Keresés
Flameus
[L]http://tech.prolific.com.tw/visitor/v_filebrw_result.asp[/L]
EzRecover is the supplemental tool to restore Prolific USB flash disk to the factory default configuration,
1.1 factory configuration data might be damaged due to the reason which haven't been perceived, and it resulted
1.1.1 PHY BLK 0 failure,* device is ''security device'',
possible phenomena, device is ''security device'' while attaching to Windows system,
1.1.2 Boot sector damaged, device is ''storage device''
possible phenomena, disk can not be accessed successfully, disk space is zero and required to format, however it could be failed.
- AMD vs. INTEL vs. NVIDIA
- Netfone
- Nintendo Switch 2
- Sorozatok
- TCL LCD és LED TV-k
- Spórolós topik
- Felhő alapú adattárolás (Dropbox, stb.)
- MWC 2026: Könnyen megmarkoltuk a Lenovo Legion Tab ötödik generációját
- Makulátlan Dell14",core i5,8-32GB DDR4,MAGYAR Vil.bill,256-512GB SSD,jó akku,W11
- Újszerű ÉRINTŐS Dell,14"FullHd IPS,8.gen core i5(8x3,6Ghz)8-32GB/256-512GB,MAGYAR Vil.bill
- Megkímélt ÉRINTŐS Dell,14"FullHd IPS,core i5,8-32GB DDR4,MAGYAR Vil.bill,256-512GB SSD,jó akku,W11
- BESZÁMÍTÁS! Intel Core i9 11900KF 8 mag 16 szál processzor garanciával hibátlan működéssel
- Újszerű Apple MacBook Air 13.6" - M2, 16GB/256GB - 6 ciklus - 100% akku(MC7X4MG/A) Éjfekete -HUN
- Samsung Galaxy S24 256GB, Kártyafüggetlen, 1 Év Garanciával
- Xbox Series S 512 GB + kontroller 6 hó garancia, számlával!
- 43999 FORINT MacBook Pro 17" i7 2.6 GHz 8GB RAM 8 ciklus az akkuban!
