Kraptor
hbbalint
#101
Úgy simán sehogy, mert 65K a limit, de vannak okosságok amivel meglehet kerülni ezeket. Van egy progi amit Microsoft Office Spreadsheet 10.0 UserForm control-nak hívnak és ezzel elvileg létretudsz hozni 18,278 x 262,144-es lapokat.Ezt nem tudom, hogy mennyire igaz vagy nem.
Vagy vannak különböző makrók amikkel megtudsz nyitnyi nagyobb fileokat, csak akkor több lapba fogja megnyitni őket automatikusan.
Sub ImportLargeFile()
'Imports text file into Excel workbook using ADO.
'If the number of records exceeds 65536 then it splits it over more than one sheet.
Dim strFilePath As String, strFilename As String, strFullPath As String
Dim lngCounter As Long
Dim oConn As Object, oRS As Object, oFSObj As Object
'Get a text file name
strFullPath = Application.GetOpenFilename(''Text Files (*.txt),*.txt'', , ''Please select text file...'')
If strFullPath = ''False'' Then Exit Sub 'User pressed Cancel on the open file dialog
Application.ScreenUpdating = False
'This gives us a full path name e.g. C:\folder\file.txt
'We need to split this into path and file name
Set oFSObj = CreateObject(''SCRIPTING.FILESYSTEMOBJECT'')
strFilePath = oFSObj.GetFile(strFullPath).ParentFolder.Path
strFilename = oFSObj.GetFile(strFullPath).Name
'Open an ADO connection to the folder specified
Set oConn = CreateObject(''ADODB.CONNECTION'')
oConn.Open ''Provider=Microsoft.Jet.OLEDB.4.0;'' & _
''Data Source='' & strFilePath & '';'' & _
''Extended Properties=''''text;HDR=Yes;FMT=Delimited''''''
Set oRS = CreateObject(''ADODB.RECORDSET'')
'Now actually open the text file and import into Excel
oRS.Open ''SELECT * FROM '' & strFilename, oConn, 3, 1, 1
While Not oRS.EOF
Sheets.Add
ActiveSheet.Range(''A1'').CopyFromRecordset oRS, 65536
Wend
oRS.Close
oConn.Close
Application.ScreenUpdating = True
End Sub
Itt egy másik is:
Sub LoadData()
Const cCol1 = 20, cCol2 = 20, cCol3 = 20, cLimit = 50000
Dim intFreeFile As Integer, i As Long, j As Long, strTemp As String
Dim arr() As String
On Error Resume Next
intFreeFile = FreeFile
Open ''c:\test.txt'' For Input As #intFreeFile
i = 0: j = 1
ReDim arr(cLimit, 2)
Do Until EOF(intFreeFile)
Line Input #intFreeFile, strTemp
arr(i, 0) = Trim(Mid(strTemp, 1, cCol1))
arr(i, 1) = Trim(Mid(strTemp, cCol1, cCol2))
arr(i, 2) = Trim(Mid(strTemp, cCol1 + cCol2, cCol3))
i = i + 1
If i > cLimit - 1 Then
Cells(1, j).Resize(cLimit, 3).Value = arr
i = 0: j = j + 3
End If
Loop
Close #intFreeFile
End Sub -
Kraptor
Mégis lehet használni, noha kellett egy kis notebookba valo másolás és onnan újra vissza excelbe. Így már nem látja a számokat föggvényeknek az excel, na már most csak azt kéne kitalálnom, hogy lehetne a 4 oszlopot ami mögötte van úgy mozgatni mint az, ahogy a számok alakultak.
Kraptor
Na mékse kell megálmodnod, mert nem jó az egész ahogy van. Akarom mondani jó, mert elvégzi azt nagyon szépen, ami le volt írva, csak én nem számoltam és gondoltam át pontosan az egészet és átsiklottam egy-pár dolgon. Ez egy nagyobb egység része lenne, és ha a nagyobb egység egyik oszlopával újra rendezem az egész egységet, akkor a kapott számok felborúlnak és a függvények újra számlálódnak. Tehát ez nem jó, de azért nagyon köszi és ez a függvény marhára tetszett, főleg, nagyon ötletes volt.
[Szerkesztve] -
Kraptor
Én most ezen egy kicsit megakadtam nagyon, mert az még kihagytam, hogy még a második oszlop mögött van 4 oszlop, amit ugyanúgy kellene mozgatni, ahogy a második oszlop mozog/igazodik az elsőhöz. Az első sort én fixnek venném és ahhoz probálnám meg valamilyen sort metodussal megcsinálni az egészet, de nem nagyon akar sikerülni.
Kraptor
VAn egy kis problémám Excelben. Nem nagyon szoktam használni, főleg manapság már nem.
A problémám az lenne, hogy van két oszlopom és mind a két oszlopban a számok 1-17000 ig vannak, csak az első oszlopban az adott számok 30000 helyen fordulnak elő, tehát valamelyikből több van és van olyan szám is 1-17kig, ami nem szerepel. A másik oszlopban a számok 1-17kig vannak és mindegyik szám csak egyszer szerepel. A bibi ott van. hogy valahogy úgy szeretném csinálni, hogy ''párba'' legyen a két oszlop. A megegyező számok egy sorba essenek, ahol meg több szám van, ott a legelső számnál legyen egybe a sor. Valahogy így képzelem, remélem a formátum nem fog eltolódni.
Ez van per pillanat:
1 1
2 2
3 3
4 4
4 5
4 6
5 7
és ezt szeretném kapni:
1 1
2 2
3 3
4 4
4
4
5 5
Valakinek van valami ötlete, hogyan tudnám ezt megoldani?
[Szerkesztve]
- Diablo IV
- Call of Duty: Warzone
- Jobb zajszűréssel és okos funkciókkal töltve megjelent az Apple AirPods Max 2
- Andras-G: #Kószagondolat - eMag tapasztalatok 2026-ban
- Vezetékes FEJhallgatók
- Mit tehetsz jogilag, ha átvertek, megkárosítottak a Hardveraprón?
- Energiaital topic
- Hario MINI MILL SLIM PLUS tekerőt keresek, mert elveszett
- HP EliteBook 830 G5, G6 13,3" i5, 16GB RAM, SSD, jó akku, számla, 6 hó gar
- 255 - Lenovo LOQ (15IRX10) - Intel Core i7-13700HX, RTX 5060 (ELKELT)
- HP 255 G8 - 15.6" FullHD IPS - Ryzen 5-5500U - 8GB - 512GB SSD - Win11 - MAGYAR - ÚJ AKKU
- 5G! Lenovo ThinkPad P14s Gen 4 Intel Core i7-1370P RTX A500 32GB 1000GB 1 év teljeskörű garancia
Fferi50
