Noha az első részt a Crysis sorozattal foglalatoskodó CryTek készítette, de mivel ők új kiadó és egyben új megbízatások után nézett, így a jogok a UbiSoftnál maradtak, aki természetesen nem hagyta feledésbe merülni a csapat 2004-es blockbuster-ét, a Far Cry második részének elkészítésével pedig a Splinter Cell, a Rainbow Six, az Assassins Creed, és az egyes Prince of Persia címekért felelős UbiSoft Montreal stúdiót bízták meg, hogy azok új erőt adva a sorozatnak újra felélesszék régi kedvencünket.
Dashes
1.01 patch megjelent, Launcher segítségével automatikusan frissít.
- Fixed Dolby 5.1 support for most sound cards.
- Fixed mission objectives marker after a loading a save game.
- Fixed for difficulty level not changing health when updated.
- Fixed Jackal Tapes and Partner Tapes pages.
- Fixed Field Manuals not unlocking after game mode change.
- Fixed glider key remapping.
- Fixed keyboard controls remapping in single mode that didn't carry into multiplayer mode.
- Prevent a buddy from getting stuck when healing him while receiving damages.
- Fixed stats of favorite weapon not properly reset between loaded save games.
- Fixed the mortar moving the player through wall.
- When creating a dedicated server with PunkBuster enabled then close it to create another but this time with PunkBuster disabled, PunkBuster will still be considered ON, on this new server.
- Display server's IP address in lobby, beside the match’s name (for direct IP join to work)
- Fixed a problem where a player could get stuck (and couldn’t get killed) after pressing the interaction key while wounded and getting rescued by a teammate at the same time.
- Fixed vehicles not being respawned if they were never used.
- A ranked match that is already started will not be listed in the match list.
- Fixed users not being able to see a match if the host switched match mode after a rank. Prevent the host from changing the server setting in a Ranked Match through the console.
- Fixed a glitch that could make a player invisible to another.
- Improved match start conditions. Ranked games can now also start if the player max is attained and everybody but the host is ready.
- Fixed if a user has too many user maps and tries to enter the map rotation menu in a Player or Ranked match, he would get disconnected.
- Fixed incorrect check for negative values when adjusting diamond count.
- Fixed a problem where a player would render through objects if healing a wounded playing while being wounded at the same time.
- Fixed players with same name by using identifiers instead of names.
- Always validate the diamond pool after class upgrades, reset or rank up to avoid getting more diamonds than the player is supposed to for his rank.
- Fixed reload not being interrupted on the host when a client picks a weapon while reloading.
- Fixed crash when creating a LAN game without a network cable.
- Fixed a random crash when joining a game.
- Fixed to make sure game is minimized in order to show the website when clicking on ubi.com
- Fixed crash in editor when deleting many objects in very rapid succession.
- Fixed crash in editor during parsing of the map headers.
- Fixed a random crash that could happen when pressing ESC to cancel a Benchmark run.
- Added CPU Intensive benchmark test run.
- Allow launching the Dedicated Server Launcher in command line.Nem találtam sehol a módosítások listáját, ezért másoltam be.
Dashes
Sirandrish
#3747
Nem ez a lényeg, azt gyorsan ki is javították, nincs azzal gond. Egy rossz link miatt az összes oldal szerint a legújabb hotfix hoz plusz fps-t, eltűnnek kövek, a valóságban ez a régi hotfix. A friss teszt szerint az új hotfix esetén már láthatóak a kövek , de az fps csökken( AMD szerint növekszik). Az fps növekedést/csökkenést nem tudom letesztelni, mivel az új driver-t a RivaTuner nem ismeri fel, nem engedi húzni a kártyát (az első hotfix esetén a benchmark 700/2200-on futott le).
Dashes
Ebben a cikben található egy link ami a legújabb hotfixhez vezet, a cikkben azt írják, hogy eltűnnek a kövek, de fps növekedés figyelhető meg.
[Ebben a cikkben már azt írják, hogy az új hotfix(71310) visszahozza az eltűnt köveket..., az fps pedig csökkent.
Közben az AMD mindkét hotfix esetén csak teljesítmény javulást említ.
Szvsz az első cikkben az első hotfixet tesztelték, kicsit későn( a második hotfix megjelenésekor), rossz liket szúrtak be, a többi oldal pedig sikeresen lemásolta az egészet. -
Dashes
Dashes
LordAxwell
#3533
Az órát csak alvásnál tudod használni.
Dashes
LordAxwell
#3509
Ahol a fegyver jel van, csak pont a domb túloldalán, ott található egy ház, abban egy gyémánt és egy arany AK-47.
