Keresés
yerico
Szóval erre figyelj:
The %SystemRoot%System32Perflib_Perfdataxxx.dat files are created by the System Monitor. When you shutdown normally, the file should be deleted.
If you have an abormal shutdown, these files can become orphaned, and accumulate on your computer.
Under some yet to be determined circumstances, these files can become orphaned during normal operation.
The best way to remove these files is to add a command in a logon script:
del /q %SystemRoot%System32Perflib_Perfdata*.dat
- Lakásfelújítás támogatási program (2021)
- BestBuy topik
- AliExpress tapasztalatok
- Okos Otthon / Smart Home
- Milyen monitort vegyek?
- Samsung kuponkunyeráló
- Intel Core i7 9xx "Bloomfield" (LGA 1366)
- Telefon felvásárlás!! Apple Watch Series 9/Apple Watch Ultra/Apple Watch Ultra 2
- Dell Latitude 5410 - 14", i7-10610U, 8-16GB RAM, SSD, jó akku, számla, garancia
- Dell Latitude 7490 14" FHD IPS, i5 8250, 8-16GB RAM, SSD, NFC, jó akku, számla, 6 hó gar
- Gamer PC-Számítógép! Csere-Beszámítás! I5 9600KF / RTX 3060Ti / 16GB DDR4 / 256SSD + 2TB HDD
