Hory
Adtam a mysql-nek 1G memoriat, a java eleszik meg kb fel gigat, igy a rendszer mellett marad 300M szabad ram. Nem rossz, nem rossz. :)
Itt egyebkent nem utkozik az ethernet controller semmivel. Jofajta integralt intel, kar, hogy csak 100mbites. Fog rajta adat folyni rendesen. -
Hory
Ínyenceknek egy kis finomság:
$ cat /proc/interrupts
CPU0 CPU1
0: 85043964 13 IO-APIC-edge timer
1: 1616 1 IO-APIC-edge i8042
2: 0 0 XT-PIC cascade
8: 4 0 IO-APIC-edge rtc
12: 32 1 IO-APIC-edge i8042
14: 1787219 0 IO-APIC-edge ide0
17: 1971993 882058 IO-APIC-level eth0
NMI: 0 0
LOC: 85047091 85047090
ERR: 0
MIS: 0
$ cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 6
model : 10
model name : AMD Athlon(tm) MP 2600+
stepping : 0
cpu MHz : 2000.474
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 mmx fxsr sse syscall mp mmxext 3dnowext 3dnow
bogomips : 3940.35
processor : 1
cpu family : 6
model : 10
stepping : 0
cpu MHz : 2000.474
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
bogomips : 3989.50
$ free
total used free shared buffers cached
Mem: 2073008 2064316 8692 0 77088 217644
-/+ buffers/cache: 1769584 303424
Swap: 987956 274492 713464
$ lspci
00:00.0 Host bridge: Advanced Micro Devices [AMD] AMD-760 MP [IGD4-2P] System Controller (rev 11)
00:01.0 PCI bridge: Advanced Micro Devices [AMD] AMD-760 MP [IGD4-2P] AGP Bridge
00:07.0 ISA bridge: Advanced Micro Devices [AMD] AMD-768 [Opus] ISA (rev 05)
00:07.1 IDE interface: Advanced Micro Devices [AMD] AMD-768 [Opus] IDE (rev 04)
00:07.3 Bridge: Advanced Micro Devices [AMD] AMD-768 [Opus] ACPI (rev 03)
00:07.5 Multimedia audio controller: Advanced Micro Devices [AMD]: Unknown device 7445 (rev 03)
00:10.0 PCI bridge: Advanced Micro Devices [AMD] AMD-768 [Opus] PCI (rev 05)
01:05.0 VGA compatible controller: Matrox Graphics, Inc. MGA G400 AGP (rev 82)
02:00.0 USB Controller: Advanced Micro Devices [AMD] AMD-768 [Opus] USB (rev 07)
02:09.0 Ethernet controller: Intel Corp. 82557/8/9 [Ethernet Pro 100] (rev 10) -
Hory
No, ma megjöttek a masinák. A silvercomp-ban szépen össze is rakták, memtesteltek is, minden klafa.
Fordítottam neki egy SMP 2.6.0-ás kernelt, egyből, gond nélkül megy az egész. Ami fura: 2600+ athlonmp, de 512KB cache van rajta és 2ghz-en megy. Nocsak, nocsak. Ebből ti mit gyanítotok?
Szép gyors, és olyan jó, mikor a /proc/cpuinfo 2 cpu adatait adja vissza... :)
Egyelőre csak 1cpu-s műveleteken teszteltük, abban kb. olyan gyors, mint az elődje, egy 2800-as barton, talán úgy 5-10% lemaradása van. Csak ebben van még egy erőmű, úgyhogy sokkal terhelhetőbb, és nekem pontosan erre volt szükségem.
Ha van valami kérdés, írjatok.
Csináljak képeket? -
Hory
Tenyleg, jut eszembe. Ha a 2800-as athlonmp barton magos, akkor elvileg alacsonyabb az orajele, mint a 2600-osnak, nemde? Vagy ez csak sima athlonxp-knel van igy?
