HZoli87
Malwarebytes Anti-Malware 2.0.3 Beta 1
New Features:
• Scans may now be set to run as lower priority processes to improve multi-tasking under Advanced Settings
• Added support for keyboard navigation of user interface
• Added support for JAWS and Windows Narrator screenreadersImprovements:
• Malwarebytes Chameleon enhanced to be more effective against active malware infections in getting Malwarebytes Anti-Malware running
• Notification for outdated databases now configured to 7 days by default rather than 1 per user feedback
• All scans with Malwarebytes Anti-Malware now create an entry in protection logs
• Failed update checks are now logged in protection logs
• Updating Malwarebytes Anti-Malware should now function even when the Scan tab is awaiting action from the user
• Support for scanning encrypted drives improved when rootkit scanning is enabled
• Upgrading to new versions of Malwarebytes Anti-Malware should no longer prompt for a system restartIssues Fixed:
• Google Chrome users should no longer experience Malwarebytes Anti-Malware getting stuck or hanging during heuristics scans with Malwarebytes Anti-Malware
• Scans should no longer hang during filesystem objects scan on some systems
• Several crashes in Malwarebytes Anti-Malware fixed
• Runtime errors during installation or upgrade of Malwarebytes Anti-Malware should no longer occur
• Rootkit scanning should no longer flag sectors on non-system volumes as forged when those volumes are encrypted
• Rootkit scanning should now work properly on Bitlocker encrypted drives
• Scanning TruCrypt encrypted system volumes with rootkit scanning disabled no longer results in the filesystem not being scanned
• Issue with repairing rootkit infected drivers on Windows 8 and Windows 8.1 fixed
• BSOD when using Driver Verifier software on a system running Malwarebytes Anti-Malware fixed
• BSOD when using Boxcryptor software fixed
• BSOD when using Malwarebytes Chameleon or self-protection in Malwarebytes Anti-Malware under certain conditions fixed
• Malwarebytes Anti-Malware should no longer crash when using the "Copy to Clipboard" function under certain circumstances
• Dashboard banner text should now reflect language changes in Malwarebytes Anti-Malware instantly
• Several issues with tray notifications fixed
• Display problems with some languages fixed
• Malware Exclusions and Web Exclusions should no longer display duplicate entries following database updates
• Occasional crash of MBAMService when upgrading from version 1.75 of Malwarebytes Anti-Malware should no longer occur
• Several issues with the right-click "Scan with Malwarebytes Anti-Malware” function fixed
• Several problems with access policies fixed
• Several UI performance issues fixed
• Several UI and user experience enhancements implemented
• More than one Malwarebytes Anti-Malware tray icon should no longer be displayed on system start under some circumstances
• Issue with Malicious Website Protection not enabling after install under some circumstances on Windows Vista fixed
• Minor display issues with tables within the UI fixed -
HZoli87
HZoli87
Nem a licenced eredetiségét kérdőjeleztem meg, csak azt nem értettem, hogy minek aktiválod be mindenképpen a programot, ha kapásból letiltod az így nyert plusz funkciókat. Szerintem nem sok értelme van.
Pár éve egyébkét én is megvásároltam a programot, de csak az ingyenes verzióját használom. Pár hetente lefuttatok egy gyors keresést.
HZoli87
Jövőhéten valószínű lefrissül az új verzióra, hivatalos fórumán ezt írták. Mondjuk azt nem értem, minek kell a Pro / Premium verzió neked, ha mindenképpen kikapcsolod a valósidejű védelmét. Tökéletesen ellátja az ingyenes verzió is azt, amire te használod (4-6 hetente teljes ellenőrzés). De lényeg, hogy megoldódott a gondod.
HZoli87
Aki Lifetime licencet szeretne még vásárolni, az jobb ha siet.
HZoli87
HZoli87
blattida
#290
Az alap Threat Scan normálisan lefut nálam is, körülbelül 3-4 perc alatt végez (korábbi 1 perc helyett). Akkor dobta nálam a kék halált, amikor egy Custom Scan-t indítottam, csak a pendrive-ra. De ott sem egyből, hanem 1 perc elteltével. Ingyenes verzióval tapasztaltam ezt, bár régen megvásároltam, de nem érzem a késztetést a Pro / Premium verzió használatára.
