Keresés
Gbcrtrtlp
Patch 1.5 has now been released on all platforms. This has been released and is now live on all platforms - on PC, the patch contains an additional fix for the audio stuttering you've reported to us, and the patch on Xbox One also contains patch 1.4, which you can find the notes for here.
English
· A missing gear fault will always be fixed after swapping out a worn gearbox for a new one.
· Fixed a crash seen loading in to any Multiplayer session.
· Reduced the amount of gearbox and engine wear when playing 25% distance races.
- Felhő alapú adattárolás (Dropbox, stb.)
- MWC 2026: Könnyen megmarkoltuk a Lenovo Legion Tab ötödik generációját
- TCL LCD és LED TV-k
- Pécs és környéke adok-veszek-beszélgetek
- Kés topik
- Vicces képek
- Makulátlan Dell14",core i5,8-32GB DDR4,MAGYAR Vil.bill,256-512GB SSD,jó akku,W11
- Újszerű ÉRINTŐS Dell,14"FullHd IPS,8.gen core i5(8x3,6Ghz)8-32GB/256-512GB,MAGYAR Vil.bill
- Megkímélt ÉRINTŐS Dell,14"FullHd IPS,core i5,8-32GB DDR4,MAGYAR Vil.bill,256-512GB SSD,jó akku,W11
- BESZÁMÍTÁS! Intel Core i9 11900KF 8 mag 16 szál processzor garanciával hibátlan működéssel
- 186 - Lenovo Legion 5 (15IRX10) - Intel Core i7-13650HX, RTX 5070 (ELKELT)
- LG 55QNED823RE / QNED / 55" - 140 cm / 4K UHD / 120Hz & 4ms / HDR Dolby Vision / FreeSync + HDMI 2.1
- Újszerű iPhone 14 Plus 128GB Lila független, 100% aksi, 1 Év garancia
- 2 TB-os Samsung 980 PRO M.2 SSD with heatsink - garanciával
