicnak indult, de itt kötök ki a kérdésemmel...
Fáj nagyon a lelkem, hogy kedves linuxos gépemre kell XP-t feltenni, de muszály... Vagyunk többen a családban.. És a gyereknek nem lehet nemet mondani számítástechnikában
Szóval a gondom:
(10 éve linuxozom, ezért XP-s tudásom zéróhoz tart....sorry.)
Fel szeretnék telepíteni XP-t a gépemre, amin linux (gentoo) van. Csináltam egy FAT32-es meghajtót, formáztam (linux alatt), majd bootoltam CD-ről XP-t. Elindul a telepítés, de amikor megjelenik a formázás kép, egyszerűen pár mp után lekapcsolja a gépet frown.gif Alaplap Abit NF7-S, 512M, 80G winyó, 2GHz AthlonXP.
Mitől lehet ez? Linux alatt hasít a masina. Semmi hw gond már egy éve.
Üdv és köszi,
Roland
- Döbbenetesen sok energia kell az érkező Nova Lake működéséhez?
- Renault, Dacia topik
- Akciófigyelő: Jelentős kedvezményekkel veheted meg a Xiaomi 17-eket
- Xbox Series X|S
- OLED monitor topic
- LEGO klub
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RTX 5060 Ti 16GB GAMER PC termékbeszámítással
- Apple iPhone 13 Pro 128GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RTX 5050 8GB GAMER PC termékbeszámítással
- Keresünk iPhone 16/16 Plus/16e/16 Pro/16 Pro Max
- BESZÁMÍTÁS! Gigabyte B760M i5 14600KF 32GB DDR4 512GB SSD RTX 3070 8GB Lian LI LANCOOL 207 750W
És az ACPI is!
