Keresés
  • e-biza
    az elpida bejelentette az 1 Gigabyte méretü ECC nélküli ramjait.
    [L]http://www.elpida.com/en/news/2003/08-25.html[/L]
    tök jo ;]
    ''1 Gigabyte Unbuffered DDR DIMMs
    Based on Elpida's newest DDR400 devices, the JEDEC-standard, 184-pin 1 Gigabyte PC3200 modules (Part numbers: EBD11UD8ADFB, EBD11ED8ADFB) are organized as 128 Million words x 64/72-bits x 2 ranks, and enable low-voltage (VDD 2.6 V +/- 0.1 V) operation. The DIMMs transfer data at a rate of 3200 Megabytes per second, and they have a programmable CAS latency (CL) of 3, and a burst length of 2, 4, 8. The modules are unbuffered for PC and workstation applications, and they are composed of 16 high-performance 512 Megabit x8 DDR400 components. The module is also available in an unbuffered, x72 configuration that supports Error Correction Code (ECC) for high-end workstation applications.''
