ASUS routerek
mrmft
92es nalunk az irdoban van, de zartuk, igy home office... 40577nel van a beta7.
58 van itthon, ott siman dirty update-el felment, eddig mukodik rendben minden. Az allapotsav mar az elozo 3.0.0.4.384.9890-es frisitessel valtozott az 58-on. 92-re nem tudok mit mondani, bar mar felmerult az otlet, hogy haza hozom, de igazabol az 58 is mindere eleg.[ Szerkesztve ]
mrmft
Az US support oldalrol tolteheto:
"ASUS RT-AX92U Firmware version 3.0.0.4.386.40451
New features
1. AiMesh 2.0
- System optimization: one click in AiMesh to optimize the topology
- System Ethernet backhaul mode, all nodes will only connect by ethernet, all bands will be released for wireless clients.
- System factory default and reboot.
- Client device reconnect, make the device to offline and online again.
- Client device binding to specific AP.
- Guest WiFi on all Mesh nodes (all node need to upgrade to 3.0.0.4.386 firmware)
- Access nodes USB application.
Connection priority and Ethernet backhaul mode introduction
https://www.asus.com/support/FAQ/1044184
How to setup ASUS AiMesh or ZenWiFi Mesh Ethernet backhaul under different conditions
https://www.asus.com/support/FAQ/1044151/
2. New Family interface in ASUS router App.
ASUS Router App for iOS must greater or equal to iOS v1.0.0.5.75
Android version greater or equal to v1.0.0.5.74
3. The unit of the WiFi time scheduler goes to 1 minute.
4. Support IPSec IKE v1 and IKE v2, and you can use the Windows 10 native VPN client program to connect to the router's IPSec VPN server. The Windows 10 new FAQ is in https://www.asus.com/support/FAQ/1033576
5. 2.4 and 5G on the network map could be configured in the same tab.
6. Captcha for login can be disabled in administration -> system.
7. Printer server port can be disabled on the USB app page.
8. Clients which connect to the guest network can be viewed in the network map -->view list --> interface"[ Szerkesztve ]
iff
Ez van a szerver logban: _check_net_status(): Found active connection on port 22 (SSH) from (itt jön az ip cím). Mint írtam fentebb az sus routernél áll fenn a problémám. Az OMV-t nagyon régóta használom, egyéb okokból maradtam a 4-es verziónál. Eddig az első routerem óta tp-link-em volt, és eddig csak az asus-nál van ez. Eddig legdrágább is.
No.01
Nem vagyok IT guru ezt azert leszogeznem az elejen
Regen amig egy masik szolgaltatonal voltam es ugyszinten sajat routerrel osztottam a netet ott eleg volt a PC ip-je es a port. Jelenleg nemigazan ertem, h mi a kulonbseg a 2 port kozott.
Ha kell egy dedikalt port ami pl az 1234 akkor ezt melyikhez kellene beirnom?
(igazabol probaltam minden opciot, de ugytunik sehogy sem jo) -
No.01
Igen a kapcsolo is zold anelkul nem is tudtam volna hozzaadni az uj profilt.
Egyaltalan mind2 port szukseges nekem? Csak azert mert a belso port meg van csillagozva, h opcionalis.Ettol fuggetlenul ha mind2-t megadom vagy csak a kulsot vagy csak a belsot akkor sem mukodik. Mivel ahogy irtam ez egy mesh-es router nem lehet, h az zavar be esetleg?
Jim74
Köszi .
Még megvárom Mrmft fórumtárs válaszát AX58U ügyben.
Remélem javították a korábban említett hibát (AiMesh node csatlakoztatása esetén nem tudom a PPPOE kapcsolatot kapcsolni, illetve a hálózati korlátozást, valamint a port forwardolások is csak azután érvényesülnek, ha bontom az AiMesh kapcoslatot). -
gahor72
Csak arra frissítek,amit a router maga feldob.Semmi rc,semmi fejlesztői varázslat.
