mepet
cdm = claymore dual miner
Ezeket tudja segédprogik nélkül:
-tt set target GPU temperature. For example, "-tt 80" means 80C temperature. You can also specify values for every card, for example "-tt 70,80,75".
You can also set static fan speed if you specify negative values, for example "-tt -50" sets 50% fan speed. Specify zero to disable control and hide GPU statistics.
"-tt 1" (default) does not manage fans but shows GPU temperature and fan status every 30 seconds. Specify values 2..5 if it is too often.
Note: for NVIDIA cards only temperature monitoring is supported, temperature management is not supported.
Note: for Linux gpu-pro drivers, miner must have root access to manage fans, otherwise only monitoring will be available.-ttdcr reduce Decred/Siacoin/Lbry/Pascal intensity automatically if GPU temperature is above specified value. For example, "-ttdcr 80" reduces Decred intensity if GPU temperature is above 80C.
You can see current Decred intensity coefficients in detailed statistics ("s" key). So if you set "-dcri 50" but Decred/Siacoin intensity coefficient is 20% it means that GPU currently mines Decred/Siacoin at "-dcri 10".
You can also specify values for every card, for example "-ttdcr 80,85,80". You also should specify non-zero value for "-tt" option to enable this option.
It is a good idea to set "-ttdcr" value higher than "-tt" value by 3-5C.-ttli reduce entire mining intensity (for all coins) automatically if GPU temperature is above specified value. For example, "-ttli 80" reduces mining intensity if GPU temperature is above 80C.
You can see if intensity was reduced in detailed statistics ("s" key).
You can also specify values for every card, for example "-ttli 80,85,80". You also should specify non-zero value for "-tt" option to enable this option.
It is a good idea to set "-ttli" value higher than "-tt" value by 3-5C.-tstop set stop GPU temperature, miner will stop mining if GPU reaches specified temperature. For example, "-tstop 95" means 95C temperature. You can also specify values for every card, for example "-tstop 95,85,90".
This feature is disabled by default ("-tstop 0"). You also should specify non-zero value for "-tt" option to enable this option.
If it turned off wrong card, it will close miner in 30 seconds.
You can also specify negative value to close miner immediately instead of stopping GPU, for example, "-tstop -95" will close miner as soon as any GPU reach 95C temperature.-tstart set start temperature for overheated GPU that was previously stopped with "-tstop" option. For example, "-tstop 95 -tstart 50" disables GPU when it reaches 95C and re-enables it when it reaches 50C.
You can also specify values for every card, for example "-tstart 50,55,50". Note that "-tstart" option value must be less than "-tstop" option value.
This feature is disabled by default ("-tstart 0"). You also should specify non-zero value for "-tt" option to enable this option.-fanmax set maximal fan speed, in percents, for example, "-fanmax 80" will set maximal fans speed to 80%. You can also specify values for every card, for example "-fanmax 50,60,70".
This option works only if miner manages cooling, i.e. when "-tt" option is used to specify target temperature. Default value is "100".
Note: for NVIDIA cards this option is not supported.-fanmin set minimal fan speed, in percents, for example, "-fanmin 50" will set minimal fans speed to 50%. You can also specify values for every card, for example "-fanmin 50,60,70".
This option works only if miner manages cooling, i.e. when "-tt" option is used to specify target temperature. Default value is "0".
Note: for NVIDIA cards this option is not supported. -
mepet
az indító batba írod a cuccokat, ugye?
pl:EthDcrMiner64 -logsmaxsize 80 -epool eu2.nanopool.org:9999 -ewal 0xee505bc03c3099c8503fdbde2fe08fac4bcf0bb6 -eworker melos5 -epsw x -cclock 1280,0,0,1280,0,0,0,0 -mclock 2070,0,0,2092,0,0,0,0 -cvddc 965,0,0,968,0,0,0,0 -mvddc 965,0,0,965,0,0,0,0 -powlim -23,-15,-15,-28,-15,-15,-15,-15
nem ír hibát a cdm induláskor?
Olyan, mintha nem venné be a cdm amit megadsz -
Szóval akkor így kellene kinézzen ?
OverdriveNTool.exe -r1 -p1"gpu1" -p1Profile_0 -r2 -p2"gpu2" -p2Profile_1 -r3 -p3"gpu3" -p3Profile_1 -r4 -p4"gpu4" -p4Profile_1 -r5 -p5"gpu5" -p5Profile_1 -r6 -p6"gpu6" -p6Profile_1
ugye összesen 2 profile-m van overdriveN-ben profile0 az van betöltve a gpu1-re profile1 pedig van betöltve a 2es vga-tól a 6os ig
Ha üzletről van szó légy korrekt :) http://phmegbizhatosag.atw.hu/
Rendben köszönöm a gyors infot. kikapcsoltam és volt gép rr is de ugyan úgy ott van a keresés a folyamatok között csak kisebb lett a mérete 200mb-vel
Illetve van itt még egy dolog, Remote controll-t hogyan oldjam meg? több gép is van/lesz és nem itt ahol én vagyok hanem erre megfelelő helyen, ott nincs se monitor se egér, ezért kellett az automatikus inditas ha gép rr lenne vagy bármi illetve a sok windowsos hülyeség windows defender ami miatt dobalja legalabb is nekem a hash ratet illetve windows update kikapcsolása,
De azt hogy hogyan tudom a gépeket majd monitorozni vagy inkább remote-ni az lenne a fő kérdés Teamviewer-el meglehet oldani ? csak mert ugye ha gép restart van mindig új jelszót add a csatlakozáshoz és azt meg honnan tudnám ha nem vagyok ott ? vagy ha megveszem akkor vannak erre opciók ?
