Fórumok
LOGOUT - lépj ki, lépj be!
SzlobiG
mi az a cap? :-)
SzlobiG
catalystbol a legujabb nem beta asszem 12.10 mert nem vagyok most otthon!
Akkor meg is van a baj.
Tedd fel a legújabb csoda catalystot és mellé a legújabb CAP-ot és elvileg jó lesz. -
SzlobiG
!!!!!please help!!!!! miert van az hogy az en configommal ultra beallitas mellett is max 30 fps em van es a minimum benchmark alatt pedig 1 ez egy kicsit elkeserit. aki tud valamit higy esetleg beallitasi
dolgok az irjon! elore is koszonomMelyik driver és CAP van fent?
SzlobiG
Jobban örültem volna egy kis optimalizálásnak, viszont az az intro movie ki skippelhetősége tetszik, mert nálam valamiért a fő logó és az intro között 1 perc feketeség van, utána indul el az intro, ami vicces...
Square Enix, IO Interactive, and Nixxes are making a first patch (1.0.438.0) available for Hitman: Absolution on PC.
This patches provides the following improvements:
- Players using the Russian language will no longer crash as soon as they use the sniper rifle.
- Various issues that have been seen on specific configurations that caused the game to not be able to start up at all have been addressed.
- Problems with the Sniper Challenge Unlocks not carrying over into Hitman: Absolution have been addressed. On first starting the patched game you will receive your unlocks.
o Note that North American users that have been provided the Sniper Challenge by Gamestop will need a separate unlock key in addition to this. Gamestop can provide these.
- Problems with negative level-scores have been fixed. Newly accomplished positive scores will be needed to erase your incorrectly remembered negative scores.
- A problem with keyboard and mouse controls where users would accidentally melee attack a person next to them when they intended to throw an item has been addressed.
- Legal and Intro movies can now be skipped immediately on startup after the game, on all launches but the very first on a machine.
- DirectX 10 hardware can now enable the simplest version of the Depth Of Field effect.
- Problems with audio occasionally being muted after ALT-TAB have been fixed.
- Various localization fixes.
- Miscellaneous other stability and general improvements based on crashes we have seen coming in.Note that the above is really just our first set of fixes. We are continuing to monitor things and expect to provide further patches in the future.
We hope this patch will help everyone enjoy Hitman: Absolution!
SzlobiG
Jött patch vajon mit javít?
SzlobiG
Cégig vittem én is a kampányt nekem összességében nagyon tetszett 4K-t simán megért.
SzlobiG
Lesznek ettől szebb részek majd akkor esik az állad.
Én lassan kivégzem iszonyatosan jó.
SzlobiG
Engem a maci részletes textúrája fogott meg.
Ez High beállítás? Vagy Ultra? Vagy Ultra Low?
Max.
SzlobiG
SzlobiG
SzlobiG
SzlobiG
Ne kezd már ezt a baromságot plz...ugyanolyan akadás mint az új NFS-be ha már 60 helyett 58FPS-el ment akadt mint a szemét. Vsync meg amúgy is be van kapcsolva.
SzlobiG
Van itt még egy operációs rendszer faktor is... Kíváncsi lennék Win8-on hogy muzsikál a CF.
Biztos igazad van elméleti síkon, de a gyakorlat, és a tények mást mutatnak. A benchmark, bárki is futtatja, egyforma. SLI-n is ugyanazok a frame-ek futnak, mint CF-en, és SLI-nél valamiért kiegyensúlyozottabb.
Tehát valamiért a multi GPU jobban megy nV-n. Ezt lehet cáfolni elméleti síkon, de itt vannak a topikban az eredmények fehéren-feketén.Én is így látom hiába az elméleti síkon levezetett leírás, ha valójában nem igaz...
Most értem a
Dexterespályára na itt volt egy olyan rész ahol a 680-is beszaggatott rendesen pedig 50-55FPS volt és még is akadozott elég durván még jó hogy gyorsan végeztem ott.
Nálam továbbra is nagyon bejön a gém.
SzlobiG
De nem a CrossFire problémájáról van szó. Az dettó ugyanúgy működik, mint az SLI. Itt a motor a probléma, ami adatot cserél a frame-ek között.
Most attól, hogy jött egy olyan játék, ami relatíve sok interframe kommunikációt használ, még nem fogja az AMD és az NVIDIA teljesen megszüntetni a multi-GPU technológiát. Az SLI és a CF továbbra is élvezi a támogatást, de azokkal a játékokkal, amelyek nem AFR-barát motort használnak nem lehet mit kezdeni. Sosem lehetett.