HZoli87
HZoli87
< CyberBob >
#260
Ezt a kettőt szokták még használni, én még egyiket sem próbáltam, nincs szükségem rá. Mind a kettő ingyenes, BD jobb szerintem.
HZoli87
< CyberBob >
#258
Természetesen. Gondolom az utóbbi esetben nem az adott oldallal van gondja, hanem maximum a beágyazott tartalom egy részével. Itt a PH-án is szokott blokkolni egy-két IP-ét, vagyis amikor használtam a Pro verziót, nem egyszer dobott fel értesítést róla.
HZoli87
< CyberBob >
#256
Beépített IP filtert tartalmaz (böngésző független), blokkol is fűt-fát. Szerintem Comodo mellett is elmegy, de érdemes egymást felvenni a kivételek közé. Comodo topikban biztos van olyan fórumozó, aki ezt a párost használja, szerintem ott is érdemes megkérdezned.
HZoli87
Új, stabil verzió!
Malwarebytes Anti-Malware 1.75.0.1300
New Features:
• Added ability to scan within archives -
HZoli87
Malwarebytes Anti-Malware 1.75 Beta
New Features: Added ability to scan within archives
Johnny Cage
Én még nem találkoztam ilyen problémával.
HZoli87
Időközben megjelent a végleges verzió is.
Malwarebytes Anti-Malware 1.70 (Released December 27, 2012)
New Features:
1. New program logo and icons
2. Heuristics for 0-day exploit detection now implemented in protection module for PRO version
3. Threats detected by the protection module are now quarantined automatically by default
4. Malwarebytes Anti-Malware now shows Windows 8 START screen notifications
5. Malwarebytes Anti-Malware now identified in scan logs, registry and About tab
6. More Tools tab enhanced with tons of new content and more to come in the future
7. Option to allow a threat to run temporarily (Allow Temporarily) added to filesystem protection prompts
8. Option to add a detected item to the Ignore List (Allow Always) added to filesystem protection promptsImprovements:
1. Heuristics for detecting new and unknown threats improved
2. Scanner efficiency improved
3. Microsoft Windows 8 and Internet Explorer 10 now identified correctly in scan logs
4. Help file updated to include information on new features
5. Better compatibility with many other security products in realtimeIssues Fixed:
1. Minor issue with password creation from CLI fixed
HZoli87
#239
Fent van, az ingyenes verziója (megvettem, de nem kell a PRO). Teljesen kikészített a webszűrője, itt a PH-n is rendszeresen dobta fel az ablakot (tudom, kivételek közé lehet adni). Hetente gyors (1 perc) vagy teljes keresést (12 perc) lefuttatok, de sosem talál semmit (egyébkén meg is lepődnék az ellenkezőjén).
HZoli87
Új termék!
HZoli87
Köszi, kis pontosítás.
Malwarebytes Anti-Malware 1.65.1.1000
Issues Fixed:
• MBAMService start type now set correctly to Automatic on all systems
• Fixed a bug which did not start protection module with Windows on certain systems
• Fixed a bug which completed scans prematurely on certain systems -
HZoli87
Malwarebytes Anti-Malware 1.65.1 beta
Issues Fixed:
HZoli87
Most látom, hogy a másik topikban már volt linkelve.
Malwarebytes Anti-Malware 1.65 Beta
New Features:
• Future versions will be able to upgrade without requiring a reboot after installation
• Protection module now controllable for the entire machine instead of being limited to individual user accounts
• Filesystem Blocking and Website Blocking can be enabled or disabled separately via the Protection tab
• Protection logs now show when malicious file execution blocking is enabled or disabled
• Realtime protection may now be cleanly terminated via the 'Exit' option in the tray without leaving any running processes
• Japanese language support addedImprovements:
• Malwarebytes Chameleon enhanced to be even more effective against the latest threats
• Realtime protection now starts much faster on Windows Vista and Windows 7
• Eliminated performance issues caused by database updates and Ignore List manipulation on Windows Vista and Windows 7
• Pop-ups for threats detected by realtime protection can not be minimizedIssues Fixed:
• Saving logs to custom locations after scans now works correctly
• Context menu setting is now honored correctly after performing a program upgrade
• Users who have previously completed the trial will not be prompted to start the trial upon upgrade or reinstallation
• Dates and times of items listed in the Quarantine are now displayed correctly -
HZoli87
Időközben megjelent a stabil ágon.