#3514 Csak AK-47, másiknak utánanézek. -
Dashes
marcus.fenix
#3456
Próbálj mellékküldetéseket csinálni, később térj vissza.
Dashes
Na mit találtam?
link
"These weapons perform similar to the standard AK-47, but are much more reliable."
#3303
Dashes
Akit érdekel részletes tejles térkép, több mint 200 oldalas leírás, az jelezze privátban.
Dashes
Sprint közben C hosszan= csúszás.
Dashes
Kaptam egy ilyet .
Dashes
Az akadás/lag akkor jelentkezik, ha az fps a megszabott maximum fps(gfx_maxfps X) alá esik.
Próbáljatok olyan beállítás keresni , ahol a minimum fps 35-45 körül lesz, majd állítsátok be a max fps-t. Ajánlom a beállításokat VeryHigh-ra rakni. -
Dashes
Dashes
A gamerprofileban lévő Machete módosításával különböző késeket választhatunk:
1:modern
2:homemade
3:primitive -
Dashes
Akinek gondja van az 5.1-el:
Nyissa meg ezt a fájlt:
C:\Program Files\Ubisoft\Far Cry 2\Data_Win32\SoundBinary\DARE.ini
majd állítsa a DISABLE_OPTIMISATION-t FALSE-ra. -
Dashes
Megszületett a megoldás a kép levágására(widescreen): link
16:10
X FOV: 1.31
Y FOV: 1.253Úgy néz ki nem várom meg a patchet..
Dashes
TazLeacher
#2752
" FarCry has a feature to read from a multisampled z-buffer, resulting in better anti-aliasing performance, and both ATI and NVIDIA support this feature. ATI supports it in DX10.1, and NVIDIA via a DX10 extension and the performance should be the same."
Kértem, hogy ne ATi vs. Nvidia legyen a topik címe.
Dashes
Widescreen users:
C:\Documents and Settings\**name**\My Documents\My Games\Far Cry 2\GamerProfile.xml
ForceWidescreen-t állítsátok 1-re, elvileg valamit javul a helyzet. -
Dashes
Dashes
KDavid17
#2289
Ikonra jobb klikk, properties, compatibility: Disable Visual Themes.
C:\Users\felh. név\Documents\My Games\Far Cry 2
Gamer Profile.xml -ban a felbontást állítsd be.
vagy hozz létre egy külön parancsikont, aminek az elérési útja:
C:\Program Files\Ubisoft\Far Cry 2\bin\FarCry2.exe" -RenderProfile_ResolutionX **** -RenderProfile_ResolutionY ****
**** helyére a kívánt felbontás.Ha windowed módra vált, egy alt+enter megoldja.
Dashes
SlaveDealer
#2266
Nem az fps a lényeg, az van elegendő, de ennek ellenére is van lag.
Mindegyik drivere esetén jelentkezik ( 8.10/hotfix/8.11 RC1) DX10.
DX9 alatt megszűnik, de ...
#2276 Az érdekes, én kipróbáltam nálam ugyanúgy jelentkezett, mint a többi driverrel, másnak sem volt jó. (8.10) -
Dashes
Utánaolvastam, elvileg a Caltayst AI kikapcsolásával megoldódik.
Sajnos nem tudom letesztelni ( display driver only) -
Dashes
Performance Test
"From NVIDIA we have release driver 180, specifically 180.42 which we are using in today’s testing. From AMD there is a specific Hotfix driver.." -
Dashes
Dashes
"Megjelent" PC-re. Megkérlek titeket , hogy a témát mellőzzük a topik érdekében. (warez)
Dashes
Far Cry 2 hotfix
Abu: Nem vártam tőle sok mindent, ez is haladás. -
Dashes
DX 10.1
Majd jön egy patch mint AC esetén.. -
Dashes
Dashes
- Xbox tulajok OFF topicja
- Starlink
- Milyen okostelefont vegyek?
- Mobil flották
- Diablo IV
- Telefon felvásárlás!! Honor 400 Lite, Honor 400, Honor 400 Pro
- Xiaomi Mi 11 lite 5G NE 256GB, Kártyafüggetlen, 1 Év Garanciával
- -75% Dell XPS 13 (9320) i7-1260P 16GB Ram/1TB SSD FHD+ Gari
- Azonnali készpénzes nVidia RTX 4000 sorozat videokártya felvásárlás személyesen / csomagküldéssel
- ÁRGARANCIA!Épített KomPhone i5 10400F 16/32/64GB RAM RTX 3060 12GB GAMER PC termékbeszámítással
. A HOC-on pedig nem olvastam végig a cikket, tehát a többi oldal jól írja.
(kellett neked fraps-el szórakozni
