NOTEBOOK / NETBOOK / Mac beárazás
Kérés előtt olvasd el az alább található összefoglalót!
gkevin
Szeretnék kérni egy árat!
HP Pavilion DV6 3010 EZ
Microprocessor ........................2.26 GHz Intel Core i3-350M Processor
Microprocessor Cache .............Level 3 cache 3 MB
Memory ................................4 GB DDR3 (2 x 2048 MB)
Memory Max ........................Supports up to 8 GB DDR3 memory
Video Graphics ........................ATI Mobility Radeon HD 5470 Graphics (switchable)
Video Memory .......................up to 2202 MB total graphics memory with 512 MB DDR3 dedicated
Display ................................39.6 cm (15.6") diagonal High-Definition LED HP BrightView Display (1366 x 768)
Hard Drive .................................320 GB SATA Hard Disk Drive 7200 rpm
Multimedia Drive .........................SATA optical drive: LightScribe SuperMulti DVD±R/RW with Double Layer Support
Network Card .........................Integrated 10/100/1000 Gigabit Ethernet LAN
Wireless Connectivity ................Bluetooth wireless networking; 802.11 b/g/n
Sound .................................Altec Lansing speakers
Keyboard .................................Full size island-style keyboard
Pointing Device ..........................HP Clickpad supporting Multi-Touch gestures with On/Off button
PC Card Slots 5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro or xD Picture cards
External Ports
1 VGA port
1 HDMI port
1 stereo headphone-out
1 microphone-in
4 USB 2.0 ports (4th shared with eSATA port)
1 eSATA + USB port; 1 RJ45 ethernet port
Dimensions ............................24.5 cm (L) x 37.8 cm (W) x 3.08 cm (min H) / 3.60 cm (max H)
Weight ..................................2.45 kg
Power .................................90 W AC Power Adapter; 6-cell Lithium-Ion (Li-Ion) batteryKöszönöm!
gkevin
Egy árat szeretnék kérni erre:HP2530P
Akku 5-6 óra. 7 órát ír, de az nem valós (szerintem) 11% az elhasználódás mértéke
Core2 Duo GEN 2 ultra low voltage 2x1.86Ghz@6MB cache
Ram: 2x1Gb = 2GB DDR2 800Mhz Dual-Channel 4GB rammal is kérhető
Vga: INTEL 4500MHD (FullHD filmet visz) Játszani is lehet rajta ésszel.
N- erős WiFi 802.11(a/b/g/n)
Ujjlenyomat-olvasó
FireWire port
Érintőgombok
DVD/RW
LED-es billentyűzetvilágítás
3G Modem(simcard hely)
Memóriakártya olvasó
HDD: SAMSUNG SSD 128 GB uSATA 2 (ÚJ)
Szálcsiszolt aluminium ház és magnézium váz.
12.1" HD(1280x800) matt nagy fényerő AG LED kijelző, tűéles képe van! (Fényérzékelős)
Bill: Magyar
HP 3D DriveGuard
Windows7
EnergySTAR
CORE2vPro(tm)
Webkamera
Gyári HP töltő
Van hozzá dokkoló is + 5000 HUFKöszi
Üdv -
gkevin
Egy hp probook 4320s-re kérnék egy árat.
Paraméterek:
CPU: Intel Core i3 350m 2*2,3Ghz
RAM: 6gb
VGA: Intel HD 512mb
HDD: Ocz Vertex 3 120gb SSD
Akku: 2,5-3óra 100%
Extrák: Multitouchos touchpad, 2mp HD webkamera, kártyaolvasó, ujjlenyomat olvasó!
Sajnos vannak hibái is: oldalain van egy apró esztétikai sérülés, kb 3mm, képeken láthatók. A jobb oldali USB-k sajnos nem működnek, elvileg olcsón javítható, bal oldai 2 hibátlan. Én is így használtam, ezekkel a hibákkal, hétköznapi használatban egyálatlán nem zavaró.