Malwarebytes Anti-Malware 1.62.0.1300
New Features:
• New advanced program updater improves upgrade speed and reduces needed bandwidth
Improvements:
• Enhanced Chameleon (v1.62) technologies to handle the latest threats
• Simplified Malwarebytes Anti-Malware PRO trial option in the installer
• Installation wizard now includes more information and guidance
• Streamlined and optimized database update module
• Updated System Requirements
• Logs enhanced to show drives and paths scannedIssues Fixed:
• Fixed bug with scheduled scans
• Korean language now displayed correctly in language drop down menu -
HZoli87
Mr.Mercury
#191
Nincs (PRO verziót), elég az ingyenes verziója, amivel havonta lefuttatsz egy teljes keresést.
HZoli87
Mr.Mercury
#189
A kivételek listájához fájlokat/mappákat/meghajtókat és IP címeket lehet hozzáadni. Te szépen kizártad a torrent klienst, mint fájlt a kártevő/valósidejű ellenőrzés alól, de a hálózati forgalmát továbbra is ellenőrzi az MBAM.
Egyik megoldás, amit előttem ajánlottak, hogy kikapcsolod a rosszindulatú webhely blokkolást vagy a felugró ablakokban lévő IP címeket hozzáadod a kivételekhez. Mind a kettő gyengíti a védelmet.
HZoli87
Malwarebytes Anti-Malware 1.62 Beta
New Features:
• New advanced program updater improves upgrade speed and reduces needed bandwidthImprovements:
HZoli87
HZoli87
Megjelent: Malwarebytes Anti-Malware 1.61 (Released April 9th, 2012)
Improvements:
1. Up to 25% faster Quick scans for 64-bit operating systems.
2. Chameleon usability enhancements.
3. Enhanced reliability of program updates with additional security checks.
4. Password command line enhancements (paid version only).Issues Fixed:
1. Scheduled scan logs now include accurate protection status.
2. Context menu 'Scan with Malwarebytes Anti-Malware' now displays in selected language. -
HZoli87
Nem aprózza el a memóriahasználatot.
KÉP
Átlagban 30-50 körül szokott alakulni, most valamiért több. -
HZoli87
Fire/SOUL/CD
#159
Elvileg a magyar az alapértelmezett nálam, bár nekem ilyen multis telepítőm van a géphez (~20 nyelv) és a telepítés legelején kell kiválaszthatom, hogy milyen nyelven szeretném telepíteni a rendszert.
Majd lepucolom a gépről (MBAM) és újratelepítem. Ha utána is angol marad akkor üsse kő úgy marad.
HZoli87
Nálam most csak az ingyenes verzió fut, így manuálisan töltötte le az új verziót.
Annyit viszont észrevettem, hogy a jobb gombos környezeti menüben angolul kommunikál velem (Scan with Malwarebytes' Anti-Malware), hiába van magyarra állítva a nyelv. Másnál is hasonló a helyzet?
Azt már meg se említem, hogy részben elhagyták a aposztróf használatát, vagyis az asztalra létrehozott parancsikonja már nem tartalmazza, de elég csak elolvasni a fent írt pár mondatomat, ahol meg igen. Jó lenne eldönteniük, hogy most megtartják vagy nem ...
HZoli87
#136
Igen, a bétát használom. Nyílt, csak egy ingyenes regisztráció szükséges a hivatalos fórumon.
HZoli87
Egyik újdonság: MBAM-Chameleon -> KÉP
HZoli87
Malwarebytes Anti-Malware 1.60.0.1400 Beta - Link
New Features:
• Malwarebytes Chameleon technology gets Malwarebytes Anti-Malware running even when blocked by infection.
