scart
Performance Improvements for CATALYST™ Display Driver Version 4.9
As with most CATALYST™ releases performance has increased in various situations. The following performance gains are noticed:
Doom3 performance improves 10-15% on ATI RADEON™ X800 XT products when anti-aliasing is enabled.
UT2004 performance improves considerably on the ATI RADEON™ 9500 PRO, RADEON™ 9700 PRO RADEON™ 9800 PRO and RADEON™ 9800 XT products. The benefit can be 25% or more in some circumstances, particularly at extreme graphics settings such as 6xAA + 16xAF.
Ez lemaradt az elejen :)
[Szerkesztve] -
scart
Megjelent a vegleges 4.9-es verzio:
[L]http://www.ati.com/support/drivers/winxp/radeonwdm-xp.html?type=xp&prodType=graphic&prod=productsXPdriver&submit.x=4&submit.y=3[/L]
Fixed in this driver:
XIII: Light map artifacts are no longer noticed in the game when loading a saved game under Windows XP with an ATI RADEON™ 9200 installed
Far Cry v1.2: Texture corruption is no longer seen on the ground
IL2 Forgotten Battles: Playing the game under Windows XP with an ATI RADEON™ X800 series installed no longer results in the display corruption and the game failing to respond when FSAA is enabled and display is set to either 1200x960 or 1600x1200
Indian Jones and the Emperors Tomb: Display corruption and missing polygons are no longer noticed in the game
PainKiller: missing textures are no longer noticed on the ground and light artifacts are noticed when moving around within the game or when moving in and out of the light.
Serious Sam SE: Running the game under Windows XP with an ATI RADEON™ X800 PRO installed no longer results in lens flares showing through solid objects within the game
Star Wars: Knights of the Old Republic: An access violation error no longer occurs when using the function Alt-Tab to get out of the game and then using the function Alt-Tab to get back into the game
Tabula Rasa: Video rendering issues are no longer noticed playing the game under Windows XP with an ATI RADEON™ 9700 PRO installed
Tony Hawk 4: playing the game under Windows XP with an ATI RADEON™ 9100 installed no longer results in white pixels being seen around the edges of objects
Connecting an HDTV 7pin dongle to the video card no longer results in TV detection issues when both the TV and YPbPr (HDTV) are active
Playing a DVD with PowerDVD on the primary display and playing an MPEG clip with Windows Media Player on the secondary display device no longer results in flickering and corruption being seen
Enabling a second display device followed by changing the positions of the two devices in the mapping area, no longer results in the images changing to a different unexpected position when click apply to the changes
Setting the Overlay option back to the default setting now results in the default setting becoming active when relaunching the CATALYST™ CONTROL CENTER
Repeatedly switching from one custom profile and another in rapid succession no longer results in the CATALYST™ CONTROL CENTER failing to respond
Canceling SMARTGART changes and exiting the CATALYST™ CONTROL CENTER no longer results in the reboot message reappearing when restarting the CATALYST™ CONTROL CENTER
A .net error message is no longer displayed under Windows 2000 when the CATALYST™ CONTROL CENTER is installed from an administrator account an then attempting to launch the CATALYST™ CONTROL CENTER from the system tray on a secondary account
Having the display properties page active and attempting to close the CATALYST™ CONTROL CENTER no longer results in a .net exception error message appearing
Assigning the same hotkey for Increase 3D Gamma and Decrease 3D Gamma under Windows 2000 no longer results in a .Net exception error when attempting to move the hotkey manager window around the desktop
Disabling the primary device and selecting the secondary device to be the primary no longer results in the Information Center displaying a blank page
The CATALYST™ CONTROL CENTER no longer reports the CPU type as Intel when installed under an AMD64 system
Launching the Task Manager and clicking on End Process for the CATALYST™ CONTROL CENTER system tray option no longer results in the system tray option for the CATALYST™ CONTROL CENTER still be selected within the CATALYST™ CONTROL CENTER
Switching from the CATALYST™ Control Center System Skin option to the CATALYST_Quicksilver Skin option no longer results in the Toolbar area skin becoming corrupted
- E-book olvasók
- A Razer új klaviatúra-zászlóshajóját meglátva biztos félrenyeled a teát
- Path of Exile (ARPG)
- Samsung kuponkunyeráló
- GoodSpeed: Mutasd magad topic!
- Linux kezdőknek
- HIBÁTLAN iPhone 14 Pro 256GB Gold- 1 ÉV GARANCIA - Kártyafüggetlen, MS4514
- AKCIÓ! 100/100 - 0Perc - WD BLACK SN850P 1TB - Playstation 5
- HP Probook 6530b,14",Intel Core P8700,4GB RAM,250GB HDD,WIN10
- Új Asus Zenbook S14 WQXGA OLED 120Hz Ultra7 258V 32GB 1TB SSD Intel Arc 140V 16GB Win11 Garancia
- 230 - Lenovo Legion 5 (15IRX10) - Intel Core i7-13650HX, RTX 5060
