F-ECT$
F-ECT$
F-ECT$
F-ECT$
New toys:
• The Grenadier! A powerful ranged unit that deals area damage, rather inaccurately (available at HQ 16)
• Leaders and Officers can spend Intel to sabotage (destroy) random defensive buildings in Task Force operations
• Added a fresh batch of new Power Bases and NPC levelsGameplay improvements:
• Dr. Terror's Wednesday event Statues have been weakened
• More consistent invasions (tap here to find out more)
• Operations will display "too easy", "easy", "normal", "hard" or "impossible" based on your Task Force's strength
• Old Flare timers are hidden when a new Flare is used
• Gunboat ability timers don't stack on top of each other anymore
• After maintenance, you can't attack player bases or Resource Bases for a short while
• You now get one extra guaranteed Power Stone Crystal after beating Terror Stage 19
• Changed VP reward to give Shards instead of Crystals (tap here to find out more)
• Leaving a Task Force at any point during an operation will make you ineligible for the OP rewardThings that look cooler:
• A captured Blackguard freighter delivers your OP reward
• Power Core and Power Cell destruction effects have been amped up
• Gears and fans have been turned on in operation levels
• New invasion and destruction animations on the map
• New attack in progress animations on the operations map
• New look for several building upgrade levels: HQ (4, 5, 6, 17), Quarry (2, 4, 5), Iron Mine (2, 3, 5, 9), Sawmill (7, 8, 9), Sculptor (1, 2, 3, 4, 5), Cannon (11) and Rocket Launcher (7)UI improvements:
• New invasion information can be found on the Radar info screen at level 6 (see here)
• Previous operations can be viewed from the operations map
• Activity Log now shows Dive Location spawns
• Visit Task Force members' bases from the chat
• Check out potential recruits' bases from their join requests
• See which Task Forces your friends are in from the Friends tab
• Attacker's name is now shown when watching a replay or spectating
• Confirmation check before committing to your Task Force attackBonus material:
• Epic win sound plays when you beat an operation, Terror Stage 20 or Lt. Hammerman -
F-ECT$
Silent77
#1615
Én ha nagyobb építkezés előtt állok, akkor már nem nagyon támadok előtte pár napig. Ha egyszer már scoutolták a szigetedet, akkor fix nyersanyagot kapnak beverés után, mindegy, hogy Neked közben több vagy kevesebb lett. Ergo a legjobb taktika arra, hogy ne támadjanak meg az, ha Te sem támadsz, mert akkor kisebb eséllyel kerülsz rá olyan térképére, aki le tud verni.
F-ECT$
Pepeninho
#1599
Nem kell játszani, mert az eset már megtörtént
Egyébként egy kicsit a másik oldalt is megvilágítva: az sajnos sehogy nincs mérve, hogy valaki a szintjéhez képest mit tud 1-1 támadásnál. Lehet, hogy valaki ott kiemelkedően jól teljesít, de amúgy ő úgy szereti a játékot játszani, hogy főleg a termelésre megy rá, nem a támadásra, így nem jön össze a 10 intel, de mégis többet lökött a teamen, mint egy 15 intelt szerző, de a támadásoknál csak bénázó egyén.
De erre vannak a szabályok, 5 fős teamnél még lehet egyéni elbírálás, 50-nél már nincs rá energia.
F-ECT$
jozefgucci1
#1405
No igen, ez a legnagyobb baj. 20 támadással még akkor is meglenne, ha 10-en szarul támadnak.
F-ECT$
jozefgucci1
#1317
Össze vissza támadás van rendesen, de azt összehozni, hogy mindenki úgy és olyat támadjon, ami optimális, azt elég nehéz, sőt az ingame lehetőségekkel szinte lehetetlen.
F-ECT$
Lvl 38, 219 VP, nem vertem le semmit a tegnapi támadásom során:
11 Diamond / 36708 Iron / 108528 StonePepeninho: 6 támadás maradt benn, szóval majdnem mindenki támadott. Szerintem nem volt optimális a támadások elosztása. Ma is mehet egy 150-es, vagy esetleg egy 130-as.
F-ECT$
Pár gondolat a klánosdiról, eléggé benne voltam a WoW kapcsán, a téma itt is ugyanaz:
1. Csinálhatsz "olvasztóklánt", amikor mindenkit felveszel aki csak jelentkezik. Ennek hatására lesz egy csomó potyautas.