Használni akarom nem kisérletezni vele,abból már kinőttem.DE,van egy kérdésem: smart connect-et használok az első pillanat óta.
Először csak kísérlet képpen,de mivel tök jó nem változtattam.A smart connect lényege,h a router dönti el,h a 2,4 vagy az 5Ghz-et használja melyik csatornán ugye.
De,ha bekapcsolom valamely eszközre a 2,4Ghz sávra a vezeték nélküli mac szűrőt,akkor csatlakozni ugyan tud a routerhez/nethez,de a smartconnect-en belül akor is van sáv váltogtás vagy marad a 2,4Ghz-en?üdv
Hát igen. Ezért írtam, hogy hosszadalmas és macerás a dolog.
Nyilván lehet, hogy valakinek megér ennyit a dolog, de az esetek többségében sokkal egyszerűbb átvezetni az új hivatkozást. Egy otthoni routeren azért nem élet-/ésszerű túl széles körben elérhető megosztást futtatni.
MaCS
Fán nem lehet motorozni, motoron viszont lehet fázni!
kiSSrac
Én is úgy gondoltam hogy elég lesz amikor beköttettem a Gigabit netet.
Ac66u B1 van, Merlin szoftverrel
Hosszabb távra terveznék, ezért is gondoltam hogy a 2 mag helyett 4 magos legyen...
Egyébként nagyon szépen köszönöm a felvetést és a tanácsokat is (mielőtt elfelejteném megtenni ) -
ricogsm
Rendben megnézem! Köszi
Itt egy log lista .. 11h előtt volt ez a leszakadás.Megnéztem 36 oson van és 80Hz-n.
Van mikor router reboot után nehezen tér vissza.
Percekig kell várni az újra csatlakozásra akár a 192.168.1.1 re is.Wed Nov 25 10:51:30 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed IEEE 802.11: associated (aid 2)
Wed Nov 25 10:51:30 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 58:00:e3:72:68:ed
Wed Nov 25 10:51:30 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed RADIUS: starting accounting session FDC3A33A3FF5DC40
Wed Nov 25 10:51:30 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed WPA: pairwise key handshake completed (RSN)
Wed Nov 25 10:51:30 2020 daemon.info dnsmasq-dhcp[3438]: DHCPREQUEST(br-lan) 192.168.1.150 58:00:e3:72:68:ed
Wed Nov 25 10:51:30 2020 daemon.info dnsmasq-dhcp[3438]: DHCPACK(br-lan) 192.168.1.150 58:00:e3:72:68:ed DESKTOP-6JO040R
Wed Nov 25 10:51:32 2020 daemon.info dnsmasq-dhcp[3438]: DHCPREQUEST(br-lan) 192.168.1.150 58:00:e3:72:68:ed
Wed Nov 25 10:51:32 2020 daemon.info dnsmasq-dhcp[3438]: DHCPACK(br-lan) 192.168.1.150 58:00:e3:72:68:ed DESKTOP-6JO040R
Wed Nov 25 10:51:44 2020 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 58:00:e3:72:68:ed
Wed Nov 25 10:51:44 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed IEEE 802.11: disassociated
Wed Nov 25 10:52:03 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed IEEE 802.11: authenticated
Wed Nov 25 10:52:03 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed IEEE 802.11: associated (aid 2)
Wed Nov 25 10:52:03 2020 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 58:00:e3:72:68:ed
Wed Nov 25 10:52:03 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed RADIUS: starting accounting session 9797E828CB5237A5
Wed Nov 25 10:52:03 2020 daemon.info hostapd: wlan1: STA 58:00:e3:72:68:ed WPA: pairwise key handshake completed (RSN)
Wed Nov 25 10:52:03 2020 daemon.info dnsmasq-dhcp[3438]: DHCPREQUEST(br-lan) 192.168.1.150 58:00:e3:72:68:ed
Wed Nov 25 10:52:03 2020 daemon.info dnsmasq-dhcp[3438]: DHCPACK(br-lan) 192.168.1.150 58:00:e3:72:68:ed DESKTOP-6JO040R
Wed Nov 25 11:01:30 2020 daemon.err procd: unable to find /sbin/ujail: No such file or directory (-1)
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: read /etc/hosts - 4 addresses