• Incremental updates (paid version only).
• Ability to password protect key program settings (paid version only).Improvements:
• Improved reliability and performance of the update process.
• Detection and removal engine enhancements.
• System tray icon now dynamically displays selected language.
• Settings for Protection Module behavior can be changed without protection being active.
• Improved DOR (Delete On Reboot) technology to enhance threat removal process.
• Restructured log formats to include greater detail on system information and detected threats.
• Improved error messages to make them more user friendly.
• Scheduled updates now occur within 15 minutes of scheduled time.
• Custom log locations now displayed in Logs tab.
• Protection logs can be saved in custom locations.
• Program version release date now displayed on About tab.Issues Fixed:
• Fix for database not updating properly on Czech installations of Microsoft Windows.
• Fix for certain scenarios where scans failed to complete. -
HZoli87
Számomra megvan a tökéletes kombó.
VIPRE Internet Security 2012 (Lifetime)
Malwarebytes Anti-Malware (PRO)(Lifetime)
Nagy a barátság a két cég között, link. VIPRE-ben már alapból a kivételek között szerepel a web védelemnél az MBAM frissítési címe.
Ennek ellenére azért ezeket a kivételekhez adtam, bár nélküle sem volt semmi gond.
VIPRE esetén: mbam.exe, mbamgui.exe, mbamservice.exe, rules.ref, mbam.sys
MBAM esetén: GFI mappákat
HZoli87
Kezdő vagyok
#96
Nem tudom.
HZoli87
Kezdő vagyok
#94
Már leírtam a másik fórumban is, hogy nálam egyedi eset van. Nyugodtan feltelepítheted mellé.
HZoli87
Új verzió: Malwarebytes Anti-Malware 1.51.2.1300
- Fixed issue with users with { or } in user account names.
- Internal bugfixes. -
HZoli87
Érdekes, hogy a káros weboldalak blokkolásának kikapcsolásához a tálca ikonon és a főablak - védelem fülén is ki kell venni a pipát, az egyik sosem elég ahogy észrevettem.
HZoli87
Greenebola
#68
ESS mellett hasít, jó barátok.
HZoli87
Takarító program: MBAM-Clean.exe
HZoli87
Core2duo6600
#45
Ha még működik (limit: 100 fő), akkor használod a kupon kódot a vásárlás előtt.
Itt nyomon lehet követni a frissítéseket: Link
HZoli87
Bekapcsolást követően mikor történik az első frissítése a programnak? (ütemezés szerint óránként keres frissítést a program nálam)(jelenlegi adatbázis: 6773, lehet nincs újabb jelenleg ezért nem frissült)
HZoli87
Akit zavar, hogy lassan tölt be a program (Vista/7), az állítsa át a Szolgáltatásoknál az MBAMService indítási típusát automatikusra, így nálam előbb betölt, mint az ESS.
HZoli87
Beálltam a sorba, én is megvettem.
HZoli87
Kezdő vagyok
#27
Nem gond.
HZoli87
Megjelent az új verzió: 1.51
- Vicces képek
- Mozgásban a Forza Horizon 6
- Xbox Series X|S
- Premier dátumot kapott az Atomic Heart negyedik, egyben utolsó kiegészítője
- ANNO 1800
- Interactive Brokers társalgó
- The Elder Scrolls Online Imperial Collector s Edition
- ÚJ Apple Macbook Air 15,3 M4 10C CPU/10C GPU/16GB/256GB - Ezüst mw1g3mg/a - 3 év gari - MAGYAR
- MSI Crosshair 16 i7-14700HX 14. gen 16gb ddr5 + RTX 4060 (140W) + 240Hz QHD+
- Kuriózum: Ozark Trail (amerikai) fejlámpa 600 lumen
- Beszámítás! Apple Mac Mini 2024 M4 24GB 512GB SSD számítógép garanciával, hibátlan működéssel
- HP Dell, üzleti kategóriás notebook kiárusítás - frissítve: 02.28