Van még hozzá egy jó kis laptop emelő "bigyót", asztalra letéve így tökéletes! Illetve egy noti tokot, fekete (vagy kifordítva piros) színű. -
gkevin
Hello! Szeretném megtudni mit érhet egy Acer gép: 1 év gari, [link]
Köszi üdv!
gkevin
Sziasztok! Mit érhet egy Toshiba l655 i3 2,27ghz 3gb ram 320hdd intel hd videókártya 2 órás akku 15,6 hd led kijelző
Köszi
gkevin
Mit érhet egy Dell m5010?Proci: amd v120 2,20 GHz
Ram: 4gb
Vga: ATI Radeon HD 4200 512mb
HDD:250 Gb
Bluetooth,Hdmi,esata,kártyaolvasó stb
2év garivalKöszi
Üdv -
gkevin
Sziasztok! Köszönöm az előző beárazást!!!!
Most is lenne egy gépem, de ezt vásárolni szeretném...Mennyit érhet egy törött kijelzős, vinyó nélküli fujitsu siemens amilo la1703?
"mobile amd semprom processor 3200+ 160 ghz. van benne egy 2 gbs meg egy 512es ram"ennyit tudok összesen róla... kérdezzek még valamit, vagy így is tudsz árat mondani?
Köszönöm
gkevin
Hello!
Mennyit ér egy 100%-os, hiba, sérülés és mikro karcementes Asus X5DIJ laptop?
2 év gariból még 1 év van ráJellemzők:
- Pentium Dual-Core 2.2 GHz
- 2 GB RAM
- 250 GB HDD
- DVD RW
- 15,6 collos LED LCD (1366x768)
- Intel Graphics Media Accelerator (GMA) 4500M
- 4db USB 2.0
- WI-FI, LAN
- Webcam
- Memóriakártya-olvasó
- Magyar billentyűzet
- 6 cellás akkumulátorKöszi
gkevin
Erre kérnék egy árat:CPU: Intel Core i7-720QM processzor (6 MB L3 cache 1.60 GHz, Turbo Boost-tal akár 2.80 GHz, 45 W) (8x1600 MHz)
RAM: 8 GB 1333 Mhz
HDD: 500GB (100%-os)
VGA: Nvidea Cuda GT 330 1 Gb dedikált + 2 GB megosztott! Mindenre alkalmas,az új játékok is hibátlanul mennek rajta!
16.9 es LED Brilliant gyönyörü kijelzö HD-s!
Dolby Home Theather hangrendszer
Több ujjas Multi touch Zoom (touch pad)
2 Mpixel wabcam
Wifi b/g/n
Akku: 48,8 W (6-cellás) lítium ion akkumulátor (2-2,5 h)
Aluminium brushed kiadás!100% karcmentes/pixelhiba mentes, garancia nincs rá
Köszi
gkevin
Ha kérhetek gyorsan egy beárazást erre a laptopra, hálás lennék! Megvenni szeretném nem eladni!HP Elitebook 8440p
Intel(R)Core(TM)i7CPU M620 @2.67GHz
4 Gb ram
NVIDIA NVS 3100M
INTEL 80Gb ssd
A gép 2010.06.17-én lett vásárolva garancia,normál:2013.07.21
kiterjesztett:2014.09.01
semmi hibája sincs,14" kijelző 1600/900 led.
A vga 512 mb mert ez irodába lett véve és dokkolóként lett használva szinte vadonatúj karcmentes!pontosabban nem venni hanem cserélni akarják erre:
Acer Aspire 5745G
RAM: 8 GB 1333 Mhz
VGA: Nvidea Cuda GT 330 1 Gb dedikált + 2 GB megosztott! Mindenre alkalmas,az uj játékok is hibátlanul mennek rajta!!
2 Mpixel wabcam
Wifi b/g/n
Akku: 48,8 W (6-cellás) lítium ion akkumulátorCsere szerinted megéri?
Nagyon köszönöm!!