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: read /tmp/hosts/odhcpd - 2 addresses
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq-dhcp[3438]: read /etc/ethers - 0 addresses
Wed Nov 25 11:01:30 2020 daemon.err dnsmasq[3438]: cannot read /tmp/adb_list.overall: No such file or directory
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain test
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain onion
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain localhost
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain invalid
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain bind
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using local addresses only for domain lan
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using nameserver 193.110.56.8#53
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using nameserver 193.110.57.4#53
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using nameserver 2a01:368:a::1#53
Wed Nov 25 11:01:30 2020 daemon.info dnsmasq[3438]: using nameserver 2a01:368:a::2#53[ Szerkesztve ]
MSI GE76 RAIDER i7-11800H RTX 3080 8GB 155W TGP FHD 300Hz
Obyboy
Köszi, ez lehet az én problémámra is megoldás lesz (#7644Obyboy) automatikusan a 13-ason volt a 2,4GHz vezérlő csatornája (lehet ezt nem szerette az eszköz) így manuálisan áttettem 6-os csatornára.
UI:
Csatorna sávszélességnél mi az ajánlott beállítás?
Jelenleg nekem 2,4GHz: 20/40 és 5GHz: 20/40/80 jó ez így vagy érdemesebb mindkét frekvencián egy egy adott értéket kiválasztani?[ Szerkesztve ]
"Ha a kacsa nem tud úszni, nem a víz a hülye."
Neoka
Köszi a segítséget.
Közben találtam egy ilyet.
Próba csereszenye, írtam nekik.[DDNS] Hogyan törölhető a regisztrált DDNS név a korábbi routerről?
Ha korábbi routerén már regisztrált egy ASUS DDNS-t (Dinamikus tartománynévrendszer), és az új routerrel is ugyanezt a DDNS nevet szeretné használni, kérjük, adja meg az alábbi információkat a helyi ASUS ügyfélszolgálatán:
A korábbi router sorozatszáma. (A router fekete címkéjén található) A korábbi router MAC-címe. (A router fekete címkéjén található) A DDNS név
Az ASUS műszaki központokban akár több napot is igénybe vehet a regisztrált DDNS név eltávolítása. Ön ezután regisztrálhatja a tartománynevet az új routeren.
Az ASUS ügyfélszolgálat információi: https://www.asus.com/hu/support/callus -
BITBOYS
Esetleg ebben a kategóriában lenne ajánlatod? Lehet drágább is, de ez is számít..
Intruder2k5
Első körben jó ajánlat, de ha van erősebb akkor inkább azt venném.Az ellenség? Ő is kötelességtudó volt, akár te. Vajon mi volt a neve? Honnét jött? Valóban gonoszság ült a szívében? Miféle hazugságok sodorták ily távol az otthonától? Maradt volna inkább odahaza...,békében. A háború mindnyájunkkal végez.
Krilehor
2.4 GHz:
Csatorna sávszélesség: 20/40MHz
Vezérlő csatorna Auto (Jelenlegi vezérlőcsatorna: 6)
Auto select channel including channel 12, 13: KI
5 GHz -1
Csatorna sávszélesség: 20/40/80MHz
Vezérlő csatorna Auto (Jelenlegi vezérlőcsatorna: 36)
Csatorna automatikus kiválasztása (pl. DFS-csatornák): KI
5 GHz -2
Csatorna sávszélesség: 20/40/80MHz (160 MHz engedélyezése KI)
Vezérlő csatorna Auto (Jelenlegi vezérlőcsatorna: 100)
Csatorna automatikus kiválasztása (pl. DFS-csatornák): KI -
Zebu
Jelenleg a legújabb van rajta, ahogy bedugtam azonnal frissített egyet. Merlint még nem próbáltam. De érdekes, mert 2 napig semmi, ma meg 3x is megakadt a film lejátszás az X96-on, mert az is Wifin megy....