A nagyobb orajel jopar feladatban jobb, mint a nagyobb cache. -
Hory
Nem ''veszek'', ceg veszi. En csak megmondom, hogy mit. :)
Kovetkezo vas lett:
-2db MSI K7D Master-L alaplap 46400+Áfa /db
-4db AMD AthlonMP 2600+ BOX CPU 39200+Áfa /db
-4db 1GB 266MHz Registered ECC DDR RAM 54800+Áfa /db
-2db Chieftec DX01BD4 midi ház táp nélkül 20800+Áfa /db
-2db Chieftec 420W Aktív PFC tápegység 18840+Áfa /db
2800-asra meg varni kellett volna egy csomot, ezert a 2600-as. -
Hory
Köszi ezt sok választ. :)), hogy ha nem megy, újra kell próbálni... :)
Mindenesetre megnyugtató, hogy az athlonmp azért igencsak erős masina a tesztjeid szerint. De azért örülnék egy barton magosnak, mert a párhuzamos mem. hozzáférés miatt valszeg nagyobb lenne a teljesítmény-növekedés, mint egy egyprocis rendszerben.
Szóval akkor hogy is van az a barton magos athlonmp-téma? magyar kiskereknél 2600-as és 2800-as van, amik jelentősen drágábbak. Már csak az a kérdés, hogy a barton mag vagy az árazási politika miatt. -
Hory
Eldőlt a dolog, első körben 2db dual athlonmp lesz berakva szervernek. Most dolgozunk a parhuzamosításon.
Ellenben kellene tipp jó dual athlonmp alaplapra. Az anandtechüen eléggé a tyan-t favorizálták, de a silvercomp aszondja, hogy nem forgalmaznak a nagy hiba-arány miatt, a magicomp meg azt, hogy bezárt a magyarországi tyan disztribútor.
Van asus a7m266-d, de nemtom, jó lesz ez? -
Hory
Baaar... Most alaposan belegondoltam, tulajdonkeppen szet lehetne dobalni tobb gepre a terhelest. A mysql tud shadow adatbazist, ami gyakorlatilag annyi, hogy a modositasokat binaris formaban atkuldi a slave-eknek (ami nagyon gyors, szinte semmi cpu-t nem eszik, mar teszteltem), a lekerdezeseket meg intelligensen szetosztja koztuk. Az alkalmazas java-s resze meg rmi-n keresztul megy (tudom, broaf, de ezen most mar nem tudok valtoztatni), azt szet lehetne szorni tobb gep kozott. Csak ki kellene kicsit okositani, hogy egymasnak atadogassak a belso allapotokat, stb...
Ezen meg gondolkozom, mert ez lenne az idealis. -
Hory
Oracle? :)
Alaphelyzetben a leglassabb az osszes DBM kozul.
Az a 2 dual gepes oracle cluster kb. olyan gyors lenne, mint az egygepes, egyprocis mostani rendszer mysql-el. :)
Az oracle akkor qrva gyors, ha kihasznalod az extra feature-it, finomhangolasi lehetosegeit, amik viszont mar konkretan adatbazis-peldany fuggoek. Azt meg mi nem tudjuk megtenni.
Szoval marad az egy gep, hiaba draga.
Holnaputan futtatok par tesztet a 2800+-os barton-on, aztan lehet, hogy eleg lesz a dual 2800-as athlonmp. Ennek orulnek a legjobban.
A masik meg az, hogy 2 gep az hatvanyozott meghibasodasi lehetoseg, marpedig az itt nem engedheto meg. -
Hory
Szoval az a baj, hogy most egy single barton 2800+-on fut a rendszer, teszteleshez elegnek tunik, de nem hiszem, hogy akar 2 db athlonmp 2800-as elbirna, amit kell. :(
Mysql ugyan van, a cpu ido jelentos (>80%) reszet a java viszi el. Sok-sok szallal (min. 8 java-szal, es 4-8 mysql szal), szoval parhuzamosithatosag az lesz rendesen. Ezert gondoltam a xeonra, a tesztek alapjan is jobb ott, ahol ki tudja hasznalni a HT-t. -
Hory
Amugy ne tudjatok meg, milyen durva, hogy _AKAROK_ szerverprocit venni, es nemtok. Sehol sincs, meg egy arajanlatot se tudnak mondani...
MO ezerrel b+ :( -
Hory
Most beszeltem a silvercomppal, aszontak, hogy MOn meg nincs nagykereskedelni forgalomban az opteron (egyelore), szal ne erolkodjek.
