Keresés
  • Bakancsok
    válasz vargalex #2049 üzenetére
    Már szinte mindent próbáltam, de mindenre ugyanazt csinálja.
    Ezek a beállítások:
    config transmission
    option enabled '1'
    option config_dir '/mnt/torrents'
    option bind_address_ipv4 '0.0.0.0'
    option bind_address_ipv6 '::'
    option blocklist_enabled 'false'
    option cache_size_mb '2'
    option dht_enabled 'true'
    option download_dir '/mnt/transmission'
    option download_queue_enabled 'true'
    option idle_seeding_limit_enabled 'false'
    option lazy_bitfield_enabled 'true'
    option peer_port '51413'
    option peer_port_random_on_start 'false'
    option peer_socket_tos 'default'
    option pex_enabled 'true'
    option port_forwarding_enabled 'true'
    option queue_stalled_enabled 'true'
    option ratio_limit_enabled 'false'
    option rpc_authentication_required 'false'
    option rpc_bind_address '0.0.0.0'
    option rpc_enabled 'true'
    option rpc_port '9091'
    option rpc_url '/transmission/'
    option rpc_whitelist '127.0.0.1,192.168.1.*'
    option rpc_whitelist_enabled 'true'
    option scrape_paused_torrents_enabled 'true'
    option script_torrent_done_enabled 'false'
    option seed_queue_enabled 'false'
    option speed_limit_down_enabled 'true'
    option speed_limit_up_enabled 'false'
    option start_added_torrents 'true'
    option umask '18'
    option upload_slots_per_torrent '14'
    option utp_enabled 'true'
    option scrape_paused_torrents 'true'
    option watch_dir_enabled 'false'
    option user 'root'
    option speed_limit_down '3000'
    option message_level '0'
    option download_queue_size '50'
    option queue_stalled_minutes '120'
    option alt_speed_enabled 'true'
    option alt_speed_down '200'
    option alt_speed_up '10'
    option incomplete_dir_enabled 'true'
    option incomplete_dir '/mnt/transmission/incomplete'
    option trash_original_torrent_files 'true'
    option lpd_enabled 'true'
    option peer_limit_global '50'
    option preallocation '1'
    option prefetch_enabled '1'
    option rename_partial_files '1'
    option encryption '0'
    option peer_limit_per_torrent '5'
  • Bakancsok
    MR3220 v2-es rooterrel használom a transmissiont, de folyton ezt a hibát dobálja pár perc elteltével. Tudtok erre megoldást??
    Köszönöm!
    Software
    Actions
    Configuration
    Free space: 100% (217.91 GB)
    Download and install package:
    Filter:
    Status
    Installed packages
    Available packages
    Package name Version
    Remove base-files 117-r35050
    Remove blkid 2.21.2-1
    Remove block-mount 0.2.0-9
    Remove btpd 0.16-2
    Remove busybox 1.19.4-5
    Remove chat 2.4.5-8
    Remove comgt 0.32-21
    Remove ddns-scripts 1.0.0-21
    Remove dnsmasq 2.62-2
    Remove dropbear 2011.54-2
    Remove e2fsprogs 1.42.4-1
    Remove firewall 2-55
    Remove glib2 2.26.1-3
    Remove hotplug2 1.0-beta-4
    Remove huaweiaktbbo 1
    Remove iptables 1.4.10-4
    Remove iw 3.6-1
    Remove jshn 2013-01-06-dde64e47cadbd245a99f145869eb400b68cc82e9