2. Ennél eggyel jobb, ha van valamilyen felvételi korlát (pl lvl35), hogy csak azok jöjjenek, akik már bizonyították, hogy nem adják föl az első nehézségnél a játékot.
3. Még jobb, ha előre megegyeztek néhány egyszerűen betartható szabályban (mindenki szerez legalább 5-10 intelt hetente; a 7 napi támadásból legalább 5-ön jelen van; stb), és aki ezt nem teljesíti, annak megy a figyelmeztetés, majd a ban.Mivel itt az 1-es verzió lett a nyerő, így hiába akarja a vezetés, hogy a 30-40-es szintű emberekhez igazodjon a nehézség, nem fog menni. Olyan napi feladatot kell választani, ami a 20-as szintűekkel is letudható.
Megoldások:
1. Marad az olvasztóklán és a könnyebb feladatok.
2. Két (kisebb) klán kell, és akkor mindenki a szintjének megfelelő nehézségen játszhat. -
F-ECT$
2 ph csapat van. 10 és 25. Én szívesen mennék a "hivatalosba".
F-ECT$
A videó leírásában van egy ilyen - próbáltátok már?
Need Free Diamonds? [ Clash Of Clans - Boom Beach ]
WORKS ON: Iphone, Android, iPad
Step by Step Guide:
1. Go to http://m.freemyapps.com/share/url/BootrampGames
2. Install the profile
3. Download the free apps, run them for 30 seconds, go back to FreeMyApps and get points!
4. Redeem the points for ITunes giftcards and have fun with your gems!
Hope this helps you guys get some Diamonds! -
F-ECT$
blackscholes
#988
A hajóról nem viszi el, csak a bányából. (De a hajón is van max tárolási kapacitás.)
Medic: én egyelőre nem használom, a 30 warrior elég.
F-ECT$
ami nyeranyagoknal fel van sorolva az plusz raktarnak szamit, nem anyit vedd meg minimum. Csak valamennyi szazalekot ved
Nem, rosszul tudod: When your Headquarters is destroyed, the Vault protects the resources contained within it as well as an additional percentage of resources outside of the Vault.
F-ECT$
marked one94
#978
Annak semmi köze ehhez. Amikor Scoutolnak, az befixálódik, és annyit fogsz nyerni, akármikor is támadsz.
Viszont kicsit utána olvastam, és valószínűleg a be nem gyűjtött fa vault által nem védett részét vitték el.
F-ECT$
Az mitől van, hogy volt 20k fám (épp egy upgrade után voltam), a vaultom véd 46k-t, betámadtak, levertek, és mégis elvittek kb 2k-t?
F-ECT$
blackscholes
#969
Nekem van egy 43%-os wood, így óránként jön 9.5k. A legtöbb támadható ellenfélnél meg van max 40-50k, de sokszor csak 10-20k, mert ez mindenkinél hiánycikk. Szóval akár napi 4-5 támadás is kellene, de az meg nagyon felnyomné a VP-t, és utána csak lerabolnának, és én se tudnék támadni.
F-ECT$
blackscholes
#949
Ja, én is elhanyagoltam a támadást a védelemért cserébe, nem is vertek be, csak 2 hetente 1x. Most kicsit rágyúrtam a támadásra, így a védelmi épületeket nem fejlesztettem, erre az elmúlt 5 napban 3x vertek le.
F-ECT$
Lassan minden hajóm eléri a 15 férőhelyet, ezzel elfér összesen 30 warrior rajtuk. Érdemes ráfeküdni a 16 férőhelyre, és így a 2-2, azaz összesen 12 tankos kapacitásra, vagy a tankok még ekkora számban is felejtősek?
F-ECT$
Ezt mivel vernétek le?
F-ECT$
Permet Elek
#853
Én nem tudok ilyenről.
F-ECT$
Permet Elek
#832
Csak 1, gyémánttal lehet lenullázni a fejlesztési időt (de nem érdemes).
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
- HP Elitebook 840 G4,14",HD,i5-7300U,8GB DDR4,256GB SSD,WIN11
- Gamer PC-Számítógép! Felsőkategória! R7 9800X3D / RX 9070XT / 32GB DDR5 / 2TB SSD / Noctua !
- BESZÁMÍTÁS! 1TB Samsung 980 M.2. NVMe SSD meghajtó garanciával hibátlan működéssel
- ZOTAC GAMING Solid OC White Edition RTX 5080 Új, számlás, 5 év garancia!