Hory
Most neztem a neten az arakat, hat persze, hogy az is megegyezik.
Kb, igy fest:
2ghz opteron - $800
1.8ghz opteron - $500
3ghz xeon, 512kb - $500
3ghz xeon, 1mb - $800
Szoval azonos teljesitmenyhez azonos ar tartozik, mindket terfelen.
franko. :) -
Hory
Nem tom. A varhato teljesitmenyekkel mar tisztaban vagyok, de amig konkret arakat nem lattam, nem tudok donteni. Nyilvan fontos az ar/teljesitmeny arany.
Az opteron jonak tunik, de ha csak az 1.4-es van megfizetheto kategoriaban, akkor marad a xeon.
Athlonmp jo lenne, ha az amd tovabbskalazta volna magasabb frekik fele.
altalanossagban baj az amd procikkal az ellatottsag. alig kapni egy-ket helyen, ok se tudnak rola semmit. xeon-t meg a sarki fuszeres is... -
Hory
No, alaposan atolvastam par megbizhato tesztet. Alaphelyzetben az opteron jo, veri vagy eleri a xeon teljesitmenyet. Csak epp ahol hasznaljuk, mysql+java, ott boven lesz thread, es bizony a hyperthreading ilyen kornyezetben 33-50%-ot dob a teljesitmenyen, igy meg a xeon mar igencsak hatekony versenyzo.
Hory
Szoval jo lenne ez az AMD, de kapni, azt sehol se lehet. Alaplapot se nagyon.
Se athlonmp-st, de opteron-ost.
A semmit meg a hajamra kenhetem, nem fut rajta a mysql. -
Hory
Abban kene meg help, hogy miben mas az e7501 es az e7505? En ugy latom, hogy valami memoria-kezeles-beli sajatossag, de nem tudom, mi.
Valamint mi van a serverworks chipsetekkel? Ugy latom, nem tudnak dual channel ddr-t. Legalabbis, amiket eddig lattam. -
Hory
Pizzafutar
#54
Ceges gep lesz, igen.
Es pontosan azert probalok minel megbizhatobb forrasbol beszerezni dolgokat, mert en se akarom, hogy lerohadjon.
Viszont a ''be van dugva a 220-as kabel?'' -tipusu user supportert meg a csilivili egyedi hazert nem fogok fel milkat fizetni. Fizettetni, de tokmindegy.
Itt az a mentalitas, hogy mindent minel olcsobban, aztan ha gond van, na bumm, majd elfaxoljak. :)
De gondolj bele, ha te nem ertesz egy terulethez, es mondanak 2 megoldast, az egyik ketszer annyi, mint a masik, es annyit tudnak mondani a ''miben jobb'' kerdesedre, hogy ''haaat, nem megy tonkre olyan gyakran'', vagy ''megbizhatobb'', akkor te kifizetnel ketszerannyi penzt erte?
A supermicroval mar szemezgettem, megnezem, mijuk van. -
Hory
Na most megneztem par szerver-arus ajanlatat, eddig a hp vitte a palmat $5000-el - csak az a kar, hogy ezt alkatreszenkent, boltbol fele ennyiert megveszem. :)
Hory
Na ettol tartottam. a hexus tesztjeben kb. ugyanott van a ketto, a tomshardware tesztjeben meg pl. az alter table tesztben a 3ghz-es 800mhz-es 875 p4 vert mindent, eleg szep elonnyel. Jo, persze, hogy ki a halal hasznal alter table-t elesben, az mar mas kerdes, de igenis vannak esetek, amikor az ilyen konfig a nyero. Gondolom, a nem parhuzamosithato IO eseten.
Hory
Igy igaz, de epp tegnap olvastam az anandtech-en az athlon64 tesztet, ahol bizony pont egy fentebb emlitett tesztben az athlonxp 3200+ elverte az fx51-et, mert nagyobb volt az orajele... Na ilyet nem akarok. :)
utananezek, hogy fest a teljesitmeny adatbazisok alatt. Specifikusan a mysql lenne lenyeges. -
Hory
Meg az is gond az opteronnal, hogy alacsony az orajele, ahova lenne, ott pedig adatbazis es java futna rajta - ahhoz pedig memoria, IO, es integer teljesitmeny kell, a p4-nek meg van mindharom boven.