    Remove kernel 3.3.8-1-5440da3a2c45184a32da6bba25b8dd2a
    Remove kmod-ath 3.3.8+2012-09-07-3
    Remove kmod-ath9k 3.3.8+2012-09-07-3
    Remove kmod-ath9k-common 3.3.8+2012-09-07-3
    Remove kmod-atm 3.3.8-1
    Remove kmod-cfg80211 3.3.8+2012-09-07-3
    Remove kmod-crypto-aes 3.3.8-1
    Remove kmod-crypto-arc4 3.3.8-1
    Remove kmod-crypto-core 3.3.8-1
    Remove kmod-fs-ext4 3.3.8-1
    Remove kmod-fs-vfat 3.3.8-1
    Remove kmod-gpio-button-hotplug 3.3.8-1
    Remove kmod-ipt-conntrack 3.3.8-1
    Remove kmod-ipt-conntrack-extra 3.3.8-1
    Remove kmod-ipt-core 3.3.8-1
    Remove kmod-ipt-nat 3.3.8-1
    Remove kmod-ipt-nathelper 3.3.8-1
    Remove kmod-leds-gpio 3.3.8-1
    Remove kmod-ledtrig-default-on 3.3.8-1
    Remove kmod-ledtrig-netdev 3.3.8-1
    Remove kmod-ledtrig-timer 3.3.8-1
    Remove kmod-ledtrig-usbdev 3.3.8-1
    Remove kmod-lib-crc-ccitt 3.3.8-1
    Remove kmod-lib-crc16 3.3.8-1
    Remove kmod-loop 3.3.8-1
    Remove kmod-mac80211 3.3.8+2012-09-07-3
    Remove kmod-nls-base 3.3.8-1
    Remove kmod-nls-cp1250 3.3.8-1
    Remove kmod-nls-cp1251 3.3.8-1
    Remove kmod-nls-cp437 3.3.8-1
    Remove kmod-nls-cp775 3.3.8-1
    Remove kmod-nls-cp850 3.3.8-1
    Remove kmod-nls-cp852 3.3.8-1
    Remove kmod-nls-cp866 3.3.8-1
    Remove kmod-nls-iso8859-1 3.3.8-1
    Remove kmod-nls-iso8859-13 3.3.8-1
    Remove kmod-nls-iso8859-15 3.3.8-1
    Remove kmod-nls-iso8859-2 3.3.8-1
    Remove kmod-nls-koi8r 3.3.8-1
    Remove kmod-nls-utf8 3.3.8-1
    Remove kmod-ppp 3.3.8-1
    Remove kmod-pppoe 3.3.8-1
    Remove kmod-pppox 3.3.8-1
    Remove kmod-ramzswap 3.3.8-ar71xx-1+2
    Remove kmod-rfkill 3.3.8-1
    Remove kmod-sched 3.3.8-1
    Remove kmod-sched-connmark 3.3.8-1
    Remove kmod-sched-core 3.3.8-1
    Remove kmod-scsi-core 3.3.8-1
    Remove kmod-scsi-generic 3.3.8-1
    Remove kmod-tun 3.3.8-1
    Remove kmod-usb-acm 3.3.8-1
    Remove kmod-usb-atm 3.3.8-1
    Remove kmod-usb-core 3.3.8-1
    Remove kmod-usb-net 3.3.8-1
    Remove kmod-usb-net-cdc-ether 3.3.8-1
    Remove kmod-usb-net-hso 3.3.8-1
    Remove kmod-usb-net-rndis 3.3.8-1
    Remove kmod-usb-net-sierrawireless 3.3.8-1
    Remove kmod-usb-ohci 3.3.8-1
    Remove kmod-usb-serial 3.3.8-1
    Remove kmod-usb-serial-ark3116 3.3.8-1
    Remove kmod-usb-serial-belkin 3.3.8-1
    Remove kmod-usb-serial-ch341 3.3.8-1
    Remove kmod-usb-serial-cp210x 3.3.8-1
    Remove kmod-usb-serial-cypress-m8 3.3.8-1
    Remove kmod-usb-serial-ftdi 3.3.8-1
    Remove kmod-usb-serial-ipw 3.3.8-1
    Remove kmod-usb-serial-keyspan 3.3.8-1
    Remove kmod-usb-serial-mct 3.3.8-1
    Remove kmod-usb-serial-mos7720 3.3.8-1
    Remove kmod-usb-serial-motorola-phone 3.3.8-1
    Remove kmod-usb-serial-option 3.3.8-1
    Remove kmod-usb-serial-oti6858 3.3.8-1
    Remove kmod-usb-serial-pl2303 3.3.8-1
    Remove kmod-usb-serial-qualcomm 3.3.8-1
    Remove kmod-usb-serial-sierrawireless 3.3.8-1
    Remove kmod-usb-serial-ti-usb 3.3.8-1
    Remove kmod-usb-serial-visor 3.3.8-1
    Remove kmod-usb-serial-wwan 3.3.8-1
    Remove kmod-usb-sierrawireless-directip 3.3.8-10
