zfarkas
dr_strange
#4797
Hát, már nyitottak egy bug-ot: Bővebben: link
zfarkas
Kernel: 2.6.13-gentoo-r3 + ipw2200 driver.
Kernel fut, minden okés,
$ emerge ipw2200
[kell ieee80211 is hozzá]
>>> Unpacking source...
>>> Unpacking ieee80211-1.0.3.tgz to /var/tmp/portage/ieee80211-1.0.3/work
>>> Source unpacked.
* Preparing ieee80211 module
Checking in /usr/src/linux/ for ieee80211 components...
make -C /usr/src/linux M=/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3 MODVERDIR=/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3 modules
/usr/src/linux/include/net/ieee80211.h
Above files found. Remove? [y],n make[1]: Entering directory `/usr/src/linux-2.6.13-gentoo-r3'
CC [M] /var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.o
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:61: error: syntax error before ''IEEE80211_VERSION''
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c: In function `alloc_ieee80211':
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:145: error: `ieee80211_crypt_deinit_handler' undeclared (first use in this function)
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:145: error: (Each undeclared identifier is reported only once
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:145: error: for each function it appears in.)
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:146: error: structure has no member named `crypt_quiesced'
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c: In function `free_ieee80211':
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:171: warning: implicit declaration of function `ieee80211_crypt_quiescing'
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:173: warning: implicit declaration of function `ieee80211_crypt_deinit_entries'
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:178: error: dereferencing pointer to incomplete type
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:179: error: dereferencing pointer to incomplete type
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:180: error: dereferencing pointer to incomplete type
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c: In function `ieee80211_init':
/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.c:255: error: syntax error before ''IEEE80211_VERSION''
make[2]: *** [/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3/ieee80211_module.o] Error 1
make[1]: *** [_module_/var/tmp/portage/ieee80211-1.0.3/work/ieee80211-1.0.3] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.13-gentoo-r3'
make: *** [modules] Error 2
make: *** Waiting for unfinished jobs....
n
Old ieee80211 references found. In order to build the ieee80211
subsystem, prior versions must first be removed. You can perform
this task by running this makefile as root via:
% sudo make check_old
and answering Y to remove the file references.
Aborting make.
make: *** [check_old] Error 1
Puff, bazz. Az ipw2200-hoz kellő ieee80211 modul talál egy ieee80211 header file-t a kernel forrásában, és b*szik lefordulni.
Na mindegy, eltávolítom a /usr/src/linux/include/net/ieee80211.h fájlt, és minden oké...
Ez megér egy bugreport-ot? -
zfarkas
Csá!
Mit gondoltok, kb. meddig tarthat egy Gentoo base-t, plusz X, firefox, thunderbird leforditani egy 400-as PII-n? -
zfarkas
Bocs, a link lemaradt: Bővebben: link
zfarkas
dr_strange ''bugreport''-ja utan frissitettem azt a scriptet, mi az olyan csomagokat listazza, amiktol nem fugg semmi.
Arra kerek mindenkit, hogy ha teheti, futtassa le, es az eredmenyt (amennyiben az hiba) kuldje el nekem, vagy tegye itt kozze. Nekem most sajna nincs hozzaferesem Gentoo oprendszerhez. Ja igen, nem kell hozza root jog.
Koszi!
Ha valaki nagyon elhivatott, akkor elkuldheti levelben a script, illetve az 'emerge -pv --deplean' kimenetet. Thx! -
zfarkas
dr_strange
#3409
Valszeg a 'for i in */*' sok neki. Biztos jo sok csomagod van...
De lehet, hogy a 'grep -q */*/*DEP*'.
Javitottam, az egy fo ciklust szetszedtem kettore (eloszor konyvtar, majd csomag alapjan keresek).
Ellenorizd legyszi (most a Gentoo-s gepet asszonykam nyustoli otthon), hogy meg mindig bugzik-e (lehet, hogy a grep-nel fog). -
zfarkas
dr_strange
#3404
Oh, hát persze. Írd csak be.
