Ubuntu Linux Összefoglaló
Hivatalos Ubuntu dokumentáció
lspci
lsusb
s4hu|SyD^
[ 1587.741001] iwlwifi 0000:04:00.0: IML/ROM dump:
[ 1587.741002] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state
[ 1587.741012] iwlwifi 0000:04:00.0: 0x000056CE | IML/ROM data1
[ 1587.741021] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 1587.741027] iwlwifi 0000:04:00.0: Fseq Registers:
[ 1587.741030] iwlwifi 0000:04:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 1587.741034] iwlwifi 0000:04:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 1587.741037] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 1587.741041] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 1587.741044] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 1587.741047] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 1587.741051] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 1587.741054] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 1587.741058] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 1587.741063] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 1587.741069] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 1587.741074] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 1587.741191] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 1587.741195] ieee80211 phy0: Hardware restart was requested
[ 1593.526771] wlan0: deauthenticating from bc:30:d9:2c:4e:dc by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1600.022804] wlan0: authenticate with bc:30:d9:2c:4e:e0
[ 1600.022818] wlan0: Invalid HE elem, Disable HE
[ 1600.022819] wlan0: 80 MHz not supported, disabling VHT
[ 1600.025883] wlan0: send auth to bc:30:d9:2c:4e:e0 (try 1/3)
[ 1600.063176] wlan0: authenticated
[ 1600.068802] wlan0: associate with bc:30:d9:2c:4e:e0 (try 1/3)
[ 1600.076093] wlan0: RX AssocResp from bc:30:d9:2c:4e:e0 (capab=0x1031 status=0 aid=5)
[ 1600.084895] wlan0: associated
[ 1600.155086] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1600.175461] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by bc:30:d9:2c:4e:e0
Jelenleg ez fogad és sikerült működésre bírni a Wifi-t 2,4Ghz-re limitálva. Természetesen az ideális az 5Ghz lenne. De egyelőre ez is jobb. Megint a kérdés, hogy marad-e újraindítás után. -
s4hu|SyD^
Telekom Deutsche Speedport Smart 3 talán. Németben.
Hónapokig semmi baja nem volt, most megint. Megnéztem Win-ben és kikapcsoltam a hibernálást, mert elvileg az is bezavar ha jól tudom, a Fast Startup. Majd csináltam egy Secure Boot ki-be kapcsolást és ment a net. Természetesen újraindítottam, hogy megmarad-e és sajnos nem maradt. Secure Boot-tal nem megy a Wifi alapból tehát mobile hotspot-ot sem tudok.
Szóval jelenleg Secure Boot off, Fast Startup Win-ben off és mégsem megy csak a mobile hotspot-os net. Gyanítom legutóbb a Fast Startup-pal volt bajom. De most ismét nem tudom merre lehet a hiba.
Igazából a legidegesítőbb, hogy fél nap elment arra, hogy csak keresem a megoldást meg diagnosztizálok valamit amihez nem is értek.
s4hu|SyD^
s4hu|SyD^
sudo-val ment csak amúgy.
ITT a link a pastebin-hez, egyébként szinte mind piros sor.
Egyébként amúgy annyit csináltam, hogy arrébb tettem a gépet kb 1 méterrel(távolabb a wifi-től). Hálókábelt kihúztam, mert amúgy sem volt beledugva a router-ba. Valamint lehúztam a nyomtató USB-t, mert az sem kell mivel Wifi-s a nyomtató. És ennyitől behalt a wifi. Volt hasonlóm, akkor meg tudtam csinálni, nem emlékszem rá, hogy hogy. Lehet valami driver-t kell beszereznem megint. -
s4hu|SyD^
Sajnos megint nem tudok Wifi-re csatlakozni és nem hardveres a baj. Win alatt jó. Nincs ötletem, hogy hogy tudnám megcsinálni. Felcsatlakozik aztán szakad is meg.
s4hu|SyD^
Valaki tudja, hogy hogy tudom azt kikapcsolni wifi-nél, hogy ne váltogasson 2,4Ghz és 5Ghz között?
s4hu|SyD^
Olyat, hogy tudok beállítani, hogy a program nézze a frissítéseket?
Rányomok Check update-ra és semmi nem történik. Repot kéne hozzáadni a Software Updater-hez?
Egyáltalán, hogy tudom azt megnézni, ha egy program megpróbál valamit elérni, de az Ubi nem engedi pl.