    Remove kmod-usb-storage 3.3.8-1
    Remove kmod-usb-storage-extras 3.3.8-1
    Remove kmod-usb-uhci 3.3.8-1
    Remove kmod-usb2 3.3.8-1
    Remove kmod-wdt-ath79 3.3.8-1
    Remove libblkid 2.21.2-1
    Remove libblobmsg-json 2013-01-06-dde64e47cadbd245a99f145869eb400b68cc82e9
    Remove libc 0.9.33.2-1
    Remove libcom_err 1.42.4-1
    Remove libcurl 7.23.1-1
    Remove libevent2 2.0.19-1
    Remove libext2fs 1.42.4-1
    Remove libgcc 4.6-linaro-1
    Remove libip4tc 1.4.10-4
    Remove libiwinfo 36
    Remove libiwinfo-lua 36
    Remove libjson 0.9-2
    Remove liblua 5.1.4-8
    Remove libminiupnpc 1.6-1
    Remove libncurses 5.7-5
    Remove libnl-tiny 0.1-3
    Remove libopenssl 1.0.1c-1
    Remove libpthread 0.9.33.2-1
    Remove librpc 0.9.32-rc2-0a2179bbc0844928f2a0ec01dba93d9b5d6d41a7
    Remove librt 0.9.33.2-1
    Remove libubox 2013-01-06-dde64e47cadbd245a99f145869eb400b68cc82e9
    Remove libubus 2012-12-15-bb856ad8a9a1e786494d01e34bbfe2b4d2134021
    Remove libubus-lua 2012-12-15-bb856ad8a9a1e786494d01e34bbfe2b4d2134021
    Remove libuci 2012-03-28.1-1
    Remove libuci-lua 2012-03-28.1-1
    Remove libusb 0.1.12-3
    Remove libuuid 2.21.2-1
    Remove libxtables 1.4.10-4
    Remove lua 5.1.4-8
    Remove luci 0.11+svn9599-1
    Remove luci-app-ddns 0.11+svn9599-1
    Remove luci-app-firewall 0.11+svn9599-1
    Remove luci-app-transmission 0.11+svn9425-1
    Remove luci-i18n-english 0.11+svn9599-1
    Remove luci-lib-core 0.11+svn9599-1
    Remove luci-lib-ipkg 0.11+svn9599-1
    Remove luci-lib-nixio 0.11+svn9599-1
    Remove luci-lib-sys 0.11+svn9599-1
    Remove luci-lib-web 0.11+svn9599-1
    Remove luci-mod-admin-core 0.11+svn9599-1
    Remove luci-mod-admin-full 0.11+svn9599-1
    Remove luci-proto-3g 0.11+svn9599-1
    Remove luci-proto-core 0.11+svn9599-1
    Remove luci-proto-ppp 0.11+svn9599-1
    Remove luci-proto-relay 0.11+svn9599-1
    Remove luci-sgi-cgi 0.11+svn9599-1
    Remove luci-theme-base 0.11+svn9599-1
    Remove luci-theme-bootstrap 0.11+svn9599-1
    Remove luci-theme-openwrt 0.11+svn9599-1
    Remove mc 4.7.5.3-2
    Remove mtd 18.1
    Remove netifd 2012-12-17.1-2eca28705a27ab37ee902308af2c134c64c95e61
    Remove opkg 618-3
    Remove ppp 2.4.5-8
    Remove ppp-mod-pppoe 2.4.5-8
    Remove relayd 2011-10-24-4e8f1fa4ca2b176500362843a9e57ea5abd4b7a3
    Remove swap-utils 2.21.2-1
    Remove swconfig 10
    Remove terminfo 5.7-5
    Remove transmission-cli 2.71-1
    Remove transmission-daemon 2.71-1
    Remove transmission-web 2.71-1
    Remove uboot-envtools 2012.04.01-1
    Remove ubus 2012-12-15-bb856ad8a9a1e786494d01e34bbfe2b4d2134021
    Remove ubusd 2012-12-15-bb856ad8a9a1e786494d01e34bbfe2b4d2134021
    Remove uci 2012-03-28.1-1
    Remove uhttpd 2012-10-30-e57bf6d8bfa465a50eea2c30269acdfe751a46fd
    Remove usb-modeswitch 1.2.3-2
    Remove usb-modeswitch-data 20120120-1
    Remove vsftpd 3.0.2-1
    Remove wpad-mini 20120910-1
    Remove zlib 1.2.7-1
    Powered by LuCI 0.11 Branch (0.11+svn9599) OpenWrt Attitude Adjustment 12.09-rc1 - OpenWrtID
