mmdms
greatchaos
#976
flesselőnek neve esetleg? mit értesz az alatt hogy szükséges hüyeség?
na ez picit hosszu lessz:
Managing and Updating Your BIOS
1.1 Upon First Use of the Computer System
It is recommended that you save a copy of the original motherboard BIOS along with a
Flash Memory Writer utility (AFLASH.EXE) to a bootable floppy disk in case you need
to reinstall the BIOS later. AFLASH.EXE is a Flash Memory Writer utility that updates
the BIOS by uploading a new BIOS file to the programmable flash ROM on the motherboard.
This file works only in DOS mode. To determine the BIOS version of your motherboard,
check the last four numbers of the code displayed on the upper left-hand corner of your
screen during bootup. Larger numbers represent a newer BIOS file.1. Type FORMAT A:/S at the DOS prompt to create a bootable system floppy disk.
DO NOT copy AUTOEXEC.BAT & CONFIG.SYS to the disk.2. Type COPY D:\AFLASH\AFLASH.EXE A:\ (assuming D is your CD-ROM drive) to copy
AFLASH.EXE to the just created boot disk.
NOTE: AFLASH works only in DOS mode. It will not work with DOS prompt in Windows and will
not work with certain memory drivers that may be loaded when you boot from your hard
drive. It is recommended that you reboot using a floppy.3. Reboot your computer from the floppy disk.
NOTE: BIOS setup must specify floppyÓ as the first item in the boot sequence.4. In DOS mode, type A:\AFLASH <Enter> to run AFLASH.
5. Select 1. Save Current BIOS to File from the Main menu and press <Enter>.
The Save Current BIOS To File screen appears.6. Type a filename and the path, for example, A:\XXX-XX.XXX and then press <Enter>.
1.2 Updating BIOS Procedures
1. Download an updated ASUS BIOS file from the Internet (WWW or FTP)
(see ASUS CONTACT INFORMATION on User Ma for details) and save to the disk you created earlier.2. Boot from the disk you created earlier.
3. At the A:\ prompt, type AFLASH and then press <Enter>.
4. At the Main Menu, type 2 and then press <Enter>.
The Update BIOS Including Boot Block and ESCD screen appears.5. Type the filename of your new BIOS and the path, for example, A:\XXX-XX.XXX, and then press <Enter>.
NOTE: To cancel this operation, press <Enter>.6. When prompted to confirm the BIOS update, press Y to start the update.
7. The utility starts to program the new BIOS information into the flash ROM. The boot block will be
updated automatically only when necessary. This will minimize the chance that a failed update will
prevent your system from booting up. When the programming is finished, Flashed Successfully will
be displayed.
NOTE: When you see the message "Boot Block is different" you may still press <Y> to update the BIOS.
Yet if the update fails, your system will run a greater risk of boot failure depending on
whether the boot block is damaged or not.8. Follow the onscreen instructions to continue.
ebből kéne kiindulnom?
mmdms
greatchaos
#974
na mit csináljak?
a flopit keresi meg cd-t is!
részletesen kellene lépésről lépésre, van crash free bios 2, ha ez segít. csak nem tom hogy kell hazsnálni -
mmdms
greatchaos
#972
aham
a flopit msdos rendszerindítónak kell formázni???
ujraindult a frissítés közbe
mmdms
sziasztok!
segíthetnétek abban, hogy egy ASUS A7V600-X alaplap bios-át az EZ FLASH nevű progival lehet-e frissíteni?
nekem nem tölti be valamiért az asus honlapját
mmdms
sziasztok!
az asus update-t el tudná mondani valaki hogy mit is takar az a Follow the screen instructions to complete the update process szöveg pontosan?
kérdezz feleleket kell majd jáccani vele?
- BESZÁMÍTÁS! MSI Z690 i5 12400F 32GB DDR4 512GB SSD RX 6750XT 12GB ASUS A31 PLUS TG ARGB Seasonic750W
- Apple iPhone 14 Pro Max 256GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 13 mini 256GB Pink használt, szép állapot 100% akku 6 hónap garancia
- ÁRGARANCIA! Épített KomPhone Ultra 9 285K 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