Ami megfontolandó esetleg az az AFR leváltása. A Lucid objektumszintű skálázása reális alternatíva az ilyen motoroknál. Ennek viszont az a gondja, hogy jó minőségű támogatást csak platformszinten lehet csinálni.Azért hibáztatja a CF-et mert volt itt SLI-s teszt eredmény azzal meg jól működik az AFR, de nála nem.
SzlobiG
16XMSAA-t hogy állít be mikor csak 8X van? CCC-be ráerőlteti?
SzlobiG
Azt hiszem, először konfig csere lesz nálam, majd utána SLI rendszer. Ez katasztrófa amit az AMD csinál.
Feltettem Abu által ajánlott 12.11 beta 8-as drivert, és lefutattam én is 1920*1080-ban...NoMSAA:
Single:
min 35,01
avg 41,90
max 50CF:
min 26,41
avg 38,66
max 108,73Minimum fps-ben -24% kevesebb CF-ben, Átlagban -7,9% kevesebb, maximumban pedig +54% hoz többet a CF.
Ragyogó. Tapsoljuk meg a drivert író csapatot.4xMSAA
Single:
min 23,30
avg 28,02
max 33,96CF:
min: 17,47
avg: 37,94
max 48Minimumban itt is -25% kevesebb CF-ben. Átlagban -35,4% kevesebb, maximumban pedig +29,25% hoz többet a CF.
8xMSAA
Single:
min 16
avg 18,96
max 23,30CF:
min: 8,54
avg: 33,54
max: 39,62Minimumban -46% kevesebb CF-ben. Átlagban +44% a CF javára, és maximumban is +41% a CF javára.
Összességében a végeredmény elkeserítő.
Pedig AMD szerint jól működik.
Gondolom a 6900-es szériára tojnak már.
SzlobiG
Huhh nálam ez kezd év játéka lenni nagyon jó a grafikával még mindég nem tudok betelni, na meg a régi Hitman hangulat...
Végre nem egy olyan fps játék amit 5-6 óra alatt végig lehet vinni (cod,mohw), hanem sokkal több órát bele lehet tenni és persze itt is van rá lehetőség, hogy rambó vagy silent.
SzlobiG
Szerintem meg pont jók az újítások a régi részekhez képest ugyanúgy eldöntheted, hogy rambóként mész vagy lopakodva. A grafikán meg csak ámulok sok helyen.
2012-be ilyen szintet várok el nem azt a pl fos BO2-t. -
SzlobiG
680-al szaggatás nélkül fut fullon MSAA nélkül.
SzlobiG
SzlobiG
SzlobiG
Megvettem én is 4K-t nekem bőven megért és csak ámulok a látványon.
A hangulat a jól megszokott Hitman féle megmaradt.
MSAA nélkül fullon már játszható, de azzal esélytelen bár nem is kell mert van FXAA.
Fórumok
- Huawei Watch Fit 5 Pro - jó forma
- Projektor topic
- Kiterjesztett valóság ASUS ROG és XREAL recept szerint
- AMD off topik: VGA, CPU, APU és minden, ami AMD
- A Linux megnégyszerezte magát a Steamen — a Microsoft ismét ígérget
- Apple MacBook
- Apple asztali gépek
- HP Omen 16" FHD+ IPS Ryzen 9 8940HX RTX 5070 32GB 1TB NVMe gar
- GoPro HERO11 Black Creator Edition KOMPLETT, eredeti doboz, alig használt
- Bomba ár! Lenovo TP Yoga 370 - i5-7G I 8GB I 512SSD I 13,3" FHD Touch I Cam I W11 I Gari
- Bomba ár! Lenovo ThinkPad X390 - i7-8G I 16GB I 256SSD I 13,3" FHD I HDMI I Cam I W11 I Gari!
- playseat evolution black actifit
- 27% - Lenovo LOQ i5-14400F / 32GB DDR5 / 1TB SSD / RTX 5060! BeszámítOK!
- Bomba ár! HP ZBook 15u G3 - i7-6G I 8GB I 256SSD I Radeon R7 I Cam I W11 I Garancia!
- Bomba ár! HP EliteBook 840 G10 - i5-1335U I 16GB I 512SSD I 14,1" WUXGA I Cam I W11 I Gar!
- BESZÁMÍTÁS! AMD Ryzen 9 3900X 12 mag 24 szál processzor garanciával hibátlan működéssel
- Vivo X300 Pro 512GB 16GB RAM Blue Karcmentes állapotban 100% akkumulátorral
Alkalmazás profil.
