Alvin_ti4200
''He deserved to die. They're all deserved to die.''
Eszméletlen jó a játék, csak lehet nem egészséges éjfélkor, egymagam egy sötét szobában nyomni
Asszem mára (ma estére) ennyi elég volt, ehhez képest a Doom 3 lófing
[Szerkesztve] -
Alvin_ti4200
F.E.A.R. by Monolith Productions - English retail v1.00 -> v1.01 patch
Version 1.01
Global:
- Fixed a problem where players could fall under the map after pressing ESC
while climbing a ladder.
- Fixed a bug where water FX would play where there was no water in the ''Heavy
Resistance'' level.
Multiplayer:
- Fixed the Game Type filter on the server browser screen.
- Fixed broken ladder animations.
- Spectator ''Fly'' mode now works as intended.
- SlowMo Score Time is now reported through the in-game server browser for
SlowMo CTF games.
- Fixed a problem where players would sometimes spawn into Team Elimination
games as a neutral player.
- Team Eliminmation servers will no longer advance to the next round if you are
the first to join and then switch teams.
- Dead players will no longer win the round in Elimination game types if they
have the highest score when time runs out.
- The score tally on the HUD now works properly in all Elimination game types.
- Remote clients can no longer log into SCMD on hosted games as original
intended. SCMD still works as before on dedicated servers.
- The weapon of the player you are watching will no longer appear on the screen
when using the ''Follow'' spectator mode.
- Fixed problem with grenades getting stuck on or bouncing off of breakable
windows in certain levels.
- Further optimized performance and fixed minor lighting and art bugs in the
Streets CTF level. -
Alvin_ti4200
bagyulajuve
#722
Igen, a CD Galaxisnál már lehet kapni, 9.990.- az ára, nemrég kaptam értesítést.
Alvin_ti4200
MINIMUM SYSTEM REQUIRED
•Windows(R) XP, x64 or 2000 with latest service pack installed
•DirectX(R) 9.0c August Edition (Included) or higher
•Pentium(R) 4 1.7 GHz or equivalent processor
•512MB RAM or more
•64MB GeForce(TM) 4 Ti or Radeon(R) 9000 video card
•Monitor that can display in 4:3 aspect ratio
•5.0 GB free hard drive space for installation
•Additional hard drive space for a swap file and saved game files
•DVD-ROM drive
•16-bit DirectX(R) 9.0 compliant sound card with support for EAX(TM) 2.0
•Broadband or LAN connection for multiplayer games
•Mouse
•Keyboard
In order to play the game at the recommended resolution, detail and
performance levels, your computer should meet or exceed the following
specifications:
•Pentium(R) 4 3.0 GHz or equivalent processor
•1 GB RAM
•256 MB Radeon(R) 9800 Pro, GeForce(TM) 6600 or equivalent DirectX(R) 9 compliant video card with hardware T&L and pixel shader 2.0 support
•Sound Blaster(R) X-Fi(TM) series sound card
SUPPORTED VIDEO CARD CHIPSETS WITH LATEST DRIVER VERSION INFO:
ATI(TM)
Catalyst(TM) Drivers (Windows(R) 2000/XP): v5.8
Radeon(R) 9000 Series
Radeon(R) 9500 Series
Radeon(R) 9600 Series
Radeon(R) 9700 Series
Radeon(R) 9800 Series
Radeon(R) X600 Series
Radeon(R) X700 Series
Radeon(R) X800 Series
Radeon(R) X850 Series
NVIDIA(R)
ForceWare(TM) Drivers (Windows(R) 2000/XP): v77.77
GeForce(TM) 4 Ti Series
GeForce(TM) FX 5900 Series
GeForce(TM) 6600 Series
GeForce(TM) 6800 Series
GeForce(TM) 7800 Series
Please note that attempting to play the game using video hardware that is
not listed here may result in reduced performance, graphical anomalies,
or both. -
Alvin_ti4200
Ha esetleg valaki hasonló konfiggal rendelkezne, mint én, akkor elárulok egy tuti beállítást a folyamatos és szép játékhoz
Mindent maximumra tenni, Soft Shadows-t és AA-t kikapcsolni, 16xAF mehet. 1280x960.
A tesztben így átlag 36-38 fps-t érek el, a minimum 25 körül van, a maximum 60 fölött picivel. -
Alvin_ti4200
Az E3 óta nagyon várom ezt a játékot, a Monolith cég következő sikervárományos szoftvere. Először is aki nem tudná miről is van szó, az gyorsan kapja le ezt a közel 350 megányi E3-mas videót, amit itt Bővebben: link találtok és ámuljatok. Profi grafika, remek fizika, félelmetes hangulat. Mi kell még? A videók alapján jobban fogok félni, mint a Doom III-ban
Várom a ti véleményeteket is.
Mentem egy 45 percig még meccset nézni...
- Elektromos autók - motorok
- BestBuy ruhás topik
- Tápos kibeszélő offtopik
- CPU léghűtés kibeszélő
- Stabilan induló BIOS-t kaptak a nem induló Socket AM5-ös ASRock alaplapok
- Revolut
- Melyik tápegységet vegyem?
- Samsung kuponkunyeráló
- Milyen notebookot vegyek?
- Samsung Galaxy S24 256GB, Kártyafüggetlen, 1 Év Garanciával
- Keresünk Galaxy S22/S22+/S22 Ultra
- LicencAruhaz.hu OLCSÓ, LEGÁLIS SZOFTVEREK AZONNAL - Windows - Office - Win Server - ÖRÖK GARANCIÁVAL
- HP EliteBook 840 G7 i5-10210U 16GB 256GB FHD 400nit 1 év garancia
- Samsung Galaxy Z Fold 6 12/512GB - Újszerű, Független, Ezüst - 1 év garanciával