Üdv -
gkevin
Mennyit érhet egy Acer Aspire 5745DG-5464G50Mnks Notebook?
ca. 39,60 cm (15,60 Zoll) Képernyő, CineCrystal Display, LED-Backlight, Widescreen-Format, WXGA-Auflösung (1366x768),
Intel Core i5 Prozessor, Modell 460M, 2,53 GHz Prozessor-Taktfrequenz,
4 GB RAM,
500 GB HDD,
NVIDIA-Grafik GeForce GT425M 1024 MB,
Double-Layer Dual-DVD Brenner (+/-),
Tastatur mit integriertem Nummernblock,
Windows 7 Home Premium, 64 Bit, MS Office Starter 2010, DVD-Abspielsoftware, Brennersoftware, Webcam, Cardreader, LAN + WLAN schwarzNagyon köszönöm!!!
Üdv -
gkevin
erre kérnék egy árat:Acer Aspire 5745G
proci: Intel Core i7-720QM processzor (6 MB L3 cache 1.60 GHz, Turbo Boost-tal akár 2.80 GHz, 45 W) (8x1600 MHz)
RAM: 8 GB 1333 Mhz DDR3
2 Mpixel wabcam
Wifi b/g/n
Akkuja kiváló állapotban (100°%)
Windows7 van rajta, doboz, papírok járnak hozzá
a gép teljesen karc, pixelhiba és sérülés mentesKöszi
gkevin
Hello!
Eladó lenne egy 1,5 évvel ezelőtt vásárolt Asus X52F típusú laptop. Még kb 3 hónap gari van rá az Euronicshez.Adatok:
proci: Intel® Core™ i3 380UM Processor
RAM: 2 GB volt eredetileg, de kapott plusz 1-et, így 3GB DDR3, 1066MHz
HDD: 320GB
kijelző: 15.6" 16:9 HD (1366x768) LED Backlight
VGA: Integrated Intel® GMA HD (~320MB)Köszi üdv
gkevin
Hello!
Mennyit mondanátok erre a laptopra? laptop link
Karc mentes, hibátlan állapotban, akku 100%
Köszi
Üdv
• Az ár nem képezheti vita tárgyát, szabadon eltérhet mindenki le és felfelé!
• A jobb áttekinthetőség érdekében a kész árazásokat OFF-ba tesszük!
• Az árazás szükségszerűen bizonyos mértékig szubjektív.
• Privátban árazás nincs!
• Csak a topik ármesterei árazhatnak!
• Képről nem árazunk!
• OFF hsz.-eket nem kérünk, ha kérdésed van azt privátba várjuk.
• Ha valami kimaradt vagy hiányos, akkor ne írj új hsz-t, az Ármesternek írj pv-ot és majd ő javítja.
• Beárazós topikok listája!
Szoftver adás-vétel szabályozása a Hardveraprón (2017.04.04.)
- PlayStation 3
- Premier előzetesen a Crimson Desert
- Youtube Android alkalmazás alternatívák reklámszűréssel / videók letöltése
- Milyen okostelefont vegyek?
- Vivaldi (böngésző)
- Starfield
- PlayStation 1 / 2
- valakiyt: Az Iobit programok - el kéne engedni
- Samsung Galaxy S25 256GB - Menta - Samsung.hu, Garanciális, Kártyafüggetlen
- Samsung Galaxy A56 5G Awesome Graphite 128GB használt karcmentes 6 hónap garancia
- Apple iPhone 13 128GB,Átlagos,Adatkabel,12 hónap garanciával
- Apple iPhone 13 128GB,Újszerű,Adatkabel,12 hónap garanciával
- Apple iPhone 13 Pro 128GB,Újszerű,Adatkabel,12 hónap garanciával
- ADATA XPG SPECTRIX S40G 4TB M.2 PCIe (AS40G-4TT-C)
- 8 GB-os GeForce RTX 2060 SUPER (OEM HP) - garanciával
- 27% - GIGABYTE MO34WQC2 Karcos OLED Monitor! 3440x1440 / 240hz / 0.03ms / FreeSync!
- 27% - LG UltraFine 27UQ850V-W 4K IPS Monitor! 3840x2160 / 60Hz / FreeSync
- 27% - Corsair Hydro X XD7 RGB black (CX-9040005-WW)Pumpa/Tartály kombó
de szerintem ezzel mindenki így van
Pyttawrx