Itt lesz mindig a legújabb változat (tervezem pl. a system-es csomagok szűrését):
Bővebben: link
Köszi! -
zfarkas
Szép jónapot!
Történt, hogy sok felesleges csomagot kellett letörölnöm a Gentoo rendszeremről, de nem tudtam, mely csomagok azok, amelyek nem függnek másoktól. Ezért írtam egy kis scriptet, ami kilistázza azokat a csomagokat, amik nem szerepelnek más csomagod dependency-jében. Íme:
#!/bin/bash
cd /var/db/pkg
for PACK_PATH in */*; do
PACK_VER=''${PACK_PATH/*\//}''
PACK_NOVER=''${PACK_VER/-[0123456789]*/}''
grep -q $PACK_NOVER */*/*DEP*
[ $? = 1 ] && echo ''NO DEPS: $PACK_VER''
done
Jó gyors (miután már egyszer lefuttattad, és a fájlok adatai a cache-ben vannak
Vigyázat: a system-hez tartozó csomagokat is kilistázhatja (pl. udev, busybox, ...). Szóval először egyemerge -pv --unmerge
paranccsal érdemes megnézni, nem jelöltünk-e ki system-beli csomagokat.
zfarkas
Tiszteletem!
Olyan scriptet szeretnék írni, ami kilistázza nekem azon csomagokat, amik nem szerepelnek más csomagok dependency-jében.
A tervem az, hogy a/var/db/pkg
könyvtár tartalmát vesézem ki.
Eddig a scriptem:
#!/bin/bash
cd /var/db/pkg
for i in */*; do
PACK_VER=`echo $i | sed -e 's/.*\///'`
[ ''$1'' = ''-v'' ] && echo ''Package name with versions: $PACK_VER''
PACK_NOVER=`echo $i | sed -e 's/-[0123456789].*//' | sed -e 's/.*\///'`
[ ''$1'' = ''-v'' ] && echo ''Package name without versions: $PACK_NOVER''
done
Tehát minden csomagról megvizsgálja, szerepel-e bármely más csomag könyvtárában levő *DEP* fájlban. Jó kis brute-force, de úgy néz ki, működik.
Egyetlen baja, hogy a ''system'' részét képező csomagokat is kiírja, pl. busybox. Mit lehet tenni? Ne írjam ki a/var/db/pkg/sys-*
könyvtárban levő csomagokat? Ha ezeket akarom unmerge-elni, akkor ad nekem ''This could be damaging to your system.'' üzenetet?
Kérdésem: van valamerre infó arról, hogy mit jelentenek az egyes fájlok a/var/db/pkg/*/*
könyvtárban?
zfarkas
Helló!
Valakinek tapasztalata emacs + gnus + imap levelezés konfigolással? -
zfarkas
Helló!
Tudtok ajánlani olyan scriptet vagy csomagot, amivel azokat a csomagokat tudom kiiratni, amiket nem használ semmi más program. Vagyis: nem szerepel egy dependency-ben sem.
Két lehetőséget látok:
1.emerge --depclean world
Kérdés: ez tényleg kiír-e nekem minden olyan csomagot, amit semmi sem használ?
2.
Ha az 1. nem oké, akkor valami scripttel megkeresem azokat a csomagokat, amik nem szerepelnek a /var/db/pkg/*/*/*DEPEND fájlok egyikében sem.
Kérdés: a fenti *DEPEND fájlok közül ({C,D,P,R}DEPEND) melyek mit jelentenek?
Azért lenne erre szükségem, mert ha pl. unmerge-elem az openldap csomagot, akkor tovább nincs szükségem pl. sasl és egyéb cuccokra. És ha jól tudom az unmerge nem szedi le a dependeny-ket (sőt, sajna azt sem nézi meg, hogy a törlendő csomagtól függenek-e más csomagok). -
zfarkas
Hello! Telepitett valalki mostanaban 2005.0-rol? A stage1 es portage telepitese utan (ami gyakorlatilag egy tar) elinditom a boostrap.sh-t, erre a glibc forditasa soran leall azzal, hogy nem jo a gcc fordito (a glibc elott a gcc-t forditja, ha jol lattam).