Még mindig bajom van egy VScode extension-nel, de csak azzal és gondolom hátha tiltja valami, hogy elérjen külső adatokat online. -
s4hu|SyD^
Na megoldottam, azt a kis elválasztót(az 1 MB-t) kellett mozgatni, nem magát a meghajtót. Majd mikor egymás mellett voltak már lehetett is hozzáadni. Minden működik. Közben a node-ot is megoldottam. Hosszas google keresés és olvasgatás lett, de végül teljes purge és újratelepítése megoldotta azt is. Hát nem egyszerű ez a Linux sokszor, de bizonyára nagy plusz kitanulni programozás mellett. Már alapból ez a gondlkodásmód, hogy nekimegyek és már akkor is megoldom valahogy.
s4hu|SyD^
Hogy tudom mozgatni? Mert a move/resize-nál nem látok olyat.
Tudom, hogy nem veszélytelen, de mivel Ubi-t csak programozás tanulásához használom így nem nagyon van semmi rajta, ami nincs Github-on. Egyelőre ezt megcsinálim aztán most a node-al akadt problémám. Hibát ír ki rá. De mivel mindig a hellyel volt gond így gondoltam először megcsinálim azt. Lassan már Linux mágus leszek.
s4hu|SyD^
Oké ehheznem kifejezetten értek. Ez a kép fogad ésnem tudom a 28,83 GB unallocated helyet a sdc3/ext4-hez csatolni. Ha jól olvastam neten akkor az Unallocated-nek a szomszédja kell, hogy legyen az sdc3. Használjam először azt az 1 MB unallocated részt és növeljem azt a 28,83 GB-ra majd adjam hozzá az egészet az sdc3-hoz?
Bocsi a képekért. A Live miatt fotóznom kellett. (net nem megy valamiért...) -
s4hu|SyD^
Kedves hozzáértők. Win11 meghajtóból lecsíptem 30 GB helyet és szeretném a Linux-hoz csatolni. Mi a pontos menete? Ubuntu USB majd live és Gpart? Egyáltalán meglehet csinálni biztonságosan?
s4hu|SyD^
Jó estét!
Olyan gondom lenne, hogy a 30 GB hely tele van, amit az Ubuntu-nak szántam. A rendszert csak programozás tanulásához tanulom és nagyon nem látom át, hogy hol is tudnék helyet takarítani. Ami esetleg gyanús, hogy a Thunderbird lementegette az üzeneteim. Lehetséges, hogy az sok helyet foglal? Valahogy ki tudom őket törölni? -
s4hu|SyD^
Szép jó reggelt!
Teljesen új vagyok Linux fronton és lenne egy problémám, amire nem találtam még megoldást. Feltettem az Xubuntut majd átváltottam sima Ubuntura, már csak a kinézet miatt is és a vas elég alatta valamint csak front-end programozás tanulásához használnám esetleg későbbiekben munkához. Win 11-el dual boot-ban van fent. Eddig semmi gond, mindent megcsináltam.
Egyelőre az egyedüli problémám, hogy a net meg meg szakad. Bár nem mutatja, de a speedtest-en is megáll sokszor, nem folyamatos a letöltés, feltöltés meg van, hogyel sem indul. Weboldalak is vagy betöltenek vagy timeout. Mondanom sem kell, hogy amellett, hogy idegesítő nem kifejezetten jó egy leendő webfejlesztőnek. A hiba nem hardveres lesz. Egy Amazonról vásárolt Ubit PCIE Intel AX200 chippes Wifi kártya van a gépben. Elvileg külön letöltve sikeresen feltettem hozzá a drivert, de semmi javulás.
Valami ötlet?
- Vélemény Ubuntu 20.04 LTS
- Diablo II: Classic és Resurrected
- sziku69: Szólánc.
- OLED monitor topic
- Kés topik
- Milyen program, ami...?
- HDD probléma (nem adatmentés)
- PC Game Pass előfizetés
- Xiaomi Mi 11i 256GB, Kártyafüggetlen, 1 Év Garanciával
- 27% - Samsung S27D360GAU VA Monitor! 100Hz / 1920x1080 / 4ms
- LG 27MR400 - 27" IPS LED - 1920x1080 FHD - 100hz 5ms - AMD FreeSync - Villódzásmentes
- HP Victus Gaming Laptop RTX 4070 / i7-13700H 16GB DDR5 1TB SSD Garancia
- AKCIÓ! KÉSZLETRŐL! Intel Core i5 14600K 64GB 6000MHz RAM 2TB Gen4 SSD RTX 5060 8GB FSP 750W
