ASUSTO NAS összefoglaló
LaliPapi
Fórumtárs angol bejegyzésébe a témában.
Re: App Central ends support for KODI (what we can do)
Postby Hyena » Sun Apr 01, 2018 1:53 am
You can find my solution this below if you wants to get back our belowed Kodi to your asustor nas if you updated your app, or uninstalled kodi....
First of all you must uninstall the following apps from that:
x.org (if you uninstall this it will also remove almost everything necessary)
ffmpeg
asustor portal
remote center
web browserAfter this you should download the following apps from the asustors website. ( http://appdownload.asustor.com/ )
0010_999_1504679933_ffmpeg_3.3.2.r11_x86-64.apk
0010_999_1507799424_web-browser_1.0.0.R4_x86-64.apk
0010_999_1508989612_remote-center_1.0.0.r157_x86-64.apk
0010_999_1512560310_kodi_17.6.0.R1_x86-64.apk
0010_999_1512708048_xorg_10.14.7.R33_x86-64.apk
0010_999_1513305050_asportal_2.2.4.r1213_x86-64.apk0010_999_1518494437_soundsgood_2.1.0.r830_x86-64.apk (its opcional but if you wants to use the soundsgood you must download this one also)
If you have everything, you must install them manually one by one , its important to manually install because if you try to install them from the app central it will update the x.org to the latest which will have no sound on the KODI.
Here are the install sequence:
ffmpeg
x.org
web browser
remote center
as portal
kodiand soundgood if you want it.
If you done everything well you can see 3 available updates in the app central (x.org, ffmpeg, soundsgood) BUT DON'T UPDATE THEM because if you do it you'll have no sound on your ac3/dts movies!
This solution works well for me, but as i can see don't have so many time since maybe a future update will cause more complications...
LaliPapi
Szia,
Sajnos én is megszívtam. Próbálom visszarakni a régebbi x.org-ot, de mivel fel van telepítve az újabb ezért nem hajlandó rá. Ha viszont törlöm az újat, akkor figyelmeztet, hogy leszedi a kodit is, azt meg nem találom sehol a listában.
Van esetleg valami ötleted?
Köszönöm.
- talmida: My Art II.
- Válságmódban a Samsung mobildivíziója
- Diablo IV
- Call of Duty: Warzone
- Jobb zajszűréssel és okos funkciókkal töltve megjelent az Apple AirPods Max 2
- Andras-G: #Kószagondolat - eMag tapasztalatok 2026-ban
- Vezetékes FEJhallgatók
- Eladó Samsung Galaxy A54 8/256GB / 12 hónap jótállás
- Telefon felvásárlás!! Samsung Galaxy S21/Samsung Galaxy S21+/Samsung Galaxy S21 Ultra
- Xiaomi 17 Ultra Starlit Green 512GB használt karcmentes garancia 2029.03.05.-ig + Photographer Kit
- Intel Core i5-9500 / i7-8700T / i7-8700 / i7-9700 /i5-10500T processzorok- számla, garancia
- BESZÁMÍTÁS! MSI B650 R7 7700 32GB DDR5 1TB SSD RTX 5070Ti 16GB LIAN LI LANCOOL 207 ADATA 850W
Gawamatsu