Most azt próbáltam meg, hogy átállítottam az 5Ghz-et 100-ról 48-ra, hátha az bolt a baj. Mivel Imesh van még dob hasonló üzeneteket a LOG-ba, de ott jön azonnal egy reassociation.
Most azt nézem, hogy fent dobál lefele pár klienst ami 5Ghz-en van kicsit távolabb a routertől, de nem teszi át a 2.4-re. Lehet a Smart Connect Rule-okat is be kellene állitani
Zebu
Van itthon egy RT-1300G plus V3 (tegnap vetem 15ért az Euronicsban, annyit remélem megért). Most azt izzítottam be egy EA-AC87 AP-vel az emeleten. Ideiglenesnek jó lesz, most kicsit elbizonytalanodtam az egész fejlesztés kérdésben...
Korábban volt R7000, E8500, de kivettem őket és gondoltam használom a szolgáltató Sagem holmiját. Nem vált be Még az is lehet, hogy ezt leviszem a szülőkhöz (RT-1300G) és visszahozom az R7000-et...
Zebu
Hehe az király. Amúgy a linksys nagy csalódás volt. Az is totálisan instabil volt... reboot, disconnect, minden. Plusz nem tudtam mindent konfigolni a web felületről, van ami csak az appból ment.
tetszik ez az asus ecosystem. Nagyon örültem ahogy belőttem az aimesht, de vicces, hogy pont a node ment szépen gond nélkül, és a fő masina térdelt le 2 nap után.
mondjuk biztos megoldják majd, csak idő kérdése.
KovA
Nálam is ez van ...
Hiába állítom be, hogy Lets encrypt-es a Cert , a Status Authorizing -ban marad ...
Pedig elvileg megcsinálja a cert-et le is tölti (ott van a /jffs/.le/-domain- dirben) de valahogy nem alkalmazza es hiába indítom újra a httpd service-t a letsencrypt service-t vagy az egész router nem változik semmi.
A logban meg ugyanazt írja amit nálad is.
AX92U egyébként ..[ Szerkesztve ]
https://kova.hu/konfig
KovA
Igen olvastam én is ...
Ellenben lehet megoldottam ideiglenesen (amig a cert nem jár le) ..
Leszedtem a fullchain.pem és a <sajat.domain.név>.key file-okat a /jffs/.le/<sajat.domain.név> dirból ...
aztán visszatöltöttem a routerre a : WAN - DDNS - "Import own certificate" options alól ..
A <sajat.domain.név>.key file a "Private Key" -hez a fullchain.pem file meg a "SSL Certificate"-hez ..
Igy van trusted kapcsolat kívülről. igaz nincs ott az ikon de az nem szamit ...https://kova.hu/konfig
- Miért vezet mindenki úgy, mint egy állat?
- Elektromos autók - motorok
- Vezetékes FÜLhallgatók
- DIGI internet
- Megpróbálják a spanyolok: megvédenék a gyerekeket a közösségi médiától
- USB to S/PDif konverter a modern RIAA, elektroncsövekkel
- (Újra)indítjuk a PH! YouTube-csatornáját
- Suzuki Swift 2005 1.3 GLX CD AC - AndroidAuto & CarPlay
- Bomba ár! HP Elite X2 1011 G1 - m5 I 8GB I 256GB SSD I 11,6" FHD Touch I CAM I W10 I Gari
- Bomba ár! Lenovo ThinkPad T490 - i5-8GEN I 8GB I 256GB SSD I 14" FHD I Cam I W10 I Garancia!
- 8db GeForce RTX 3090 Egyben
- VAST AI - VAST AI - VAST AI - GeForce RTX 3090
