hunaqua
Elnézést,nem jó az angolom,de akinek van már S905W annak hasznos lehet.
FYI: I successfully ran latest LibreELEC ( LibreELEC-S905.arm-8.2-8.1.9.img ) on that box using gxl_p212_2g dtb (I do have the 2GB RAM version).
Direct link to LibreELEC image : http://kszaq.libreelec.tv/s905/8.2/8...2-8.1.9.img.gz
Direct link to DTB : http://kszaq.libreelec.tv/s905/8.2/d...xl_p212_2g.dtb
Etcher download page : https://etcher.io/* Use etcher to write LibreELEC-S905.arm-8.2-8.1.9.img.gz to microSD (rufus works if you unzip the img file and force it or change the suffix to .iso).
* rename gxl_p212_2g.dtb to dtb.img.
* overwrite the original dtb.img inside your microSD.
* put the microsd in your UNPOWERED Tanix TX3 mini.
* press and keep pressed the reset button inside the hole on the botton while plugging the power cable.
* libreelec should do some work (booting, rebooting... stuff) and then you'll be inside LibreELEC's wizard.PRO so far:
* LibreELEC works!CONS so far:
* no wifi.
* front LCD struck with "BOOT".NOTES:
* up to 2160p @30Hz.Here you can see the boot dmesg: https://pastebin.com/ejHZE7C0 (what's that empty USB3 root usb hub it shows?)
IMPRESSIONS:
At the end of the day this AMlogic 905W seems just another 905X flavor (a little tweaked one), it runs and act like the older brother and only lacks some features.
Tanix box is good for what it is (kudos to Javimetal for the slick case); it isn't exactly a "low end" or "budget" "chipset" STB, it's a S905 for people that doesn't need 4K.
Lacks of wi-fi support was expected, I hope it will be fixed but it isn't exactly deal-breaking. -
hunaqua
Itt van ez a MEASY S905 1/8
https://www.gearbest.com/tv-box-mini-pc/pp_272898.html
Ez is most 30usd.- ,és a Measy nem csak OEM gyártó.A kínai piacon van "neve".. Jó régen volt onnan még Realtek-es belső HDD-s lejátszóm,és szerettem.
Vajon ez milyen lehet LE-vel?
hunaqua
4K @ 30fps és a 4K @ 60fps között mi a gyakorlati különbség? Nem játszik le 4K.s anyagokat,vagy rosszabb minőségben?
hunaqua
A Tanix TX3 mini S905W 2/16 31usd.- a Banggood-on. Az ára 2/16 lévén nagyon kedvező.
..milyen cucc lehet?
hunaqua
A gyakorlatban csak LE használattal ,mivel gyengébb vagy más az S905W mint az S905X
hunaqua
szabi__memo #23422 üzenetére
Ezért gondolom,hogy értelmetlen,ill. a S905X gyártása során felmerülő gyenge darabok így nem kerülnek selejtezésre.
hunaqua
kmarci25 #23420 üzenetére
Nem nagyon hiszek benne.Egy bizonyos összeg alá nem tud menni,hiszen minden más ua.-ba kerül (táp,ház,stb). Gyári profit,nagyker,kisker,Ez szerintem egy 30usd.- s postázott,leszállított terméknél nem lesz számottevő. Azt el tudom képzelni,hogy ami szint alatti cucc,az bekerül a vérkeringésbe kicsit olcsóbban,más néven.
..szerintem .
hunaqua
kmarci25 #23416 üzenetére
Szerintem meg nem nagyon van értelme Amikor egy S905 (x) 30usd,akkor ez mennyi? Lehet,hogy 20usd vagy 25USD.-? Teljesen értelmetlen,ráadásul minél többet gyártanak valamiből annál olcsóbb. Akkor már inkább az S905 cuccokat kéne erőltetni.
....vagy, el akarják adni a selejtet S805X néven.
hunaqua
Egy S905 tr@nsmission cuccal, USB-s 2.5 HDD-vel ,mennyi MB/s le és feltöltésre képes? (digi 500 )
hunaqua
A VONTAR-ban ilyen wifi cucc van,ez is 30usd. a 1/8-as . (S905x)
ezt írta:VONTAR MINI M8S+:
1G 8G WIFI IS 8189
2+8 IS AP6212Ez jó vagy rossz?
hunaqua
Szerintetek melyik jobb döntés? Mind a kettő 30usd.-
MEGOGO MXV vagy VONTAR M8S S905X
..csak olyan jó amin van optikai kimenet.
hunaqua
Ezt a Wechip V5 cuccot ismeri valaki?
Érdemes lehet ilyet venni?
hunaqua
Amennyiben az LE a cél,akkor most már ajánlható az S912 ?
Valamit szeretnék venni,és amennyiben stabillá válik az S912 akkor lehet jobb lenne már mint az S905X ?
- Ryzen 3 3200g, Gigabyte A520M K V2, 16GB ram, 512Verbatim Vi560S2 M. 2 ssd+256 GB ssd
- BESZÁMÍTÁS! Gigabyte B760M i5 14600KF 64GB DDR4 512GB SSD RTX 3080 10GB Corsair 4000D Airflow 1000W
- BESZÁMÍTÁS! Gigabyte B760M i5 13400F 16GB DDR4 512GB SSD RTX 3070 8GB Pure Base 500DX fehér 650W
- BESZÁMÍTÁS! MSI B450 R7 7 5700X 32GB DDR4 512GB SSD RTX 2080 8GB Fractal Design Define R5 FSP 750W
- BESZÁMÍTÁS! ASRock Z370 i5 8500 16GB DDR4 512GB SSD 2060 Super 8GB Zalman Z9 Plus Enermax 750W
- BESZÁMÍTÁS! Gigabyte H370 i5 9500 32GB DDR4 512GB SSD RTX 2060 Super 8GB ZALMAN S2 TG be quiet! 650W
- Iphone 15 Plus 128GB Pink Dobozos 12 Hónap Garancia
- LG 65G4 - 65" OLED evo - 4K 144Hz & 0.1ms - MLA Plus - 3000 Nits - NVIDIA G-Sync - FreeSync Premium
- ÚJ HP EliteBook 840 G8 - 14"FHD IPS - i5-1145G7 - 32GB - 512GB SSD - Win10 - 6 hónap Garancia
- Apple Watch 9 45mm LTE
Cég: PC Trade Systems Kft.
Város: Szeged
Város: Szeged