Csak ugy megy tovabb, ha a 'gcc-config'-al beallitok egy konfiguraciot (pont azt, amit elozoleg leforditott). Ez valami csavar? Mindent a handbook szerint csinaltam, megis beszart valami.
Tapasztalatok?
A fenti ''hack'' ellenere az 'emerge -e system' szepen lefut, be is boot-ol a rendszer, ... Szoval ugy nez ki, nem veszes a dolog. -
zfarkas
dr_strange
#2557
Ettöl a hatalmas CD-image letöltéstől akartam megkímélni magam, de úgy látom, nincs más út...
Nos, a changelog-ban van olyan, hogy:
* added madwifi drivers
De gyanítom, hogy csak a forrás. Azért próba szerencse...
Szerk: ja, és köszi a linket!
[Szerkesztve] -
zfarkas
Tudna valaki forgatni nekem a 2005.0 telepítő kerneléhez passzoló madwifi kernel modult?
Nagyon hálás lennék
zfarkas
Aham. Én legutóbb a 2004.x-et próbáltam, és pl. boot során nem nagyon sikerült belőnöm a WLAN-t, mert nem is tudom milyen csomagot (valami base-layout, asszem) kellett volna ~x86 maszkkal felraknom, és nem sok kedvem volt hozzá. Meg gondom volt a suspend2-vel is, de azt mára felváltotta a STR, szóval ez talán nem lenne probléma.
Szóval azt mondod, hogy nem kell semmit sem ~x86-al felrakni, most már támogatott a WLAN?
[Szerkesztve] -
zfarkas
Helló!
Ha 2005.0-ról telepítek, kell akármilyen gányolást csinálnom ahhoz, hogy működjön az Intel 2200BG WLAN kártyám?
Vagyis a kérdésem az, hogy támogatott-e alapból a wireless networking ebben a kiadásban?
Köszi! -
zfarkas
zfarkas
#1800
Megtaláltam:
Bővebben: link -
zfarkas
A nagy problémám az, hogy a /-ben csak 1,3G hely van, és ott nem fér el az Openoffice fordítása. Hogy tudom megadni, hogy az 'emerge openoffice' során más helyre tegye a kitömörített forrást, és ott is fordítsa? Úgy tudom alapból a /var/tmp/portage. A source már megvan a /usr/portage/distfiles-ban.
Köszi! -
zfarkas
dr_strange
#1777
Remek!
Kezdem is backup-olni a régi rendszert... -
zfarkas
Kedves Gentoo-sok!
Azt hiszem kipróbálom ezt a disztribet is.
Kérdésem: x.org támogatott? Aztán hogy megy a frissítés? Pl. mint Debian esetén van az 'apt-get update && apt-get upgrade'. Van itt ilyen?
- Vezetékes FEJhallgatók
- TCL LCD és LED TV-k
- Path of Exile (ARPG)
- AMD vs. INTEL vs. NVIDIA
- gerner1
- Gitáros topic
- Parfüm topik
- Hario MINI MILL SLIM PLUS tekerőt keresek, mert elveszett
- LENOVO ThinkPad T14 Gen 2i - i7-1165G7, 16GB RAM, 512GB SSD, jó akku, számla, 6 hó gar
- í kilenc! AKCIÓS PRECÍZIÓS KÉSZÜLÉK! 7560 i9-11950H 64GB RAM 1TB SSD Nvidia RTX A3000 6GB 1 év gar
- Telefon felvásárlás!! Apple Watch Series 9/Apple Watch Ultra/Apple Watch Ultra 2
- BESZÁMÍTÁS! ASUS Z790 i9 14900KF 64GB DDR5 1TB SSD RTX 5080 16GB LIAN LI LANCOOL 216R ADATA 850W