Az is zavar, hogy nem vagyok biztos benne, hogy egy 3ghz-es, 800MHz-es fsb-s, p4 egy 875-ben olyan sokkal lassabb lenne egy dual 3ghz-es xeon-nal, ami max. 533MHz-es fsb-vel megy e7505-ben. Kene valami teszt, csak ezek elegge elhanyagoltak sajnos. -
Hory
Bocs, hogy csak most nezek be, latom, probaltok segiteni azert.
Epp most borult ki az ebedem a sebvaltora egy hirtelen fekezes miatt, szoval most ehes vagyok es duhos, de amugy minden OK. :)
Szoval:
Penz van, de azert ugy 1 millio alatt kellene maradni, ha egy mod van ra, mert igy sokkal konnyebb elfogadtatni a vezetessel.
A gepen linux lesz, ez teljesen stimmel, fel sem merult, hogy mast rakjak ra.
Szukseg van ilyen teljesitmenyre sajnos - meg ez is keves lehet kicsit. En eleinte negyprocesszoros gepben gondolkodtam, de ugy nez ki, az legalacsonyabb hangon is sokmillional kezdodik. Es mivel oda csak 400MHz fsb-s, eleg regi xeonok vannak, nem is vagyok biztos benne, hogy olyan hudegyors lenne.
Opteronrol az egvilagon semmit se tudok, bar filoztam rajta kicsit - lehet szo errol is, csak mar igy is eleg sok bizonytalan tenyezo van, nem akartam meg egy parat. Nem is tudom, lehet-e egyaltalan kapni.
Megneztem par osszeszerelt masinat is - az a baj, hogy gagyit adnak dragan. A supportot nem hasznalnam (ott a net, gyorsabb es hozzaertobb), scsi-t se, meg a sok egyeb szir-szar management es stb... kepessegeit sem.
Athlonmp-vel az a baj, hogy nem tul meggyozo a teljesitmenye, es eleg draga is. Hardveres modositasokat meg ilyen helyen azert mar nem akarok.
Az opteronos szervernek hol lehet utananezni? -
Hory
Aham, en is korbeneztem az intel homepage-n, tenyleg csak xeon marad.
hjam, a regi szep p3-as idok, amikor bp6-ban 2 366 celeron 550-en ment, raadasul bagoert, azok voltak a szep idok :)
Az ar nem olyan lenyeges, cegnek lesz.
Viszont tudtok-e olyan boltot, ahol hozzaertok arulnak xeont es dual (esetleg a quad elol sem zarkozom el) lapokat?
Szervertemaban nem vagyok annyira jartas.
az asbist most nezem. -
Hory
2 db 800 MHz FSB-ju, 2.6-3.2GHz-es P4 procit szeretnek egy dual alaplapban.
Ehhez 2 dolog kellene:
- dual alaplap, 800MHz-es fsb-vel
- olyan P4, ami tamogatja a dual mukodest
Kerdes, hogy adott-e a fenti 2, es ha igen, hol, hogy.
- Biztosan felbúgnak a ventilátorok az új GeForce driverrel
- Diablo II: Classic és Resurrected
- LCD, plazma és projektoros TV-k hibái
- AliExpress tapasztalatok
- OLED monitor topic
- Óra topik
- Huawei Watch GT 3 Pro - korlátolt szépség
- Parkside szerszám kibeszélő
- MSI Prestige A16 AI+ Ryzen AI 9, 32GB DDR5 7500, QHD+ 165Hz csúcskategóriás ultralaptop!
- szinteÚJ, dobozos Dell Pro 14 Core Ultra 7 255U 32GB DDR5 1TB AI PC FHD+ 1 év garancia
- Dell Vostro 3425 6magos Ryzen 5 5625U 8GB RAM 256GB SSD
- FANTASZTIKUS áron eladó dobozos új Hp Laptop 17 /Ryzen 5-7520U/16 GB RAM /512 SSD/FHD/IPS/Garancia/
