VIBO
tsao
nahh sikerált szerválni egy p5q-e --t
kéne egy kis hellp
ilyen beállítások mellett prime alatt blend test egy perc alatt hibázik
vmi 5let?e8500
mushkin 2x2 1066JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 8.0
FSB Frequency: 500
PCI-E Frequency: 100
FSB Strap to North Bridge: AUTO
DRAM Frequency: 1000 (BIOS says DDR2-1102)
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: MANUAL
1st Information : 5-5-5-18-11-36-6-11
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 18
RAS# to RAS# Delay : 11
Row Refresh Cycle Time: AUTO (for this RAM is 36)
Write Recovery Time: 6
Read to Precharge Time: 11
2nd Information : 11-5-5-4-5-5-6
READ to WRITE Delay (S/D): 11
Write to Read Delay (S): 5
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): 5
WRITE to WRITE Delay (D): AUTO
3rd Information : 14-13-1-5-5
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO (I think it is PL-13 at this clock freq)
CPU Voltage: 1.25
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.66
FSB Termination Voltage: 1.30
DRAM Voltage: 2.10
NB Voltage: 1.4
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Delay 400ps
NB Clock Skew : Delay 200ps
CPU Margin Enhancement: Optimized
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled -
VIBO
tsaohal
kérdésem hogy adott 2x2 mushkin ram 1066 os
per pill 9,5x453 on stabil a procc (small fft)
ramok 543-on
de blend testen erroros a tema
ebből gonolom hogy a memo a cink
kérdésemhogy sztetek mennyi max feszt adhatok a ramoknak?
2,1 a gyári érték
és ha elérem a max feszt akkor az időzitéseken milyen szisztéma szerint változtassak?
VIBO
mijen biosbeállítást javaslatok ram tyunnghoz
vmiért 500fsb dölé nem enged adhatok bármekkora feszt
ja meg vki eemongya röviden érthetően mi is ez az időzités?
VIBO
sztem adhacc neki biosbol kb 2.2-2.25v-ot is.ezeknek birniuk kell.
más....
vizsont az én kérdésem hozzátok hogy:
4gb ramnál kell-e vmi extra beállítás hogy kezelje a vista vagy alapbol keni vágja a témát?
az időzítéseknél van vmi szabály ami szerint változtatjuk?
vagy mondjuk most van 55515 és ezt szeretném csökkenteni de a 44412őt nem viszi akkor lehet mondjuk 44513 vagy ilyesmi?fesz ügyileg meddig lehet elmenni biosbol olyan ramnál ahol alapban 2.15V-2.25V fesz van 44412nél 800mhzen?
konkrétan exceleramrol van szo 2x2 gb EX-DDR2 PC6400...
VIBO
Martin2004
#4070
de akkor nem indul a rencer már.
ááá
2.3 alatt 430as fsb vel nem megy
VIBO
ollo
4x1 gb ddr2 800 kingmax ramnak mennyi fesz kell sztetek?
az normális hogy niosban adok neki 2.3v ot?
- Ryzen 7 5800X + WIFI-s GIGABYTE lap azonnal vihető
- ÁRGARANCIA!Épített KomPhone Ryzen 5 5600X 16/32/64GB RAM RX 9060 XT 8GB GAMER PC termékbeszámítással
- ÚRIS10!!! RAMÁRON! LEGION 5 i7-13650HX 32GB RAM 1000GB SSD RTX 5070 8GB
- iPhone 14 256GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS4422
- Apple iPhone 12 128GB,Átlagos,Adatkabel,12 hónap garanciával