illetve mennyire terheli a gépet? van e esetleg másik program ami jobban ajánlott erre a célre ?Ha üzletről van szó légy korrekt :) http://phmegbizhatosag.atw.hu/
Wackond
Nekem jelenleg egy rx570 -es rig üzemel 6db vga-val a fogyasztás mérő azt mutattja konektorba dugva hogy 850W fogyasztás van 0.16$ az áram , 177eth hash rate, 1000 pascal jön így whattomine azt írja jelenleg 100+ $ profitba vagyok / month
szóval itt elv még többet termelünk mint az áramszámla de már nem sokkal ..Ha üzletről van szó légy korrekt :) http://phmegbizhatosag.atw.hu/
Nem tudom alaplapira dugni mert nincs az alaplapon hdmi kiemnet Gigabyte h110 d3a
viszont ez esetben akkor át kell állítanom a biosban a primary vga adaptert a vga-kra? mert most ugye az integrált alaplapi a primaryHa üzletről van szó légy korrekt :) http://phmegbizhatosag.atw.hu/
m4rc!
Lehet nem fogalmaztam jol. Az a lenyeg, hogy a 6bol par kartya ugy reagal a magasabb orajelre, hogy visszabb esik a hashrate, nem csak a tobbihez kepest, hanem magahoz kepest is. Pl.: 1920-on megy 28at, de 2000en mar visszaeseik 19-re, akar nullara. Gondolom amiatt mert nem birja az adott orajelet
We are analog players in a digital world
Ha az aprót veszem alapul a kártyák alja 80-85K körül van.
Vegyünk egy átlag 90K-s árat, meg a körítést mellé ami ismerete nélkül megint csak saccolni lehet, de kb egy komplett RIG így olyan 600-700k környéke, e felett elég sokáig árulós.
Természetesen mondom, ezek átlagos alkatrészekre lebontva (H81, cerka, 4g, kicsi ssd/hdd, keret, riserek, valami 800 körüli gold táp)Új hardverek számlával, garanciával érd PM.
AAntii
A kártyák 75-80-ért talán elmennek, (de inkább az előbbi) meg xy ezer az apró, attól függ mi van alattuk.
@tom120514: igen, a mérleg másik oldala, hogy bizonyos ár alatt amíg termel az ember járatja, majd elrakja a fiókba és ha aktuális lesz, előveszi megint. Nyilván úgy, hogy a felét nagyjából visszahozta már ezt könnyebb megtenni. Novemberi árak akkor lesznek, ha vagy teljesen befuccsol az egész és a nagyhalak is kiszállnak (100+ kártya), vagy a kisker új árak is a novemberi szintre esnek vissza. Egy bizonyos szint alatt már egymásra licitálni sincs értelme (lefelé), mert ha nem kell, akkor nem fog kelleni 5 ezerrel olcsóbban sem. Persze ettől függetlenül ez fog következni, ilyen a piac és az emberi természet működése.
"Az amatőrnek ihlet, a profinak előleg kell."
Vigilante
Jaja, legalább ennyi pozitívuma van, nekünk bányászoknak. Akik meg befektetésből vették, ne adj isten rövid távra, most téphetik a hajukat.
△ Asrock X570M Pro4 △ AMD Ryzen 9 5950X ~ 4.4GHz - 1.248V +Corsair H115i PRO XT △ EVGA RTX 3090 FTW3 ULTRA GAMING 24GB (1950 MHz/20000MHz) - 0.950V △ G.SKILL 32GB KIT DDR4 3600MHz CL16 - 3600MHz △ Samsung EVO 970 M.2(500GB) +Samsung 980 PRO M.2(1TB) △ Samsung Odyssey G7 C27G75T ívelt 240Hz (27") △
sanzi89
Köszönöm a tippet, elteszem magamnak!
Sajnos a Claymore paraméterek alapján nem vezérli jól a kártyákat. Ez nem tudom minek az oka, nagyon nem is érdekel. A megoldás végül a telepített Windows Update-ek eltávolítása valamint a legújabb beta Afterburner felrakása volt: 4.4.3 Beta 3
Érdekes, hogy hiába töröltem le a frissítéseket, a régi, stabil verziójú 4.4.2 nem működött, kellett a beta szoftver.
Ezen kívül beállítottam a forgalom díjas kapcsolatot, meg 2 hónapig szüneteltettem a Windows frissítéseket, legalább addig legyen nyugtom.
Köszi mindenkinek a segítséget!
"Mindent azért kell tudni mert kérdezik, nem azért mert hasznos."
pimpi001
mekkora memot irtal be hogy megjavult? nekem is hasonlo a problema 6db nvidia -ccminer az awesome minerben, miningpoolhubra. xmrig tol nekem 3kh/s minden share megvan, a ccminer tolna 3,6 kh/s de az osszes share elveszik az eterben........ a virtualis memot feltoltam 20 gigara de semmi javulas. otlet?
tboypimpi#2319 ---Az idő nem vész el csak átalakul XP-vé--- :D
lacos001
Ezt a faszságot....
"Egyetlen bitcoin előállítása bányászattal 1400-1800 dollár értékű elektromos energiát igényel, ami nagyjából egy négytagú németországi család éves energiafogyasztási költségeinek felel meg."
Akárhogy is számolom, ez kb. 1.000€. Be is bacccna, ha ennyibe kerülne az energia nekünk...
Havi 50€ átalányunk van és minden év végén kapunk vissza.
Természetesen az irásom akkor érvényes, ha kizárólag az elektromos energiára értendő....áram
Csodaindex......
- Milyen TV-t vegyek?
- Melyik tápegységet vegyem?
- World of Tanks - MMO
- Wuthering Waves
- Milyen okostelefont vegyek?
- ZIDOO médialejátszók
