dannynet
www.ati.com
Kijött az új driver, lehet tesztelni
Fixed in this driver:
3DMark2001: A black screen is no longer displayed when launching 3DMark2001 after launching Aquamark3, when the CATALYST™ CONTROL CENTER is installed. Topic number 737-1140
Code Creatures: Running the benchmark under Windows XP SP2 with an ATI RADEON™ 9250 installed, and the desktop display set to either 1600x1200, 1280x1024, or 1024x768 no longer results in the ground textures appearing corrupted. Topic number 737-10108
Pacific Fighters: Playing the game after playing any track for a short period of time and having the landscape detail set to perfect no longer results in the clouds becoming blocking when flying. Topic number 737-209
Thief Deadly Shadows: Setting the desktop display to 1024x768 32bpp and setting the Texture Preference to High Performance in the control panel no longer results in corruption being seen at the end of the introduction movie. Topic number 737-10109
Attempting to apply a higher refresh rate to a non-DDC monitor no longer results in the refresh rate reverting to 60hz. Topic number 737-10101
Accessing the Problem Report Wizard option from the ATI icon in the system tray no longer results in Problem Report Wizard not being translated in the supported localized languages. Topic number 737-341
Entering the Video option found in the Graphic Setting tab of the CATALYST™ CONTROL CENTER no longer results in the side scroll bar being missing for the secondary display device connected to an ATI RADEON™ 9800 series under Windows XP. Topic number 737-347
The Welcome tab found in the CATALYST™ CONTROL CENTER is now completely localized for the Japanese version of Windows XP, or 2000. Topic number 737-351
Using the CATALYST™ CONTROL CENTER to access the Display Manager no longer results in corruption being seen on top of menu text in the Dutch, French, Spanish, and Portuguese versions of Windows XP. Topic number 737-353
The TV formats now corresponds to the country selected in the TV properties. Topic number 737-1438
Having a CRT and TV connected to the ATI RADEON™ X850 series no longer results in the TV image quality page not being grayed out when enable video mode is enabled. Topic number 737-1439
Launching the Hotkey Manager found in the CATALYST™ CONTROL CENTER no longer results in the Hotkey Manager window not closing when hitting the ESC key. Topic number 737-10097
Creating a profile for clone or stretch mode and attempting to change to that mode from an extended desktop mode, no longer results in the task failing to complete. Topic number 737-10098
The Windows desktop and Full-screen video options are no longer missing when clicking the back button found in the Video Wizard of the CATALYST™ CONTROL CENTER. Topic number 737-10098
The CATALYST™ CONTROL CENTER tool bar now displays correctly after applying a new skin and restarting the CATALYST™ CONTROL CENTER. Topic number737-10098
Defining a custom view in the CATALYST™ CONTROL CENTER by deselecting the graphic adapter and applying the changes, no longer results in the Advanced view taking on the properties of the defined custom view. Topic number 737-10102
The font size used in the CATALYST™ CONTROL CENTER for the Quicksilver and Steelblue skins have been readjusted in order to be seen clearer. Topic number 737-10103
Enabling Temporal AA no longer results in a noticeable flicker on the display device. Topic number 737-10103
[Szerkesztve]
- Xbox Series X|S
- Apple MacBook
- Meghozta az első, memórapánikból eredő áremelését az NVIDIA
- PlayStation 3
- OLED monitor topic
- Google Home/Nest
- Mégis meglepi egy új GeForce-szal a rajongókat az NVIDIA?
- MWC 2026: Megnéztük a Lenovo Idea Tab Pro Gen 2-t
- Dell Latitude 7420 Core i7-1185 G7, 16GB RAM, SSD, jó akku, számla, 6 hó gar, szép állapot
- Apple iPhone 13 Pro 128GB,Átlagos,Dobozaval,12 hónap garanciával
- HIBÁTLAN iPhone 15 Pro 128GB Blue Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS4658, 90% AKKSI
- iPhone 17 White 256 GB - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok - Számlás
